PDA
View Full Version : Evo X General
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56
  1. Thoughts? New 2015 GSR or Final Edition?
  2. 2010 Evo X SE - Blown Engine - Value??
  3. OEM Push Button Start
  4. Cp-e 4" intercooler question
  5. FAST key range
  6. weight reduction on evo x
  7. New to the Evo scene
  8. 100WHP feeling?!!!!!
  9. Removing The Hood Prop Is A PITA
  10. Seat belt harnsess with roll cage.. Is roll cage necessary?
  11. Bumper Tab Broken
  12. new owners helpful guide
  13. Broken?!
  14. clutch master cylinder
  15. Valve cover torque spec
  16. 2015 X Owners
  17. Boost drop on 2 step
  18. Whos vinyl wrapped
  19. Boost Spike
  20. Anything else I should consider getting?
  21. Timing chain question
  22. Noob Questions
  23. New EVO X Owner from...
  24. Is this ad a scam?
  25. X wing modified to look like VIII/IX!!!
  26. New Evo Owner
  27. Wife stepped on side skirt....
  28. OEM rear O2 sensor WTF!
  29. Louisiana EVO Technicians
  30. UICP placement
  31. Finished rebuilding my Salvaged 14' EVO GSR :)
  32. Eibach Pro Kit + New Tires 255/35/18 + Alignment. How Do You Know The Specs?
  33. Please help me figure out this noise!
  34. Running low e85?
  35. JSC Speed problems
  36. How loud is the ETS Mitsubishi Evolution X Dump O2 Eliminator Downpipe
  37. Alingment!!!!!!
  38. Rex speed carbon parts quality and fit?
  39. Ignition not turning to ACC
  40. RHD Evo X?
  41. SMOG and thinking of going back to stock
  42. Oil Leak Ralliart
  43. Oil catch can
  44. Any EVO owners from NY/5 boros/Tri State area
  45. Qatar Guys, im looking to buy an evo, you got one for sale?
  46. Need Help!
  47. How much for a 2010+ Evo X MR
  48. H&R spring help
  49. Want Help for tips on buying Evo X MR
  50. Help me
  51. Evo X MR SST Transmission & Transfer Case Fluid Change
  52. Tech diagrams
  53. Looked at a Focus RS today
  54. Youtube Channel
  55. First performance mod. Please help
  56. Evo Owners in Qatar, a Question please
  57. Bumper replacement
  58. Fuel relay and tune
  59. New Evo X and New to the Forum
  60. Question on repainting Evo X
  61. CNT RS Exhaust Modification
  62. EVO X MR Weird Knocking Noise
  63. Anyone using Sylvania / Sylvania Zevo LED bulbs for DRL? Do they work?
  64. New to MA
  65. Instrument cluster gauge pod
  66. Used Evo shopping
  67. 2014 gsr, Cobb ap "buzzing"
  68. Anyone ran with an RS?
  69. Thoughts on these two?
  70. Car making a rattle
  71. 1st time getting evo tune
  72. What did you do with your EVO X today?
  73. New guy - '14 GSR wicked white
  74. High fuel pressure
  75. Water temp not staying constant on cooler days
  76. Front Bumper Part
  77. MAP cam angle sensor
  78. Please help me understand on how to get a front bumper quick release!
  79. Injen SES1899DP and SES1899DPC Down Pipe for the 2008-15 EVO X 4 cylinder 2.0 L
  80. keeping up with the kardashians (jk) GTR talk!
  81. Evo X weird sound/whine
  82. New '15 Phantom Black Member
  83. Mod list question
  84. Better year for first time buyer?
  85. RPM's jump when clutch is engaged
  86. Tips on pistons, rods, and crank setup for an Evo X newb?
  87. Evo seats upholstered
  88. Is hks hi power dual exhaust legal in CA ?
  89. 2008 mitsubishi evo gsr
  90. 2008 evo x gsr fuel pump relay
  91. Car won't crank!... Any advice?
  92. Shorter shift boot help please!
  93. Reputable/credible shops that deal with and/or specialize with Mitsubishi Lancer Evol
  94. Alternator Bolt Sizes
  95. How Many HP gains??? AMS boltons + Tomei
  96. Stock Evo X shifter - Heavy or Light Shift knobs?
  97. Exhaust too QUEIT!!!!!
  98. Replacement FAST key
  99. Thoughts on the new Bosch AGM battery?
  100. Final edition 0-60 4.2 ?
  101. Additional parts needed for H&R Springs?
  102. EVO X Hood Vent cover Thingy...??
  103. Build list
  104. Accessport ?
  105. Conventional vs synthetic oil
  106. How noticeable is the difference between an Ultra Light Flywheel and OEM?
  107. problem starting car after battery replacement
  108. $750 ny/nj Clutch labor pricing?
  109. Allow me reintroduce myself
  110. Grinding noise? clutch? master cylinder? transmission?
  111. Looking at a 2011 GSR
  112. Recaros from wrecked car
  113. Drivebelt pulley recall
  114. 10.2 inch Android Car Stereo
  115. Do Luck Trunk
  116. Bad wheel bearing affects on braking?
  117. 2010 SE question and pricing?
  118. E-Tuners?
  119. 2015 FE, thoughts?
  120. $380 for a tune?
  121. Im looking for this Shift Knob
  122. TWM Shifter Issues
  123. Billet block and head
  124. Voltex front lip owners, how to do you cope with the ground clearance issue?
  125. Back License Plate Light Plug?
  126. Could use some opinions on upcoming purchases
  127. Who's evo was this? Any info on it?
  128. Modification
  129. aftermarket parts!!
  130. Getting a VSC check system error
  131. Exhaust Flow
  132. Cold weather idle issue
  133. More Power!!
  134. 2015 Touch screen radio on 2008 EVO X
  135. A Pillar Triple Pod Suggestions
  136. ASC light
  137. Ac and heater problems
  138. Exhaust recommendation
  139. camber arm issues
  140. Evo x parts
  141. Importing a Canadian evo
  142. 2011 Evo X GSR - Battery replacement
  143. Tuned with a blow off valve. Can i change the valve and not effect the tune?
  144. New owner 2010 EVO X MR
  145. Stoptech pads... "Street" or "Sport"
  146. What is the battery icon on the screen for?
  147. Where to buy demon eyes, halos, etc. Who bulids them?
  148. Anyone using the AMS V2 shift knob?
  149. Online contest
  150. 2011 MR Touring
  151. Evo X Towed for parking in the wrong lot
  152. Looking for a new dealer in Michigan
  153. New 15 Evo Owner Here
  154. Evo x with vi wing?
  155. Greddy profec boost controller issues
  156. Ethanol free gasoline
  157. What is everyone getting for 2016 black friday?
  158. Black Friday SALE. What do you want to see?
  159. Someone already wrecked a 2015 FE Evo X
  160. Stock Clutch Failed at 3400 miles
  161. Will 15' sliders fit on recaro seats?
  162. Charging System Service Required Light
  163. Stock Exhaust vs DP + HFC + Stock Catback
  164. What cams for setup?
  165. Shift knobs with reverse lockout for MR
  166. How much did color play into your purchase?
  167. FA Air piston lift system
  168. Sideskirt help
  169. ETS Quiet Suitable for Newborn?
  170. Brake pads?
  171. Performance Upgrades
  172. Evo X MR boost gremlin - input appreciated.
  173. Evo FE review video
  174. Tires rubbing something!!!!!
  175. EVO X GSR - Boost Issues? Would LOVE some help!
  176. Fuel pump relay on the 15'?
  177. Garage Whifbitz titanium exhaust
  178. 60k maintenance? Help
  179. Are any of these a good buy?
  180. Sup Y'all ! Finally own the EVO X!
  181. Evo x HID CONVERSION
  182. Looking for information on ww 12 evo x
  183. Heat issue
  184. underhood shifter bushings
  185. EVO X - ECU problem wont start
  186. Transfer Case?
  187. Little help here?
  188. My Story $25k WRX to an $45k EVO X
  189. MAP investment cast manifold w/ stock exhaust shield
  190. Bad Turbo
  191. My EVO X journey, it has given what I thought was forever taken away
  192. SST gear shift shock problem
  193. Bad Vacuum Hose
  194. Car is being used in a movie and director wants upgrades
  195. Went to dealer for a noise, regret it
  196. Calling all experienced Evo owners
  197. Local Mistu Dealer "AYC/AWC Pump" recall
  198. Why Two wastegate solenoids?
  199. Finally pulled the trigger on an Evo X
  200. Aftermarket cams on daily driver
  201. noob questions for oil change supplies.
  202. Highest Mi EVO X MR + HP/TQ
  203. Thinking about selling the EVO X
  204. Launch Advise?
  205. Newbie 2010 EVO X MR-T
  206. If you could only choose 3 go-fast mods for your Evo X, what will they be?
  207. ECU burnt
  208. Protekt Skidplate Product Review
  209. Tail lights, parking, license plate lights won't work
  210. Owner's Manual
  211. 50k Mile Maintenance Help
  212. Evo X Cobb SF Intake with Cobb Air box-Advise Needed
  213. Help to Recommend a brand of Clutch for EVO X GSR
  214. New 2013 owner
  215. Opinions wanted, where to go next?
  216. For sale question???
  217. I'm sure this isn't stock...
  218. Looking for a shop that can built my motor and to all the work instal and tune
  219. New Evo X Owner
  220. Evo x gsr.
  221. Synchronic Engineering BOV vs DV
  222. EFR 7670 1.05 External Gated Stock Block
  223. Honda Civic Type R
  224. State Ref questions
  225. AMS harness bar for sale Evo X
  226. HKS BOV with the ETS Intake?
  227. Can RPM's tell me if I am leaking or not?
  228. Evo X Tuners in Tucson, AZ?
  229. Regarding ppl with UR mini Muffler
  230. evo x final edition mods and going.
  231. Cruising AFR's
  232. New Evo Owner
  233. New user, maybe new evo buyer?? tc-sst questions
  234. Finally got into some twisties today.
  235. From BMW to Mitsubishi?!
  236. Need help guys! Evo8/9
  237. rear windshield width
  238. Daily Driving Evo X
  239. Best beginner upgrade
  240. What to look for in a used evo.
  241. Car running slow?
  242. What do you think about excess 2015 inventory
  243. swap or increse power? how?
  244. Looks or Performance first?
  245. Tarmac, garvel, snow flashing...
  246. JDM crash beam and vents
  247. Tall drivers, how do you deal? + Aftermarket seats?
  248. L Bracket for Clutch Master Cylinder
  249. stock turbo not holding full boost
  250. Weird noise when driving
