PDA
View Full Version : ECU Flash
Pages : [1] 2 3
  1. pinout ecu
  2. Looking for TephraMod XML for ROM 56870008 (Evo X JDM)
  3. HELP: Lean Spool 58010005
  4. Knock sensor tune
  5. I Need HELP 54550007XML
  6. ID1000 injector data
  7. Need tephraxmod v2
  8. 2-step (launch control) lancer non evo 4b11 and 4b12
  9. adding tephramod v1 to lancer +2008 non evo and outlander
  10. 59570004 tephra or replace rom
  11. finally mitsubishi +2015 can read and write with ecuflash
  12. adding brake pedal switch for tehpraxmod v3
  13. about xml definition
  14. xml def for ralliart-2009- id 53600017
  15. Ecu ROM definitions needed
  16. need mitsubishi pajero 6g75 TCU bin file
  17. EvoX no boost at 2-steep after installing boost controller
  18. Need adresses for evap and 0031 dtc disable 53040010
  19. Need Ecuflash Definition JDM Colt R version 1.5
  20. help with OBD2 Patch on 59590004 rom
  21. not making boost at 2-step
  22. 58010005 Spark cut not working
  23. 56890013 Idle Timing Compensation Definitions
  24. ecuflash xml def
  25. DTC P0300 and P0183
  26. Standalone RAX logging with Tactrix?
  27. Evo X - P20A0 DTC
  28. EvoX Tephra v3 Some tables not available
  29. Request for 56920008
  30. subaru 72543R
  31. need xml for this subaru SH7058
  32. Galant 4G64 GDI Fuel Map
  33. Pop and bang (not working)
  34. New Injector tuning help!
  35. Immobilizer Delete for 53600010 2009 USDM Ralliart
  36. new to the ecuflash needs help
  37. 2008 Evo X SST Tuning with Tephra
  38. 53050012 missing Idle table
  39. Unable to change periphery bits on 56890014
  40. ecuflash wrong definnitions
  41. ROM ID not found at 0x5002A
  42. DTC disabling not working on 2014 Evo X MR
  43. Evoscan Data Logging for 2014 Evo 59580005 HELP!
  44. 2008 evo x gsr Stock ROM
  45. Tephra V3 registry file?
  46. SST 10plate kicking
  47. I can not read ECU EVO X Final Edition
  48. E-x 2014 usdm 59580304
  49. Unknown ROM ID ����
  50. Final Edition Disable DTC p0247 p0243
  51. 2015 Evo Final Edition Rom
  52. HTG - Gearbox Control Unit (GCU) for EVO X SST 6DCT470
  53. OBTR tables for PSI based boost
  54. Downloaded definitions but cant see tables in ecuflash
  55. Why can't I get mo boost
  56. ECUFlash definition needed please 2015 Lancer- base MT
  57. Tephra v3 missing code?
  58. Boost adress
  59. LTFT accuracy
  60. Evo X Tephra V3 alt maps help
  61. Evo X V3 tephra nlts
  62. Noob Needs Help
  63. 2012 GSR Rom image not found
  64. Injector Dynamics 850 scaling
  65. MAPcalc based only load, load fluctuations
  66. E tune questions
  67. XML 52370023 XML Def
  68. Lancer RallyArt 2009 ecu Definition. Need help!
  69. Hot cranking issue
  70. Changing transmission type?
  71. error sending kernel size
  72. Disable DTC Definition for 5269?
  73. N/A 2008 Lancer GTS ROM ID
  74. High Octane Fuel Map - Load 10 question
  75. Sudden rich spot of afr on wot......
  76. Rom Needed
  77. ETACS module, and TPMS
  78. Uknown rom
  79. Idle Timinng Compensation maps - 56910009
  80. New to EvoX and ECUflash. Very low injector scaling. Please help!!
  81. ROM 50845084 - wrong definition ?
  82. The definitive EcuFlash Evo 10 thread (Recovered)
  83. MIVEC Solenoid Delete
  84. Black smoke
  85. Ecuflash can‘t read my ROM! HELP!!!
  86. EcuFlash not reading/writing
  87. MA inspection question
  88. 2012 Evo X GSR ECT Fuel Compensation Tables
  89. TUNING help???
  90. Is Tephra V3 Still avalaible?
  91. Definitions
  92. Evo x logging/reading map
  93. Overrun Decel Fuel Cut
  94. ECU locked, need help, please!
  95. rear o2 datalog with 58010005 rom
  96. bricked ecu got 0x1A response instead of 0x1B
  97. V3 live tuning help
  98. Fuel injector tuning question
  99. Able to ECUFlash along with AP?
  100. JDM EVO X ECU all options greyed out
  101. How do I disable O2 sensor 1 in ecuflash Tephra V3
  102. IDA PRO open rom.bin file
  103. Requesting 54560007 xml file
  104. Reflashed now no start
  105. Tephra Mod V3 Speed Density Tuning
  106. Looking for an xml definition file for 55580010 for 2010 SE
  107. ECUFlash can´t identify rom
  108. Is anybody doing email tuning
  109. Another p0300 thread evo x
  110. 57140101 Tephra V1 ROM help
  111. North jersey help O2 not ready
  112. Pop on acceleration
  113. Logging wideband through rear 02 input
  114. TephraXmod V3 question
  115. Mut Table address question
  116. Omni Patch .xml 2012+ MR's?
  117. 53050012 - all idle tables needed
  118. New Car -I Think Tune is Garbage
  119. 3 port tuning question
  120. Tephra v3 for JDM 2015 Final Edition
  121. help with ecuflash rom unknown
  122. Montero ECU
  123. Knock sum Help!!!
  124. ECU Part # & ROMID
  125. Need an xml or rom for rax , golden or mode 23 rom version 53040007 EDM Evo will pay
  126. Evo 56890014 - P1238
  127. "Closed Loop - LT Trim Control" scaling and unit
  128. USDM Ecu in UKDM Evo X
  129. ECUflash 6v75 Mivec
  130. Id 56950006 4b12
  131. 2011 EDM SST ROM's needed
  132. Is chet still around
  133. Unknown ROM - 2011 EVO X GSR USDM 5MT
  134. Firmer shifts for Normal and Sport mode
  135. Unknown ROM - 2008 EVO X GSR USDM 5MT
  136. Boost cut or fuel cut?
  137. 2015 GSR, weird error when reading
  138. ECU based boost control for 905 rom?
  139. EvoX -my11 294hp US
  140. obd force patch for ROM 59590004
  141. 2012 MR buitl weird Idle
  142. Need Help Defining 09 Ralliart ROM
  143. ID1050x scaling
  144. ECU Issues?
  145. 53050012 Logging
  146. Magic flash question.
  147. ecu definition problem
  148. actual ex vvt varies differently from target
  149. Help needed with 52370024
  150. EVO X JDM ROM Request
  151. How to shield U0101 and P1590 code on 5mt swap Evo???
  152. Support for ROM or Bench?
  153. 53050012 Direct Boost tables
  154. Unknown ROM
  155. 08 GSR TephraV3
  156. Rev Limit Question
  157. Will I be able to put my CVN and CAL ID back to stock?
  158. Evoscan/RAX/Golden Tuning guide and glossary
  159. tephra v3 2011 aem 5 bar
  160. MAF readings on idle.
  161. Tuner PLEASE HELP
  162. 58010005 2012 Mitsubishi EvoX Mode23 Golden
  163. '13 Ralliart ADC input RequestID & Evoscan boost equation
  164. Need help with setting up Mode23 and 2byte Load
  165. Paid Tephra v3, Not Received yet
  166. Rolling Antilag?
  167. Knock Cell Flash
  168. Logging EVOSCAN with new laptop
  169. Issue with PSI based WGDC correction. Help please
  170. Can I get the permissions while flashing?
  171. Tephra V3 alt maps switching - how ?!?
  172. Evo X RPM/MPH
  173. XML definition for rom id 56870004
  174. Tephra V3
  175. Load logged in evoscan and timing numbers
  176. EVO X MR - TephraXMOD V3 - launch map - altmap
  177. EVO X Barometric Parameters
  178. P0500 VEHICLE speed sensor signal disable
  179. 2008 GSR CEL flashing
  180. Age old question...ecutek unlock
  181. Rich When Returning to Idle/Upshift
  182. EcuFlash Help Needed JDM Ralliart
  183. aem uego 30-0300 datalogging with evoscan
  184. XML definition EcuFlash .Mitsubishi
  185. Stationary revlimit always @ 5100rpm
  186. openecu.org
  187. Target AFR & Actual AFR WAY OFF!! HELP
  188. Direct boost on altmap TephraXMOD V1
  189. Running lean at WOT
  190. BootCamp, Windows 10 x64 – Tactrix
  191. Definition id 55570010
  192. Help from the GURU'S MODE23 on MIRAGE 2014
  193. Evo x - tehpra v3 - how to get consistent AFRs in different termperatures
  194. Weird Stock ROM File on Final Edition
  195. ECU can't read rom
  196. 2008 rom in 2014 car
  197. Need Help
  198. Need help for more boost
  199. SST Update - El Paso TX
  200. A/f aem
  201. EVO X FE EBCS Tuning on ECUFlash
  202. 2009 evo x ECU burnt JDM
  203. Need stock rom for 2016 Evo.X Final Edition USDM
  204. Need stock rom for 2014 Evo X
  205. Injector Duty Cycle (IDC)
  206. The BOOST error need help!
  207. Car Fails to Start After Reflash
  208. How to turn off throttle cut while breaking and accelerating at the same time
  209. Pin 9
  210. ECU Bricked- HELP
  211. rediness for smog
  212. Introducing the Spark Cut patch, finally a solution for SST Boost of the line
  213. Rom id 58020006
  214. Knock TPSCut
  215. Questions/thoughts on boost solenoids
  216. Need definition for 54070014 Evo X 2009 MR SST
  217. Need help with RomID and XML... PLEASE :(
  218. E Check Issue. Machine says VIN is incorrect
  219. Tuning boost, showing PSI based now?
  220. Why can't I access Tephra Mod website?
  221. EcuFlash DTC Code HELP!
  222. Real 2-Step
  223. Locked Ecutek ECU HELP
  224. Flex fuel readings
  225. unknown rom
  226. Ecuflash help!!!!
  227. Dual maps question
  228. Any E-tuner that can tune today?
  229. Final Edition Rom (Tactrix)
  230. Constant Data Logging?
  231. How to discover Request ID's?
  232. Logging discrepancy?
  233. HELP! - 53600017 '09 Ralliart XML ROM Definition
  234. MAP - Manifold Air Pressure linearization
  235. Benchflash fails
  236. IN NEED OF HELP! NEED to go back to Stock ROM
  237. How can I tell if mode23 already activated?
  238. EGT from Zeitronix Zt-2 on Evoscan 2.9 when using RAX Patch
  239. FE Tuning
  240. MAT - Manifold Air Temperature linearization
  241. ECU RPM controlled exhaust valve
  242. Tephra V1 for 2013 GSR
  243. how to fix this
  244. 12' GSR Boost Tuning
  245. Injection timing
  246. Tactrix standalone logfile
  247. Evo X ACD dev thread
  248. ECU Flash 1444503 Crashing
  249. 2014 Evo X GSR definition file evoscan
  250. Jumping IPW during constant speed&2200rpm
