PDA
View Full Version : Evo X Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19
  1. Tire tear....
  2. To patch or not to patch.
  3. Worst winter rims
  4. Winter tire season 2011
  5. Ohlins Road & Track from CBRD
  6. TPMS nightmare
  7. 2010 MR Touring + Advan TC III 18x10.5 + Hankook RS3 + Swift
  8. Lowering springs for 2011 MR?
  9. Anyone running TRMotorsports rims
  10. Evo x mr Winter wheels and tires installed.
  11. Wedsports
  12. brake rotors
  13. Gruppe-S Wheel Database *Need Your Help!!!*
  14. bent my rims
  15. Winter Tires
  16. brake pads
  17. Eibach Pro Kit Bump Stops
  18. where's the swift sports?
  19. WW GSR with Gold (powdercoated) Oem Wheels
  20. Wheel Offset that does not require Rolling
  21. Stock Tires with Aftermarket Rims
  22. Brakes for Evo X MR
  23. How do I get my X to corner?
  24. Average cost for powder-coating?
  25. Volk CE28 center caps and decals?
  26. Need suspension advice.
  27. Need some help deciding...AME TM-02 18s or 19s & 9.5" or 10.5"?
  28. Slightly bent knuckle
  29. More ASC options
  30. Replacing pads...
  31. Help ??!?!?!?!? Evo wierd vibration
  32. Swift Spec R + Alignment ?
  33. snow tires and new wheels help
  34. Can't find any eibach pro kit springs
  35. Winter Tires Fitment??? Please Help
  36. New Enkei Raijin: MR BBS Style!!!
  37. Brake bleeding problem, need help fast.
  38. Eibach Pro-Kit owners - cut the bump stops?
  39. Fender Roll + Alignment
  40. 255 45 18 on 18x9.5 rota gforce
  41. 255/35 on 19x10?
  42. Help - rusted frozen rear toe bolt
  43. Robispec KW Clubsport w KMAC Camber Plates Install Help Needed
  44. 20mm Spacers & Handling
  45. wheel balancing weights
  46. How much is too much?
  47. First Look at the newest Meister S1R - black on black and bronze on bronze
  48. VOLK TE37V Now available in 17"
  49. What wheels are these?
  50. Taking out wheel studs...
  51. Stock tires
  52. Lug Nut Suggestion
  53. VMR V710 Picture Request
  54. SSR wheel fitment question
  55. Cusco bracing
  56. Camber/toe correction arm - complete lower control arm
  57. Gold wheels on GG
  58. Real vs "Fake" wheels. Who manufactures what?
  59. Deal, Who Wheels: Who Makes the Real Makes the Knockoffs?
  60. ce28n 18x9.5 +15
  61. I'm giddy as a schoolgirl!
  62. lulz. check out my fake varrstoens. made in Japan.
  63. coilover questions.
  64. Fortune Auto Brackets
  65. Tire discussion - All Seasons
  66. Too many miles???
  67. Camber question
  68. Michelin Pilot Super Sport Vs Dunlop sp600 Vs Yokohama Advan
  69. Ultra racing Front member brace
  70. Tire Advice.
  71. Attention those with 19x10 wheels!
  72. springs and sway bar
  73. winter tires
  74. cross-threaded lugnut....and spinning aftward..
  75. anyone here with Eibach pro kit for road racing
  76. Wedsport TC105n 18 x 10.5 +12
  77. i need rear wheel bearings....
  78. fitment with rotas grid
  79. Lower or no Lower
  80. varrstoen 3.3.2 19x10.5 +12
  81. Possible to paint over rpf1 sbc rims?
  82. Rim identification
  83. alignment help
  84. 285's on 9.5 wide rims??
  85. What Shall it be
  86. 2 piece MR rotors
  87. I need a review for Girodisc pads...
  88. Hankook RS3 or Federal 595RS-R
  89. swapping pads without turning rotors
  90. Soooo confused please help, Rim & Tires..
  91. Best daily driving pads?
  92. Evo X Rear Control Arms from TimmySpec
  93. comfort DD: springs or coilovers
  94. Upgrading Sway Bar End Links: Is it neccessary?
  95. GTS/RA Wheels on Evo X?
  96. Will Evo IX brake pads fit in a Evo X
  97. Who can help me out with the specs on these wheels?
  98. Where to get OEM rotors & pads?
  99. So I just dropped my X and hearing some noises...
  100. Any vendor selling XXR 522?
  101. Painting/ Powder Coating Chrome?
  102. 2011 evo x bbs rims
  103. NRG black chrome locks and lugs
  104. ROTA GRIDS 18x9.5 +20
  105. Painted Blue GSR Wheels
  106. setting up coilovers, ride height... I got some questions...
  107. Wheel size help....
  108. 255/40/18 on 18x9.5 ?
  109. +Size Tire Pressure
  110. Gunmetal or Hyper Black wheels for AS Evo X?
  111. Upgrading to coilovers?
  112. Stock Wheel Coating Delaminating
  113. GSR center caps
  114. coilovers, alignments, corner balance?
  115. Brakes are dragging on rotors.
  116. NT03 rubbing stock studs on ichiba 15mm spacers
  117. What size wheel spacers can I run on stock EVO X GSR wheels
  118. Evo X Brake Disc Help
  119. Lowering and rear camber?
  120. Who has 19x10 SBC RPF1 on order?
  121. XXR 527 @ WW Evo X
  122. what is the stock lug size?
  123. Tire Rack TMPS sensors?
  124. Best Place to Buy Volks?
  125. Speedline Wheels - Adapters. Need input
  126. Toyo Proxes 1 - Anyone tried these yet?
  127. need help with rear alignment
  128. Fortune Auto brake bracket solution for the Evo X
  129. Wheel/Tire Size Question
  130. WORK Brombacher **Special Edition**
  131. clunk/pop noise from front end passenger side.
  132. 265/35 18 on stock wheels
  133. RPF1 Center Caps
  134. XXR 522 18x9.5+25 gold on WW
  135. Enkei RPF1 + Eibach Pro Kit Question
  136. 5-spoke STI wheels - fit on Evo X?
  137. help stock evo 8 wheel size and offset
  138. Project Kics R40 Lug Nut Set
  139. Front Camber Issue
  140. Coilover decision!
  141. Wheel Spacer Manufacturer
  142. Gold rims on my X
  143. Help vibration when turning
  144. TPMS Service light?
  145. Removing rear dust shield
  146. tires evo mr x
  147. Help!!!!about changing brake pads...
  148. tires & rim package?
  149. Attn Evo X rim owners
  150. ADVAN RGII question
  151. Volk Racing TE37SL Limited Edition NOW ON SALE
  152. Bridgestone Potenza RE760
  153. Swift Spec-R at 46K Miles... New Struts?
  154. coilovers + winter: your experience
  155. Offset question
  156. CL brake pas review
  157. Evo X enkie's Paint bubbling
  158. my AST suspension feedback
  159. painted stocks, much better now.
  160. Wheel Weight Question
  161. Amaizing wheels ...
  162. Need help choosing tire for 18x9.5!
  163. my chrominum black xxr527 on octane blue x
  164. Ohlins Evo X Install
  165. are these wheels in good condition?
  166. Good sticky drag tire question
  167. Offroad evo's
  168. Fortune Auto??
  169. Suspension gurus help now!!!!!
  170. roll center kit question
  171. Best Wheels for performance?
  172. Tire Wear Question
  173. SA55M offset and tire
  174. question regarding wheel fitment
  175. Stock Wheels and Tires Question
  176. Baller wheels but stock suspension no drop?!?
  177. Need new brakes? 8k miles ?
  178. tire size
  179. lug nuts 35 vs 55mm
  180. New Tires Just Came In
  181. 265/35 front & 275/35 rear
  182. Hankook Ventus V12 evo K110
  183. changing front rotors
  184. Best $500 wheel
  185. Looking for coils!
  186. what size advan rg-d
  187. Can I run 265/35-18 tires on stock X wheels ?
  188. SWIFT Spec R's & Giro 2 piece goodies
  189. 3-Wheeling
  190. Uneven fender gap
  191. Where to get these Rota Grids?
  192. Matte Black Rims
  193. Introducing the New Rota T2R's in 18x9.5 and 18x10!
  194. strange noise
  195. Advan RGII 18x9 +29
  196. tire and fitment question
  197. 19x10 RPF1 question??
  198. Any springs with lower drops than 1.4?
  199. 265/35 w/ H&R lowering spring??
  200. XXR 527 on WW
  201. Volks vr g2 18x10.5 +27 matte blk
  202. If you have Volks TE37???
  203. Work XT7 18x9.5 +12 clearance?
  204. wheel strength, oem bbs vs volk se37a
  205. recall for jdm evox
  206. Tire Pressure for HPDE
  207. 36,550 miles and brake line failed. Warranty not covering?
  208. Does anyone know the specs on these rims, and car if you feel like it hah
  209. Shocks/Struts
  210. Best bang for buck Coilovers
  211. Michelin Promise Plan
  212. I just ordered Ohlins DFV
  213. Evo X balance/spring rate?
  214. do TEIN lowering springs cause problems on 06 MRs
  215. Suspension GURU'S please help
  216. TPMS syncing
  217. Anyone Tracked/AutoX Hankook V12 K110 Evo
  218. time to buy new rotors. recommendation for street use?
  219. Anyone know if Coilovers from a IX will fit a X?
  220. TPMS problem with Work 11R-FT
  221. Rotas for track use.
  222. Question for those who are low and have the factory aero kit
  223. WORK Emotion 11R with Oem Tires?
  224. Dealer quotes rotors+pads for $2800!!! Can I resurface or should I buy new?
  225. my car
  226. Question: Pulsing brake squeal
  227. Hankook Ventus v12 evo k110 tire noise or something else?
  228. 335s on the back and 275s on the front on my evo x
  229. What is the going rate for stock tires?
  230. Unique(?) Tire Needs
  231. staggered offset on evo x?
  232. Powder Coating Stock BBS Rims
  233. Broke a wheel stud
  234. Which wheels are these on this Evo X Ralliart?!
  235. Help – I’ve ruined my Evo’s handling
  236. lowering springs
  237. Continental DW or Hankook Ventus V12 evo K110 ?
  238. 9.5"s up front on a sedan?
  239. Need piano black rims!
  240. Clear coat peeling on brembos
  241. is it possible....
  242. Went to bleed brakes after magnus CMC install....
  243. Which brand for brakes?
  244. suspension question..
  245. Tial QR + ETS Question
  246. Hawk HP+ Nightmare, Help!!!
  247. what the best tires for stock rims?
  248. BREAK PADS and DRILLS - WICH BRAND?
  249. Hypermax, KW v3 or Mono Flex with EDFC
  250. coilovers making sounds!
