View Full Version : Evo X General
- cobb ap v3 question
- Calling all oem nav owners
- goodbye evo x
- Evo x large factory wing and APR Products
- Evo 10 Stock headlight ?? HID ??
- Can I cancel my extended warranty? Add 400 HP
- got this
- Deciding on the "Perfect Evo X" for me.
- New to me car...trying to identify aftermarket parts...
- Failed inspection
- Please Help Me Win the TunerBattlegrounds Contest
- ...Picked up an Evo. It begins....
- Rough erratic idle with mx1 cams.
- First time evo buyer advice
- Picture request: Cosworth high flow intake system
- Got rear ended today
- 1st and 2nd real sluggish --- help
- What do you think of this formula: bhp=whp×1.2+20?
- Anyone here has the APR GTC-300 Adjustable Wing 67" span
- Cobb EBCS w/o a Tune
- Shops cutting off aftermarket support for the Evo X after production run ends
- Meets in Nova
- 5th gear highway in EVO X = Not Fun
- Weight of stock Evo X trunk and hood
- Heat wrapping downpipe
- Installing GSR Wing, still need the dampers?
- ACD Pump failed less then 10k bone stock.
- 4th of July Sales?
- P0134 help!!
- Prolonging the life of my SST.
- Weird issue I saw when buying my Evo today
- New Evo X owner assistance
- 2003 Lancer radiator fan issue
- Opinions on T4 Twin Scroll Turbo kits
- Selling my X to buy a C7 Stingray - Am I nuts or no?
- "Mod-Friendly Dealerships"
- What is a good source of mesh for the Evo?
- Front License Plate Frame
- Evo won't start, little play in brake pedal
- Mod choices
- One reason that you need to buy an HKS exhaust now
- Compression test and leak down test nightmare!
- Using cobb ap
- 08 Evo X for sale - worth buying? Help!!
- No spark=Airbag issue?
- Upgraded ETS MAF intake
- Fitting surboarf on passenger`s seat
- Warranty help!
- 2014 Evo vs 2015 Evo
- 08 Evo MR...
- Evo's and other cars
- WTF do I do?
- New Evo X owner - Need exhaust/Wheel advice
- Rally Armor Mudflaps at Stock Height
- TurboSmart blowoff Valve ??
- 2015 Evo X F.A.S.T. key keyless entry problem
- Question about insuring leased Evo.
- Soon to be dad looking to going to an Evo X
- Where to find a good used Evo X
- HELP!! MAP/Walbro E-85 line will not fit onto fuel pump
- Evo X Throttle body Plug, PLEASE HELP!
- Safety Recall: Shaft and Bearing Inside Front Blower Motor and ECU
- 2008-2013 Mitsubishi Evolution X Cusco D1 Roll Cages (original from Japan)
- WTS: Owen Development Turbo for EVO 10
- Is this the death wine?
- EVO X with ETS TBE system, does stock test pipe fit w/ it?
- Just how similar are Lancer and Lancer Evo's?
- Quick Question: Wrapping some engine hoses
- Good level of Horsepower for a Daily Driver Evo X
- Evo x help with mods
- OEM MR Eibach Springs on GSR?
- Orders open for Final Edition Evo X. Who is getting one.
- gasket for Greddy RS exhaust help
- AAM Competition is Hiring!
- Anzo LED tail light flicker issue please help
- Rims WANT! 215/50/17
- Romanian Prime Minister and his 300 HP Lancer... good stuff
- If you had to choose.....
- Ecu information for swapping.
- Airbag System Service Required?
- Help a Evo owner out part two and get into a magazine
- Value of Evos in the future
- issues under WOT
- Does a dirty FMIC after xx,xxx miles become less/ineffective?
- Please help a Evo owner out
- Brand new Evo X owner with basic questions.
- Looking for mods for Evo X
- Evo X MR won't start (but will crank)
- Evo x 350hp goals
- New evo! Help with logs?
- Can evo X seat sliders be taken apart?
- Bolt ons.. What Next??
- What maintenance steps should I be taking at this time?
- Turbo XS Intake vs. AEM Intake
- Only get spark one time on spark plug 3
- Car Wont Start
- Drive cycles
- When Is Time To Change Your SST Fluid/Filter?
- Evo X immobilizer
- clutch master cyl recall
- bought second hand evo x
- SST Question
- Centre Grill Lights
- Opinions needed.. Considering 100k mile evo 2010
- cobb ap V3 launch controls adjustments
- AYC pump leaking / failure ?? Shop recommendation in NorCal bay area
- Evo X Front License Plate Bracket
- Leasing vs Buying
- Chris Carbee (Evox2nr) great tuner! Review
- sss front lip /lower deflector
- Opinions on Cobb Accessport?
- Is this an OEM Double Din Dash kit?
- Used Fast Key Help
- First mods for Evo X
- Opinions on wing selection
- Evo Mr steering
- exhaust years differences
- newbie need some tuning device info
- Need Control Arm Bushing Part - Help
- 2014 Evo X AMS DP
- 14 MR value
- In Need of Driver Side Fog Light Assembly
- MR manual mode shifting automatically
- Gauge install labor costs
- Intake
- New Ride- TT RS (2012)
- rear o2 sensor and NYS
- Driven Fab "In The Shop"
- 2015 gsr exaust info
- MHI-18k vs BW EFR7670 Video
- Considering an Evo X
- ETS V2 Turbo back
- First oil change
- Whats next?
- Bogus move by dealer
- OEM Aero kit Spoiler
- Less than 60K warranty question
- Dragstrip tires for 700whp?
- Longtime Lurker, in a new WW 2015
- Leasing a 2015 Evolution X
- Help! Where can I find this part? (Pictures)
- novice question about buying used Evo X with mods
- Bike Rack
- Evo x new owner questions
- Anyone heard from Jdp Engineering?
- 14 evo mr sst issus
- First Post/Introduction
- Synapse DV leaking in pull but not in push?
- New WW Special Edition owner here
- Please help identify this noise
- CBRD- New Turbo kits- Around the shop!!
- Just got first Evo, helping modding?
- Bought my first Evo!
- battery vent
- Evolving my Lancer
- Gtx3576r
- Cobb drop in filter
- Derp
- new 2015 evo gsr
- track times
- Pshhhh sound and suction every 2 minutes driving only with ac on - please chime in
- High flow cat or test pipe
- Salvage Evo in Brooklyn, NY
- Boost gauge vacuum line size
- ETS review
- Missing engine part
- Foglight Bulbs
- AMS or ETS
- Replacement Clutch
- Stalling & Stuttering
- AEM Boost, UEGO, Oil Pressure Gauge Wiring
- Couple concerns - new 2015
- A plug in our firewall?
- Loudness - Exhaust Setup Question
- Ganador LED Lights
- Where to buy voltex lip
- Track days
- ETS Intake & Aftermarket BOV & Soap Water = Leak
- Garret GTX3076 strange sound
- Possible awc pump failure?
- Possible awful pump failure?
- having problems removing screw plugs
- AMS Single Exit Exhaust is comparable to any other?
- admin help
- How do you guys like the Chargespeed front fenders?
- Swapping Seatbelts from Cloth Lancer Seats to Evo X Recaro Seats
- Should I tune myself or bring it to a pro tuner?
- Several Gallons Later...I Still Have Air in the Brake System
- Is my Evo JDM or USDM?
- Windshield washer fluid "issue?"
- Will running an 18x11 wheel ruin my car?
- New bumper vs fixing old one + Lip.
- reputable e tuners
- Found a 2008 evo x for $22,000 with 78,000 good deal?
- Would or did you buy new when you planned to mod?
- Pros and cons of a part out
- 2015 evo x fuel relay
- Cobb Quad Tip CBE Trade
- Installed Navi, bluetooth no longer working..?
- High Mileage Evo X's
- is it overboost?
- Should I get back into a Evo X?
- '08 Evo X MR Starting Issue
- Evo Noob! Bought used with mods?
- LCA removal help
- Intake
- Help!! Key fob stopped working!!help asap plz!
- Evo Noob please help
- Billet aluminum throttle pedal
- 450- WHP 93 Tune Gas Mileage - Evo X Gsr
- (Another) New Evo X Owner - Rockford,IL
- WTB Volk RE-30 18 by 9.5
- A new way to shop for rims. Evo X Rim Visualiser available for download
- Is the SST on Evo X reliable
- Back in a evo for the 3rd time
- hey guys new to the EVO
- ETS V2 Shipping Times
- full exhaust??
- New to me Evo X SE! Introduction and some questions.
- Anyone live in Jamaica Estates Queens
- Engine turns only a quarter turn
- How do you reset the driver's window?
- Is this how a stock exhaust is supposed to look?
- What to do for wheels while I powdercoat the stockers?
- 08 Evo X not starting/hard to start
- 2014 evo help!
- DP to Cat bolt size
- May buy this evo need advice
- 94 Oct
- dumbfounded situation at PepBoys. What should i do????
- AMS intake with missing bungs NEED HELP!
- Need some advice on SST build or move on..
- How many post before I can...
- Tuned 92 Octane. Only 90 Octane Available
- jerky...bad motor mount?
- Stock clutch knock sound
- Check Engine came on. Scanned and got these three codes P20B8, P1871 and U0100
- 2008 OEM navigation unit work on 2014 GSR?
- My sleeper x Build
- Mitsubshiparts.net no response, no parts
- Mitsubishi Lancer Evolution Final Edition (Japan Only)
- Looking to sell
- Strange Knocking Noise from Driver's Side Wheel
- Does the stock rear diffuser for a '13 Evo also fit the '08
- Evo X #6 on list of cars to increase $$$ in 10 years.
- Hid for EvoX
- Throwing C 1219 code after steering wheel install
- Invidia N1 Question
