PDA
View Full Version : For Sale/WTB - Engine / Drivetrain / Power
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228
  1. Evo 8 turbo 10.5 Hotside
  2. FS: in NY AMS HTA35R Complete Turbo Kit.
  3. FS: Chicago Cobb AccessPort VIII
  4. FS: NY Evo 8 5 speed Transmission
  5. Evo ix 20g turbo 6k miles, FP 18lb actuator, FP inline oil filter
  6. ARP Headstuds
  7. Muse o2 dump
  8. CA 5 spd trans stock fs
  9. FS: Brand new AMS intercooler 3.5"
  10. F/S Buschur Test pipe
  11. FS: FP 3082 HTA Turbo, HKS 272 Cams EVO 8, Exedy Twin Plate Clutch
  12. 8 block w/crank, twin disk,cams, valve cover
  13. FS: Samco radiator hoses (red)
  14. SOLD! Full Race VERTICAL core Intercooler
  15. Bosch fuel pump 044 new
  16. FS: Walboro fuel pump
  17. Bc springs, avid mount, stock mr gauges
  18. FS: APS BOV, Ingalls Stiffy, Stock MAF Sensor
  19. Full Race Manifold for Stock Frame & o2 housing
  20. FS: Brand new Cusco twin plate clutch (Evo 8/9)
  21. Mini battery tray/Evo VIII TB/FP race LICP
  22. fs: oem 560cc injectors
  23. Carrillo H-Beam with car bolts 1200+HP
  24. FS: Spoolin' Up AIT w/ MAF plug
  25. FS: Exhaust Hangers
  26. FS: Stock 9 Ignition Coil
  27. JM Fab coolant tank, ETS hard upper rad pipe, Weapon R power steering tank
  28. AEM Boost Control Solenoid
  29. FS: (2) EVO 8 & 9 complete 6spd Transmissions *cheap*
  30. FS: Kiggly HLA, FIC Bluemax 1650cc, STM fuel pump rewire
  31. FS: Greddy Ti-c comp
  32. FS: AMS FMIC - Brand New!
  33. FS: FIC 1450cc Injectors!!!
  34. FS/NC: 4G63 OEM crank
  35. MAP SST Turbo Ported and Coated $900 Shipped Atlanta
  36. AC Compressor and Bracket Atlanta
  37. exedy twin hd, quartermaster, stock flywheel
  38. F/s new ngk iridium spark plugs ''bpr7eix''
  39. FS: Megan o2 Housing
  40. AMS Intake - Cone Style K&N filter with adapter plate
  41. FS: BNIB Forge Adjustable WGA
  42. FS: Precision 6262 DBB CEA turbo, Like New!
  43. FS: Megan Racing o2 Housing
  44. MR 6 speed :)
  45. intake, tb, koyo,indivia,gsc,bc springs
  46. Titek o2 Housing.
  47. FS: Complete Evo 8 Stock Intake
  48. FS: Stock Evo 8/9 intercooler w/pipes
  49. FS: Megan test pipe, Licp, etc...
  50. Map 02 Dump
  51. FS: ETS 3" Wide Tank
  52. Fs: Hafe t3 3582
  53. FP Intake - 84mm
  54. OEM Evo 8/9 Radiator CHEAP $85 Shipped Atlanta
  55. FS: OEM Airbox
  56. FS: OEM Turbo Intake Pipe
  57. FS: OEM IC Piping
  58. Borla Tublar MANIFOLD!!!! Fresh out of the machine shop
  59. FS: OEM Intercooler
  60. FS: OEM Injectors
  61. OEM Evo 8/9 Catalytic Converter CHEAP Atlanta
  62. EVO 9 Stock Ecu
  63. FS: Injen Intake no filter
  64. FS: FP 3794 - 1,300 Miles
  65. BNIB OEM turbo gasket and studs repair kit
  66. Tial MVS 38mm wastegate silver with all springs! Mint!
  67. FS: Evo 8 Driver Front Axle (x2)
  68. FS: evo 8 stock TB / intercooler (CA)
  69. FS: Built Aluminum Rod 2.0 Long Block
  70. FS-ACT Clutch just over 2k on clutch just needs wave spring
  71. Garage sale evo 8 clean out CHEAAP
  72. 06 MR Complete Swap
  73. FS: NORCAL: Prosport Gauges, Stock evo8 intake & O2 housing
  74. FS: *RARE*- HKS Racing Type-I BOV
  75. 2.3L stroker shortblock.
  76. F/S(PA) Evo 8 turbo 04'-No shaftplay
  77. F/S (pa) Brand new ACT throw out bearing
  78. F/S (PA) Forced Performance evo 9 wg- 25 psi
  79. FS: EVO 8 9 TPS Sensor Throttle Position MD628074
  80. wtt t3 kit.
  81. PTE 6766 dual BB Turbocharger w/ .82 A/R V band turbine housing
  82. FS: Quartermaster Street Discs Almost New!
  83. 5spd swap, (BNIB GSC s2's, ams rail, 255) jdm rear, greddy og ti exhaust, oem parts
  84. Forced Perfomance Billet GT3586R aka HTA86, like new!!
  85. FS Walbro gss342 standard 255 fuel pump.
  86. AEM EMS V2 with Sensors and Cable EVO 8
  87. Torque Solution (VII-IX) 6spd trans mount
  88. AMS VSR Intake Manifold - $500 Shipped/paypal included
  89. HKS TwinPower DLI NEW
  90. WTT: greddy ceramic coated o2 housing got o2 dump + cash my end
  91. exedy twin hd cheap but today !!!!!!!
  92. FS: Injen Intake, 9.8 turbo, stock exhaust, airbox, radio
  93. FS: HKS intake kit(6k miles) with stock MAF( 21k miles)
  94. FS EVO 8 ACT "Heavy Duty" Clutch & Fidanza Flywheel $350
  95. Evo 8 Turbo with 10.5 hotside
  96. FS EPM 02 DUMP FP race j pipe coils HKS intakes fuel housing ect.77..
  97. FS NYC : Injectors, maf & filter,springs,rods & sensor
  98. F/S Chase Bays engine harness
  99. F/S A'C brackets
  100. F/S OEM T-Stat housing cover with Bung for water tempsensor
  101. F/S -6 fuel rail fittings and EGR block off plate
  102. F/S OEM & Aftermarket sensors.
  103. F/S brand new magnaflow 3.0 muffer and used burns V-Band muffler.
  104. F/S evo 8 engine mounts, trans mounts, & rear dif mounts
  105. Ported Skunk 2 IM, Full Blown TB, S2 Cams & GSC Valve Train
  106. Evo 9 rad fan
  107. Fs. E85 Eca. Low mile 9 turbo! Stock manifolds! Cheap
  108. BNIB: Megan O2 housing 8/9
  109. Air box bracket & lid - boost solenoid - acd pump bracket, silencer ect
  110. greddy oil block adapter - Apex turbo timer
  111. BNIB Shep 5spd Trans and 5spd Conversion Kit
  112. Rnr ramhorn manifold, and 38mm to 38mm adapter
  113. (FL)For sale ~ 2.4 LR motor, best parts used!!
  114. Ams fuel lab fuel pressure regulator kit brand new in the box.
  115. FS: FIC Hi-Z 1680 Injectors - $500 Shipped
  116. FS: AEM Cold Air Intake (Polished)
  117. FS: Greddy 720cc Injectors
  118. DIY AEM Dryflow Filter and EVOX Maf Sensor Tube
  119. IX valve cover, Ams fuel rail silver, perrin gauge pod more
  120. Stock 5spd Evo Ix Trans, ACT Clutch w/flywheel
  121. Samco Radiator Hose KIt $100 shipped obo
  122. Buschur, Mishimoto, Megan, MAP, ETS, STM, and more!
  123. Magnaflow 3' Catback
  124. 500WHP (Dyno proven) Stock Frame Turbo Kit CHEAP Atlanta
  125. Precision 6262CEA BB v-band
  126. PORTED FP GREEN(1st gen) TURBO
  127. FS: Deatschwerks 740cc injectors for evo 8/9
  128. FS: ETS uicp stock battery route
  129. FS IL: HKS DLI 2 twin power $225 obo
  130. FS IL: eagle rods with 600 miles on them. $225.00
  131. Fs aps bov
  132. FS: Muse o2 housing (external dump)
  133. aem tru boost controller
  134. FP Red turbo
  135. FS: Evo 9 ECU
  136. bbk-b 1050$ shipped
  137. FS: (CA) BNIB ETS Mitsubishi Evolution 8 and 9 - 4" Speed Density Intake
  138. OEM Evo 8 Parts 20-40k Miles Block, Crank,EM,FR,HD,8Turbo
  139. FS: Evo VIII head and (red) Tial Q 50mm BOV
  140. FS: MAC Boost Solenoid, Crank Pulley Dampener, 2 Catch Cans, Stock Flywheel cheap!
  141. FS Evo 8 Energy Suspension Rear Diff Bushing set
  142. FS: Low mileage 9turbo, MAP 02 dump, FP 25psi wga, OEM ported exhaust manifold, etc
  143. Fs: Like new OEM oil pan, megan radiator cap, driveshaft loop, oem oil pickup
  144. FS: Brand new PTE 6262 Journal Bearing Turbo
  145. Evo 8 HKS dli and magnecor wires
  146. Map EF3
  147. FS OEM Head Gasket brand new EVO 8
  148. Manual Boost controller's and a shift knob
  149. for sale BR 65mm throttle body
  150. OEM Intake mani, BR HFC, PTE & DW Injectors, Vishnu TBE, Stock Exhuast, Coils, etc
  151. AEM EMS Version 1 1313u Evo8
  152. Parts for sale, Spark Tech, AEM, Kiggly, Kelford, Tial, FIC
  153. FS: Magnus SMIM, PP 70MM TB, IAC CT/NYC
  154. FS: JM Fabrications Twin Scroll Stock Replacement Exhaust Manifold, Greddy TypeRS BOV
  155. FS: Magnus, MAP, Full Blown, Tial, AMS, Omni
  156. Super sale oem parts real cheap!!!!!under 13k miles on everything
  157. FS (FL) CXracing turbo manifold $80.00 shipped/trades welcome
  158. Fs: Bbk full ported
  159. Ball Bearing FP Black
  160. (MI) 2 Evo9 Turbo(s)
  161. FS: Stock FMIC and Stock 8 DownPipe, Cat, Exhaust
  162. GSC S1 Cams for Evo 8
  163. Precision 1200cc injectors for sale
  164. FS: Stock Exhaust for evo 9 $400 shipped
  165. Map wga $100
  166. Skunk 2 Throttle Body $225
  167. VSR Intake Mani $450
  168. FS - Apexi Catback, UICP w/ Synapsis BOV
  169. 4.5" inch exhaust silencer - New
  170. 4/S 5spd Tranny /Clutch combo ...
  171. FS: STM ss full clutch line
  172. 2006 GSR non-HID headlights MINTY**
  173. Engine bay harness & Complete cabin harness
  174. REBUILT QM 7.25 vdrive $550
  175. 06 front brembos (clips pins pads) F&r
  176. FS: ACD t-case 05 43k
  177. Spoolin Up COP VIII - $300 OBO
  178. FS: Stock Clutch/Flywheel , 2 Stock Fuel Pumps
  179. Direct Bolt-on Aeromotive FPR - $175shipped cont US
  180. FS: 2003 Evo Parts, Radiator Hoses, Throttle Sensor, Flywheel
  181. FS: Custom short route UICP with Synapse Dv flange $100 Shipped
  182. FS: Tatrix cable
  183. Two Ported Stock Exhaust Manfiolds
  184. buschur hta37r turbo kit 1800 OBO shipped.
  185. FS: FUELAB Fuel pressure regulator
  186. FS: Turbos, Garrett, Turbonetics, Tires, Nisei Battery Tray, etc.
  187. FS: Ported Evo8 Exhaust Manifold
  188. FS: Stock throttle body (two)
  189. FS: HX40, Half rad setup, Evo8 turbo, stock rad, Lower ic pipe
  190. Half width cbrd rad
  191. GSC S2 cam, Manley rods, Arp head studs
  192. COP,Powerflex roll stop, underdrive pulley, SS IC Pipes, Greddy BOV, Apexi air box
  193. FS:WA K&N panel filter, Odyssey Battery
  194. Hx40 Super 40 7 blade BILLET wheel 17cm twin scroll
  195. 2006 Evolution - Rear Hubs, Control Arms, Subframe - 36K Miles
  196. 2006 Evolution Rear Differential and Axles - 36K Original Miles
  197. NJ:FS Trust Ti Exhaust
  198. Holset HX40 600hp turbo
  199. FS: FP Black, NEWLY REFRESHED from Forced performance.
  200. Evo 9 turbo kit,samco hose kit
  201. Badev0's T3 turbo hot parts kit. Manifold/dump tube/downpipe
  202. FS: O2 metal gasket Brand New
  203. Moving out of state sale.
  204. Evo 8 head, oil cooler, other engine bits
  205. FP BB Red Toxic Fab manifold
  206. FS: AEM and Autronic ECU
  207. Evo 9 MIVEC head, Crower valve springs/retainers, cams, throttle body
  208. F/s aem ems v2
  209. AZ: FIC 1450cc Injectors, PTE 6262 DBB Turbo, 4" Intake pipe
  210. $25 Sale - 4" HKS Filter, Carbon Fiber Cam Cover, MAC Valve, Stock Coils, O2 Sensor
  211. FS: Tilton Twin Cerametallic Clutch + Flywheel
  212. Greddy / TiAL / Vibrant
  213. FS: Competition Twin
  214. FS: ETS 3.5" FMIC -Used
  215. 4g64 block ,crank,hks intake, injectors
  216. F.S. Stock Evo IX MR Downpipe
  217. 4G64 Block and Crank
  218. Ams licp
  219. FS: Colorado TOXICFAB FULL SS TWIN SCROLL STOCK FRAME MANIFOLD!!
  220. Fs: Ps pump
  221. FS:Exedy Twin HD:cheap
  222. FS:Sparktech non-cdi w/7,500 miles
  223. FS: Lancer Evo 8 & 9 Parts!!!
  224. FS: Evo 6 Tommi Makinen Turbocharger
  225. FS: Oem parts
  226. Evo ix MAF w/ adapter and KN filter
  227. Fs: Sold
  228. FS: Fujitsubo Downpipe
  229. FS: ATP GT3071R Turbo Kit
  230. Apexi Titanium cheap
  231. Evo 9 mr turbo
  232. Percision 6262BB .63, and ACL 4G63 EVO 8-9 rod/main bearings
  233. FS: HKS Balance belt & GATES T41038 Balance Shaft Part
  234. evo 8 project valve cover, carbon fiber radiator shroud, weapon r catch can
  235. FS (WI) Buschur LICP (for stock fmic)
  236. F/S Package deal ARP L19 & HKS Head Gasket
  237. FS: Exedy HD Twin Disc Clutch (MD)
  238. 2005 ssl evo 8 ACD pump
  239. 5 speed quartermaster v-drive
  240. torque solutions 6 speed mount NIB
  241. kings preformance main race bearings cheap!!
  242. buschur ported throttle body
  243. evo 8 10.5 turbo w manifold
  244. FS: Evo 8 Ramhorn Mani with Tial Gate and DT
  245. Turbo Kit for sale
  246. Bucher race fmic
  247. FS: stock parts, HKS, ACT,
  248. FS: Magnus, Hyper Force System, HKS, AMS
  249. FP 18 PSI wastegate
  250. (WV) FS: Buschur, FIC, MAP 02 ELIM DP, MAP Stock mani, Megan, ACT, HKS, Pioneer AVIC!
