PDA
View Full Version : Evo X Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19
  1. Please help with choosing r-comp tires and track wheels
  2. Alignment woes....
  3. need pros and cons on the following coilovers
  4. Experiences with Advan RS 18x10 +25?
  5. Swift or Works springs
  6. 2 peace rotor replacement cost???
  7. 225/45 or 245/45 on stock gsr wheels??
  8. Rolling fenders
  9. Continental Tires
  10. Help! Terrible Noise in Suspension
  11. anyone uses KW V1 on their X?
  12. So Which Is Stronger?
  13. wheel and tire suggestions
  14. Brakes squeek like mad.
  15. STANCE or BC racing???
  16. Questions B4 purchase...
  17. All 4 Wheels Bent?????
  18. MR owners is it worth it to upgrade your suspension?
  19. Weird clunking sound when hitting the brakes?
  20. Advans fitement
  21. WedsSport SA55M Group Buy for one-off Red-spoke batch
  22. Tires size
  23. Stance GR+ vs. BC Racing BR+
  24. Do new tires really need to be broken in gently for 500 miles?
  25. new nitto nt-05's
  26. D2 coilovers
  27. Hawk HPS pads...who runs them..opinions?
  28. Summer tires for 19x9.5 +22 Rim setup?
  29. HELP~~~~Emergency !!!!
  30. Lowering Springs to stay away from?
  31. Looks lowered to me...
  32. Will I have problem with this set up?
  33. New wheels and tires
  34. How often should I bleed or flush the brake fluid? Re-use old ATE fluid?
  35. What do you use for brake cleaner?
  36. Duralast Cmax ceramic brakes installed
  37. Anyone rubbing on 285/30 Hoosiers on stock wheels with -2 deg camber?
  38. A couple fender rolling questions
  39. 245's on a wheel that normal runs 225's?
  40. Tires...It may be time soon :(
  41. Wheel paint question...
  42. Continental ExtremeContact DW (Not DWS) or Hankook Ventus V12 evo
  43. Coilovers Recommendation?
  44. Suspension/Spring Question - What is this??
  45. Need some help! Looking for good dampers with custom spring rates
  46. Bolt pattern question?
  47. Anyone know where to get Advan center caps cheap?
  48. 30K Brake Caliper Failure Blot Flew off while driving...
  49. suspension recomendations
  50. Sidewall Damaged - Advice?
  51. Nitto NT-555
  52. That time of year for new DD Tires...
  53. Pads....
  54. 275/35/18 with Coilovers
  55. Question about alignment and getting the "free" 1 degree negative camber
  56. alignment or balance problem?
  57. Brake Squeal
  58. Good DD tires?
  59. Pictures: Evo X on OZ Superturismo LM 19
  60. Do I need spacer for 18x9.5 +38 offset ?
  61. Tire rotation
  62. Hsd=stance???
  63. CE28N 18X9.5 +22 Clearance problems!!
  64. UPS guy drop these off today
  65. A little advice for those who shop at discount tire!!
  66. For those of you with mudflaps/lowered
  67. ButtonWillow.. Will my brake fluid / pads last?
  68. Review: Agility Coilovers
  69. Advan Wheel Color
  70. Eibach + black top aero
  71. MICHELIN Pilot Sport PS2
  72. Advan rz help
  73. Where to Buy Lugs
  74. Fender Clearancing of Volk TE37 18"x9.5" +22, Z1's 275x35 at Muellerized!!!
  75. Brake Man #93 Compound Brake Pads
  76. Can I stretch 245's onto 10.5"?
  77. Review: Dunlop Z1 Star Spec tires
  78. Replacement rotors - blank face
  79. 18x10.5 +15
  80. where to get a new lug key?
  81. AST coil overs
  82. New robispec endlinks
  83. Rally question - evo x
  84. wheels scratched
  85. RS-Delicious!
  86. need help picking out coilovers,
  87. Best size for enkei rpf1's in 19
  88. kumho XS 265/35/r18 on stock bbs rims 8.5?
  89. Talk to me about tire sizes
  90. new wheels with out tire sensors
  91. Powder Coating Advice Needed
  92. Tire size
  93. The Brake Rotor, Pad, Line, Fluid, and Duct Thread (Evo X)
  94. Brakes = ZERO!!!
  95. GTWORX Camber/Caster Plates
  96. First season going to the track/solo..Coilovers, Springs or nothing?
  97. Got a good price quote on some Potenza 960 A/S PP should I pull the trigger?
  98. Will springs void my warranty...
  99. 2008 Evo x MR Work 11R wheels
  100. Need help on coilovers.TY
  101. Offset help
  102. Brake Pads and Rotors
  103. Will it fit?
  104. conti dsw extreme contacts hit the snow
  105. Anybody on Swift springs come from an VIII/IX?
  106. tire size for 18x9 +15
  107. 1st set of Wedsport SA-55's in the US
  108. Inflated tires to 45 PSI - bad idea?
  109. Anyone install robispec kw V3's streets?
  110. Ordered some entry level suspension parts
  111. So I just bought a set of springs...
  112. Introducing a new affordable race coilover option from JRZ and GTWORX!!!
  113. rotors...
  114. AYC sensor warning light
  115. OEM pads for Evo X MR?
  116. need advice on this rims for my evo x
  117. Help choosing summer budget rims...
  118. Rims and Tires ???
  119. perrin evo x sway bar problem
  120. 32mm rear sway bar = broken link?
  121. Limitations on the Camber Bolts?
  122. Moderate priced performance tire shootout. Come in and vote
  123. knocking noise front left?
  124. Rpf1's?
  125. Will these wheels work?
  126. Stock GSR rims - what is the coating from the factory?
  127. Stock Wheel Powder Coating
  128. 18x10 +41 wth 275.40.18 ?Help
  129. need recommendation for brake lines
  130. RS-R Down springs
  131. Tire review sticky thread?
  132. Kics or Ichiba wheel spacers?
  133. Adjusting dempening on rear coilovers?
  134. Discount Tire says TPMS Rebuild is required?
  135. Help with lowering springs for Evo X MR
  136. help my tires are rubbing!!
  137. Front end lift during acceleration.
  138. Need an input on Brake Pads
  139. Evo 10 measurements for model
  140. What rims on Modified Mag March
  141. New Advan D Wheels
  142. What Tires Are On Your Evo?
  143. Anyone used Hankook Ventus V12 evo - Tread life?
  144. Wheels and Tire question...
  145. Evo X Motion Ratios ?
  146. lost rays lug
  147. About to pull the trigger on some NT-05's...quick questions
  148. Weds Sports SA-60M 2010 model
  149. looking to see 2010 evo x with 18x10 rims w/265
  150. 19 x 11 +20, work it fit?
  151. Help!!!!
  152. Tire Height Question
  153. Chunked my sidewall
  154. wheel spacers and recomendations
  155. Do X wheels have identification on them?
  156. Wheel specs to mount 275/35 18" tire?
  157. Best looking Evo 9 Wheels
  158. This just arrived
  159. chunk noise on bumpy roads at low speed
  160. All-Season tires SUCK (it's a constructive post however)
  161. Light Weight Wheels
  162. HRP Coilover Covers
  163. Question about HankookVentus V12 evo K110 tires
  164. New StopTech Trophy Sports Look SICK!!!
  165. Tire Size Question?
  166. TEASER: Linea Corse LeMan's for Evo X *Aggressive MESH*
  167. What size Spacers for Enkei nt03 +m 18x9.5 27mm
  168. KW V3 coilover camber plates?
  169. Height adjustable shocks (Not coilovers).
  170. New brakes at 5000 miles??
  171. Manufacturer Tire width trends
  172. Anybody running Tein S-techs?
  173. RPF1's 18x9.5 +15 thoughts
  174. Bedding Procedure Hawk Pads
  175. Rear Sway Bar Bolt Broken and Stuck
  176. Evo X T145/70R18 spare
  177. Tire Opinion thread
  178. Fronts 2 Piece floating rotors for 2010!
  179. Advan RS or RZ 18x9 offset question
  180. FAIL x 2
  181. do the rota grid 18x9.5+38 clear brembos
  182. HKS Hipermax III
  183. Will 18x9.5 ET35 Clear the Caliper ?
  184. Electronic Controlled Coilovers
  185. Tire fitment Question? stock tire= 9.5" rim
  186. Component Compatability
  187. Drag DR-32
  188. toyo proxes4 all season uhp!
  189. How does the E-brake work?
  190. Evo x brake kit
  191. Brakes suggestion?
  192. Summer tires, Need some feedback
  193. Enkei 18x10.5 +15 w/ 275/35 tires
  194. Fitment question
  195. Light wheel for our evo x
  196. Eibach Pro-Kit vs. Winter??!?!?!
  197. Running smaller wheels, with smaller brakes
  198. will these fit??
  199. anyone running this setup?
  200. Gold Advan RGII on WW Evo X
  201. swift spring installation this weekend, tips?
  202. Black Work XT-7
  203. No center/dust caps
  204. Suspension Goodies for my Evo X - Installed by DG Motors
  205. Robispec Streets
  206. White Powder Coated EVO 10 Enkies Pic's anyone?
  207. Stud length Concern/Question
  208. Need Opinions
  209. Anyone installed Swift lowering springs with Upgraded Sway Bars in front/rear?
  210. How close are we to the suspension with stock wheels/tires?
  211. Best Rims for Silver Evo X
  212. 245-40R 18 Nitto Invo
  213. Need honest opinion on tire width and street usage
  214. recommendation on coilovers
  215. Evo 10 driving on spare tire
  216. Control arm
  217. Eibach Multi-Pro R2 w/ Vorshlag Plates
  218. Stock Advan tires: Worn outside, inside fine
  219. 18x10 +35 with 265/35/18 any rubbing ?
  220. Weds Sports SA-55M
  221. Does this car need Roll Center Kit?
  222. Comprehensive wheel weight list
  223. Would this fit? staggered fitment...
  224. Hawk HPS Pads
  225. Hydralic handbrake on x?
  226. Will the Enkei Nto3m+ accept our stock Tpms sensor?
  227. almost no brakes! WTF
  228. Help pick out my wheels
  229. Flat tire when traveling?
  230. Are your brakes getting too hot at the track? Have $30 and an hour?
  231. Has anyone fitted Works XD9 at any offset on Evo X?
  232. New coilovers, Eibach Pro R1
  233. suspension? coilovers? etc etc so confusing
  234. TE37 R19-9.5J +22 vs 265\30?
  235. 255 star specs tire pressure track day
  236. Tires for Arizona driving only (i.e. dry only)
  237. Are you able to put 17's on an 2010 MR
  238. Combat a Soft Side Wall - Conti DWS
  239. Advan RZ on Swift Springs
  240. Front end rubbing on Advan RZ 19x10 +25 Hankook Ventus V-12 EVO 275/30/19
  241. Ball joint press from autozone?
  242. 265/35/18 star spec z1 on stock 8.5 rims...
  243. Tire pressure monitoring system EVO X MR
  244. Blizzak WS60 vs LM60
  245. Poll: How long do the stock Advans last?
  246. Horrible Tire Mounting Story [Metro Mitsubishi, Southgate Michigan]
  247. Paint code for the GG?
  248. Motive Bleeder
  249. Advans RS 18x9+29/Kics R26 Lugs (NH)
  250. Took the Plunge
