Log In
View Full Version : Evo X General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56
  1. Vibrant resonator to quiet down exhaust
  2. Swapping non heated to Heated Seats?
  3. The Noisiest X There Ever Was
  4. Help me!!! Service light.
  5. Evo X power/torque limit - stock block/trans
  6. Evo X Clutch
  7. ETS intake question
  8. Anyone know the size of the transfer-case drain plug?
  9. Seat cushion improved
  10. Might have idea how to protect Brembo calipers
  11. Tune question about e85 and 93.. Open source.
  12. rear 02 sensor help
  13. battery vacuum hose
  14. Boost cut
  15. Evo x GSR 2010
  16. Heat wrapped test pipe and part of exhaust.
  17. Evo X Rear Corner Extensions
  18. Launched my evo x gsr, but no clutch smell AT ALL?
  19. Custom exhaust input
  20. turbosmart bov
  21. Blowing a lot of black exhaust soot car is tuned
  22. Proof the EVO X is rather heavy!
  23. Oil swap
  24. Help with Price for 2008
  25. Long Term Storage
  26. Anyway to completely turn off the ASC/Traction control?
  27. Dog Dented My Rear Aluminium Panel
  28. Stuck thermostat is costing me.
  29. has anyone had any issues with the aftermarket crank pulley?
  30. What did you guys do with your stock parts?
  31. Cel light all of the sudden. Need help
  32. SES after UICP breaks loose..
  33. 4WD system service required?!
  34. Were your boltons worth it?
  35. Fuel Pump / Pumps for 550whp +
  36. Check Engine Light
  37. Received my ETS 4" IC, but...
  38. Need help with buying an Evo
  39. Need some re assurance in modding
  40. What to do, what to do
  41. Happy new years guys!
  42. Accident
  43. Found a good floor jack adapter
  44. X MR couldn't rotate tires freely in neutral with hand brake off?
  45. Tomei Expreme not a true 3 inch exhaust?
  46. Short Shifter squeak
  47. Car won't move after snow storm
  48. quick question..
  49. AEM intake to ETS
  50. Broken Transfer Case
  51. DEI Radiator Relief Additive
  52. Evo at dealership for the weekend....
  53. General Tuning Questions
  54. U0100 and C1617, car won't start
  55. Why is the X's rally red NOT red, but aggies maroon color?
  56. OEM vs. Aftermarket Skid Plate
  57. Info before buying an 08
  58. Lancer Evo X OEM Xenon headlight
  59. Ets or k&n
  60. Windscreen washer tank location ?
  61. More fun issues
  62. reluctant to work
  63. Great new comparo..EVO..WRX..GOLF R
  64. 2011 used mr or new GSR
  65. Oppinions on 2008 Evo X
  66. EVO X going overseas
  67. high knock count? help
  68. Christmas gifts evo related!
  69. Of course another exhaust question, but reg resonators and mini mufflers
  70. IX tie rods fit to X ???
  71. Do You Want Roof Racks?
  72. Evo x sightings in the snow! news!
  73. Am I running lean ?
  74. Brembo stickers
  75. Help please! =( recent accident - rust/dent damage
  76. Squeaky noise when idling
  77. New Battery Replacement?
  78. Need help (installing clutch)
  79. Pretty good video/review on the X
  80. AMS Single Exhaust
  81. New Video: 2013 Evolution GSR vs 2010 Honda CRF450R -CAR and DRIVER
  82. Switch From Test Pipe To HFC w/o New Tune?
  83. Downpipe question about bung hole.
  84. What is the paint code 2012 blue evo x ?
  85. Suing for lost Value
  86. Any clean up tips ?
  87. How much tuning can effect fuel economy?
  88. ARP Headstuds Torque?
  89. Yellow Triangle Warning Light?
  90. Ebrake won't hold my car up on a hill..
  91. How much whp should I expect with a ots stage 2 with this mods?
  92. Blacked out Tail lights...
  93. ARC parts
  94. Am I insane for doing this?
  95. My CNT RS dual exhaust vids.
  96. What is this code ? P0017
  97. Do I need a rollcage?
  98. Evo X Exedy Stage 1 Clutch - Please help
  99. Weird Idle: Not FPR hose
  100. Will 18x9.5+12 fit with out using camber ?
  101. Why does my car jerk in 1st Gear?
  102. Evo real jerking after tune and boost isnt loading in 1st gear.
  103. Works exhaust?
  104. Clutch pedal to floor. CMC or TOB problem?
  105. Help needed - FPR hose
  106. Factory exhaust question
  107. gsr steering wheel on a ralliart
  108. Cat->TP: Tune?
  109. I want to paint my brembo brake calipers and have a few questions
  110. Educate this little guy here.
  111. question before I purchase this..
  112. Wheel Alignment and possible issue with my Evo X 2010 GSR, pulls to the left
  113. Bad Evo X Crash Footage.
  114. Quiet high flow cat?
  115. Evo crash **Video**
  116. Anyone Know about MBS brand for HFC?
  117. Driver door rattles when window is UP
  118. Transmission oil change
  119. TC-SST Question on Used X
  120. Cold start issue
  121. Are there any evo x front lip threads?
  122. Canada Rear Bumper Protector
  123. Clutchless shifting Who does it?
  124. Exhausts???
  125. what to cover when cleaning engine bay?
  126. Having problems when shifting into 4th. Help please
  127. Redline mt90 too thick?
  128. Am I running too lean?
  129. Evo X Engine blown a week after buying it
  130. Master Cylinder popped
  131. Stock Parts Worth Anything?
  132. What to clean seats and interior door panels with?
  133. DTC - B223D Fix (A bit more complicated than usual)
  134. What did you name your EVO?
  135. HELP! EVO Will Not Start
  136. Car cuts off!!
  137. Engine Hose Connection - P0171
  138. I love it!!!
  139. Evo X Joint Terminal Block
  140. Phone call from Mitsubishi Dealer
  141. Is the cobb ap worth it?
  142. I love my EVO but....
  143. New 08 GSR Owner here
  144. Evo viii --> gt-r --> evo x mr
  145. How to brake boost?
  146. Oil filter looks crushed
  147. T-Bolt Clamps How tight?
  148. removing swirl marks other then BLACK cars
  149. Going to check out an 08 MR - what should I look out for?
  150. Pro Tunes on stock turbo increase partial throttle hp also?
  151. Old Evo 8 owner wants feedback on 2012-13 Evo X MR
  152. RPM/TPS signals
  153. Roaring at 60 mph?
  154. 2 Issues paint & recaros
  155. Smart key for evox 08 GSR.
  156. Splitter that does it's job?
  157. clutch pedal hit the floor this morning...
  158. Evo X fast key glove.
  159. I'd like to point out re:Evo X parts
  160. Gauge mounting on Steering Column
  161. What HP/TQ should i be expecting...
  162. 2008 GSR with a strange issue
  163. Wideband values
  164. Ets intercooler tuning question.
  165. Installed TBE and now car rattles/vibrates
  166. Evo X 2008 to 2013
  167. Sard Catalytic Converter
  168. Introducing a new era for Varis Japan!!!
  169. Aem Wideband UEGO Communicating with ECU?
  170. Need help with a part #!!
  171. AEM FailSafe Gauge?
  172. Need help!
  173. Automatic door locks inside ?
  174. So if you had 35K would you...
  175. Oil Filter 4g63=4b11?
  176. Its been a while..... Need input
  177. asc+airbag service required after? steering wheel installed
  178. Stealth TP/HFC using Oem Heat Shields?
  179. Another question about tune..
  180. Buying first Evo soon
  181. Wing types for the Evo X
  182. 20k miles on my Evo X no dealership type maintenance
  183. Noo! Hit a curb with my baby;(
  184. 20k miles, haven't done any maintenance, what do you recommend?
  185. ARC UICP diameter??
  186. Catless... Carbon Monoxide/unsafe?
  187. Powershifting/Flat foot shifting question
  188. Wire question..
  189. Do all MR models come with leather seats?
  190. New evo, new problems!!!!
  191. Are all oem gsr evo x rims the same?
  192. More pleasant ride in traffic?
  193. Cnt cat back exhaust..
  194. New IC option for X?
  195. Coolant in SSP Catch Can? Blown Turbo?
  196. Blox and Works Shift
  197. Finally getting another evo!
  198. Downpipe question..
  199. car blows white greyish smoke?
  200. replace the fuel pump relay?
  201. Can't seem to get a break
  202. Take over payments?! Evo X
  203. why wingless?
  204. Winter Tires & SoCal
  205. New to Evo X MR, new to California. Where to start modding?
  206. Gauge Pillar for X?
  207. intake+exhuast.. will i need a tune?
  208. I have no choice but to put Regular gas!!
  209. Odyssey PC925. Anyone use it?
  210. Test Drive Question
  211. EVO X Vs Aston Martin Vantage GT4/ C6-Z06 / M3
  212. Experience with Cobb Turboback?
  213. Ets intercooler mounting question
  214. Help*should i buy this evo?
  215. Rear-ended
  216. Headlight Issues (DRLs and High beams)
  217. magnus cmc q
  218. Evo X RS fume smell in car
  219. I'm pretty excited to turn my X into a snowmobile
  220. Turbo Inlet Pipe
  221. Mobile 1 advance fuel economy
  222. Just picked up my 1st 08 GSR:)
  223. Most Wanted's X
  224. Oil change every 3K miles or 5k miles?
  225. EVO X GSR BOV Replacement
  226. Car Color regret
  227. Everyone ok with this Sandy Hurricane
  228. Need a evo x gsr wheel.. urgent!
  229. Need a evo x gsr wheel.. urgent!
  230. Seat cushion uncoformatble - air2gel?
  231. Goodbye to the exact GSR I wanted :(
  232. FQ 400 Hood
  233. Thinking of going from GSR to MR
  234. FP Red upgrade
  235. P0133 thread
  236. Which side do you put your front plate
  237. Hows the top end pull on a X MR ?
  238. How loud is ETS exhaust
  239. The No BS Fuel Thread
  240. Exhaust slipping off rubber hangers!
  241. Wideband & Boost Gauge's
  242. Agp intercooler fitment issues
  243. asc with service lights on! please help
  244. Planning to go for the Cosworth MX1 Cams for my EVO X
  245. Winter is around the corner
  246. 50 degrees outside = 8 second crank time?
  247. ETS FMIC rubber couplers
  248. Knock on the Cobb ap
  249. My 2011 X was mint, until today :(
  250. test pipe
