View Full Version : Evo X General
- Evo x problems
- What is this plug for
- What do you think of these stock tune compatible bolt-ons?
- Radium fuel set up, fuel return vibration problem
- Evo x exhaust
- Clip/retainer for holding the tweeter housing PN ?
- Cobb Green Speed Update
- Need help with P0017 code after timing chain replaced. PLEASE!
- Does the EVO short shifter fits the Lancer?
- Berk Technology HFC and CEL
- Front Diff Leaking Should I...
- Just bought an EVO X FE and need some advice
- Does EVO X body work fit on Lancer?
- DRIVETRAIN PROBLEM! dealer?
- Wierd noise coming from behind the right front wheel/top right engine bay area
- need help Troubleshooting - Engine and A/C
- Rust paint spray, brake fluid & bleeder: Are these all I need to install a metal CMC?
- Looking to buy a 2014 EVO X MR, could use some help.
- Strange Noise coming from front and center of evo x
- Speaker wire location help.
- Where do i place S-video cable for reverse camera into back of MMCS console
- Road Trip Tuned on 91
- Question about 2015 EVO X FE
- In need of GSR transmission (options)
- Idle issues need help
- MAPerformance Evo X Valve Cover
- 2015 EVO X code U0431
- Final drive gear confusion
- New Evo owner. Whats been done?
- Trunk harness question
- Evo X's maximum cargo payload
- Rear seats
- Brand New Motor, With 'Service Engine Soon', light won't turn off...
- 4b11t swap for a 2015 Mitsubishi Lancer se AWC
- Won’t start
- Radiator motor not engaging
- Cylinder #3 Ignition Coil burning hot even with car not running.
- I'm Able To Move My Traction Control Button?!
- Evo X SST Transmission Rebuild
- Mysterious front end shaking at highway speeds--feels like wheel hop
- Short Shifter Feels Like It Wants To Lock Me Out Of Gears.
- ID 1300 with black 14mm adapters
- Should I buy the Evo X in 2021/2022?
- Sell my Si for an Evo X?
- Evo x engine bay rattle/shaking
- Drivers side interior leak
- Tools For MAP cast manifold and Stock Frame Turbo
- Purchasing Evo X in 2021 - 2022
- Where do these 2 harness plugs go?
- Engine Rebuild Taking Over 6 Months
- Clutch Disc Life Left (picture)
- Boost leak Passenger side
- New Exhaust Question
- Short belt anyone?
- Vland headlight question
- Ignition harness clip
- Turbo Support Bracket
- Clutch replacement 2021
- Boot covers
- Evo 6 wing on an evo X?
- Anyone seen this piece before? Fog light related
- SAS calibration failed with air bag light on from aftermarket seat
- Lancer 4b11 oil pump
- AFS SERVICE REQUIRED after installing new VLAND DEMON EYES headlights. please help!
- 2015 Evo x mirror how to remove the mirror as in glass
- Weird Vibration. Please help!!
- PT 5558 gen 2 and 6266 gen 2
- Evo x Headache....
- Please help me identify this clip/grommet!
- No click no crank start on EVO X GSR
- Automatics?
- Need help with a Lancer conversion please
- Evo x ralliart Mr
- Used 4B11 Longblock
- 2016 Lancer GT seat swap with Evo X Recaro seats
- California Modding Frustrations
- Evo X Canbus ID's
- Found My TWM Shifter
- Innovate afr gauge
- ABS/Brake & ASC OFF lights, code C2104 Valve Power Supply Circuit - Need Help
- Evo x idle issues
- Looking for Cobb Stage 3, 93oct map for 2012 MR / MRT
- Evo X Does Not Crank. Help?
- Evo X MR Trans Vs Ralliart Trans
- Evo X Cranks but won't start... is one of my relays blown?
- What color is my 2013 white Evo ?
- New Evo X O2 Sensor Code
- 2015 Evo X hood on a 2017 Lancer SE
- Evo x vs lancer ES
- A/C Recharge
- Power Distribution Center (PDC) ??
- Fuel system upgrade
- evoscan logging with AEM obd2 X series Wideband
- Drinking problem.
- Injen Short Ram Air Intake
- Steering shaft problems
- Thoughts...
- Custom FAST key knob
- What parts do i need?
- Evo x ayc help
- Will a Evo X Differential fit a 2014 Ralliart?
- headlights washer system liquid
- Tuning parts store in europe
- Looking for awd dyno and tuner
- I’m back but with a x
- SCCA Road Racing
- Hood swap
- Side Mirror Adjustment Not Working
- Weatherstrip Identification
- Best evo tuners in Long Island NY?
- Evo x 2015 rpm’s dropping while driving.
- Evo x idle issue
- ACD AYC Pump
- Recaro Seat Bracket
- AWC light
- P0243 turbo wastegate solenoid
- Evo X GSR Constant miss fire @ idle, occasional miss fire @ 5k+
- What boost controller is this????
- Need help with exhaust.
- Smelling Fuel
- 2012 Evo X Heater Pipe is cool, No heat.
- Red CHECK light
- 2011 53k miles
- Aluminum dress up washers on carbon fiber. Corrosion?
- Removing black Cloth Under Hood With Pins
- Question about tuning and replacing parts
- ABS, ASC, Brake light, brake service & lost display power
- Help carfax
- Wideband cable length
- Good buy or pass
- Going back to stock
- Huge shout out at Chet Rickeman tunes!!
- EVO X SST drain plug
- Evo definition 56910011
- Market destination
- Service engine soon light
- Steering wheel noise
- Strange electrical issue
- Need a tune
- I'd like to hear your opinions...
- Smoke out of tail pipe
- Cheap open source tune setup
- Evo x hood latch bolts ,size?
- Should i tune first?
- Water pump delete belt routing
- Hand-made front lower control arm bar
- *New* 08 GSR Mod Help / Suggestions
- 2015 Evolution Fe running rich
- Final Edition - To modify or not to modify
- Evo x cranks but won’t start freezing temperature
- What can I possibly make in WHP and safely hold
- 2015 GSR No one offers Metal shifter cable bushings?
- Did a boost leak test need help??
- Headlights
- Crossmember brace screw ??? Evo X
- No TCU communication after SST Flash attempt
- Light weight water pump pulley evo x
- New to the Forum | New 2014 MR owner
- Front Lips for Varis bumper?
- Final Edition black Headliner part number
- Can I use LED bulbs for the various tail lights without issues?
- Catch Can idea
- Dragy times EvoX MR vs Mustang GT2016.
- Noob Winter Prep Question (Calgary)
- Coolant flush
- Is it okay to buy it like that?
- Hand-made fq400 style intake vent on front bumper
- Hand-made rear strut tower bar - probably the strongest one in the world
- Evo x transmission fill bolt help
- Anyone in Germany ?
- Who else grew out of this platform?
- Two different cars and one purpose....
- Buying a used grimspeed EBC
- Chatter/rattle noise when starting in 1st gear
- Bumper Bolt Thread Specifications
- Abs
- Boot leaking grease?
- Evo x shutting off, and won’t crank after
- help plis, information Evolution X
- Las Vegas force pass emissions monitors for evo x
- Water pump coolant feed pipe heat sheilding?
- Water Pump Underdrive pulley
- Turns off randomly and only starts sometimes ahhh!
- Evo X Steering wheel trim
- WTB Oem Intake and Exhaust
- Help: Fuel Pump Assembly connector voltage at each pin
- No boost pressure
- Little black metal ‘brackets’ in the trunk of Evos with spoilers
- Authentic Jun Front Lip Spoiler Question
- Got another Evo
- Transmission Service Required
- Evo X fluid change
- Evo x fog light screw size
- Damaged paint
- Seat swap and airbag issues - please help
- Evoscan they didn't send me the serial number
- Looking for previous owner of this evo X
- 2010 EVO X MR wont crank headlights wont turn on. fob wont unlock/lock
- Anybody have this issue with Carbon fiber trunk/hood??
- Where can I find this part?
- Any Ideas on Source of My Vibration?
- halo headlight bulb
- Evo x mr lost 1st 3rd and 5th
- Do luck trunk availability?
- Under Trays
- Bank 1 Lean p0171
- 2009 evo x gsr
- OEM Carbon fibre Engine cover
- Evo MR won’t start
- Aftermarket Shift Knob blocking reverse lockout.
- 2010 Evo X service manual
- AFRs reading lean...
- 2015 Evo X GSR fluid recommendations
- bulletproof racing double pumper install
- 87k mileage evo x MR
- Loud noise engine, flywheel, or starter
- Weird Screeching Noise
- DFW Evo X stock manifold
- Anyone know the Brake Booster stud size?
- Matching factory paint
- Maybe i buy back my 2008 Evo X mr.
- Aero side skirt passenger side
- Hot hot knobs
- OEM Recaro’s
- Yet another Idle Issue...
- Help buying exhaust:/
- NEED HELP!! 2014 GSR Burning Oil!!!
- Buying new (to me) Evo X. Needing advise.
- Air leak at turbo inlet
- OEM Evo X Recaro’s
- Final Edition Logo
- Help!!
- Evo X rear differential
- Right hand Inner Fender
- Under Trays
- PLEASE HELP - car randomly stops accelerating
- Help. A/C causes RPM fluttering.
- Fuel Pressure Increase after unplugging MAF
- Evo X MR - 2015 - Mod Recommendations
- Idle issue
- bolt size that holds STM catch can to radiator support m8
- SideSkirt fix
- 2015 Evo GSR Clutch/Master Cylinder issue
- EVO X GSR 2015 not making compression
- Annoying rattle at high rpm.
- Making Carbon Fiber Parts for X
- EVO X Rise form the ashes.
- EVO X Front tubular Subframe + Manual Rack - Diamond Race
