PDA
View Full Version : Evo X General
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56
  1. Transmission Fluid Evo X MR need help.
  2. Airbag light
  3. EVO ad and previous owner seemed a little suspicious
  4. Exhaust Manifold to Turbo Bolt Threads
  5. Evo X 2014 MAF sensor replacement
  6. Will a Ralliart Differential fit an evo x
  7. Will GFB stealth fx fit onto Evo x oem BOV hose?
  8. Evo x won’t turn over
  9. EVO X OEM Wire Harness clips
  10. Evo X radiator shroud: To keep or not to keep?
  11. Priority Mods?
  12. Missing Components ("NEW" CAR).
  13. Help please...
  14. CEL P0134, things ive checked..
  15. SERVICE for 9 years old and 66k mile
  16. EVO X jerking and gas to turn on hot start.
  17. Building a Time Attack EVO X RS..
  18. EvoX SST Gearbox reinstall - parts help
  19. Torque pro app sst temp
  20. 2015 Evo X GSR- Accessport recommendations
  21. Need Help With Throwout Bearing!!
  22. Evo x - Removing Driver Seat Only
  23. Plugging Up The License Plate Holes.
  24. Building my Evo my self
  25. Buy or walk away?
  26. Cobb Accessport | NEED HELP!
  27. Need help!
  28. Final Edition Evo X with a rebuilt title
  29. Bone stock Evo with new BOV?
  30. Intake Valve Buckets
  31. Short shifter cage replacement: IRP vs WK Motorsports
  32. Where to buy coilovers in Australia?
  33. Is this an oem fog light for the X?
  34. 2015 evolution gsr oem floor mats
  35. VOTE / Car of the 1/4
  36. P0134 Code/Super Rich Idle Problem
  37. Evo X MR wont start
  38. Need Help for my ROM ID!!!
  39. EVO X - Problem lights ASC and ABS
  40. EVO X - Problem lights ASC and ABS
  41. Mechanical Baffles in Exhaust
  42. Battery Recommendations
  43. My Evo x doing 32 psi
  44. 1st gear at 85, cluster reset
  45. Stupid question Time (Jack Stands)
  46. Lower deflector
  47. The golden unicorn
  48. Jacking one rear control arm joint?
  49. Question regarding stroker kit upgrade
  50. Buying a 2011 Evo X MR soon
  51. header options ???
  52. Question for you all that has pulled your motor
  53. AMS 2.2L or AMS 2.4L Longblock Experience
  54. Nothing working after battery replacement
  55. Stock headlights Halo size
  56. Check your injector connectors!
  57. Larger heatshield for AMS intake
  58. Evo x Mr build advice
  59. Inline Fuel Filter Recommendations
  60. Overheating codes flashing on start up
  61. Evo X Vs. Similar Cars Of Today
  62. Building without experience
  63. Transmission Issue?
  64. evo x turbo upgrade
  65. Anyone ever regret selling their Evo?
  66. Maxton Design products
  67. I need help. Unsolvable issue
  68. Aftermarket cams on daily driver
  69. Stock Motor Build
  70. Cluster Trim Color
  71. First time evo buyer
  72. C161e code
  73. Is this appraisal Legit?
  74. Fuel Slosh?
  75. Quieting down the ETS V2 Extreme with results
  76. What ground effects kit is this?
  77. How Does The Stock Alarm Work?
  78. Rough acceleration
  79. Password JDM sale..
  80. 60K Mile Service in Colorado + Short Shifter
  81. Evo interior lights
  82. RHD JDM Evo X Upgrade path?
  83. Throttle Sticking!!! xxxDANGERxxx
  84. Need help looking for OEM parts
  85. Track day - warning message on dash
  86. What is the best way to install a Walbro 450 fuel pump?
  87. Adjustable headlights? WHY???
  88. Lean Bank One Error
  89. Odd vibration at specific RPM's
  90. Any good shops in North/Central Jersey?
  91. Cobb AP Install Question
  92. 9 basic things a newbie EvoX owner has learned
  93. HELP! Swapped ECU Evo X Car doesn't Start HELP!
  94. Bought my first Evo! (heavily moded)
  95. Solved: B2102 code stored because of remote starter
  96. Shop manual PDF?
  97. Evoscan reading Ethanol%?
  98. Looking for info on what radio had been in car before buying used GSR 2011 EVO
  99. Rolls over but no start.
  100. Help! Can’t unlock car!
  101. Hail Damage... NEED HELP!
  102. Closing in on buying my first Evo!
  103. Keeping oil warm in the winter
  104. Torque Pro Android app showing Ethanol% ?
  105. Choosing some gauges.
  106. Evo x leak down and compression results
  107. Catch cans, Winter, Blowing smoke
  108. gauge shows only 13PSI when WOT? normal?
  109. Bought a used, built Evo.
  110. Stock 12 Evo X MR hitting fuel cut
  111. Anybody know Sarah21?
  112. Anyone know what these front end sensors are?
  113. Need help identifying what this transmission shifter part is
  114. Front end frame repair advice needed
  115. Front Bumper
  116. Trunk reservoir fluid drops. (Blinking Tarmac)
  117. Brake Bleeder Screw and Cap?
  118. What is Omni boost?
  119. Yellowish sludge under car
  120. Newer Steering Wheel for 08 evo model?
  121. What To Do Before A Tune?
  122. EVOX & Ralliart fuel tank filler tube same?
  123. Looking for a evo ..
  124. 4WD System Service Required
  125. Help identify tail lights
  126. OEM bi xenon PROBLEMS. weird electrical situation
  127. Issues with ABS, ASC system
  128. Running without a blow off valve?
  129. Help with Boost Leak Test- <5psi
  130. What’s in my Evo?
  131. Boost gauge recommendations
  132. 2010 Evo X SE worth the buy?
  133. Headlights and tail lights
  134. Evo's in BC
  135. Do you guys switch to high mileage oil?
  136. Idaho evo owners
  137. AMS Downpipe removal help
  138. Stock Downpipe Restriction on Horsepower
  139. Jerky Shift on SST during upshift - P2733 - Solved
  140. Thoughts on "Performance" Winter / Snow Tires?
  141. 2013 Evo Blower motor drain location
  142. Tires rubbing inside wheel well
  143. Various scratches appearing on the car
  144. Evolution X Trunk Badge
  145. New Walbro/Ti 255lph design?
  146. Anyway to raise Bride seat level?
  147. Coilover Bracket Clearance with Ohlins R/T
  148. Bride seats real?
  149. failing clutch master cylinder?
  150. Springs & Exhausts
  151. Evo X Final Editions
  152. Tri state area tuners 2019
  153. Whine noise on left turns
  154. HELP!! Operating temp 1st to 2nd gear CRUNCH.
  155. Confused on getting a replacement bumper for my 2012 gsr
  156. My parts list for first time tuning
  157. Too lean and Burst PCV breather hose
  158. camber and toes?
  159. Filling Rear Diff and Transfer Case
  160. Ayc and asc along with 2 step.
  161. Serpentine Belt Partially Off on the Tensioner Pulley
  162. Mechanic ****ed up my Headlights up now they are not turning off
  163. random high pitch sound
  164. Looking at buying an Evo GSR...need advise
  165. Shopping for an Evo X
  166. Just replaced my fuel pump relay! Don't forget to change yours
  167. Engine Noise Videos + Burning 1qt per 3k miles
  168. Mitsubishi Lancer Evolution X GSR: Regular Car Reviews
  169. Parts websites
  170. what do i need to do on my evo x
  171. MMCS keeps restarting and i cant get it work anymore [video ]
  172. Strange lights
  173. Autopower 4 point roll cage install questions
  174. Overheating...
  175. hks hi power dual evit or single
  176. AMS's metal CMC has become unavailable on their website
  177. Tomei Exhaust
  178. New Evo X Owner
  179. Help identify a leak.
  180. Evo X front bumper swap
  181. Aftermarket Head/Tail Light Reliability
  182. 2008 Mitsubishi Lancer GTS ..EVO X Gsr Conversion
  183. SSP Undertray
  184. EVO X Lower Deflector Replacement
  185. Grinding noise when decelerating/engine braking below 20mph
  186. Timing Chain Replacement Costs
  187. Batteries!!!
  188. 2015 EVO X owner
  189. Archives For Evo
  190. ETACS ECU Recall + Tune
  191. Eliminated the stock fog lights evo x
  192. What can I get for salvaged EVO X 10 gsr?
  193. Wheels cannot be aligned on an older Evo X?!
  194. Locked Out. Please Help
  195. Which is correct ID1050 injectors?
  196. ID1050 injectors not seated
  197. WTF Flexfuel kit Reading Ethanol Content level
  198. Help diagnose White smoke from exhaust
  199. Beatrush engine roll stopper turns the Evo X into an insanity-inducing NVH machine
  200. Parts with no tune.
  201. LF: EU 2014/08 or newer EVO X
  202. Evo X Value Changes
  203. MAPerformance Evo X Catch Can Available NOW!!!
  204. smoke on decel
  205. Intermittent Cruise Control
  206. Fuel Pump Relays
  207. New 2015 Evo X Owner
  208. Maintaining an EVO MR?
  209. S-AWC Screen on Highway
  210. No Muffler Heat Shield Safe?
  211. 2010 EVOX MR Touring with tons of MODS but
  212. New evo gsr owner.
  213. Dash lit up like a Christmas tree.
  214. Need help with LED taillights (vland)
  215. Car sat for a month - now no boost :-(
  216. Clunk noise + jerk when taping throttle?
  217. Leaves and stuff inside hood?
  218. shifter knob adapter
  219. I have my eyes on a 2011 EVO X and wondering how reliable they are in general.
  220. Compression test Evo X MR?
  221. I'm new please help (clutch)
  222. Lug nut with BBS wheels
  223. Evo X MR Cranks but will not start
  224. Lowest mileage EVO X
  225. Tune shop near San Diego, CA??
  226. How much is my Evo worth?
  227. 18k/fuel/dp install postponed tune?
  228. Evo x project
  229. HPDE- OK to use ST43 front pads, DS2500 rears?
  230. Fixing engine roll- and torque-related squeaking noise in the Evo X
  231. First Mods
  232. Front mesh grille
  233. Not hitting target boost and rough idle
  234. What’s Going on with Driven Fab???
  235. New Engine P0013 HELP!!!!!!
  236. What choices are there for Evo X's replacement trunk lift support struts (5925A041)?
  237. gearbox noise.
  238. Evo X or Charger Scatpack?
  239. Fixing brake clicking noise and "Brake System Service Required" warning
  240. Best performance tires for 2019
  241. Nub question about CV clamps
  242. Powder coating valve cover
  243. Help!! My battery is dead and i'm locked out!
  244. Clutch engagement issues.
  245. AutoLite XP Plugs?
  246. Fair price for my Evo?
  247. Tires rubbing?
  248. What rotors and pads are you running?
  249. Won't start. Seeking insight.
  250. anything else to consider?
