PDA
View Full Version : ECU Flash
Pages : 1 [2] 3
  1. Addresses for IPW Patch 56920008 Rom
  2. Addresses for IPW Patch 56920008 Rom
  3. Problem reading Rom in ECU flash.
  4. Need help
  5. 2015 X FE unknown rom image
  6. omni 4 bar setup?
  7. Evo x Rom first look.
  8. 2015 GSR EvoScan Help
  9. ROM 50845084 definition file does not match
  10. Help, Rear 02 ADC Memory Address
  11. "RAX Patch Version 3 - Official and Latest"
  12. 2015 evo x MR usdm help
  13. Evo X Intercooler Spray definitions
  14. Tephra V2 Launch Control problems and inconsistent.
  15. XML Ralliart
  16. Who has 52360018 V1 RAX Patch?
  17. Issue with dialling in 1600cc injectors
  18. urgent Need help with 2015 Rom
  19. Need an XML
  20. No Definition
  21. Beginner help with ECUflash
  22. EVO X Help, Reads but no editting
  23. Flex Fuel testing in TephraXMOD V3
  24. Help determining phantom knock please!
  25. FFFFffff rom ID?
  26. looking to pay for support
  27. Read ecu fail/no start Please Help!
  28. evoscan on mac book pro?
  29. need help
  30. IMMOBILIZER help
  31. Psi based boost control setup
  32. Def for ROM ID 54550007
  33. Tuning my first X
  34. Asheville, NC tuners
  35. New EcuFlash 1.44.4497 Version
  36. Any decent big injectors that work with the stock ecu
  37. Ecuflash Evo X Locked ECU Even with Bench Tool!
  38. Stalling right after starting
  39. Using my AP to E-Tune?
  40. another unknown rom image 2008 evo x
  41. I have not received my download from evoscan
  42. 25g troubleshooting
  43. MAP Based Load Calc Copying Problem
  44. How do you log the zeitronix ZT-3 wideband in "EVOSCAN"?
  45. A little help with boost tuning
  46. evoscan reading wrong values?
  47. Tactrix Cable
  48. EcuFlash Rear O2/Heater Patch or Delete Question
  49. Counterfeit tactrix? is it a fake?
  50. Having problems with Live Tuner
  51. Tuning Recommendations?
  52. need definition for EDM 2014 SST ROM 50855085
  53. It isn't turning Off What should i DO
  54. disable P0300 address for 55570005
  55. Tried to download my current map and this is what I see...
  56. Evoscan:having troubles logging my Evo x gsr
  57. tomei poncams, mivec settings nad two blown turbos...
  58. Speeding up OP 2.0 standalone with TephraMod V2
  59. 55580005 Not passing emissions
  60. need definition file for 53050016
  61. Leanspool?
  62. having difficulties opening ecuflash on my new windows 8 laptop.help please
  63. SD Setup on ECUFlash
  64. Tactrix looking for a Evo X in the San Francisco Bay Area
  65. Tephra reaching?
  66. Mode23 inccorect readings?
  67. Tephra V1 ROM: 2010 USDM 5MT - 55570106
  68. Need assistance in defining fuel accel enrichment for 56920008
  69. Help me modify my rom so i can log rax or mode 23
  70. Brake boosting 2011+
  71. HOW TO: Improving SST Throttle Response
  72. need ecu definition for rom 59580006
  73. Xml for Subaru and Mitsubishi. Ecuflash
  74. stock rom different then other stock roms
  75. NEED STOCK MAPS asap
  76. Map scalling
  77. JDM/EDM Evo x xml needed please
  78. Launch control, detonation, and spark plug failures
  79. Need correct 58020005 XML for 2012 MR in ECUFlash
  80. pulling timing at peak load, no knock
  81. No definition for Ralliart '09 ID 53610014?
  82. Ignition Coil Dwell Time
  83. Ecuflash 1.44 problems
  84. Need ROM reviewed
  85. EvoScan definition for 2013 GSR
  86. 2010 USDM 55570006 Calibration Fuel Map
  87. 52680017 rom boost control problems
  88. Need some help with 52360018 def
  89. read out xxx.srf ?
  90. Need some 2011 Evo X MR tuning wisdom
  91. Anyway to tell a ROM ID from the ECU part number?
  92. Switching Roms Evo X FQ330
  93. From US to EU need re-flash and warranty
  94. Rom 52695269
  95. Mivec timing
  96. Aquamist HFS 4
  97. Best way to "Lock" and ecuflash tune?
  98. The hell to tune 2013 evo X GSRs???
  99. Evo10 + kelford 214-B ( stage2 cams ) = bad startup :(
  100. Evo X Mode 23 required to log?
  101. M32R DASM question. RE: FP relative addresses
  102. Please help with loss of Boost @ WOT
  103. Any side effects of reading OBD2 port for a longer period of time?
  104. MIVEC Hysteresis?
  105. Rom 55580010
  106. Evo scan map tracer playback
  107. U0121 fault
  108. P1320 Fix
  109. XML for Subaru Impreza 2008_2.0l_M32r (Mitsubishi)
  110. Sharp Accelerator drop -->> TPS maps
  111. 59590005.hex
  112. Exhaust that fit JDM rear evo 9
  113. New Rom 56890014
  114. evodroid7 question
  115. Can't read stock ROM using ECUFlash (noob)
  116. Switching from Cobb to evoscan?
  117. Injector Scaling Questions...
  118. AYC Cold Weather Flash and COBB tune Interference?
  119. 2011+ Brake Boost - Solved
  120. Tactrix 2.0 and EvoScan
  121. 59580004 - Various Defined Tables
  122. A few questions on a 2012 GSR
  123. Stock evo fx360 to reflash
  124. '13 CEL wont turn off...
  125. TephraXMOD V2
  126. Fuelcut decel overrun TPS base
  127. Need help diagnosing a fuel issue
  128. Used Evo X locked ECU
  129. 12 Evo X Throttle Help During Tune
  130. WTB Evodroid7 APK
  131. Help 2008 Lancer Ralliart Ecuflash
  132. RequestID="CALC" not working for EvoScan v2.9.0023?
  133. ECT Fuel Compensation definition (53040010)
  134. TephraXMOD V2 may be released at Christmas:D
  135. Evoscan help
  136. cooling fan tables
  137. ECUSCAN, Tephra Mods, and AYC
  138. High oct vs low oct fuel and ingnition maps...
  139. Excel problems
  140. help with evoscan gauge designer. upload to evodroid7.
  141. Boost drop tuning help
  142. New to ECU flash.. Please help me make sense of this error log
  143. this might be dumb
  144. P0243 disable
  145. Need some Boost tuning Help
  146. grimmspeed 3 port tuning help
  147. Ecuflash: "The current map description is invalid or incorrect"
  148. Need SST tables help - Single Gear Clutch Slip - ROAD TRIP TOMORROW!!!
  149. Tuning Issue with EVO MR with SSP 600 Transmission Upgrade
  150. Zeitronix Wideband not logging in EvoScan
  151. min/max speed for cruise control?
  152. Definition needed.
  153. Why is my AFR's at WOT all over the place?
  154. '13 MR stock ECU/TCU rom - where to find?
  155. Unknown new rom ID 52370028
  156. AFR goes lean when turbo finished spooling
  157. Tuning my boost curve... how much for how long?
  158. TPS vs Airflow
  159. AC on => engine OFF
  160. There are no stupid questions
  161. Flashing a 2011 Evo X MR with a 2010 Rom for Tephra v1
  162. Need assistance from tuning crowd
  163. obtr tables for psi based
  164. high knock sum count at low loads
  165. Abit of evoscan help
  166. Force Ready Car for State Inspection Question!
  167. Definitions for intercooler spray control
  168. Rom id 52320004 + mode23 = bricked ecu :(
  169. Problems check C03E0
  170. Help MH8206F (stock ecu-mirage ls 2002)
  171. Help! Rom ID 52690027
  172. throwing code b16a0 on 2012 evo x
  173. How many of you knock value, WOT in more than 180 load
  174. Evo X knock sensor disable
  175. EVO X MR ECUFLASH from China
  176. Evo X Immobilzer
  177. 2013 gsr
  178. Cannot Disable Rear o2 Sensor EcuFlash 12' Evo X
  179. AFR really rich only when engine is cold
  180. Looking for 54560003 speed limiter addresses
  181. Unidentified rom
  182. over boost timing retard addresses
  183. Advice on dialing in the MAF
  184. Starting Over
  185. Someone help me log my wideband!
  186. Can I trust MAFgs number?
  187. Ralliart EvoScan Log - Question on TPS and LTFT
  188. Disassemblers, please check my code (DTC disable)
  189. HELP ASAP!can't Read/write to ECU. Error in ECU flash. Log provided
  190. Who is running or ran the SD-only patch?
  191. Routing of evoscan extension cable
  192. Just got my Tactrix Openport 2.0
  193. Evo scan problem after ecu flash update
  194. How to tune for best emission at coldstart,warmup and cruise?
  195. 2012 map for 2011
  196. EcuFlash 1.44 and Mode 23 DoMode Table
  197. Help a little brother out!!!plzzzz :)
  198. ignition cut for rev limiter ?
  199. New EcuFlash 1.44.3719 Released
  200. 2013 gsr 59580004.xml
  201. Why is my AFR Fluctuating so much?
  202. RAX Fast Logging
  203. Knock and extra timing tables USDM RA 53600010
  204. ECUFlash for FR-S BRZ?
  205. Tactrix Won't Install on Windows 8
  206. EvoX EDM throttle closing at 236 km/h
  207. A bunch of load calculation related maps
  208. TPS Acceleration Enrichment - err WTF
  209. Evo GSR Base Maps (Do they Exist)
  210. Loggin AEM Failsafe Gauge in Evoscan
  211. Help With CEL Disable
  212. Jumpy idle while decelerating...?
  213. new fuel related maps
  214. 2012 edm/audm evo x gsr definition file?
  215. Need help on 52360189 jdm evo x definition
  216. Idle Stability map?
  217. Help on recovery mode
  218. evoscan MUTIII Actuators?
  219. 2012 Knock Tables?
  220. ECU flash for 2011 world market evo X
  221. formula for "Boost Error psi based" data item
  222. XML needed
  223. Universal ROM for Evo X
  224. got an omni4bar? GET A NEW ORING
  225. Stationary Limiter MIA for 52690021
  226. Trouble Logging 2010 GSR With EvoScan. HELP!
  227. Nube Evoscan Question
  228. 2008 GSR Maf table XML?
  229. Maf Compensation and Fuel Trims
  230. How to increase Boost Limit past 319 load
  231. How to Increase Boost Limit Beyon 319 ?
  232. High Idle?
  233. In-dash nav with evo-scan
  234. high knocksum on low load/rpm - 09 stock tune
  235. ODB-II Codes map for what is used?
  236. Price drop on Tactrix 2.0?
  237. Disable P0300 on the Evo 10
  238. clutch slip - how big should it be
  239. DTC P04A0 - Has Anyone Ever Seen this?
  240. First time tuning. Need sugestions.
  241. Evoscan - understanding the xml
  242. Evo X, openport mut2 logging ?
  243. LTFT_High no longer zero
  244. DTC P00A0 after flashing V1??
  245. Anywhere to bench ecu in So Cal ?
  246. GTR Evoscan Gauges for OEM Navi?
  247. Stock injector battery voltage latency not right?
  248. LC1 AFR not logging correctly
  249. *****Read rom issues...... PLEASE HELP*****
  250. Lets see your Fully Tuned Timing Maps..Evo X Style !!
