PDA
View Full Version : Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12
  1. Buying New Wheels and Tires, Question
  2. Need help with tire pressure
  3. RDD Strut bars installed!
  4. Need advice on new shocks
  5. Another one dropped
  6. brake replacement recommandation
  7. Ksport Adjustable Suspension
  8. Half done.... got a nice surprise to boot
  9. Jumpy ride
  10. brake thingy
  11. bent rim question
  12. What type of BRAKE setup to use.
  13. Broken Wheel Stud
  14. clinky Noise from wheel
  15. shocks!
  16. Brakes Recommendations
  17. Hit a curb at like 25-30
  18. JIC's FLT-A1
  19. Brake Spindle. Help Please
  20. APEX lowering springs... help
  21. Broken sway bar endlinks
  22. Tein or Progress for my ES?
  23. Evo Suspension
  24. rear disc brake conversion?
  25. Question about brake pads
  26. 2003 OZ Rally Bushings
  27. Strut Bars?
  28. buying used coilovers
  29. 215 50 17
  30. Will 17X7 with a 42mm offset work
  31. Question about rims
  32. 15s w/ drop or 17s w/o drop
  33. 205/40-17 Fit on an ES?
  34. 18x7.5 with a 48mm offset fit
  35. Will 215/35/18 fit?
  36. Give me your opinion on these rims
  37. TEIN-S, tanabe GF210, or hotchkis for an 02 OZ?
  38. 03 lancer oz suspension
  39. Help me pick a rim
  40. help with locking lug nuts on 02 OZ
  41. rear suspension
  42. 17 x 7.5" +45mm on es?
  43. Alignment REALLY bad??!!
  44. Poll of whos running with springs/sleeves ONLY
  45. Converting Drums to ABS in the rear
  46. will this lower my car without problems? tein springs only or
  47. Squeaking Noise From Tire/Wheel
  48. Wobbling brakes
  49. STRUT/BEARING? help
  50. brake ?....
  51. question about stock wheels
  52. 2003 Oz Racing Rims weight?
  53. RMR SRI not compatible with RRM X bar
  54. EBC rotors
  55. Brembo rotors
  56. installing springs
  57. Lancer adjustable coilovers
  58. rotors and brake pads
  59. Inexpensive anti-sway bars
  60. Clunk on Bumps and Left Turn
  61. 2006 OZ Rims
  62. OEM brake pads or aftermarket pads
  63. I have a question on offset rims
  64. Aftermarket caliper
  65. Tein S. Tech spring too much for 03 OZ?
  66. Springs
  67. measure drop
  68. sway bars
  69. New treads with profile change
  70. Buying Tires need Help
  71. I'm on vacation May 6th thru the 14th
  72. BOMZ Lancer Coilovers
  73. Question on bolt pattern
  74. Struts...my mission to find the facts
  75. Rim Advice
  76. Lowering Springs question
  77. Tien S-Tech Questions
  78. rear brakes for my OZ rally...
  79. racing tires on stock es
  80. performance struts ?????
  81. Springs
  82. Evo suspension on 02-03 OZ
  83. evo 8 style rims for es
  84. What's up with this?
  85. Tires width
  86. OZ replacement struts?
  87. rolled fenders
  88. Barke cooling
  89. good 14" rims
  90. Help me make this decision
  91. Brake Problem
  92. Installing springs
  93. Polished lip got messed up
  94. trouble with strut
  95. I need sugestions....
  96. tire question
  97. help! ROTOR QUESTION
  98. Stock 2002 Lancer ES Wheels
  99. 215/50/15 on OZ wheels?
  100. tein ss adjusting
  101. I changed my brakes this weekend and
  102. tires...?
  103. Good Rotors for a good price?
  104. What'sup with Wanli tires?
  105. new wheels and tires, braking problem
  106. evo II sprint on lancer oz
  107. Ksport Kontrol Pro Coilovers
  108. General question about Progress Springs Installation.
  109. Dealer parts availabilty?
  110. Brake pads
  111. Straight Wheel
  112. Rusted Nuts
  113. Extended Studs
  114. Springs for 05 Lancer ES
  115. Strange noise from brakes or steering?
  116. BBS rims! HELP!
  117. Brake pad confusion
  118. Had a little boo-boo
  119. KartBoy Exhaust Hangers for 2002???
  120. Help with Springs
  121. 15" Winter Steel Rim-HELP
  122. wht do you think of these rims?
  123. Drum to Disc
  124. what do you guys do with aftermarket rims when a tire goes flat?
  125. can i put these on my lancer? help!
  126. Getting ready for autox
  127. will these fit?
  128. These pads worth it?
  129. Question about lancer aftermarket shocks?
  130. 16"rims look to small?????
  131. Anyone running 225/40/17 with a pictures so share
  132. How long do stock pads last
  133. HELP! Rotor Selection
  134. KYB Shocks from RRM
  135. ES brakes?
  136. Brake rotor hot spots?!
  137. 225/40/18 On 2003 Lancer LS
  138. Noobtastic Question (mainly for urbanknight and jober)
  139. front strut bar
  140. evo springs
  141. Wheel Alignment
  142. Falken ze-329
  143. 17" tire size suggestion?
  144. Suspension Upgrade question
  145. wheels
  146. OZ stock sway bar
  147. 40 series on an 18" wheel
  148. Poly Urethane Bushings and RRM
  149. Suspension Lowering
  150. Wheel Bearings:
  151. Oversteer from strut bars
  152. Evo suspension fit other lancer models
  153. installed ebay h chassis bar
  154. attn all lancer owners with aftermarket rims
  155. Which tires?
  156. Enkei J10 weight?
  157. RPW Anti lift kit
  158. Tire height
  159. evo mr rims on a lancer
  160. WTF?! oz rally wheels
  161. Are these stocks legit ???
  162. rear disc brake conversion?
  163. Problem with brakes
  164. Widening wheels?
  165. S tech's
  166. How much does it cost to get a car lowered?
  167. Airbag Coilovers
  168. Eibach springs for 2002-2006 OZ rally
  169. manual steering conversion
  170. TEIN FLEX for US Lancer Possibility
  171. Someone w/ a camber kit installed = pics?
  172. Front Motor Mount
  173. KYB Shocks fitment?
  174. Wierd noise when rolling backwards after breaking
  175. Which springs
  176. weight of stock 03 oz wheels
  177. lowering on progress by myself!
  178. OZ Springs On An ES?
  179. How To Get Drums Off???????
  180. question help pls
  181. spring Q
  182. OZ Rim project.
  183. Is it even worth it?
  184. Brakes ?
  185. got Tein Basics.....
  186. Crashed my car, need parts... anyone selling?
  187. New to supension repairs.
  188. Sway bar question.
  189. tein basics
  190. Nexen tires? good or bad?!?
  191. Opinion: Michelin MXV4+
  192. Tire Brand Question???
  193. Disc Italia rotors
  194. 2004 lancer es spring question
  195. Sticky as **** tires?
  196. just got Tires and.....
  197. i hate to ask...
  198. Blizzard tires?
  199. Awesome Wheel Sale.....
  200. SQUEAKY BRAKES!! Need some help here.
  201. RRM X-Bar
  202. Wheel Wieght vs. Size
  203. Coilovers
  204. Newbie rims/tires ?
  205. New rotors, old pads?
  206. Coilovers
  207. JDM Netami springs? Good or bad?
  208. suspension question - body roll - tighter handling,etc
  209. Shocks/Struts for 02 lancer?
  210. ROAD/RACE- Last K-bar shipped
  211. TEIN Pillowball Upper Mount Compatibility
  212. HAWK HPS Pads
  213. Rim and Tire size on my 03 OZ
  214. wishbone frame
  215. Light Weight Rims?
  216. question on rims for a lancer es
  217. compare strut bars
  218. Best tire size for 15" rim
  219. 225s VS 215s
  220. ws-50's are awesome...!!
  221. Synthetic Brake/Clutch Fluid
  222. Coilover snow performance
  223. cross-drilled/slotted rotor question
  224. 205 tires on 03 ES - rubbing - ideas?
  225. shocks and springs and none of them are the same size
  226. Goodyear's TripleTred Technology for SUVs and Light Trucks
  227. how much damage did I do ?
  228. Stupid Bish Bolts
  229. Front Left Tire/Rim Wobbling
  230. o.z rims
  231. another suspension tech ????
  232. K-sport coilovers?
  233. Are these Low-Profile tires?
  234. Please help pick a winter tire, others already listed are a no go.
  235. how to get stripped lugs off???
  236. DRUMS brakes to ROTORS
  237. Winter Rubber time
  238. Any Wheel Pics for OZ
  239. can't get susp on
  240. brakes grinding
  241. Winter tires in the front?
  242. Tire Size Options for OZ
  243. What Size Wheels?
  244. Could these symptoms be broken/worn tie rod?
  245. ARP Wheel Studs
  246. wreck.....
  247. Strut Bar Question...
  248. My caster is off??
  249. Uneven tire wear!!
  250. Refined Performance for your Refined Sport Utility Vehicle
