- Who makes camber plates for the X?
- Woo, look what FEDEX brought me
- Rear Strut Brace
- These tires are F***** up
- Yokohama problems
- Aggressive setup!! Help!! Help!! Please
- Which springs to go for.
- Strut boots on KWs?
- Help with Coilover Choice
- Installed Suspension...Poor Steering Response?
- Help with rim damage!
- Need help, will this wheel/tire fit without rolling/flaring fenders?
- advan rs tire advice
- Sway Bars: Hotchkis and Cobb
- HKS Adj Coil overs Keys/tools
- Squeeky Brakes
- Tire pressure for track day
- 275/35/18 on 18x9.5 +28. Will it work?
- Best Wheel locks for evo x MR?
- what kind of rims is this?
- spring seating question
- need help raising my ride height
- RE30's in Formula Silver almost on
- DAI wheels
- Rota weight
- should i keep the strut tower brace on my MR?
- PICs needed 5Zigen ZR520 Wheels on WW EVO X
- 18x10.5 +15 - 295/40/18
- Tire Rotation Pattern
- To those with Rota Grids
- new evo x caster prob
- Work CR Kai
- Suspension Help??
- eibach mr springs fit gsr?
- tire size to go with my 19 x 9.5 rims???
- Perrin vs. Cobb Rear Sway Bar
- MR BBS wheel touch up paint?
- Advan Neova review
- Michelin X-ice versus X-ice2
- 18x 7.5" +25mm offset wheel fitment
- Advan RZ18x9 plus what size tires?
- best springs for auto-xing?
- Has anyone successfully retrofitted Evo X brakes to an Evo 8 or 9?
- Help with new brakes.
- coil over setting & adjusting
- Volk RE30 and Bridgestone RE-11 on Edmunds project car
- What is the hub/bore size of the Advan RZ 18x9 +35 rims?
- Performance A/S Tires Recommendation
- Anyone with a pic of the factory camber bolts?
- Spacer Recommendations?
- Anyone with pictures 18X9.5" wheels with 245/40/18 tires?
- is it any non brand center cap fits gramlights?
- CV Axle
- springs in winter
- Teins springs for Evo X
- 5Zigen ZR+520 EVO X offset??
- Advan Rs
- Stock tires replaced for free.
- Anyone running cobb springs/pics?
- A different kind of Lugnut Question
- Will these wheels fit on my X with no rubbing?
- CE28N Formula Limited 18x9.5 arrived today... so why am I depressed?
- Perrin PSRS - anyone tried?
- Any good 19x10's out there?
- Eibach Pro-Kit for Evo X MR on a GTS?
- Wheel Torque Specs and PSI on aftermarket wheels
- Cobb sway bars question
- Stock Wheel and Alignment Specifications
- TPMS Sensor Programming
- Fender liner???
- Stock tires average life
- Fluctuations in Alignment Settings:Causes
- Quietest Tires Possible?
- Valve Stem Question
- Brand Spanking New Apexi S1 Coilovers
- what tires should I run on advans
- Rear suspension making clunking noise after alignment
- Advan Rz/Rs?
- Advan + eibach
- KW 3 on the X...help.
- What alignment to run with Eibach springs?
- Tire Sizing?
- Brake Noise
- Anyone stuff a 265 on a stock X rim?
- Eibach GSR Install
- New Eibach Springs for X MR
- Summer tire recommendation?
- How wide can you go?
- Topping off brake fluid...
- How can I tell if it's lowered?
- Suspension Spring Spacer
- Please read: This is not a FS forum
- E-Brake AKA Hand brake AKA Parking Brake adjustement.
- Cobb Rear Sway Bar Installed **PICS**
- Will X MR brembos fit other Lancer editions?
- What Wheels To Choose On GG
- Anyone paint axel nut?
- coilover advice
- Different colors of OZ
- What color wheels look best on RR?
- swift springs change camber too much?
- Powdercoat or special order?
- Would this be considered the lower control arm
- MR spring on GSR
- Motor Trend snow comparison of Evo X and STI... and how poorly summer tires perform
- TSW Thruxton
- Toyo R888 vs BFG R1 Fitment
- Anyone using Meullerized suspension parts?
- Anyone have Eibachs for over 6 months?
- G-Games Baracuda Gunmetal
- 17x7 215-50
- Rear sway bar (Perrin & others)
- HKS Hipermax 3
- Hubcentric Ring Fitment Observations
- Girodisc Stage 4 Brake Kit
- Wheel Spacers and vibration
- ~OEM replacements - Tire Feedback for the EVO X
- Which brake disc should I go with
- EVO X GSR - Brakes
- stock wheels, spacers, longer studs, and open lugs !!!
- Brake Wizards, Attention
- So I finally lowered my x
- $500 to install Lowering Springs?
- Evo X MR Rims?
- Do i need spacer?
- Camber and toe write up
- Blitz BRW profile 08F forged wheels
- Rim Size Questions
- will these fit?
- H&R wheel spacers
- Coilover Fitment Chart
- Tire reviews
- Tires - Is Bigger Always Better?
- KW V3 question
- TPMS in Rota Grids?
- Evolution MR Owners ... considering suspension options
- Alignment
- work or tanabe springs
- vs-xx?
- Brake problem after switching wheels
- Wheel Offset Fitment Chart
- gsr shocks vs mr bilsteins
- Camber Adjustment on stock suspension?
- 18x9+30 BuddyClub's.. white. on white.
- Are your tires safe?
- question about tires and alignment
- Stock GSR RIMS with 225/45 18?
- Rota Grids Gold on WW
- tire help 19x10 rims
- Evasive Motorsports tests out new Tein Super Racing Dampers
- work cr kai's 18X9.5 20MM
- Question: lowering springs
- Needs brakes and tires soon!
- Installed Megan Coilovers on my Evo X
- Coilover setup/install in northeast Ohio?
- Nitto NT-05 Tires
- Anybody run the Sumitomo HTR Z II's??
- What Wheels should i go with?
- Megan Coilovers vs Eibach Springs
- Wheels back from the powdercoat shop
- 19 x 9.5" Wheels and 275/30-19 Tires - Wheel Spacers?
- Second Set of rims
- Squeaking Brakes
- Anyone know what wheels these are?
- fender roll place or person in the tri state area
- 255/40/18
- Anything that can be put on wheels to avoid dust sticking?
- Advan RS fitment
- Anybody really pushed the stock tires in the rain?
- Benefits of different offset?
- anyone running MR suspension on GSR
- Anyone know effective/wheel rate of springs?
- Wheel Fitting Room !! Fit whatever wheels you want!
- should i put wheel spacers on my mr?
- Brakes Grinding?
- TPMS question
- Rear swaybar upgrade?
- Wonder if this is going to fit when on the ground?
- Whats the biggest time you can run with Eibach springs?
- stance gr+ on my car
- eibach pro vs. tein s
- how crappy are oem brake pads on evo x mr?
- Project Mu brake pads? Any good?
- Hawk Brakes
- Powder coating gsr rims in nyc
- tire pressure sensors
- Apexi S1 Coilovers
- Tire size question
- Do all coilovers squeak and need rebuilding?
- Trying to figure out bolt pattern & offset on wheels
- mr suspension or coilovers??
- Tenzo R Type M info
- MR BBS wheel center caps size
- Best way
- Mr springs
- 9" rim tire size
- 6mm wheel spacers?
- Track Pads
- coilover question
- Tire questions...
- anyone running oem bbs wheels w/ spacers?
- +22 Offset – bad for car?
- 18x11 +25 CCW C14, doable?
- What are the best X brake pads?
- GSR vs MR/SSS Wing Performance
- Warping of OEM Discs
- I think I found my next set of wheels
- Advan rs
- Some Advice
- Intro: BC Racing ER Series Coilovers - 2-Way Adjustable *** Darkside Engineering ***
- Stock height rides smooth, but.....
- Prodrive 18x8.5 34mm offset
- KW Variant 3
- Cheapest place to buy wheels
- Anyone running Nitto NT01 in 275/35/18?
- Gauging interest.....EVO X suspension parts from GTWorx
- Enkei GTC-01 Evolution series
- Project Mu HC+ brake pads?
- Rota Grids 18x9.5 +20 offset Part II (finally lowered)
- Does the NT03-M in 18x10.5 +30 require a spacer?
- Lexus F Forged Black wheels
- Girodisc Has 1pc Slotted EVO X Rotors!
- What back spacing with 275/35r18
- Stance GR+ Coilovers Review
- Finally got the Rotas and Blizzacks.
- kw clubsport
- Brake Rotors
- Anyone has thought of RAYS GT-C FACE 2 on their EVO X?
- Tire Sizing Question for 19x10 20mm offset
- Urgent wheel spec question~!!
- Anyway to check for TPMS Senors without dismount?
- wheel & Tire size help
- Evo X GSR with MR Bilsteins, Works .9 springs
- Aftermarket Springs...on an MR???
- Fender Rolling
- People with HKS Hiper Max III Sport coilovers....
- When/how do new springs settle?
- 18x9.5 +22 TE37 - work required?
- Center Caps for Advan RZ
- How to disable ABS? Removing fuse din't work properly
- Robispec in Denver
- Stock Alignment settings?
- wheel clearance/brake clearance
- T1R B-52 Coilovers Have Finally Arrived!!!
- Dealer front and rear air dams
- SS1 Suspension Package is Here!
- What's wrong with my brakes? Anything?
- Brake pad options (Definitive List Thread)
- TPMS Sensor Lag
- Evo X Time Attack CE28, Where to buy?!?
