PDA
View Full Version : Evo X Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. KW v3 rear rebound
  2. VolkRacing Ce28 19x9.5 +22
  3. All Season Tires?
  4. What coilovers for tarmac rally?
  5. evo x mr ,rotor question
  6. A long scratch going around the inside of rim
  7. help a noob decided on winter tire size
  8. Bag Evo X or no?
  9. 18x10.5 +22 VS 18x10.5 +15
  10. Brake pad suggestion for MR?
  11. Brake Pad and Rotors. Can you tell me if this will work?
  12. eibach pro kit springs and bars for evo x mr
  13. Ohlins Pre-load vs No Preload
  14. Tire Pressure for Daily
  15. KW V3 Rebound/Compression
  16. Two part question, expected life of Ohlins, and expected life of GSR KYB?
  17. 275 vs 265 tires and best wheel width
  18. TPMS Sensor issue
  19. TPMS Sensor issue
  20. Volk wheels + stock tpm sensors ??
  21. Perrin Endlinks
  22. offset and wheel help needed
  23. advan rg-d or tciii
  24. What pad would be just a little more street friendly than Ferodo DS2500s?
  25. 18 x 10.5 wheels < $1500 ???
  26. Will they fit???
  27. Best Winter tire size?
  28. 1" lift kit on EVO X?
  29. Help with street/track suspension package
  30. Will Konig Milligrams fit?
  31. Will these wheels fit?
  32. Tire Size help
  33. 2014 Winter Tire Reminder
  34. Winter wheels !
  35. Winter tire help
  36. Different spacers front & back?
  37. Help D2 Coils or Fortune ?
  38. Need tire help..
  39. Nitron NTR R1
  40. Can i fit these wheels?
  41. Will these fit?
  42. knocking/clunking noise
  43. New Pads and Rotors installed - Did I do something wrong?
  44. Looking For Low
  45. Plasti Dipping My Wheels
  46. Wicked White and Blue Wheels
  47. What size Blizzaks?
  48. 18X9.5 +15MM and 265/35.. will I need to roll?
  49. 25mm spacers and rubbing
  50. So this just happened today, thanks Eibach...
  51. HELP xd9 18x10 +18 Evo X what size spacer?
  52. Whiteline rear sway bars and stock endlinks
  53. Work Cr Ultimate (Kiwami)
  54. Neo motorsport coilovers
  55. Tire suggestions?
  56. High-Speed Vibration
  57. white line center roll kit question
  58. XXR 969s vs. XXR 527s Advice Needed.
  59. GarageLine or Ichiba ?
  60. Caliper issue?
  61. Winter & track rims
  62. GarageLine spacer torque specs
  63. I need some tips, Spacers? Camber kit? Thanks!
  64. Suspension
  65. Cusco Rear Sway Bar
  66. centric caliper rebuild kit
  67. Leaking Rear Strut
  68. Tein StreetFlex Damper clicking noise on front Left
  69. Fab'd Chassis Bracing
  70. Noob Help: Rear Camber Bolts & Tabs - What do you recommend?
  71. Rotor suggestions
  72. Brake problem evo x
  73. FS: Girodisc 2 Piece front rotors and Titanium heat shields
  74. Anyone know what wheels these are?
  75. Bad squeaking breaks so i need recommended aftermarket brake pads
  76. Rs-r sports I coilovers
  77. stock wheels with tpms for sale.
  78. Slight wheel rub, alignment?
  79. Rpf1 wheel fitment!
  80. Camber adjustments
  81. Cosmis XT-206R Evo X Fitment Question
  82. XXR 527's Fitment offset vs Stock.. Help please
  83. Swift install, post alignment stats...does this look right??
  84. 57xtreme 18x9.5+12
  85. RG-D and tire rotation issue
  86. Weird clunk noise from Rear suspension
  87. I can't figure it out! The dealer can'f figure it out! Please help guys
  88. Front Control Arm Bushings
  89. Ohlin set up question
  90. What rims are these!? [HELP]
  91. Great deals on Hankook V12 K110 close out sizes
  92. new wheels for my evo x
  93. Tires that don't stick so well.
  94. To those with an upgraded front strut bar
  95. Swift Metric Coilover Springs- Which length to get?
  96. Stock sized tire, 10.5" wheel, ok for a little while?
  97. what are these wheels !
  98. Which wheel size with require more work to fit?
  99. Front right wheel well clunking (2008 Evo X GSR)
  100. Aggressive DD / Track Recommended Coilvers
  101. Getting New Tires - Alignment/Camber Question
  102. Has anyone tried these on yet?
  103. What Size wheel and tire is this?
  104. swaybar preload
  105. Evodynamics Adjustable Camber plates for Stock Struts
  106. Best Non-Slick Track Tire?
  107. Evo x gsr rims problem?
  108. Looking for new wheels
  109. Will I need spacers?
  110. KW V3 adjust
  111. Quick Color Guide for WORK Emotion Kiwami (CR Ultimate)
  112. "Jingling" while Rolling
  113. Anyone run 265/40/18 for the extra mph capability?
  114. rpf1 or 57dr ?
  115. Aftermarket brake options?
  116. Alignment Advice
  117. Help with coilover pre-load question
  118. 335 tires
  119. Camber on my evo x -3.5 or -4 using the H & R coilover
  120. RAYS Gramslight 57FXX 18x10.5 on EVO X (Black)
  121. MR Bilsteins
  122. Continental contact dws
  123. Swift Sport/Swift Spec-R
  124. HSD coilovers
  125. Stoptech slotted sport rotors; directional vanes?
  126. ABS Pump Problem!
  127. Suspension extra bits?
  128. Got a nonagressive wheel (CR +30 9.5), will it rub lowered?
  129. best brake kit brand and best suspension? for evo x
  130. Xxr 531's
  131. suspension stiffening
  132. offset gurus HELP!
  133. Rear strut bar and whiteline control arm bushings
  134. What is the weight of the Forged BBS wheels on my 2104 MR?
  135. Rear Eccentric camber bolts
  136. Swift Spec R noise
  137. Lug nuts, valve stems, hub centric
  138. Front sway
  139. Wheel spacers different size for Front & Rear?
  140. Advan RS and RSII
  141. Feal or Ohlins?
  142. Question for you wheel junkies
  143. New to the evo community,need help!
  144. Staggered Setup Dilema
  145. change or not change brake before track day
  146. Ohlin Road and Track Suspension
  147. Winter wheel size question
  148. Value of stock wheels and tires.
  149. Bought new tires. Thought they wouldn't rub but they do. Any ideas?
  150. Is this bad?
  151. Stock Pads for Track Day?
  152. Rubbing cant find where...
  153. Removing fender liner
  154. Alignment Help
  155. rattling question
  156. Anyone run 18x10, +30 on stock body Evo X with 275 tires?
  157. will this work?? HELP
  158. 18" x 8" Wheels?
  159. Odd road noise
  160. MB Weapon / MB Battle
  161. 18x9.5 +22 / 265/35 fitment issues?
  162. LOOKING FOR ce28's
  163. Rs05rr help
  164. Fitment Question.
  165. Question for Tire Rack: RE-11A
  166. New EVO X bad alignment
  167. Lowering Springs and effect on handling?
  168. Coilovers, what to get?
  169. Tire noise when losing traction
  170. Bigger tires with stock rims?
  171. DIY TE37SL/RT center cap adapters: $5
  172. Widest wheel / tire combination with fender roll or overfenders?
  173. Wheel Offset vs. Wheel Bearing Health
  174. Whiteline Sway Bar Installed
  175. Sizes to Match the Evo X Spare
  176. Most aggressive wheel spacer on OEM wheels?
  177. 18x9.5 +35
  178. 2mm spacer?
  179. Got the summer wheels on finally
  180. Rota Grid Stock to Lowered
  181. Track Brake Pads
  182. How is this Brake kit?
  183. PF01 Evos.. Installed!!!
  184. Do i need new coils?
  185. Wheel Question
  186. Hotchkis Front Rear Sway Bar Kit
  187. BC BR spring rate?
  188. what brakes are good
  189. Tein Street Advance
  190. need new pads
  191. Cant Find Replacement BBS Wheels Anywhere!
  192. Eibach Multi-pro R2 Questions
  193. Aluminum Hubcentric Rings OD=75mm, ID=67.1mm
  194. Bridgestone S-04 Pole Positions vs Michelin Super Sports
  195. Centric rotors
  196. Help needed for winter tire
  197. Front brembo clearance...
  198. 19x10.5 +22 Wheels Fit on Stock Bilstein suspension with Swift
  199. Lugnuts that fit te37sl
  200. car pulling to right under acceleration
  201. Who Has Ohlin R & T's in stock?
  202. Suspension 101?
  203. Is there any solution for front rubbing only when I engage full lock position?
  204. where can I get my rims mounted???
  205. Evo X Replacing Front Rotors & Pads
  206. What do I do with stock springs?
  207. Ralliart/EvoX BMC
  208. Alignment, balance, tie rod?
  209. RPF1s don't fit :(
  210. Stock Lug nut size for Evo X MR 14'?
  211. Help camber kit...
  212. You think you've had warranty problems? .8 degrees difference in camber
  213. New WORK Emotion Limited edition color - Grim Red, Blue and Titanium
  214. Option Labs S401 ordered
  215. Small Fire in Engine Bay.
  216. Review: H&R Camber Bolts
  217. Review: Swift Spec R
  218. Alignment today. Need help.
  219. 18x8.5 rims offsets
  220. Brake pads and rotors
  221. Is my alignment ok?
  222. Running 18x12 .. Need some questions answered
  223. looking for te37s
  224. Just ordered my wheels, and im scared..
  225. some please look over my alignment
  226. wheel fitment
  227. HELP me decide on wheels!!!
  228. Upgraded pads for autocross and the rain?
  229. There is a ton of threads about this.
  230. Rubbing issue?
  231. Evo x camber curve
  232. Pothole killed a Blizzak this weekend :(
  233. Stock summer tires worthless in cold weather
  234. Nice set of cheaper winter wheels
  235. Brake master cylinder/booster replace
  236. car pulls hard to right when given gas
  237. New tire time .. Can't decide
  238. Pic Request: 275 tires on Swift Spec R or GTWORX springs
  239. Continental DWS (245/40/18) All Seasonal Tire Review
  240. Volk TE SL question
  241. springs for stock 2014 gsr
  242. Work Emotion CR Ultimate Warping
  243. lowering spring install- which coil compressor
  244. DD Brake Rotor Advice
  245. Konig ssm?
  246. 10mm Ichibausa V1 Spacer question(s)
  247. Brake bleeding Problems
  248. Dumb question on rotors
  249. Brake rotors why you so much $
  250. Ideal tire size on stock rims, autox/track
