View Full Version : Evo X General
- Fully Built sleeved 2.0L GTX3071R
- two different part number for rear bumper cover???
- Hand built Evo's
- Radio Harness Color Code. Need Help.
- Clutch and Gearbox
- Fluid change overhaul!
- Exhaust to turbo bolt keeps coming loose
- Clutch Grabbing Real High
- Car sat for 2 years before purchase, what fluids should be changed?
- Are you tired of your EVO?
- AYC pump relocation reliability
- E54 Anyone?
- Evo 10 noob, looking for some advice.
- Evo X - Intermitten starting issue - Car wont crank/start
- All services and warning lights come on....
- faint but high pitched whine/noise
- 2008 Evo X Rough Idle
- Does removing the side vents make the car look better?
- Bigger Turbo?
- What lines should I run for E85
- Selling my x for a 9...yes or no
- Where are the track oriented Evo X's?
- I went and did a 10k service and got some pics underneath
- How important is the carpet under the hood? Can we remove it?
- car not starting & ascs, warning lights flashing
- New Evo X owner - any mods I should get that I am missing?
- Question about cabin filter
- Has anyone used a TapTurn on their X?
- Finding E-Tuner?
- Ets exhaust too loud
- Latest Fuel Pump Relay
- plastic slider(gate slector) part# Help
- AWC Pump warranty denied for ECU flashes?
- Part # help: metal clips for rear diffuser?
- FAST Key pairing process
- Hard to E tune?
- Stripping factory Recaros to bare frame
- Cobb Stage 3
- Radio not working!!!!
- What are OEM HID headlights worth?
- Feels rough at higher rpms
- Drivetrain and transmission fluid change
- Engine code issues
- August 2017 Featured Car of the Month
- Does this Evo X seem fishy?
- RS motor or DB performance
- 2015 and 2013 door swap?
- Exhaust change - impact to drivability
- Alcantara steering wheel cover
- What exhaust is this!!!!!
- Headlights
- Evo is still a head turner
- Rebuild in Russian SST DCT470 st1 st2 st3
- ETS Hardpipes Question
- Can someone tell me something more about this Red Devil
- Seat Rails
- Will an 08 mishimoto radiator for STI fit on evox
- Evo X or earlier?
- Achieved 27.2 mpg with fresh spark plugs and RedLine SI-1
- Evo X map sensor logging.
- Any AC Repair Shop Recs for North Houston?
- Electrical issues??
- Tuning
- Help 22 + fault codes :/
- Real Price for EVO X MR transmission Replacement
- Putting evo in storage
- New Member!
- Evo X Key Remote
- One daytime running light isnt working
- Black 08 from PA/Ohio carbon fiber, buschur etc who owned it?
- Possible new owner/intro
- Front bumper lip
- Canards fit?
- Idle surge a/c on defroster (solved)
- 17' WRX Stage 2 to a 15' EvoX - what can I expect?
- 6 months till go time
- Amsoil Severe Gear 75W-90 - Transmission, Transfer Case, & Differential
- Newbie Evo X 2008
- New EVO X Owner
- Rom and Definition Database - MitsuRoms.com
- MAP Delrin vs AMS V2 shift knob
- Has anyone seen this ????
- U0121 error code. CAN bus timeout
- NEED HELP!! What is the name/part number of this part? ***SEE PICS***
- Super clean, what do you think? Help!
- Sportback GTS (AWD)
- GoldenEvo Down
- Should I replace this tire as a set?
- Code B2102 stored in ECU. Does it mean my battery is going out?
- July Featured Car Of The Month (FCOTM) Contest
- Help Engine Overheating Stop Safely
- Engine light still comes on after O2 sensor spacer installed
- Father's Day Sale
- Fast key
- EVO X MR SST REBUILD ADvice
- Possible "new" Evo X
- ACD Pump going
- who can read my Logs (Boost)
- Buying my first Evo!
- Code P0171 Bank 1 System Too Lean - Solution
- Dialling in Injectors
- Evo x sheepey turbo manifold
- Parts recommendation for a semi built Evo
- Recently bought an Evo X, first mods??
- Evo x clutch master cylinder upgrade issues
- Evolution x 2009 gear problem ••
- I still have boost spikes even with a softer bov spring
- Strange groan noise occasionally when both accelerating and braking - Videos inside
- Does anyone have a maperformance manifold
- Moving to Hampton Roads Virginia
- 400hp/350tq what type of clutch you guys running?
- Help:Evo X rear quarter panel replacement
- Should I get this Evo?
- Can the OEM Lancer Sportback rear bumper protector fit an Evo X?
- Mitsubishi might discontinue or limit the production of "MR" badges
- Cusco rear strut bar owners: did installing the bar require cutting factory plastic?
- ABS AYC and break problems?
- Trouble starting Evo FE - need opinion
- 9 basic things a newbie EvoX owner has learned
- EVO-X SST-330 S-AYC oil?
- I have about $1500 to spend
- 3500 Mile Update
- Closed loop AFR
- Track Results (1/4mile) EVO versus MUSTANG 5.0
- maintenance time
- Minor play in REAR passenger side wheel
- Going from R33 GTST to Evo 8...please talk me into it.
- Low boost
- give me that woosh woosh...
- What are the differences between HKS Super Turbo p/n 31029-AM003 and p/n 31029-AM004?
- evo x and ralli art doors the same???
- Newbie
- Part hunting.... Overseas
- Finally got an Evo.. Any good websites?
- broken plastic piece found in driveway help identify it
- new to this, Question regarding SST flywheel
- evo x grinding noise from front left wheel
- Evo X oem large spoiler (white)
- Trying to buy stock evo X MR that owner claims is stock but carfax says otherwise
- AMS STX500(Garrett GTX30R ) vs GTX3076R
- Brake fluid reservoir. Any none plastic versions or caps?
- 6 speed manual swap
- Mishimoto oil-FAIL-cooler
- Steering Wheel Mods
- HKS Legamax drone?
- Buying a Modded MR. Have Questions on Mods
- Oil spiking
- New Steering Wheel installed.
- going E85 (flex fuel)
- Help!! Why is my evo only running 12.5 boost?!?!
- advice me on BOV/DV Replacement
- Ses light only when it rains
- Looking at getting an evo..thoughts?
- Oil on top of the airbox after autocross runs
- Need some specifications for my 2011 Evo X GSR
- Clutch master cyclinder full upgrade or not?
- Getting ready to install OEM Recaros on FE, quick question
- Evo X cutting power at low rpms, no codes
- Anyone know where I can get this duckbill spoiler?
- Overrevved and Misshifted - Will I know if i damaged valvetrain right away?
- Tachometer shift light install help!!!!
- Need knowledge! Buying an evox
- Help identifying a part plz
- Front License Plate Placement
- Wheel spacers for the X
- Anyone have the APR front lip with APR splitter?
- Getting a evo with some mods, plz help me to decide
- 2015 pb evo x gsr
- New to the Community and Introduction
- How to 400 whp with pump gas?
- Are there different versions of factory MAF?
- Finance question?
- Stupid Downpipe question
- Got an Evo x, too much boost?
- Need new oil cooler
- Driving Season Sale
- Ralliart replica side mirrors for evo x?
- Lightest front mount intercooler and piping?
- FE recaro seats
- Thinking about selling my Evo FE
- FNG - '14 WW GSR w/SSS
- Is this Evo worth it?
- Need help with boost gauge
- Looking for OEM MAF housing Evo x
- What is this evo worth?
- Engine sputter
- Probably Not Going To Go Back To Stock
- What tuner for Stock Block FP Black
- H&R lowering springs on an MR
- Low tyre pressure light
- Dream EVO
- odd vehicle problem, seemingly random limp mode
- advise about AEM Wideband and Etune
- HKS Hi-Power Spec-L Review
- Bolts on cat at dp are literally melted
- New member!!! 2013 EVO X GSR Winnipeg
- PassThru Can Installation
- Evo x MR tuning
- Innovative ECB-1 multi gauge
- Just purchased a brand new 2015 GSR
- Intake and TBE with no tune
- I've lost the factory drivability after a pro tune
- Evox - Electronic Throttle Body - 6-pins Connector
- Instrument Cluster Swap
- Wanting to buy OEM spoiler!
- Evo X Build
- SST - sport mode question
- Frame bolts and undercarriage plastic
- Daily Driver Build - Criticism wanted
- leaking fuel?
- Anyone putting down more horsepower than me?
- Evo x ETSv2 Quiet exhaust note changes
- IX owner, what's a X worth??
- Congratulate me on my new Evo
- help
- Authentic ARC parts
- Dead light bulb stuck inside of headlight
- The Intro (newbie) 12' GSR
- 2014 Lean Spike
- 2014 mitsubishi mirage es
- New Owner Questions
- AYC DTC C0420? - Need help find out this DTC
- 2015 Seat swap
- Seam Welding
- What happened to MitsubishiParts aka Bruce Titus Mitsubishi?
- Twin Scroll TURBO
- Buying an evo x with over 60k miles
- Clutch or tune
- Should I buy this Evo?
- Fastest 1/4 mile EVO X 8.4s by ETS
- Buying New EvoX
- TTY (one time use) bolts in the knuckle
- Seats Stolen, replacement options?
- car won't start, dealer giving me run around
- oil
- With or Without.....wing
- Thinking of buying a NEW Evo, how much could I hammer down a dealer now?
- Exterior Parts
- Evo x idle rough
- Xpel Ultimate
- Evo X problem !
- Vacuum leak or what?
- '11 GSR pillars wrapped carbon fiber
- Max 10 psi Issue
- Weird noise
- Got my in take ported and coated (2011 GSR) !
- Quebec or Japan?
- Couple of scrub questions
- About to hit the dyno with the new setup
- Manzo Exhaust
