PDA
View Full Version : ECU Flash
Pages : 1 2 [3]
  1. Which map for a 2011 MR with only a cosworth drop in?
  2. Switches logging
  3. Slightly Confused about address
  4. Tuning for better MPG?
  5. 30 degree temp changes cause big AFR changes
  6. EvoScan Seeing Errors in "original data.xml file"
  7. Fuel trims zero?
  8. Need guidance.... not getting it right
  9. Ugly Boost Curve with Target Boost Error Correction On
  10. GTR gauges for evoscan navigator
  11. how to log AEM WIDEBAND UEGO with EVO SCAN?
  12. Sd.......
  13. Tephra Help! P0247 fail?
  14. evoscan navigator help
  15. 2011 cruise control
  16. 2011 evo x gsr 56890013 xml
  17. Wrong ROM?
  18. A New Spin on MAP and Tuning Fuel
  19. ***We have started tuning the Evo X ACD !!!***
  20. Ecuflash - Definition Help
  21. SST Tables - Development thread
  22. TephraMod V2 (2011/2012/2013)??
  23. Where's the torque
  24. 52680027
  25. openport 2.0 canlogger.cpp settings
  26. Logging Addresses Needed Please
  27. What is map traceing
  28. 2 byte load.....
  29. 2008 X, P0403 & P0090 disable? Need help ASAP!
  30. read rpm and load axis from hex
  31. Tuning Options 2012 GSR?
  32. 2012 gsr
  33. DTC code clear C2116
  34. Help downloading ROM
  35. Lean and Rich SST shifts.
  36. Noob to ECUFlash
  37. cruise issue
  38. Crossroads........
  39. a Load plummet issue
  40. Dtc patch question
  41. injector scaling
  42. Openport2.0 pin 11
  43. Weird stumble
  44. 11 Evo X GSR can't flash the stock map..Please help
  45. Total NEWBIE question
  46. Bricked ECU HELP!! 2010 GSR
  47. Changing data element in pre-made Evoscan gauge?
  48. 360 load ceiling
  49. idle problem with mx1 cam
  50. Where to connect WBO2 Sensor
  51. Working on my Timing Tables....
  52. S.o.s ecu
  53. Definition XML for AUDM Evo X GSR 2010
  54. Ok to use Evo X 56890009 rom for 56890013
  55. EvoX ACD reprogramming
  56. Dyno tuning nj?
  57. ecuflash and cobb ap
  58. Plug and play HP upgrade map?
  59. Knock Algorithm (and the Low/High Oct table delta)
  60. ecuflash base maps
  61. How Load is Calculated
  62. MAF scaling multiply 3.8 is it normal???
  63. Post your E70 and E85 fuel/timing maps
  64. Splice or not to splice?
  65. SST super rich shifts in S-Sport mode only
  66. Requested Torque/Throttle Ramp Rate Tables
  67. You won't believe this
  68. who would pay for a
  69. Idle stumble/misfire on a 2.2L...thoughts.
  70. RAX Patch - ROM patches
  71. MAF Scaling
  72. knock, knock---who's there?
  73. Help with SST shift- boost spike with FP Red
  74. question about revlimiter
  75. having some problems with ecuflash help
  76. Tuning and exhaust gas flow
  77. Resolved: PSI Boost issues with 2010 RA/ max upward correction not working
  78. VirtualDyno - tire size
  79. EvoScan Gauge Layout Including NEW trans gauges.
  80. Please help me
  81. help reading data logs
  82. 2010 USDM Evo X GSR flash back to stock
  83. EvoScan Temperature Formulas
  84. ecuflash questions
  85. 2011 Evo X MR 56900010 - Need EvoScan Datasetting update
  86. ROM disassembly as raw text file
  87. XML Def for X/RA "Lean Spool switch-off RPM"
  88. SST MR/SE 1st gear TPS limiter FOUND!
  89. Ultimate Alt Maps
  90. TephraXMOD V1
  91. P0420 CEL fix rear 02 sensor
  92. Evoscan Navigator in Evo X? Yes please !!!
  93. The DTC Disable thread (P1235, P1241, P1238, etc)
  94. Enabling mode23 illustrated
  95. Evo X Logging
  96. The definitive EcuFlash Evo 10 thread
