PDA
View Full Version : Evo X Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19
  1. Brake Sound
  2. "Clunk" or "popping noise" resolved?
  3. Suspension concerns after new wheels/tires setup...
  4. Cut stock eibach springs 2012 handling package
  5. Help me pick a wheel color! Hypersilver or Black?
  6. 8mm spacer?
  7. Weds sa55m bbm on 2010 GG
  8. In need of new brake pads, what's ur choice?
  9. will 18x10 +18 sit flush with 245 stock tires
  10. 225/45/18 on 18x8.5 Wheels - *Who is doing this winter setup?
  11. Tire size question (but not the normal one)
  12. coilovers finally shipped after 7 weeks
  13. Winter Season Reminder
  14. Rear fenders rub after installing 18x9.5 +20 with 245's
  15. 265/35 with Bridgestone RE970AS require fender mod?
  16. Which coilover would be best for a daily driven evo x?
  17. what are these wheels?
  18. Swift Sport Springs.. rubber silencer??
  19. Loctite and antiseize
  20. Neal out till Sept 24th
  21. Would these fit my 08 gsr?
  22. Weird ride
  23. Rear oem pad life
  24. I come to you again. What wheels are these!?
  25. Which top hats/strut mounts for evo x?
  26. Nitto NT05? Or buy something else?
  27. The ultimate affordable OEM GSR wheel cleaning tool
  28. Ce28 vs dpt
  29. Whiteline RCK
  30. Any difference between 08 and 11 Evo X MR BBS rims?
  31. MAP stage 2 brake kit.
  32. MAP stage 2 brake kit.
  33. JRZ RS Pro - setup tips for a UK newbie :)
  34. Anyone running Wedssport SA55M in 19"
  35. Evo X wheel size options? help please!
  36. TPMS sensors wont fit Gram Lights
  37. kw v3 sound
  38. Researching around on wheels, ? on these rota g forces
  39. Hawk HPS clunking when applying brakes
  40. Evo X - Auto Cross set up?
  41. Review: Nitto NT05, Works Blue Brake Pads, AP 600 Brake Fluid
  42. Need ROTAS!!!
  43. Evo X Lug Nut 'washer' question.
  44. Please advise: Coilover install caused "Service Required: AWC"
  45. Need help with wheels
  46. Call to Suspension Guru, Shock Dyno Inside
  47. Neal out till Sept 4th
  48. SAI/Scrub Radius of the Evo X?
  49. open ended lugs for stock gsr wheels?
  50. ss lines that replace both the hard line and rubber line up front
  51. brake bleeding issues:/
  52. What wheels are these?
  53. What tires should I get?
  54. Sub Frame Rigid Collars
  55. Tires
  56. volk decals?
  57. TE37 18x9.5 or 18x10.5
  58. AMR Engineering customer service A+
  59. Odd? Bolts loosening...
  60. Help: After Front Sway Bar & Spring Install Service AYC, AWD, Airbag Light is On
  61. Which spacers?
  62. Should I try different tires?
  63. Enkei RC-T4
  64. What's wrong with slamming an Evo X?
  65. Swift Spec R/H&R/GTWorx w/ Greddy Front lip
  66. New lugs for ichiba spacers?
  67. 2011 Evo X GSR - All Season tires
  68. Need help with new wheels!
  69. KW V3 vs FA 510
  70. Rays TE37 or Rota?
  71. Best Camber Plate for GT Worx Springs
  72. Shop has to drill into the rear LCAs??
  73. why higher rear spring rates??
  74. Anyone? What wheels are these?
  75. JIC FLT-TAR coilover??
  76. Neal out till Aug 13th
  77. Pic Request - Matte Black Enkei PF01/Raijins Blue Evo X
  78. delete.
  79. Wheel Questions!
  80. Where can I find an 8mm hubcentric spacer???
  81. 2012 Mitsubishi Lancer GT Springs need help
  82. need help picking new 18x9.5 rim
  83. New Wheels + Rally Armor Mudflaps
  84. Price for oem struts for MR..NEED HELP!!!
  85. Can somebody please help me with rims?
  86. Need help!!! Bent struts??
  87. Coilovers or revalved blistein w/ swift sport ?
  88. Stoptech Street Performance Pads - Review
  89. varrstoen 2.2.1 18x9.5+12 fitment question
  90. Obnoxious Suspension Clunk..need input
  91. Replacing brake pads. scratching noise heard while driving. Need recommended pads
  92. In Need of Tire Help for Evo
  93. Swift Spec-R Spring Review
  94. Do BBS Wheels Really Suck This Bad?
  95. Swift spec r with stock BBS
  96. Why only 9.5 or 10.5 width on rims? Please help
  97. evo x noob suspension question
  98. Ride quality: Swift Sports, Spec-r or GTWorx?
  99. Do I need new rotors when getting new break pads?
  100. Gram Lights 57DR
  101. Impact of running a 18x8.5 +40 offset wheels
  102. Tanabe Sustec Z40 Coilover
  103. Rear subframe replacement!!
  104. Spacers?
  105. AP Racing Big Brake Competition kit
  106. Just ordered gtworx
  107. Question about Next set of tires
  108. Evo handles like crap! Need some insight
  109. Ichiba Spacer circumference too small?
  110. Lighter Wheels = First Mod; Options for best performance?
  111. Camber plates for stock springs and aftermarket shocks?
  112. Replacement Struts
  113. TSW 18x10.5 +27
  114. Eibach Springs Alignment question
  115. road race, auto X, street driving suspension setup! need help!
  116. Spacers on the stock BBS rims?
  117. Stock EVO X wheels/lugs
  118. Pads and rotors?
  119. GSR - Help with suspension setup!
  120. Neal out till July 9th
  121. having a hard time deciding on tires
  122. Evo X GSR with MR Shocks?
  123. Video Review Hankook Ventus V12 Evo K110 265/35/18 mounted on Enkei RPF1 18/9.5/+15
  124. X springs
  125. Front Camber Differences
  126. Patch for Nitto NT05's...
  127. Best autocross coilover
  128. Outer CV / Axle boot replacement
  129. Do I need new rotors? Please help me!
  130. wheel color
  131. Can't decide on FAs :/
  132. Eibach Pro-Kit drop comparison
  133. will these fit? please help
  134. 19x11 Wheels?
  135. What do you think of these D Force rims?
  136. If anyone wondering which is the best coilover
  137. Bushing grease on rear sway bar question
  138. Installing KW V3 coilovers - FAILING
  139. asc and brakes on after cmc install
  140. H&R Springs + Aero kit.. speed bumps?
  141. caster difference left-right
  142. You are subscribed to this thread A couple Dunlop super sales right now
  143. front axle "play"
  144. Brake Booster Leak
  145. Neal out till June 18th
  146. Best Coilover for DD X?
  147. offset vs. tire width vs. lowered height
  148. Crazy noises from Stock Evo X Advan A13C?
  149. Question about stock springs on GSR
  150. Rear sway bar install help
  151. Suspension problems? =/
  152. 55k+ miles evo x suspension setup
  153. Rear alignment bolt/washer part numbers
  154. Verified FAILED Tire/Wheel Fitments (only)
  155. Verified Tire/Wheel Fitments (only)
  156. KW V3 + RS3 vs Stock Suspension + NT01s
  157. Stance GR+ PRO
  158. Must change all 4 tires at once?
  159. best tire choice HELP? DRAG and Motor Sport
  160. Yellow Racing DPS coilovers
  161. Closeout on Griots Total Wheel and Tire Care Kit $30!!
  162. Hankook Ventus V12 Evo K110 265/35/18
  163. Need some advice on sizing....
  164. EVO MR Rims verses EVO GSR Rims
  165. Review Request : Stance GR+
  166. Pro-kit and bump stops - what to cut?
  167. Brembo 2 piece Rotors
  168. new rotors and new tires
  169. Help!! Asap
  170. Brake Rotor Advise
  171. Recommend 265/40 or 35 for 10.5 wheel?
  172. Valve Stems & OEM TPMS
  173. Hex nut missing from rotor. Should i be concerned?? PICTURE INCLUDED
  174. Enkei RFP1 18x9.5 + 265/35 rubbing after roll?
  175. installing springs question
  176. Tire without rim guard lip?
  177. SSR Type F 18x9.5 5x114.3 +22mm Fitment Question
  178. XXR 527 Vibrations
  179. OEM Lug Nut Shank Diameter
  180. I need a measurement, can someone help?
  181. brake booster not working?
  182. Tires for 9.5 rims
  183. Hankook Ventus V12 or Yokohama S-Drive
  184. Tire recomendation for IL driving
  185. AD08 on Swift Spec-R
  186. 18x9.0 +20mm offset Would fit evo x?
  187. motive power bleeder question
  188. Roll Center Adjustment Kit on Stock Suspension?
  189. PIC Request
  190. Coilover question/concerns
  191. Anyone know????
  192. whats more comfortable; springs or coilovers?
  193. anybody put on XXR 530s on their X yet?
  194. Replacement Wheel Spacer Bolts?
  195. H&R Springs?
  196. Pic Request - Enkei PF01
  197. max camber on kw v3
  198. help with tire size
  199. Enkei edr9 on Evo X ?
  200. What springs on Blisteins?
  201. Swift sport springs too much drop?
  202. Looking for a new set of tires for my Evo X
  203. Tires have seperated from itself?
  204. Bad Alignment Experience
  205. 2012 Rear fender liner?
  206. H&R springs. A before and after pic.
  207. New Enkei RSM9 racing Wheels..Who has it?
  208. Shaking steering wheel
  209. Linea Corse questions
  210. JRZ RS1 Suspension Kit Review
  211. Post your Lug Nuts
  212. Swift Spec R/ GT Worx EVO Tarmac need advice from MR owners
  213. need advice from wheel gurus
  214. StopTech vs EBC BlueStuff vs RB ET500
  215. brake pads
  216. Brake ducts/fog light holes?
  217. ABS issues
  218. Evo x wheel locks
  219. polished
  220. There's an app for that
  221. Hawk hps brake pads
  222. Tire Pressure
  223. Matching paint for Flat Gunmetal Rotas?
  224. Wedssport SA-55M question
  225. Spring/ Wheel?
  226. Evo X MR rotors?
  227. need tires for 2010 MR
  228. Swift spec r
  229. Bilstein DampTronic
  230. 15mm spacers - Ichiba vs. H&R trak+
  231. 18x9.5 +12 for track
  232. "No fat girls or I will rub"
  233. Spacers and alignment
  234. Ferodo DS2500 review
  235. Drop advice with 2012 Aero kit and speed bumps
  236. Car pulls from side to side
  237. Toyo Proxes?
  238. Brake rotors
  239. Changing from BBS >> VOLK's TE37.. HELP!
  240. Right Front Wheel Camber Change
  241. Evo 8/9 vs. Evo X suspension/coilovers
  242. Brake failure??
  243. How important are backing plates/grease for brake pads?
  244. Budget Coilovers?
  245. Are our rotors this cheap?
  246. Need help with RP03's
  247. No fender rolling, no rubbing, maximum tire size on stock evo x
  248. Knock noise from rear
  249. stock top hats and kw clubsports
  250. Love the new Pilot Super Sports
