PDA
View Full Version : Evo X General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56
  1. Tomei Extreme TI or HKS Hi Power Exhaust?
  2. 2010 Evo X
  3. Question for the BRAND new evo x owners
  4. New to Evos. Overboosting Issue!
  5. loud ticking under valve cover
  6. Cryogenic Air Intake
  7. New to Evos...about to buy MR
  8. 10 Years and FINALLY!!!
  9. depo headlights on a 2013 evo x?
  10. Back in 4B11 land
  11. Extended Warranty Recomendations
  12. Evo 311RS
  13. Just found a stock evo 8 for 13000.!!
  14. help running lean
  15. my day at cobb tuning socal
  16. wanting to buy a EVO X thoughts on YR?
  17. Those who left the ct9a platform
  18. ASC/4wd system/traction control/ sst transmition failed...fun
  19. Spill in car
  20. Potential X owner
  21. Here's where to buy a service manual if you want one
  22. Do i need to tune after this???
  23. Full Build # guesses?
  24. Installed Torque Solution rear diff bushing kit
  25. exhaust pic
  26. Looking For Evo X GSR Trunk With Spoiler
  27. What HFC should I get for best performance?
  28. Strange Noise
  29. Car not starting
  30. Need modification guidance!!!
  31. 2012 Evo X Issues, maybe stock map?
  32. CNT Racing catted test pipe feedback?
  33. 08 GSR won't start
  34. Shifting into 3rd gear
  35. Paint protection film - is $1235 a good price?
  36. Suggestions for Info-Graphic, Goal to create something that benifts Evo commu.
  37. Voltex Lip
  38. Question about Stock Clutch
  39. Power Level at which fuel pump is required?
  40. Defi boost and AEM Wideband Gauge void Warranty?
  41. Intake Question
  42. What do you think he has?
  43. 2014 Mitsu's (Evo) Get HERE Traffic/Road Updates
  44. Timing chain TSB concern
  45. Lets laugh together!!!
  46. Is anyone else having this headlight problem?
  47. Looking at putting a map exhaust manifold help
  48. Power delivery not linear
  49. Need help from the evo/lancer guys
  50. Will it fit?
  51. time to start modding my mr
  52. Is this what it cost to get approx 350hp?
  53. Full exhaust with open downpipe from header?!! Help please
  54. how to refit stock boost controller
  55. 2013 Evo X MR dyno results and Road Race Engineering review
  56. tap from exhuast area
  57. Oil cooler is bent
  58. Guys my 2010 x mr touring will be here soon and I'm worried...
  59. Driveshaft removal
  60. What to look for when buying used Evo X?
  61. Exhaust ticket
  62. rear o2 sensor stripped
  63. Tune of stock Evo x
  64. Need some help looking into an Evo X MR
  65. Mods with serious gains on stock turbo
  66. GSR blank key programming problem?
  67. Injector sale question
  68. Just got a new 2014 X
  69. Best Under Brace for Evo X
  70. Tired ....and need help
  71. how to remove shift knob
  72. Can it be the BOV?
  73. 2014 Evo head unit question
  74. Evo X "power band"
  75. new whining noise when in reverse after ACD replacement
  76. Walbro 400 hose crimping?
  77. FQPerformance.com ... Problems/Question
  78. Keeping dust out of the Cabin
  79. Evo X on track day in Brazil
  80. Upgrade path
  81. VP style gas can in trunk?
  82. Went from 93 octane to 89 by mistake
  83. Weight Reduction Guide for The Average Joe
  84. noob intake question.
  85. Is this how you bypass a boost solenoid? (diagrams in here). For Aem Failsafe Trigger
  86. trouble with trouble codes
  87. definitely not having car luck this year.. can anyone identify this part
  88. Steering Wheel Vibration
  89. Thinking of getting an sst evo
  90. Air Fuel Ratios
  91. white wire strip from hazard to radio face plate replacement
  92. ID1000cc pnp adapter
  93. Can't log my AFR's!!!
  94. ACD Pump disconnect for winter
  95. Looking for an Evo
  96. '14 GSR Question
  97. Flutter from BOV after letting off gas
  98. HELP: OEM HID bulb clip came off (SSS Package)
  99. Does Ebay lights require reseal before installation?
  100. Steering wheel lock message at low speeds
  101. Exhaust smell in cabin with defroster on
  102. AMS STX300 vs. COBB OTS review
  103. Numerous choices missing in 2014 MMCS
  104. Clutch Master cylinder?
  105. Amsoil - 5W-30 or 10W-30 - NJ
  106. Oil catch can
  107. intercooler
  108. ASC/4 wheel service required
  109. Evo X as a DD
  110. Considering purchasing an evo
  111. Need bolts specs for 2 MAF bolts on AMS intake
  112. ACD Flash Online
  113. Tell me if the way my motor revs is normal
  114. Mind bending performance...kinda
  115. Need help, spark plug issue
  116. evos not fast anymore after CMC change
  117. Evo X front license plate mounting
  118. Need help with new build
  119. schrothe rallye 4 install
  120. AEM boost gauge boost reading error
  121. how much 4b11t can handle torque untill walls will blow?
  122. Leaving car in a high gear when slowing down?
  123. Difference between Seibon VR lip and Carbon Creations VR-S lip for the Evo X
  124. am i right?
  125. Looking to mod my evo
  126. EVOscan to read DTC... and i doing t correct? lol
  127. Evo x upper diffuser?
  128. Brake system service required
  129. AEM Boost gauge "---" help!?!?!
  130. P1871 and U0100 problems
  131. Evo X Top end sucks
  132. recirculated bov question
  133. Used Evo X warranty question
  134. 30,000 Mile Maintenance at South Coast Mitusbishi
  135. Timing chain at 14k??
  136. Way to have drls on all the time?
  137. front mount intercooler?
  138. Meshless fogs
  139. trying to install strip lights
  140. Whistling air conditioning?
  141. techie mod questions
  142. Dyno tune at sea level for a car that lives at 5,000 ft?
  143. Inconsistent performance
  144. time to finish my evo x
  145. Should I buy the 2010 MR for 29k?
  146. Best Performance Upgrades?
  147. ABS engine light!
  148. laborday 2013 deals?
  149. Boost gauge vacuum line...?
  150. hesitation around 6500 rpm?
  151. Need help!!!
  152. Long Term Living w/EVO
  153. Question about my final mod before tune
  154. Tein hood dampers evo x
  155. Help: Build for Evo X. Feedback please?
  156. dash-maintenance interval meaning
  157. New Member EVO X MR, track day coming up
  158. Evo X turns off after startup
  159. Need some advice on gauges
  160. Cobb stage 3...what else do I need?
  161. Downshifting during daily driving?
  162. Second hand Evo X 08 MR
  163. Evo x downpipe removal
  164. fp relay
  165. New Owner soon??
  166. AEM Failsafe or separate boost and AFR gauge?
  167. Evo X - Lease vs Purchase
  168. Question about Rexpeed Test Pipe...
  169. More differences between '08 and '10?
  170. Clicking noise
  171. Downpipe nut part number
  172. Water?? Leaking from left front?
  173. 2012 X - First maintenance visit
  174. A/C noises, questions?
  175. Device which will pass emission test?
  176. Exhaust leak question
  177. can somebody identify this dash icon?
  178. Lights
  179. The blood of your engine and how to ensure is top notch
  180. New evo x driver
  181. Please help me (boost controller issue)
  182. Need help, pcv hose size
  183. info/reviews for UR testpipe with mini muffler?
  184. Crazy KBB value...
  185. Shifting cable adjust (manual page)
  186. Running an evo after long storage?
  187. Need help locating a Evo tuner near Fargo, ND
  188. Help locating connector
  189. buschur mbc question
  190. Exhaust Help
  191. HELP my Evo MR died!!!???
  192. Swapped OEM HID bulb but having issues
  193. driver window problem
  194. MUT 3 Tool
  195. Superb road test video of a Cosmic Blue GSR modified by RRE
  196. Lol, how do I drive this thing...
  197. Year to year changes?
  198. Tuners close to the border
  199. AST 4100 vs HKS Hipermax III (nonsport) vs KW v3 vs Robispec KW Streets
  200. This a good start to a build...correct order?
  201. Can't get the top nut on the rear suspension loose. Help!
  202. Just got a TBE, tune question
  203. Stuck in Limp mode
  204. My evo x journey
  205. Vibrant Performance 02 Sensor Spacer (CEL Fix)
  206. Evo x after-market modifications help!
  207. Tire spin issue, coil overs?
  208. First Time Owner Roadmap
  209. topping coolant off in a 2011?
  210. Gauge wiring question
  211. Cloth seat cleaner
  212. 2008 evo x ecu brick
  213. New evo owner and I have questions!!
  214. Dealer gave me wrong battery?
  215. Two quick modding questions
  216. Evo X Steering Problems
  217. Rough to idle to death!
  218. Need help buying advice!
  219. would i need a retune?
  220. Service engine soon light ==> limp mode ==> then was normal
  221. Spare tire question
  222. Today we say good bye
  223. WTB: Evo X turbo/X Manifold/Lancer & Evolution X Side Window Deflectors (vent visors)
  224. Go follow @evosociety on Instagram! Chance to win free evo prizes!
  225. Dimming Side Mirrors?
  226. New to Evo X/Community.
  227. Evo X Starter
  228. Cleaning Interior
  229. Shift Knob with White Stitching?
  230. Stupid rust spots!
  231. low voltage codes
  232. Don't Wreck Your EVO!
  233. Weird metallic vibrating noise above 5k rpm??
  234. Can I get some suggestions....
  235. Grip Issue
  236. Got the short end of the evo stick....
  237. so text drove a evo x mr finally on saturday and....
  238. Service engine under boost
  239. 2014 EVO X GSR with hesitation above 6k
  240. The most quiet catback exhaust??
  241. which model to pick? evo x gsr or MR
  242. Bad Tune?
  243. how long should the car warm up for and sit for ?
  244. ETS single tip exhaust review
  245. From IX to X
  246. SRS Light Issue
  247. Evo X Exhaust Upgrade!
  248. Car cover suggestions?
  249. HID fog lights wont work
  250. Taking out passenger seat for drags?
