PDA
View Full Version : Evo X Tires / Wheels / Brakes / Suspension
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. Alignment Help
  2. Girodisk rings
  3. Thoughts on ZEAL FUNCTION X coil overs....looking to buy
  4. Would these fit without any issues
  5. Patch or Replace
  6. Air ride?
  7. Volk CE28RT 18x9.5 +24 need spacers
  8. handling all effed up
  9. Help with offset question!!
  10. Enkei PF01 information needed
  11. What Sway Bar to Buy
  12. tire hook up in southern ca?
  13. mmm girl
  14. What Springs to Buy
  15. TPMS cloning (not NGS)
  16. What is wrong with my setup?
  17. Coilovers for spirited DD
  18. I need to replace this parts, need help identifying them pls.
  19. Tein street flex
  20. Wheels and spacer
  21. coilovers under $2000
  22. Car Pulling To The Right
  23. Suspension Ideas (Tein Flex Z)
  24. installed giro disc magic pads
  25. Questions about lowering
  26. KW Variant 3 Question
  27. 14 MR coilover question
  28. RE71R Full Review: Dry/Wet Track & Street
  29. Roll center kit and there REAL usefulness??
  30. Girodisc Magic Pad shims
  31. Any pics? 17x9.5 with 265/40 or 255/40
  32. Is this much rust normal on a 2015
  33. 18x9.5 +38 , will I need 10 mm spacers?
  34. Enkei RPF1 18x10.5 +15
  35. Work D9R 18x10.5 +23 Fitment Help
  36. re71r
  37. Lug nut for Gramlights 57DR
  38. BC Racing BR Coilover Review
  39. Whiteline RSB + endlink question
  40. FFT Wheels?
  41. Tire fitment
  42. New to Winter driving - Winter tires needed?
  43. Hotchkis Rear Sway Bar and Endlink Review
  44. No Money For Ohlins
  45. Wheel shifting left to right
  46. issues after new tires/rims and alignment
  47. Wheel spacers question!
  48. Latest Greatest All Season?
  49. Caliper Piston & MC Size
  50. coilovers overkill?
  51. what wheel size fit and suspension good for evo10
  52. enhancing ride quality
  53. The DEFINITIVE guide for selecting & sizing TIRES for PERFORMANCE
  54. Tire Pressure
  55. Coilover choice?
  56. Enkei Tuning Series - KOJIN question on the bore
  57. TPMS and valve caps
  58. XXR 526 18x10.5 +20
  59. Fortune coilover height adjustment?
  60. Anyone ? Ralliart lug nuts ..
  61. XXR 550 w/255/40/18 DWS 06
  62. 235/40R18 on stock wheels?
  63. Cross speed Premium 10 JDM wheel ??
  64. Do me a favor - rear strut measurements?
  65. Ordering Eibachs....two different product #s??
  66. Camber/toe bolt stripped
  67. repairing BBS EVO X wheels.
  68. Help - Assembling Coilover to Stock Rear Hat
  69. AD08R vs Avon ZZ5 vs ... ?
  70. Eibach Springs Wheel Alignment Camber, Caster & Toe Questions
  71. New wheels too wide?
  72. What wheel/Rim is this ?? plz help
  73. Eibach vs H&R real measurements?
  74. Enkei RP03
  75. Stock GSR Center Cap Issues
  76. Bushing sizes
  77. Work D9R 18x10.5 +15 or 19x10.5 +15, Brembo clearance?
  78. Evo X sat for a while, not rotors are grinding HARD
  79. Highway miles impact on R compound tires
  80. Shimmy shimmy
  81. 08 Evo Mr Struts
  82. What are the best spring rates corresponding to different grades of tires?
  83. I Finally got $1500 for coilovers! What should i get! or should?
  84. CY4A to CZ4A coil overs?
  85. Enkei wheels for BBS
  86. Fender Rolling Needed - Northern IL
  87. Hawk HPS 5.0 Brake Pads
  88. Lock washer on inner tie rods on the Evo X?
  89. HELP: Steering wheel vibration
  90. What Wheels and Tires
  91. Suspension 101
  92. Trying to make new wheels fit..
  93. Dsg limited edition fortune auto 500 coilovers
  94. Need a lil help with ohlins install
  95. Toronto - curb rash on '15 MR stock BBS rims
  96. Anyone know what wheels these are?
  97. Decision between KW v3 vs Ohlins R/T vs DSG Edition FA500
  98. H7R Springs Are Lower Than Eibach Springs? How? Please help.
  99. Stock tires=fail
  100. Slightly mushy pedal after stainless brake line install
  101. Works wheels setup and thanks
  102. Subframe
  103. Trying to confirm a Brembo OEM part fits
  104. Don't buy Godspeed Toe Arms
  105. Rotors, pads & brake lines suggestions in 2015?
  106. Powdercoated Brembo's Thread
  107. New Japan Racing Wheels JR-5
  108. ESR Wheels on an EVO X?
  109. Keep revalved Bilsteins or go for Fortune Auto 500?
  110. My car lowered on Ark springs
  111. rear caliper bolts (allen key type) torque spec
  112. Works wheels CR ultimate caps
  113. 19" TM02's vs 19" Kiwami Ultimates on GTWorx Springs
  114. Need More Low
  115. Evo X OEM Front Caliper Bolt sizing?
  116. Tire suggestions for stock wheels
  117. Rear problem
  118. Finally Arrived!
  119. Whiteline rear end links coming loose? What about front end links?
  120. GSR springs on MR Bilsteins?
  121. 20x9.5 OZ Ultraleggera 20/255/30 fit without fender rolling?
  122. Dry-wet summer tire suggestions
  123. WTB MR Bilsteins with Swift Spec R Springs
  124. new wheels installed. now I have steering wheel shake
  125. Circuit Performance Wheel
  126. Will 18x11 +10 clear calipers?
  127. 245/45/18 Fitment
  128. Wheel Lock Key
  129. VIP MODULAR - Fitment Help - Aggressive
  130. Coating a coilover for longevity?
  131. HELP!! This noise is driving me nuts.
  132. brake pad/ rotor suggestions
  133. Lug Nut Studs For Evo X
  134. Tire Suggestions
  135. BBS LM: Legit or Reps? Help
  136. Wedssport sa10r questions
  137. Torquing Our Wheels.. I need specs!
  138. Where can I find stock X MR BBS's?
  139. help alignment question
  140. Any vendors have Hotchkis RSB (22440R) available?
  141. Factory bolt sizes on an Evo X?
  142. 265 or 275 dilemma..
  143. Will they fit?
  144. Best alignment specs for H&R springs info needed!
  145. Whiteline Swaybars
  146. LIQUI MOLY anti-squeal brake paste
  147. ? for you guys on brake noise and tire rotation
  148. Anybody use ARK DT-P Coilovers?
  149. Tire size help
  150. Swift Spec-R vs H&R springs.
  151. Showing off new wheels :)
  152. Coilovers question!
  153. What to expect with light weight fly wheel?
  154. Help! Need help identifying these wheels
  155. NT01 275's OR Star Spec ZII 265's on 9.5" x 18 +22 Optionlab S401
  156. Help please. 18x9 +34 offset?
  157. Removing rear dust shield
  158. About to pull the trigger
  159. 18x9.5 +15 rpf-1 w/ h&r springs?
  160. Miata Washer Solution to Stripped Rear Camber Washers
  161. TPMS Cloning Problemo
  162. evo x mr coilovers help please
  163. weird question but please answer..
  164. Brake hardline snapped... Help!
  165. Difference between NT03 and MT03+M
  166. 18 x 10.5 - +15 or +22 - which is ideal?
  167. Ohlins R&T with Swift springs?
  168. H&r springs vs eibach pro kit
  169. Brake parts question
  170. Ambit RT8 18x9.5 +15
  171. Wheel Size - Advan RG-D: What offset?
  172. Evo X Brake cooling system
  173. H&R Springs plus spacers
  174. Anyone own a 2014 lancer SE you know? Or just advice please!
  175. Fender work?
  176. Girodisk wear fast?
  177. Chicago area suspension tuner - APM, Fizz, Touge, other?
  178. Brembo pistons not releasing fully
  179. Wheel measuring
  180. Weird noise - sounds like a flat tire on my rear
  181. Interest in ball joints that lower car????
  182. Need Help with Noise - BC Coilovers - Brand New
  183. Need help
  184. Rear brake pad replacement question
  185. brake service light.
  186. Evo x BBS wheels.
  187. best coilovers under 3k?
  188. BFG Rival-S Update
  189. My review on a spoon rigid collar subframe alignment kit alternative
  190. Need help for brakes
  191. Help with suspension noise
  192. coilovers
  193. camber toe adjustment
  194. Offset of rota dpt
  195. Vorrstein es2 fitment
  196. 18x9.5 +20 OS rims
  197. Fitment Questions for RPF01's
  198. Price for used BBS MR wheels?
  199. brembo clearance
  200. Fortune Auto 500
  201. Work wheel Evo confusion
  202. Wrecked BBS
  203. need new tires
  204. Need help
  205. Torque Solution Adjustable Rear Control Arms
  206. Help with wheels
  207. Brake Pad Replacement. Did I just OVERpay ? ?
  208. Looking for 15x8 5x114.3 wheels
  209. Wider Wheels With Tein S-Tech
  210. Need some new wheel+tire help
  211. nto3's
  212. Question about valve stem hole
  213. Weds SA-15R
  214. Question Raising Car 4 winter on Coilovers
  215. ???'s for suspension gurus - scrub radius
  216. RPF1 Question.
  217. Tpms question!
  218. How many miles are Blizzak LM-32's Good for
  219. Hankook Winter Tires
  220. Evo X weird tires worn patterns
  221. Eibach springs
  222. ATEQ Mitsureset TMPS Tool
  223. coil overs
  224. ssr gtvo2
  225. Advan GT 19's
  226. ce28rt 18x9.5 +24 dont clear calipers
  227. 3 piece wheel
  228. Tires balanced and alignment done, still having steering wheel vibrations
  229. Volk Racing "Hyper Gold" Color?
  230. Need some help with Evo X Brake pads/rotors
  231. Lowering Springs Help
  232. Question on adjusting front suspension to bring up height on evo x
  233. Alignment spec on 19 inch Volk c28n +12 running 265/30/19?
  234. Is this normal?
  235. Lower springs, Spec R's.. Very new to suspension topics. help?
  236. Problem with my KW Clubsport
  237. New
  238. Track/Street tires
  239. New BC BR's - Squeak
  240. CCW or VOLK opinion
  241. If these Brake Pads were the same money what would you choose?
  242. Using Donuts for winter
  243. Any recommendation on tires for 19x9.5 +12 Volk c28 wheels?
  244. "spring" noise when i push on brakes
  245. Time to get a new set of wheel. Any good ideas?
  246. Squealing Brakes!!!
  247. Enkei RPF1s on Evo X
  248. AMBIT wheels
  249. Pressed graphite te37 on GG evo x?
  250. Where did you buy gold or bronze Rim?
