PDA
View Full Version : Evo X General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56
  1. Got a misfire code today and can't find any diagrams on which injector is #4!!!
  2. New CMC Specs?
  3. About to change Drivetrain Fluids
  4. FAST key low battery
  5. Oil change question
  6. 2014 Evo X Recall?
  7. Opinion's on the AMS STX300 Package
  8. Suggestions for my Evo X?
  9. How many inches
  10. External camera mic
  11. I keep throwing the "Timing Chain Light". Whats the deal?
  12. Evo numbers?
  13. Problem with my Evo : power cutting out around 5K RPM followed by CEL...
  14. UR Rally Armor flaps Track use
  15. quick ice question
  16. throwing flames
  17. Does hard driving eat our wheel bearings?
  18. Cobb tuning V2 or V3
  19. EVO X fanatics care to chime in...
  20. New X owner with minor issues
  21. Cobb AP V3
  22. Storing Evo X
  23. Springs
  24. List of things to do for new owner?
  25. Hey im searching up some info
  26. ETS V2 Quiet Drone at certain RPMS
  27. Oil Flush/change
  28. Need help to identify an electrical connector behind bumper...
  29. Evo X or 8/9 for daily driver?
  30. Ams
  31. Running too rich. O2 sensor problem.
  32. New Evo X!
  33. My STI blew a ringland, going to look at an Evo MR, concerns?
  34. Extreme noob question
  35. Works Bell
  36. EVO service
  37. Intercooler hangers
  38. Key problems
  39. need help
  40. Hks bov doesn't sound right on Evo X
  41. Synapse dv question
  42. Picked out a intake
  43. 2008 mr
  44. Launching and failing and it's after-effects
  45. 2015 EVO at Nurenburg!!!
  46. Do you guys think??
  47. I have head problems, lamp issue exactly...my Headlamps
  48. Fujita Heat Shield 08-10 Mitsubishi Evo X
  49. Front Bumper
  50. Ichiba V2 25mm spacer
  51. Possible Scam
  52. Burning smell from rear?
  53. CBRD EVO X final- fueling solution-
  54. UICP Installed Correctly?
  55. Aftermarket steering wheel
  56. O2 sensor symptoms? P0134, crazy idle
  57. Ryan Gates 311RS EVO X
  58. A few questions about new GSR
  59. the most HP with minor mods..
  60. is it okay to run higher octane than what the car was tuned for?
  61. Aftermarket heated seats
  62. Required/suggested gauges for built engine.
  63. How many gauges can run off the cigg lighter fuse?
  64. cold start=check engine
  65. [zadda]Watch Frozen | American Hustle Free Online
  66. 2011 EVO MR compression test
  67. Where is the HVAC air intake located?
  68. Rally Armor mud flaps help
  69. Schroth Profi II Sub install
  70. Evo X Diagnostic Code C2001
  71. ETS IC install
  72. Looking for a intercooler
  73. What do you guys think?
  74. Aftermarket MAF?
  75. high rpm noise around 5000 to 7000
  76. price for 400hp??
  77. unknown Cams
  78. DW300 fuel pump install
  79. Please help comment on my driving habbit.
  80. DP help
  81. noob question on intake
  82. New Evo, starting issues...
  83. Evo X Flashlight Help
  84. Help me find the previous owner of my Evo x
  85. Fuel Sock for e85?
  86. Factory ECU Updates
  87. Not getting signal to starter when keys turned
  88. Mitsubishi Motors US - staying put?
  89. Traction control noise when cold?
  90. those who transported their OEM exhaust with the same car
  91. Smart key, not so smart.
  92. TP or DP
  93. Dinging Sound Randomly
  94. ETS V2 standard problem
  95. Noisy blower when heat on auto
  96. Car won't start
  97. plz help issue about 2014 evo x mr k&n intake!!!!!!
  98. All my noob questions into one post.
  99. Horrible constant squealing need help
  100. P0068 - Stock 2011 MR with Panel Filter Drop In
  101. Help just bought bov gfb deceptor throws asc light
  102. Can this be repaired?
  103. 2014 mr recall
  104. How much really my car worth?
  105. ZINC Provides Proven Wear Protection for Engine & Turbos
  106. New to Maryland: Need help with safety inspection
  107. OMRON relay failure
  108. Mitsubishi boost leak test
  109. Cobb Accessport v3 guage
  110. Service Engine Light came on after some pulls.
  111. ETS FMIC fitment problem with stock LICP
  112. Buying an Evo X soon, need some advise "Please Read"
  113. Boost leak?
  114. Problem with Prosprot Premium boost gauge
  115. Building my evo from scratch
  116. wastegate
  117. Garaging Evo for Winter
  118. stuck in bessemer alabama!
  119. CMC Recall vs AMS CMC
  120. Buyers remorse?
  121. need advice engine rebuild
  122. Need help
  123. New Car Buying Question
  124. AMS STX400 Package Thoughts
  125. What to get for xmas?
  126. fog lights auto on?
  127. how much gas is left at refuel?
  128. Bypass emission test?
  129. gauge set up
  130. Changing my evo x seats.
  131. Product that can display,rpm boost afm ect on double din
  132. Evo x future setup
  133. Anyone have any information on this exhaust system?
  134. 2011 Owners Manual?
  135. MITSUBISHI pulling out from the US market ???
  136. Used car purchase checklist
  137. Do 2011 MR's have heated seats standard?
  138. Car tuned for 92 gas stations switched to 93
  139. Bride Vios
  140. Is this to much play for ams shifter bushings?
  141. A/C and/or heater blower fan noise
  142. Thoughts on buying/leasing an Evo X?
  143. First Oil change and transmission grind
  144. Evolution X 860+ WHP Dyno (VIDEO)
  145. Something good for test pipe folks
  146. How to Remove Driver Seat Slider Sensor
  147. Evo X or House?
  148. buying a used X
  149. AP upper pipe.
  150. Shipping Evo
  151. VMS Evo X Deep Transmission Pan Not commercial
  152. Best Venue To Sell My 2011 Evo MR
  153. Mil.Spec100 hfc fitment
  154. MR mods
  155. Mods suggestion for GSR
  156. Doesn't go into gear smooth
  157. evo caught fire
  158. boost leak?
  159. Abnormal high reving
  160. stalled at red light
  161. Ready to pull the trigger on some mods - '12 MR
  162. Driving with full bolt ons for a day or so prior to tune
  163. Any Red flags?
  164. Any changes on this build?
  165. 12 ralliart
  166. HELP with cam sensor wiring and BOV vacuum lines cut!!!!!
  167. Making my custom CAI box
  168. Lowering Springs
  169. Might switch from USDM to JDM Evo X, need advice...
  170. Time for a new BOV?
  171. Lookin at an 08 GSR
  172. mystery chime
  173. Under Tray question
  174. Cost for installing a WBO?
  175. Stock TOB or Clutch Kit TOB?
  176. whining at cold start-up
  177. Rally armor mudflaps
  178. help me decide
  179. standard oil at dealerships
  180. Engine whine
  181. Disconnecting battery while in storage
  182. 2013 Evo help regarding Dash panel
  183. Welding a pin when doing clutch???
  184. Evo X RS vin
  185. High flow cat
  186. Evo X RS 2.5 ??
  187. Considering Getting An Evo 9 MR
  188. Optional fuel tanks for the X?
  189. Test Pipe Question
  190. Evo X - Considering
  191. who has gone from a 8 or IX to a X?
  192. Spec D Tuning Dual Catback Exhaust w/ 4" TITANIUM TIP
  193. Mustang dyno vs. Dynojet and Open-source vs. Cobb Tune
  194. Evo X vs 8/9 - insurance costs
  195. ATP vs ETS ?
  196. EVO X : Headlight Question
  197. EVO X MR MODS/WHP/TQ and how is your SST doing?
  198. MAF help
  199. 08 MR doesn't have stuff listed in faq
  200. Which mods really work?
  201. 380 whp possible with these upgrades?
  202. Seat cushion for recaro seats
  203. Clutch slipping in cold weather??
  204. How much would you pay for a wrecked X
  205. Can anybody list the performance shops in the DFW area?
  206. Might be getting a 2010 MR
  207. upgrading option
  208. Hello guys I'm new to the forum
  209. Depo Racing parts?
  210. Hit a damn skunk need help..
  211. Walbro 400 vs Buschur Double pumper
  212. Magnetic drain plug
  213. noise at front left wheel
  214. Side skirt question???
  215. Evo X GSR 349whp/343wtq vs. Stock '12 911 C2S
  216. Black dots on rear bunper?
  217. afr showing between 12.3-13.5 at idle???
  218. Good deal for 2011 WW Evo x?
  219. X MR Owners (okay GSR too) - How does your x feel after mods
  220. Engine shaking
  221. suspicious oil leak
  222. depot racing gauges?
  223. Anyone running ETS uicp with Password JDM strut bar?
  224. Depot racing gauges?
  225. Wheel Bearing/Hub HELP
  226. Awd drifting
  227. hey guys i just got my 2010 mr touring and im already having problems....help
  228. Timing Chain Question
  229. Part Number ?
  230. Wide body evo x
  231. 2008-2013 Mitsubishi Lancer Evolution Recalled For Clutch Failure
  232. 343/346 EvoX MR/ New Tune/ Problem
  233. Terrible Grinding Noise Coming from the Rear
  234. Can the dealer tell if I put in non-OEM TC-SST fluid and filter?
  235. about the navigation
  236. Something weird is going on!
  237. Loud banging noise when blower is on
  238. From 11 STI/12 WRX/ 09 135I...and now 13 Evo X MR
  239. SEMA 2013? Who's going?
  240. Suede Cleaner
  241. Where is a good place to buy silicone couplers?
  242. Blitz Turbo Controller and Timer
  243. Quad Projectors. where and who?
  244. Trade my STI for EVO X?!
  245. What's this part called?
  246. Fuel issues!
  247. looking for e85 compatible fuel strainer
  248. ~~Question - Do I need to replace my fuel pump?
  249. RECALL- Manual trans Evo X's
  250. Bought an MR almost 2 weeks ago
