- FS: Evo 9 mivec valve cover
- FS: Stock Evo 9 catback exhaust in SoCal (DIRT CHEAP!!!)
- Evo 9 6 speed transmission - 50k
- FS: exedy twin HD Cheap!
- FS: BC272 cams
- Skunk2 intake mani, Carbonetic triple, Carrillo rods
- ARC,TOMEI,INJEN,BRIAN CROWER,B&M,TURBOXS,APT GARRETT,DEJON,FIC for evo 8
- F/S, eBay, turbosmart, gaugepod, aem
- Brand New Wiseco HD Pistons!
- FS: Hallman Pro MBC w/in-cockpit control
- O2 Housing Coated by Loko to retain heat and maximize performance.
- FS: Intake Pipes, Oil Cooler, Misc Items $20 for any Part.
- wastegate
- FS 4G64 Block 156mm LR's Wiesco 87mm pistons and more!!!!
- FS: Hallman PRO MBC (anodized red)
- FULLBLOWN Double pumper, O2 dump and more!!!
- Grimspeed 3 port boost solenoid
- FS: MAP o2 eliminator downpipe/dump w/3 bolt AMS flange
- FS: RCI 2200cc injectors (high impedance)
- FS: Ebay Short Shifter, Stock Fuel pump (pump only), Rear Trailing Arm
- Precision 1200cc injectors
- COMPLETE FP HTA82r Dbb turbo kit for sale! LOOK
- HTA3586R for sale
- FS: Stock Evo VIII catalytic converter
- Like new AMS high flow cat
- Stock EVO 8 ECU with ignition, key, and immobilizer box
- Grimmspeed 3 port boost controller brand new in box
- Triggerdisc for quicker AEM starts / AEM Boost control solenoid - use with stock ECU!
- Exedy Twin Disc "CARBON"
- FS: QM 6 leg and ACT streetlight flywheel
- FS: Works exhale full 3" catback exhaust modified to fit JDM bumper
- F/S: PTE/Delphi 650 Injectors
- Full-Race 6265 Complete kit. Ball bearing. CHEAP
- FS: EVO VIII-IX Parts
- OEM Parts sale ! FMIC, pipes, etc
- T3 manifold and wastegate f/s
- f/s OEM Mitsubishi Throw out bearing lombard,il
- FS: HKS SSQV V2 Black & Hallman MBC Black
- NV: APS 50/50 bov
- fs:Exedy twin hd w/ agency power clutch line
- NYC: DIY COP Kit / HKS Twin Power DLI / SunAuto Hyperforce/Evo9 BOV
- FS: Stock IM, TB, Inj. New O2, catch can, etc
- Stock IM,TB,cams
- FS:HKS turbo timer, stock intercooler, precision 1200s
- SpoolinUP COP evo8
- FS: Custom Evo8/9 CAS heatshield Stainless
- EVO VIII valve cover. $50 shipped
- ToxicFab CT9A coated manifold w/O2 bung (new)
- MAP H11 head studs and ARP main studs
- FS: Injen LICP,UICP, Intake w/ T-bolt clamps
- FS:Evo 8 turbo, Evo 9 WG actuator
- Walbro FP, Injectors, Boost controler, Pistons
- FS: K&N filter, OEM MAF, Vibrant Coupler
- FS: GSC Cams (Evo8)
- FS: Tilton twin carbon clutch , BR spec 10.1 pistons
- M2 Turbo Manifold
- tomei mivec 280, gruppe s flywheel, no name flywheel, mynes t3 mani
- FS Greddy intercooler, o2, GSC Cams, Precision Turbo, manifold, throttle body
- evo 8 oem accessory belt tensioner, all star motorsports catch can
- FP black, JUN 272, Aquamist HSF3, Forge
- Fuelab fuel pressure regulator kit
- Evo intake for MAF with couplers
- Hallman Boost Controller (Brand new) $70 shipped
- For Sale: (MN) Kinetic Motorsports Front Mount Intercooler + Lower Intercooler Pipe
- ETS 3.5" intercooler/uicp/licp..
- CA:FS- Stock Air Intake with K&N filter / Stock Infinity Radio and other misc parts
- OEM mitsu oil pump
- Evo 8 Stock Catalytic Converter 49k
- FP Inline Filter BNIB
- mini-battery w/ tray
- Buschur RACE intercooler w/ pipes and Tial Q 50mm
- Evo VIII transmission w/ low mileage
- FS: Deatschwerks 1300cc injectors, Spoolinup resistor bypass
- FS: Greddy Ti-c comp
- Fs: Omnibar Map Sensor Speed Density $75shipped!
- FS: Buschur Magnaflow Exhaust
- FS: HKS 272 deg Cams (original grind) Evo 7 and 8
- 2006 ACD Transfer Case - 36K Original Miles
- 2006 Mivec Longblock - 36K Original Miles
- T3 Manifold, 3" v band downpipe, Bullseye performance housning
- ATP Stealth 30r Turbo Kit, ARC Heatshield, CompCams 272 and more...
- STM Fuel Pump Rewire
- -12AN Earl's Perform-O-Flex Stainless Braided Hose
- FS: Precision sc6152sp turbo - t3 .63ar
- Cheap!!! Parts!!!
- Evo IX Turbo complete
- Perrin Intake $165.00
- 2 Synapse wg 40mm NIB AEM WIDE Band NIB
- ETS 3" interccoler; ETS V-1 LCIP
- Shep Ultimate Ratio 5-speed transmission; Shep Stage 2 non-ACD t-case with Quaife
- Evo IX Long Block-complete $2,400
- FP Intake & Perrin Intake adapter
- FS: FIC 1000cc
- FS: OEM Stock FMIC
- FS: OEM Evo IX Cat Catalytic Converter
- RevHard/Buschur Cast T3 Turbo Kit
- FS: COMPLETE Evo 9 Turbo Kit! w/ FP Wastegate/FP Install Kit and Titek o2 Housing!!!!
- FS: Perrin Air Intake Evo 8/9 , starter
- FS:Evo 9 Cosworth M2's
- Magnus Head Studs
- LIKE NEW Exedy Twin! FIC 1450s
- EVO 9 Metal bov
- FS: ETS LICP Brand New Black
- FS: Evo 8 A/C Componets
- evo 8 Fuel stuff
- FS: HTA Green, Kelford cams, GSC vlave springs, AEM EMS
- FS: used OEM evo 9 intercooler in socal
- FS: brand new Synchronic Blow-Off Valve in socal
- Buschur Ported / Jet Hot Coated Exhaust Manifold & O2 Housing (NEW)
- FS: HKS EVC 5 in Socal
- FS: Stock ECU Evo VIII (03-05)
- F/S: Evo 9 Rear axles
- Muse Ported Exhaust Manifold and front o2 sensor
- FS: Kelford 272 cams for EVO 8!
- In NEED of Amsoil severe gear by Friday. Help!
- ACD Transfer Case - 29k miles
- Fs: Gsc s2 mivec cams
- BNIB Apexi TT, used Megan 02, New STM steel flanges...CHEAP
- (MI)FP 25psi WGA, JMFab Spark Plug Cover, RMR Filter w/Adapter, Stock Parts...
- FS: two carbon fiber catch cans
- FS: ETS 57 trim T3 Turbo kit
- FS: Never used, Never opened GSC No-Tick Lifters Evo 8 and 9
- FS: ETS Intake Kit
- FS: (OR) Stock Evo 9 Turbo/coated hotside - super low miles!!!
- FS: Buschur COP with CDI box
- Zeitronix ZR-2 multi gauge
- FS: CT - Injen Mitsu Exedy Forge Parts
- FS: AEM Tru boost controller/gauge
- BNIB: Purple Tial Q BOV $212 Shipped & Purple Tial F38 WG $200 Shipped
- Australia - R&R 156mm Con Rods
- Stock Parts: CHEAPEST PRICE on EVOM. (injectors, TB, IM, Coils, etc)
- FS NEW 4 Inch Speed Density Intake CHEAP
- BNIB Aeromotive 340 stealth pump $130!!!!
- FS: NEW, UNUSED Mitsubishi OEM Evo headgasket and Walbro 255lph HP fuel pump
- F/S NYC: Synapse Bov and Synapse Diverter Valve
- evo 9 turbo
- F/s aem ems
- FS: Competition twin disc clutch & Perrin HFC
- FS (FL): Evo VIII-IX Drop-in Pauter rods/Mahle Std bore pistons
- FS: OG Synapse Synchronic DV
- FS: Evo IX MR motor, Trans, Acd t-case
- Fs: Hks dli 2
- FS: Evo IX parts, starter, injectors, alt, ps pump, sensors
- F/S Driven Innovations Intake mainfold
- FS: EVO IX Turbo with lines
- no longer for sale
- Sold
- ETS 4" FMIC MINT Condition
- Denso IW24 Evo8 Used
- FS: FL Buschur HTA3586 turbo kit, down pipe and race intercooler
- FS - Wrinkle Black IX Valve Cover
- FS: Stage 2 Exedy racing clutch
- AEM,Buschur Dual Stage,Full Race
- FS: FIC 2150, Hafe t3 mani/02, Tial bov, Aeromotive a1000 and FPR, fuel cell, etc!
- FS:BNIB:PA: HKS Cams/Cam Gear/Synapse DV/BR Bushings
- FS: SpoolinUP COP - EVO VIII!!
- FS: Evo 8/9 FIC 950 Injectors
- F/s F/T Aftermarket 02 housing with Sensor
- FS: Kelford and HKS cams, STM, Buschur, AEM
- Fs-buschur ported/coated mani, aem intake, new gaskets
- FS> Cosworth M2 Evo IX cams
- FS: CBRD custom v band o2 housing and downpipe. Swain coated ;)
- T4 Undivided .81 A/R P Trim Housing 3'' V-Band
- FS: *RARE* HKS Cast Aluminum JPIPE
- FS: FP Oil Line Kit! (RED,GREEN,BLACK,HTA) $175
- FS: FP 18psi Wastegate Actuator $95
- FS: 10.5 Hotside evo9 ported! $175
- FS: okada coils plugs and wires!!!!!!!!!
- Stock Evo 8 turbo & o2 housing
- FS: (CA) Evo GSR 5 Speed Tran 50K Miles
- VA: Evo 8/9 Turbo Parts for sale (16G Turbo, o2 housing, downpipe, etc.) Come look!
- FS: FL buschur, 5 spd built trans, boomba, tons more!
- Lucas 1200cc injectors brand new
- 3" XS Power Exhaust + Test Pipe
- JUN 272 cams Feeler
- FS: Cosworth Rod Bearing Set $70 shipped
- Fujitsubo RM01A Turbo-back Exhaust Quietest Exhaust available for an EVO!
- FS walbro 255 pump & fuel pump assembly
- FS ETS UICP for Magnus intake
- FP Black Journal Bearing, Megan Exhaust Manifold, JM O2 Housing
- FS: Leftover parts after new build- AMS, Magnus, Megan, Stock 9 IM + TB + more
- OEM VIII valve springs and retainers
- exedy hypersingle stg3+flywheel -cheap-(REBUILD NEEDED)
- Hks 264/264
- FS: 10.5 hotside (cheap)
- Random stuff, Low Ballers welcome
- Evo 8 Stock Cams, 02, Springs, Studs, Jpipe
- FS: AEM gauges, gauge panel, & radio relocate kit
- FS: ETS LICP 2 $170 shipped
- FS: Used Evo IX MR Injectors
- FS: MilSpec 65mm throttle body
- FS: AMS CDI coil on plug ignition system
- FS: Omni 4 bar MAP sensor $85 shipped
- FS: injen LICP and MEGAN o2 housing (CA)
- Kelford, Aem, Supertech, Monster Sports Parts
- FS: Turbo XS downpipe, Test pipe, Megan Cat back, Hallman BC, and Tatrix cable!
- go fast parts must see
- Spark Tech CDI Mounting Bracket
- AEM 3.5 bar map sensor
- Energy Suspension Mustache and Rear Diff
- 1600cc injectors
- Hallman Pro Boost Controller
- AEM High Volume Fuel Rail
- FIC 950 CC injectors with new Seals
- FS: BRAND NEW PARTS. ARP headstuds, OEM MITSU, GATES belts, REXPEED
- BNIB Koyo Half Radiator
- evo 8 harness, mr gauges, galant hvac, hyperforce, evo 9 turbo, 8.5 turbo, abs module
- F/S: used '05 ACD pump (rebuildable?)
- t3 6776 bb
- Evo 8/9 JDL Autodesign O2 dump F/s
- Evo 8/9 Fluidamper F/s $185 Shipped
- AMS 3" Intercooler Piping Set
- FS: oem tb
- BNIB BC 272 Cam kit
- sold
- Delete!!!
- FS: Precision BB 6776 aka 37R
- Fs:bnib act hdss clutch kit
- FS: Aftermarket LICP
- FS: OEM IC pipes: LICP & UICP
- FS: Evo 9 plug cover (*MINT*)
- FS: Buschur Racing MBC (~brand new)
- FS: Cosworth M3 cams, HKS cam gear, JDM 3bar map sensor
- complete stock 4g63 shortblock
- Injen SES Catback
- FS: Red Evo 4 Valve cover
- Stock evo 9 manifold
- Mini battery ETS tray
- Injen licp!!!!
- FS: Walbro 255lph Fuel Pump (45k miles)
- ACD transfer case 58k
- Precision T3 .82 housing 4 bolt
- ACD Pump
- FS: EVO 8/9 ETS T3 manifold, BYC 3.5" intercooler
- FS:Exedy Twin HD,Cosworth 272 M2 (Mivec),ACT HD Street Clutch,OEM Springs,Headstuds
- 100mm 4g64 Crank
- Aeromotive Fuel Pump
- FS: Brand New/Never Used FIC 1100's
- Garage clean out, JUN 272, AMS LICP, lots of stock & aftermarket,TIAL
- BN: FP Intake 3.25" / 84mm
- fs- pte 880s
- FS: Tomei Arms M7960 Turbo, Tubular Manifold, boost controller, and O2 housing.
- Used Exedy triple disc clutch / flywheel and TOB lombard, il
- FS: Kelford 272's for Evo 8. Nearly brand new
- FS: 3.5" ETS Exhaust, 3" Cat Back, Walbro 255, misc
- Aquamist HFS-1 priced to sell
- Full HX40 Turbo Kit
- FS: NY - Some stock some performance.. ALL PARTS!
- FS: Evo 8 HKS 272/264 Combo Cams Cheap
- spec e twin disc
