- Evo x 10.5 or 9.5 rims
- Stock Mr suspension
- Need some opinions on suspension
- Questions About Pads and Rotors
- tire rubbing question
- Rota SVN-R
- Top hat replacement
- Bilstein with lowering springs longevity (Swift, GTWorx, Tanabe, Tein, H&R, etc)
- TPMS Oddities
- Cosmis MR7's spacer needed?
- Found a comparison picture of Work Emotion T7R deep concave vs ultra-deep concave!
- Rear bumper bolt.
- Advan RG3 in racing red!!!!
- 18 x 9.5 35mm offset question???
- Wheel Size For Toyo R888
- help needed tyres/strech Question
- 255/40/r18 STOCK SUSPENSION
- HELP, choosing new suspensions..
- Has anyone used the Hankook RS4s yet?
- Spacers needed on rear? +30
- c2116 abs pump
- Vibration at high speed?
- No dust pads
- Weird Clunk On initial rev.
- Ball Joint questions
- Work Wheels/Suspension -- Need your advice/help!!!
- Super Pro front control arm setup?
- Best tire for the dragstrip?
- Apexi N1 Evolution coilovers vs Ohlins Road and Track
- HELP - Need New Pads
- Function and Form Ty 2
- 16's on an Evo X?
- MCS 2-Way Remote reservoir Dampers Review
- evo x MR bbs tire fitment question????
- Steering rack binding/hitting something on full lock - See video
- 1 new tire or 2?
- Lightweight Larger Wheel
- 10.5 +18 fitment
- SSR GTX01 18x10.5
- fender rolling near staten island
- brembro breaks
- brembro breaks
- HR wheel spacer caused vibration
- Ohlins coilovers?
- Vibration after swapping over to summers
- AVID.1 AV06 on EVO X
- Is B65 brake pads the same as XA5 brake pads?
- Wheel spacer
- DC or AEM front Strut bar?
- Tire Blowout
- Konig milligram 18x9.5+25 wheel results
- Evo X KW x Greddy coilovers
- Evo X Sway Bar Endlinks Bolts
- What else do i need to make my X MR Handle BETTER?
- Recommended Summer Tires
- cs2a alignment
- Fortune Auto 500 Series Coilovers with Air Piston Lift System - Evo X
- Front End Clunk - Sway Bar Movement
- Track day alignment questions
- Honest assessment of HKS coilovers
- Varrstoen es1 fitment ?
- Front wheel rubbing front bumper hanger
- Oem Center Caps in RPF1
- Rays TE37 - 19x10.5 +22 - Do you need spacers on fronts)
- TE37 SL Center Caps
- Where to buy rubber inspection grommet
- Tire Rack site
- Used BBS from Evo X
- Enkei ts-10
- Continental, ExtremeContact SPORT tire review -with Motec Data (MotoIQ)
- Ceramic Brake Pads
- Gramlight 57Getter Wheels
- Bilstein PSS10 Coilovers Installed
- Help - Front Drive Axles Shot?
- CE28n 18x9.5 +22
- 18x8.5 et 30 doesn't clear front calipers
- UMBRELLA Cup Kit
- MFactory/YCW Suspension/SWIFT Springs - Looking for sponsored driver(s)!
- Rear sway bar link replacement bolts?
- Need help after pad/rotor change!!!
- What are these!!!!!
- Help! Which to choose?
- AP Racing Radi-cal Pro 5000 Caliper interest?
- wheel fitment
- BC Racing Coilovers Question
- Neal retiring as your moderator
- Ohlin Road & Track dampening/rebound setting
- CV boot leaking/front axle replacement
- Ohlins Road and Track or KW V3
- 2015 Evo X Final Edition Front End Suspension Noise Help!
- Rubbing on Coils
- lug stripped, stud spins with wheel on
- Dealership pricing for brake job
- R888 in Evo X stock size
- Ark design R8 18x9.5 +22 Shining Silver!!!
- electronically controlled suspension
- WORK Emotion CR2P – 18×10.5 +18mm 5×114.3
- Final Edition (MR springs or GSR springs??)
- looking for new wheels
- Volk te37sl 18x9.5 +22 on hankook evo2 120K 265/35
- Anyone knows where can I get the camber bolt for my kw?
- Brembo clear coat peeling
- 15 MM Spacer and Lug Nut for Stock BBS
- camber adjustment question (stock struts)
- Suspension Advice
- Wanted to re look at Tire sizing for the enkei rpf1 18x9.5 +15
- Hawk, Girodisk, Stoptech: Which street pad has the least amount of dust?
- Whiteline RCK - Tie Rod End Failure After 50K-60K
- Bridgestone Potenza RE760 SPORT with XXR 527 18x9.75 Fitment
- Will 18 x 9 +35 clear the brembos
- Getting my evo track "ready" opinions plz
- Recognize these rims/tires?
- Mickey Thompson ET Street Drag Radials
- Part number for 2015 Final Edition wheel
- Lift and Mud Flaps!!
- Help identifying these brembo rotors
- Query on top strut mount bearing for GSR and MR
- Rear Suspension Assist Link Bushing
- How long do tires last?
- How crucial are mud flaps?
- Advan RZ rim
- What brand of 265/35/18 tire would you recommend to run without rolling fenders
- Springs for X se
- Offroad/ "rally" suspension upgrades help.
- Snow Tire: 245/40 vs 235/45
- Ohlins R&T 10k/7k - revalving?
- Cosmis XT-006R
- TPMS Cloning
- Fortune auto 500 help/opinion on ride height
- Larger rotors on stock calipers?
- PLEASE help me find SSR Wheels or replica or deep dish wheels!
- Where to get Stock Enkei Center Caps?
- 2014 Evo X Momentary Brake Failure
- easiest way to get rear calipers off?
- Rear brake pad wearing faster than front?
- AMR coilovers?
- Another aftermarket wheel question thread!
- Why does my car pull to the left
- Uneven tire wear?
- Whiteline RCK in rear control arm
- Volk center caps
- Need Advice on Advan RS2 setup!!
- I just realized that Amazon.com officially carries Advan wheels now
- Brake Pad Review: Stoptech, Ferrodo, Project Mu, Carbotech, G-LOC
- Corner Balancing
- ABS Pump Module
- Recommended Winter Tires for Canada
- Roll center adjustment
- Anybody recommend a fender roller in NJ?
- Outer tie rod ends replacement question
- Varrstoen ES2 Fitment question
- Will this setup need fender rolling
- Ride height difference in one corner with coilovers
- Do I need to reprogram tpms?
- Regular TE37 center cap size?
- Function of Brake Dust Shields
- Upgraded my rotors second time
- Eibach springs or Pro - plus kit?
- Need some help with better handling.
- New to performance cars, when to change tires?
- XXR quailty/experiences
- Stoptech or dba ( 400 or 500 series)
- H&R with stock tires.
- Project Mu sports (rear drum brake) inner shoes, anyone?
- Wheel fitment Evo X
- Any info on AodHan Wheels
- Bleeding my brakes what do I need to know?
- Help with brakes
- Steel spacers
- aftermarket coilovers which maintain same ride high and travel?
- Feal 441?
- Will these fit?
- Federal 595 RSR Sizing help
- 2015 Evolution x steering wheel vibration.... HELP PLEASE
- Say Hello to my little friend
- Wheels that Clear Stoptech Brakes
- Best current performance tire for stock EVO X
- Control arm advice
- Gorilla Acorn lug nuts for RPF1s?
- Ohlins R/T question
- What parts made for evo x fit ra
- Work Emotion Cr Kai 18x9.5 + 38 fitment
- Coil overs that are better than one Bilstein?
- Confirmed with DSG Performance, Volk VR.G2 has indeed been discontinued
- Cracked Spoke - Volk CE28N
- How to give Ohlins R&T a little air lift for the bumps?
- Old Tires, New Free Alignment, New Tires.. Do i need it again?
- caliper clearance issue
- Michelin Pilot Sport A/S 3+ First Look Review
- Factory Rear Brembo Calipers
- Lifting the Evo?
- Anyone sells front control arm bushing?
- 18x10 295/35
- Help me choose
- help trying to find
- inner rubbing, fitment questions
- The ultimate solution for understeer?
- HELP! With wheel size
- Evo X GSR OEM Enkie Wheels
- JRZ Clunking in rear
- Pics of your evo on tein springs, not coils
- Evo x final edition springs
- Coilover setup for Auto X
- Apex ARC-8 for Evo X
- Enkie Black TY-5 18x8.5 on WW X
- 57DR 18x9.5 ET22 with Hoosier A7's pics
- H&R 20MM Spacers.
- A Daily Driver and Track Viable Setup
- FORTUNE-AUTO 500's & 510's
- Question about the rotor ring installing.
- High Speed Pulse at specific speed range
- JNC 021/Sumitomo GTR Z III
- 18x9.5 +15off RPF1 on 245/40/18 stock tire, with swift spec r
- Problem re installing rear strut with new gtworks spring
- Revalved Bilstein profile ?
- Sneak peek at my new wheel setup
- Revalved Bilstein/Swift Spec R ???s
- Enkie RS05RR
- Need Help With Wheel Offset!!!!
- 18x9.5+12 Es1?
- Brake Retainer Pins Question
- Suspension Question
- Abs system
- 255/40/18 or 265/35/18
- Thoughts on Toda Fightex Coilovers and Roll Center Kit?
- 255/35/18 or 265/35/18 Do they go wider then the mudflaps?
- Wider tire - Evo X MR BBS wheels
- Powdercoating rims in western NY area
- how do you know when your tires are done for?
- Searching for Coilovers, need help/suggestions
- Rota Torque with 245/40/18
- Lowering Springs - Roughly how much should it cost to get them installed?
- ST43 pads for the street?
- Anyone Running an aggressive setup
- Enkei RPF1 18x9.5 +15 on 245/40/18 with Swift spec-r's
- Please help me figure out a tire for XXR wheels
- Spacers and coilovers
- Upper Mount Substitutes for Ohlins R&T
- NT03+M and no fender modification?
- Tires and Coils
- 15' evo x gsr Brake problems
- Aragosta Type-S review
- RS05RR 18X10 +22 R-Face
- Will 18x9 36 offset clear the brembos?
- Tire Pressure Display
- knocking noise when turn right, come to a stop and reverse....
- Bridgestone RE71R's pix
- Taller sidewall tire question
- Alignment Specs
- New Summer Tires
