PDA
View Full Version : Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12
  1. Could a wheel expert, or the TireRack gut explain this?
  2. BRAKE light always ON!!!! ahh
  3. Advice on Rota rims
  4. Which tire size for these wheels?
  5. stock evo strut bar....
  6. find me wheels, get $20!
  7. Disc brakes on the back!
  8. 16 or 17's for my Lancer ES?
  9. Need Help Deciding Which Tires!!!!!!!!!!!!
  10. Stock OZ wheel offset?
  11. Suspension Parts.
  12. New front brakes are on
  13. does BREMBO really make rotors for OZs?
  14. lowering...
  15. question about the s-tech springs?
  16. help with strut bar install!
  17. Help!!! broken suspension
  18. could use some info...
  19. whats the real drop on the tein s tech springs
  20. Tire Pressure on a 16 inch rim
  21. blown struts - what does that really mean?
  22. Totally new front brake question
  23. help with spring install!!!!
  24. Best set of rubbers on the market
  25. Nex Susoension
  26. New rotor option
  27. Lug nuts
  28. OZ rear disc brake upgrade, Possible??
  29. Nex Coilovers?
  30. Mitsubishi Center cap size?
  31. Brembo Gran Turismo Kit for US Lancer?
  32. Will these Coilovers work on a 2003 Lancer OZ Rally?
  33. suspension problem i think
  34. Help Wheel Rub & Squeaking!
  35. Possible to rebuild struts?
  36. Ralliart Struts?
  37. suspension for 2005 ES
  38. Coil Over Sleeve Question
  39. Brakes
  40. need help????
  41. Problems finding strut bars...
  42. Rebuilding rear brakes
  43. looking at wheels!!
  44. Aftermarket Springs on stock suspension
  45. Rotors for the ES?
  46. Enkei Rim repair
  47. Help me with my 16 Rims!
  48. how does strut bar work?
  49. 16s on an ES
  50. Summer tire suggestions?
  51. Finally Lowered My Lancer!
  52. Tein Superstreet SS
  53. the basics or super streets?
  54. Strut Bars
  55. rear drum to disc conversion
  56. 16-20 in rims/tires what's the use?
  57. What is up with my wheel alignment???
  58. Brake Rotors
  59. Painted Springs
  60. load rating
  61. Center Caps?
  62. Alignment question
  63. Lowered Lancers; how much for alignment?
  64. Progress Sway bar w/perches
  65. A question at power coating my rims ...
  66. Cheap ES Wheels
  67. Suspension for ES
  68. stock oz tire size (quick help)
  69. anyone attempt 19's on theirs?
  70. Rear camber
  71. Which Brake pads
  72. OZ rims
  73. How much have u paid for tires?
  74. Truck tires?!?!?!?!?
  75. rims on thunder gray lancer
  76. Found tien basic coilovers for $130 cheaper than RRM!!
  77. Looking at Kosei Rims on TireRack
  78. shut her up!
  79. lowering the coilovers help
  80. 205/50's
  81. I need someone with experience with springs...
  82. Rim Suggestions. . . . . .
  83. Hankook Tires.... Anyone have them?
  84. need quick tire/wheel help
  85. S.Techs settling unevenly...
  86. Kuhmo Ecsta ASX 205/55/15 on stock rims
  87. Best And Cheapest Place To Get Tien Coilovers
  88. Product Review: NEX Technology Coilover
  89. Will be out till Monday!
  90. Tire size advice
  91. NEX Full Coilovers?
  92. What do you think of these rims for my car???
  93. Snowy weather and tire pressure question?
  94. sway bar parts question
  95. Springs for LS..
  96. brake pads pronto
  97. Front Sway?
  98. TEIN BASIC COILOVERS fit 02-03 Lancers & 04 Ralliart
  99. life of the road race break pads vs. a cheaper alternative
  100. Drag radials
  101. Curious about tires rubbing?
  102. your welcome guys;)
  103. Guys with PDX trunk bar...
  104. Help! Looking for upper strut mounts
  105. rear suspension combo
  106. bolt pattern adapters
  107. Maybe Repost Question On Ebc
  108. Tires Rubbing . . . help
  109. Air Bags for '02, '03 Lancer
  110. Any OZ with 18s????
  111. Need help with rear brakes ASAP
  112. Dropzone Shock Strut
  113. 17in OZ wheels question
  114. Drum-Brake to Disc-Brake conversion kit?
  115. Wheel storage
  116. Handbrake
  117. H&R Springs for the ES?
  118. studding stock tires?
  119. OZ Wheel Specs?
  120. Snow tire instal problem
  121. Volk TE-37 or Racing Harts J5's
  122. aftermarket shocks
  123. Cost of Install???
  124. 2003 ES Springs - Help
  125. Rigo's review of RRM rear strut and tie bar
  126. I need help with knowing the tire pressure
  127. Glazing already on new rotors/pads?
  128. Resurface rotors or not?
  129. # of slots on Slotted Rotors?
  130. Winter Tire and Wheel Reminder
  131. Just a reminder
  132. Will 205/40-R17 Tires fit on 04 Lancer ES?
  133. Need to know
  134. tein basic coilover
  135. autobarn ?
  136. Best Performance Tires
  137. Camber kits
  138. Buying used springs?
  139. Brake Conversion
  140. Are these koni shocks really for our car?
  141. stopping power
  142. Question on RRM springs for ES
  143. sumone take a pic??
  144. Arospeed Rotors @ Andy's Autosports?
  145. quixk sumone????
  146. new wheels..
  147. 19" rims for ES and OZ with a wide body kit.
  148. Disc Brakes
  149. Has anyone put low profile tires on their stock OZ wheels?
  150. Best Break pads for an 03 OZ??
  151. winter
  152. dropzone spring, good or not?
  153. Nokian Winter Tires??
  154. Squeaking brakes
  155. EFD on a Lancer
  156. wheel studs??
  157. OZ rims on an ES?
  158. performance winter tires
  159. I am going to ask for help from now until my car is done.
  160. A question about brake fluid?
  161. Teins SS Coilovers same for OZ and ES?
  162. 02 oz and any other model springs difference?
  163. rotors?
  164. strut bar question
  165. ride became kinda bouncy
  166. Aftermarket general maintainence parts?
  167. 03 Lancer ES OEM size rims
  168. Installing Tein S-Techs
  169. New Tire Model - Any Reviews/Opinions?
  170. wondering if my jam lugnut....
  171. Knocking sound when I brake
  172. new springs/stock shocks?
  173. bad brakes?
  174. Winter Tires. will these fit stock rims?
  175. air bags or regular suspension lowering kits??
  176. Brand name Vs. Ebay Brands
  177. Need a walkthrough on Coilover Install
  178. New tires and rims
  179. 2002 lancer oz Electrical Specifications
  180. RRM vs. other sites on SWAY
  181. Need help on difficult supension/alignment/camber problem
  182. New rotors and pads
  183. Eibach pro kit=best choice?
  184. Motegi MR7 4-lugs. Will they fit my OZ Rally?
  185. Tein S-Tech springs vs Progress, Stock rims? After Market?
  186. anyone heard of this company?
  187. Another Tire Size Question
  188. anyone know what rims look good stock >>lancer??
  189. What to do with bump stops
  190. RDDesigns (PDXRalliart) Sub-Friendly Rear Strut Brace Install
  191. brake fluid question
  192. Important Tire/Wheel Info For All In Maine!!!!
  193. I bent my rim...need help
  194. pple wid rims
  195. Who's got TEIN Basic Dampner?
  196. Scratched my RIMS TODAY!! :(
  197. love my new pads and rotors!
  198. Air Ride for lancer?
  199. Need help with broken lug
  200. oz rims on es
  201. Rotors and Pads questions
  202. will these rims fit ok??
  203. Steel braided brake lines
  204. front strut bar vibrating
  205. these can fit can they?
  206. DC Sports Strut Bar
  207. ES springs question for the wiser peeps
  208. It looks like my rotors are being eaten...
  209. Front and Rear Sway Bars
  210. k bar wont fit
  211. Stock shocks making noise
  212. Toyo Proxes 4
  213. how strong are SSR rims?
  214. NTB scratched my Rims
  215. Skunk 2 Coilover
  216. Winter Tire and Wheel Reminder
  217. quick tire question
  218. tire recommendations
  219. Which springs are better?
  220. Brakes making noise
  221. Need Lower control Arm replacement$$$
  222. Can I replace ES strut to OZ strut?
  223. suggested replacement shocks
  224. Tein installed but clung noise =(
  225. Do the ES and OZ use same spec rotors?
  226. where to buy pads
  227. Lowering Springs
  228. What's the Best type assymetrical tire?
  229. Spring clips inside or rotors
  230. Big brake kit or not?
  231. BUYER BEWARE......Brembo Rotors on Ebay
  232. Will These fit??
  233. How do you take apart the drum brake?
  234. installed rear sway bar & perches
  235. Strut Bolt Problem
  236. Replacing rotors, if topic already exists please post link
  237. Loosening the top nut during spring installation
  238. Ever since I lowered my car I've heard some odd noises
  239. Another lowering springs Q
  240. Installing springs is a biatch!
  241. Broken lug nut
  242. Where can I get Enkei center caps?
  243. a lil help? i dont know what to do (coilovers)
  244. Drum to Disc Conversion
  245. BEST ALL SEASON TIRE? help needed
  246. 2002-2003 lancer ES coilovers
  247. Axxis Brake Pads
  248. Do you got S-techs???
  249. suspension upgrade on a budget
  250. Tein coilovers - Basic or SS?
