View Full Version : Evo X General
- Evo 10 2008 Servie Manual
- HELP: tranny bolt
- clunk when wheel turned?
- Please help!!!!
- Issues after engine swap
- afr when you let off throttle
- Good deal on an Evo X??
- Whats the name of this part?
- Fog lights
- New ATC/ACD pump, still doesn't work?
- Wide fender options
- What are some little mods/things to do to an evo?
- MHI 18k turbo, Cams and p0304 code?
- OEM Part Number for Exhaust Bolts and Springs, front & Rear?
- Aem digital boost gauge reads positive psi at idle!
- humming noise
- New clutch problem?
- broken oem seat rail
- Noise after solid motor mounts.
- Evo X DLC connector does not have 12v on pin 16
- What could cause vibration in the dashboard on idle only??
- Question on next Mod step
- gauge help
- GREAT Infant Seat for Evo X owners
- supertech springs question
- New 14 MR modds
- Clutch pedal part numbers
- Speed Density intake options and Luicp
- Having an issue with warning lights after battery died question???
- Buying a new car next week! Need some advice.
- Figured it might b a good deal
- Dome Lights, Map Lights, Unlock Door Remote. Fuse?
- Fog lights
- Up Keep
- To roll or not to roll rear fenders
- Evo x tuning
- evox a/c low pressure hose same as lancer?
- Launch control RPM recommendations?
- Weird sound coming from exhaust
- harness bar
- Second Hand Evo X 2008 thoughts
- EVO X Squeal on cold start up (video)
- Evo x stock tires
- Guys someone stole my evo x engine cover
- Headlights problems - high beams
- Lots of knock past 6000 rpms
- New clucth
- Airbag light stays on.. Help
- Slight front bumper damage, advice needed.
- Has any one done the CMC Recall with an aftermarket clutch/flywheel?
- A/C clicks?
- Need some info on underpinning pannels
- compressor surge plz help
- Brake System - How long is it supposed to last?
- ETS downpipe
- 370z Totaled Looking at an Evo X
- 2014 Evo Recall
- For you sound and acoustic guys
- Do these need plugged?
- Possibly purchasing an Evo, looking for information on its current/past mods
- Putting my car back to stock, have a quick question
- Side view mirrors and wind noise
- wideband sensor location?
- Oem Nav help
- Clutch?
- 2014 Evo X W/Blue Interior LED Install
- accessport?
- tune
- welding o2 bung on test pipe is less accurate?
- What's this piece called? I need a new one..
- Hey guys!
- Stock wheel corrosion
- ASC System
- Down pipe
- 26-28 Psi with stock everything other than AMS intake
- Settings to get the most oversteer on a GSR?
- Rattling noise
- Black Soot on heat shield?
- ASC Service Required, P0108, P2253.. Please HELP!
- gurgling sound when letting off the throttle...
- General Maintenence
- If you own a ACD/AYC testing/bleeding device...
- Clap Clap - Noise after Spring Install
- Problems with AEM gauges?
- Cluster rpm
- AEM failsafe wideband
- evo x tcase??
- Got some goodies. Should I slap them on?
- Misfire
- p0513
- First time doing this input needed.
- Oem Ralliart Flutted Lugs
- No vin stickers on Evo X's?
- Unidentified Mechanical Sound Help
- Evo X Automatic? (Questions & Questions)
- Picking up an X for once..
- Walbro 400 issues
- HVAC help - blower working but no hot or cold air
- My new 14 MR
- Rally Armor
- BBX Lite (Ball Bearing) - 93 octane
- How long should it take to get my Evo X Please help!
- Need Help... Looking to do a build!!!
- Turn signal on side view mirrors
- Rubber on the bottom of the front bumper
- Help buying an Evo X
- Alumilite
- Potential EVO buyer, quick question.
- Maybe I'm not fit for a AWD car.
- AEM A/F gauge stuck at 14.8???
- Intake help
- Sakura intake and upper intercooler pipe review: Evo X
- rear suspension noise
- Detail and paint chip correction?
- Spoiler
- Short Shifter
- Where to start with MR
- How soon can I tune?
- arrgh stupid me...
- Advice Installing SpeedCircuit Aluminum Spilitter
- Which leather option would be best
- Parking at an angle
- DRL Replacement
- Is there a way to see whether I have stock tune?
- Evo X OEM/Duraflex Bumper Comparison
- Turnbuckles
- e85
- Stock Exhaust Question
- Before and After exhaust tones ETS V2 quiet version
- New Car - Mod all at once?
- royal purple gear oil
- ETS, AMS, and HKS together?
- Bunch of installs today and the WOW factor
- help! about to pull the trigger on a used evo
- Bad TPS?
- Front bumper/tab/bolt
- [Question]Evo will be disconnected ?
- Hail damage
- Exhaust cut out ? Anyone done it
- Whiteline RCK
- [AYC Pump] ...Solution yet??
- Exhaust question
- In search of an Evo 7 Rear Spoiler to fit 2010 Ralliart Sedan, Hook-Upz Any1??
- Capital Seating Evo x seat covers
- Random Beep/Ding while driving occasionally
- eibach pro kit
- High Wing Recommendations?
- 1st car for 22 y/o gf transferring lease
- Any photos of no center cansole?
- ETS couplers make any difference?
- Delay between accelerator pedal and revs
- Is my O2 Sensor dead?
- For those with GT style wings
- CMC Recall finally done! review
- Estimated Power For New Setup?
- car wont stay running
- If you leased your Evo, step inside
- Thoughts on buying this evo?
- clicking/vibration under driverside floor
- Also rpm problem
- RPM issue
- Leaky BOV cause issues even if recirculated?
- Loud whine
- Damn Brembo retainer pins!
- Third Brake light doesnt work.....
- Check engine notification during acceleration.
- opinions on Cobb DP and Test pipe
- need help looking up part
- Noob question
- Walker O2 sensor for Evo X?
- Evo x front bumper cover
- Evo MR - Build Advice/Questions
- Heat shield issue
- wider wheels and drag racing
- Boost Leak or Bigger Issue?
- Evo x mr tranny issues
- Next step?
- Best way to quiet a preexisting CBE?
- Tpms
- Noob question: What is this?
- Evo x mr question!
- Unable to set Evoscan gauges
- Cobb Accessport
- SST cooling Greddy vs. SSP
- Too much oil?
- expected WHP?
- Engine clunk? Shady dealership?
- Service Engine Soon flashing under acceleration
- Kick pads/seat protectors
- How much should it cost to have wing removed
- Coilover or lowering spring
- What fluid changes need to be done??
- Front Brake Pads after only 11K
- Ultimate Racing Catback Question
- Aem failsafe vs aem uego
- Need a new hood
- Damn you, fountain tire.
- Seat harness with no harness bar
- Downpipe removal - bolt broke off
- Any reason why this says non synthetic
- where can I find a cheap good intake system
- Maintenance Light 2011 X
- Forcewerkz lip fitment?
- New Here
- Sight and Sound Package Questions
- Locking for dual AMS catback
- Evo x innercooler
- Voltex lip vendors?
- Rear Differential
- Slammed evos... Help
- Evo X Firewall Heat Shield
- Kaizen vs CBRD Tuning
- Normal wear or suspension issue
- Scarborough Mitsubishi EP3
- Just purchased my first Evo!
- 91 Octane OK?
- any good?
- Any damage appraisers out there?
- blitz ss venturi drive?
- carbon fiber
- Counterfeit/Fraud OEM Evo shift knob?? NEED HELP!!!
- Louder then AMS single exit?
- Can't remember where transfer heat protector goes
- Veil laser coating - who has used it?
- Pop Clip Fastner Tool
- dp help
- varis front bumper lip fitment
- What first mods.
- AEM failsafe install help!?!
- RPM Issue
- Intake install help!
- Looking for center dash wire pass through
- Evo X Muffler Delete
- Looking for aftermarket or OEM o2 housing bolts
- Who Sells this Exhaust in the United States?
- Question on Evo X intakes?
- Evo X front bumper options?
- which is better short ram intake or cold air intake
- Front grill mesh/bumper - replacement
- Voltex type 5
- Modification Regrets?
- Best place to buy T-Bolt clamps
- Won't Start, Won't Move?
- Looking for a nice quality License Plate Frame
- Is there a different dealer other than mitsu that you use?
- No More Evo For 2015
- Middle Exhaust Hanger stretch too long..
- Grooves inside rotors?
- disabling rear o2 sensor
- Exhaust
