View Full Version : Evo X General
- Replacing Headlight Housing - Question
- Cold Start Issues
- skip the test pipe?
- OBDII port lock/guard
- Gates submersible some E85 safe??
- Brown Brake Fluid
- Varis tail light Install
- Exhaust cam angle sensor
- ETS V2 CBE Back Firing questions
- MR stage 2 launching?
- Evo x engine swap/starter problems
- AWC Service Required....but???
- Does anyone here own a 311rs?
- Stock X- no fuel filter to change with regular maintenance?
- What do you look for when purchasing from a Vendor?
- what to clean and reaplace when rebuilding motor with spun rod bearings
- 15' Evo X GSR Shift Knob Options
- Help.
- **Hyper Rev EVO Wagon Spread**
- headlight change?
- Possible new owner?
- shift knob recommendations please.
- Final Edition EvoX @ Don Herring Mitsubishi Track Day. October 24th 2015
- Will the rattles ever end??? (loose change sound behind radio)
- Evo running rich???
- Idles up and down
- timing chain info
- Trading in financed Ralliart for Evo
- Any install top speed pro1 short shifter?
- Coasting to a stop. Neutral or in gear?
- Paint peel on center hood scoop insert
- 64 MM Throttle Body
- Will oem hid healamps work in non sss cars?
- new evo with like grind transmission
- Could an Exhaust Leak cause...
- wtb triple gauge pod RHD ----
- Please help. Knock noise when moving after tightening exhaust.
- How Do You get Under a Lowered Car? Special Ramps? Suggestions?
- Idle hang and bouncing help!
- Lean on idle
- H2Oi
- The end of the Evo
- Remvoing Front Bumper & Fender Liner questions
- Cobb AP longterm question
- CX Racing FMIC kit
- Looking for advise on FE purchased
- Engine rebuilding - Need Parts Websites
- Get an Alignment or buy New Tires?
- Tire losing pressure. Warranty?
- last Evolution made
- Will this work? Cobb accessport stage2 map.
- Canbus sniffing, Arduino+sparkfun Canbus-Shield?
- 2014 Evo X GSR Exhaust onto a Lancer SE?
- Help, boost leak?
- Starter Help - car won't turn over (video included)
- I'm back. With a question.
- 2008-2015 evo x gsr engine and transmission diffrences?
- PSI drop to 6 from usual 16
- 2014-2015 Recall
- Has anybody sold a GG 2010 gsr evo x in the last 6-9 months
- need help: dropped clips after removing faceplate and head unit
- cold start, 1st to 2nd is rough.
- HELP: 2015 EVO GSR, whining at idle :(
- Weird FAST key problem - Car always thinks key is present?
- Need help identifying part # (diagram included)
- MAP single exit exhaust
- 08 Evo X GSR Front Axles same as 2014?
- Help asc problem
- 3rd gear metal grind
- Brown ATF fluid
- New here.
- Need help, 08 Evo X clean title confusion
- Oil Pressure Gauge started reading 0 today.
- Leak issue. New to site, also not a "car guy"
- Looking to add a third gauge
- Evo X ETS v2 standard exhaust install question
- ballpark figure for a 2010 wicked white gsr?
- Low Load Knock, Taking off in first (GSR)
- Police officer inspection for registration question
- AWC Pump Warranty voided with tune?
- ETS Extreme Catback Question
- (EVO X) ETS V2 Quiet Catback Review
- Buying a new MR
- E85 or bigger turbo?
- Evo X STOLEN !!!! $5000 Reward !!!!
- What are Evo X running in 1/4 with launch and with out
- T-case or Rear Differential, I hope not both.
- Import or not to Import!
- RECARO cloth to leather
- Undertray OEM or SSP?
- First oil change
- Advice on mishimoto radiator hose hookup or installing hoses
- Good price for EVO X GSR
- When I press the steering wheel for the horn, the horn stays stuck on. Do I have a ba
- P0014 help
- Perrin Dual Gauge Pod ASMINR305
- I need 2008 Evo x info
- [Video] - Evo X vs Evo 5 on circuit (UK Evo X VLOG)
- oxygenated vs non-oxygenated fuel
- Xxr 521
- Question about noise from right front wheel
- few questions
- Intro & a few questions
- Opinions on COBB Accessport and Downpipe Install
- Help need DTC C1210 and C1242, ASC off, ABS and 4wd service needed/warning
- Question about AEM digital boost gauge
- Rear license plate mounting screws?
- Cheap or Expensive exhaust?
- WTK: can an 'unmarried' cobb ap for gtr r35 be used to read diagnostic codes on my X
- Plug n play resistors?!
- Warranty Expiring in 400 miles - What to Check?
- EVO X MR shifter cable removal
- Fair Price for a Downpipe Install? Or Full Turboback.
- Noise under part throttle
- Window Deflectors/Rain guards Products
- Question about.....glue?
- Quebec to Ontario registration - Fees?
- Ams uicp issue
- Cobb exhaust
- clip stuck
- windshield wiper fluid in coolant reservoir ...
- Replacement headlight bulbs
- trouble recirculating my bov
- Finally got my Evolution !! MOD check list!!
- High Pitch Whistle/Whine/Resonance noise
- Upgraded from VIII to X
- Output shaft part#
- Help needed! removing metal shavings from sst drain plug that had to be tapped
- Buy a Evo MR / Evo Gsr
- Quick question about Canards
- Trunk swap! (California)
- built evo x destroying oil filters
- Gauge Compatibility
- 2014 Evo X MR Highway MPG
- Rockford System changes over the years
- Evo x mr problem
- Depo Racing Test Pipe and UICP
- Front Strut Tower Bar Paint Code?
- Painting an Engine Cover
- Time attack X's
- New Clutch
- Mod Priority List
- 2015 Shootout DVD Teaser and Pre-Order List
- AYC Yaw / G Sensors
- Lowest Mileage Evo X Thread
- Suggestion on afr's and TP ecu code
- Removing stock reverse cam ?
- Well i guess i am going to keep it afterall!
- Who is still using stock clutch master cylinder ?
- So where can I get a triple gauge A pillar since OrtizCustomPods is awful.
- Spoiler painting question
- Compression numbers - 2012 Evo X GSR
- Evo X project update
- Can someone tell me what upper intercooler pipe this is?
- What to do?
- Evo X Subframe
- DRL question after HID install
- Looking to Buy A 2014 Evo X
- Slim Fan Install Help with Filler Neck
- A/C not working after mod install?
- purchasing 08 GSR need advice
- ETS parts
- How to get minor water streaks off EVO X
- Grimmspeed ebc wires cam out!!!!help please
- newb exhaust question
- Need All Fluids Changed, Shop/Dealer Recommendations in Bay Area?
- APR GTC300 Install Question
- Boost leak, vacuum leak or bad turbo?
- When to upgrade BOV?
- Ebay Catback opinions
- what to look for when buying a high mileage evo?
- Chicago E85 variability (non-seasonal)
- 2015 evo x - seats
- RPMs staying high when letting off launch control
- AMS 500 HP Package for $7,300
- gsr or mr??? chime in guys
- Will Evo's be tough to get?
- Boost
- Bumper bracket
- Seat decisions inside - yikes
- need help
- MPG's post full bolt ons / tune
- First Evo Build Ideas!
- Need help with wheel offset
- My X
- maintenance light????? help
- EvoX MR - Advice
- Bumpy start the first few minutes of driving.
- Any 2015 owners?
- Carmax offered 28k for a 2014 GSR 4,800 miles
- After about a month of owning my biggest gripe is....
- Fixing the aero sideskirts
- Tomei Ti with emissions
- new guy. new evox
- Noob here:Help with aem wideband underbody connection
- Evo 10 oil/Fluid question
- boost gauge suggestions
- Wifey first experience at the race track
- Finally got my Evo 10 !!!
- Does anyone have measurement of the trunk
- Evo sputters and drives like crap after new cams
- 2008-2015 Aftermarket Parts & Evo Difference
- 10 facts about the EVO X
- Bad cat
- Evo x Exhaust Ideas and Questions
- Evo X shook while going into boost
- wideband location question
- Evo X vs M3. How do they compare?
- FINALLY Apart of the club! New Evo X MR Owner :)
- What do you guys think of this Evo 10 ?
- Ultimate racing shipping times?
- Can i put a 7" DVD player inside a 6.1" Dash?
- Cleaning exhaust tips
- And so it begins...
- Dash area compartments in front of shift knob.
- A/C and heat only blowing on feet and defrost
- New 2015 X MR, thunk after letting go of gas
- EVO X Maintenance (Stock Cars)
- Evo X MR: ETS V2 Quiet or ETS V2 Regular (Standard)
- Knocking front suspension
- Engine/Turbo heat in cabin
- Seats - Lower - aftermarket- inform me!
- HKS Exhaust Difference
- Evo x idle issues
- When does a tune become necessary?
- Evo x good second car?
- Stuck brake caliper pins
- want ets v2 extream
- Trying to pick a new exhaust
- 4wd service rec
- P0340
- 2015 oil service interval help please.
- Electric power conversion
- AUSTRALIAN EVO X owner
- Cat heat shield
- DSG Performance Varis Ultimate Evo X Project Teaser Clip
- a/c issues on my 08 gsr
- Ets or AMS Full Turbo Back Exhaust
- ETS or AMS
- ETS or AMS
- Looking for a evo 10 - NZ
- New Recaro Airbag?
- few questions about warranty
- Evo X Aero Kit Front Lip
- Cloth Recaro Seats
- Hood pins
- AP Readings
- B-Magic Carbon Fiber 6pc XRS Body Kit Add On
- loud exaust without deleting cat
- what kind of lip is this ??
