- Looking for Stock MR Rims
- spacers question?
- X GSR Actual Height on Eibach Pro Kit
- New Sponsor of evolutionm
- rota grids 18x9.5+22
- Review: Continental ContiExtremeContact All-Seaon tires on Evo X
- ARK Design R8 - 18x9.5 +22
- Front Camber adjustment...
- tire rotation
- Steering Wheel Sensor Calibration Needed post Alignment???
- fitment question
- Which vendor carries Endless or Project Mu brake pads, in stock?
- Backdating rear brakes
- Brembo GT setup and wheel fitment
- installing extended studs on rear hubs?
- Swift Sport Mach Spring Review
- Any opinion on a alignment specs?
- Work XT7 weight?
- Rotors for the X
- Best price for lowering springs installation?? :(
- Cheap Track Wheel
- Will A +35 Offset Fit A X?
- **Product Release**AMS Evolution X Brake Cooling Kit
- toyo proxes T1R
- Nitto NT05 Review [Modified Magazine]
- Enkei RPF1 18 x 9.5 + 15
- Bleeding Brakes
- Do I need to cut the front strut bumpstops when installing SWIFT springs?
- Widest wheel/tire combo
- My alignment numbers-Help please!
- wheel/tire specs for this X?
- mystery leak
- advan wheels (europe)
- weighing in advan rz 18x10
- GG Evo X - Which Rims?
- Winter Tires + Wheels
- Can anyone confirm that Tire Rack TPMS sensors work on the EVO X?
- Any brake duct kits out yet?
- Need a good all season
- Enkei Rpf1 18x8.5 +30
- Enkei RPF1's 18x10.5 + 15
- pink brembos
- lower the front suspension(change the spring)
- GG evo x with black rota DPT's
- Any one know the size of the subframe bolt?
- Anyone running these RE30s
- Evo X GSR VS MR Wheels
- Are there any vendors here who would be capable of finding me a single Volk CE28?
- Running stock tires inside-out?
- downgrading the brakes/rotors.
- 5zigen F1ORC 18x9.5
- So who here has Robispec KW Race coilovers?
- Suspension Discussion Thread Links
- Wheels spacers
- Swift and stock ride height
- quick fitment question
- Vendors: Still searchin for 19" wheels
- Volk CE28 +28 or +22?
- will it fit?
- Does anyone make non-slotted/non-drilled aftermarket rotors for the X?
- WIDTH: 275 NT05 v. 265 Star Spec
- Tire Comparison: Nitto Invo vs. Nitto NT05 vs. Nitto NT01
- Konig Zero In for evo x anybody try them?
- Fender modifications needed for Enkei RPF1 18x9.5 +15?
- do any vendors have a 19" rim in white
- Eibach springs?
- Help with wheel/tire size
- Car and Driver Tire Test
- help finding rims
- Issues after alignment
- Endless RF-650 Brake Fluid - Explained
- Where to find Center caps
- HKS Hipermax III manual
- How many miles are you guys getting from stock tires?
- Auto-X Tire pressure
- Gauging Interest Again: Parts for your Evo X!
- Enkei NT03+M or ADVAN TC II
- ame fs01 18x10 +25
- Do you need more camber for less money?
- BC Racing BR coilovers user review
- Stock BBS Rims
- EVO X Race Day HDR Shots - Race City (Calgary, AB)
- How not to ship wheels......19x10
- Stock O.E. Advans vs Michelin PS2s
- Robispec KW vs Standard KW?
- Help Finding a Fender Roller
- Curbed an Advan. FML.
- Strut Bar Nut specific torque
- More from Predator Performance in Puerto Rico
- Ordering new tires
- First Mod for my Evo X!
- Need help!!!
- Who makes an 18x10.5 ??? (list)
- quick steering wheel alignment question
- Picture Request: Advan RZ in Bronze on RR
- watanabe racing service
- Will I have any issues with these?
- Sway Bar Install Affects Headlights
- eibach's or sprint springs
- 18x10.5 +18 fitment
- humming noises comming from tires
- Suspension Replacement Suggestions.... All Weather Conds.
- stance coilovers
- Blue X with rims?
- Tires for 19x10 +25?
- 19 by 10 with a 37 offset??? question?
- 08 GSR GG w/ Rota G Force
- can i use the springs from evolution 8 2003 to my oz 2002???
- Dope EVO X
- Hawk Performance Ceramic Brake Pads
- Recommended tire size for 18x9.5 +20
- Has anyone had experience with K Sport coilovers??
- What wheels w/ stock suspension?
- The power of an alignment
- Where can I order some Endless SS-H pads?
- EVO X GSR: Suspension Geometry Swift+KYB+Whiteline should I get Perrin PQRS?
- Quick Suspension Question
- Hydraulic Handbrake EVO X MR
- Weight from the stock bbs rims on the MR?
- Eibach prokits, good ride?
- Are Stock Tires directional?
- progress springs
- Eibach Spring Offset: Stock vs Aftermarket Wheels?
- Te-37 rims gold or bronze???
- Horrible brake or bearing noise when raining
- AMR Engineering coilovers
- Has anyone got ABS working in an EVO X RS?
- rear sway and drift
- Replacing stock tires
- which drag tire
- Are MR 2-pc Rotors Serviceable?
- Replacement rear shocks for Evo IV - CN9A
- Lowering springs and Whiteline RCA?
- Some help please
- EVO X MR Lowering springs
- Is there any risk for buying 2nd hand springs??
- Coilovers track setup?
- How many track events did your OEM shocks last?
- Need some help on picking new tires.
- need to verify dealer info regarding OEM X brakes
- Nitto offers Contingency Program for Redline Time Attack
- How hard would it be to source a single wheel?
- Factory Shock Lifespan w/ Aftermarket Springs
- TPMS for the win?
- Dunlop z1 star spec or Nitto NT-05
- WORK Emotion XC-8 Bronze 18x9.0 on White EVO
- BC Racing Coilovers BR Series
- Stock KWs vs Robi Spec'd KWs
- Rubbing after new wheels went on !!
- Roll Center Adjustment kit
- New Shoes!!
- quick tire size question...
- HELP - need torque specs on front strut bar!
- 18x10 +22 with 275/35. Much rubbing?
- Steering wheel shakes 70+???
- Weds SA-70 18x10 +20 RR Face
- stock advan tire life
- Megan Coilovers?
- Recommend Me Springs Swift vs. WORKS ...
- cheap winter tires & rims
- another tire size question
- Upgrade Rear Sway Bar only?
- Revalved Bilsteins
- Uneven camber? Weird sound?
- 275-40-18? nitto nt05
- Eibach coil overs?
- Stock wheels stolen...
- How does the TPMS mount?
- Ti wheels
- Showcase: JDM Ralliart Front Strut Bar
- Straight answer...PLEASE!
- Nitto NT-05 or Flaken RT-615
- Camber question
- Front tires rubbing on OEM mud flaps and Aero kit side skirts
- Any opinions on Ferodo's DS2500 pads?
- Performance Friction Calipers and Rotors for the Evo X
- BBS LM or BBS RS-GT?
- Rota P45R Questions
- Evo X hub specs?
- Anyone with intrax springs?
- Quick Help Please!! Wheel Spacers
- How do the wheel bearing hold up at the track?
- Help with Rays center caps
- Will ANY 17" wheels fit a stock Evo X?
- Show your X with SWIFT springs
- Steering wheel problem?!
- New Rota G-Force 18 X 9
- AD07 vs AD08
- BBS replacement tuner lugs
- Looking for a good shop in Jacksonville
- Evo X Wheel experts needed!
- Brake cooling...
- KW Streets coilovers feel a little harsh
- Alignment after sway bar install?
- New Wheels No TPMS Light?
- Spacer Question
- Black Te-37 rims anywhere?
- Pads................
- bbs center caps
- Where to put new wheel weights?
- Stock Suspension with Aftermarket Spring Reliability?
- need help on my brake...
- Painting Stock Rims
- Anyone know about Konig Swurve wheels?
- need help with bbs wheels!!!
- D2 Racing Coilovers
- 255/35/18 Evo 8 Tire Pressure Recommendations
- Tire Bubble with Stock Rubber
- EVO X MR (2 Peice) Rotor Weight ?
- Eiback Prokit question
- Wheel gouging!!!
- Tuner Lugs with Stock Enkeis
- Popping sound
- Another coilover question...
- Summer Tires vs. Winter Tires
- Konig Runaway fit on the X?
- PICS: Techna-Fit SS Brake Lines - EVO X
- Wheel Studs on Evo X MR
- Recommended tires?
- Advan neova ad07 vs ad08
- loud clunking??
- MR Bilstein vs GSR KYB
- i have this squeaking sound in front when moving slowly..
- **Product release**AMS/Wilwood Evo X Lightweight Front Brake Kit**
- Brake pics
- Swift Sport Mach's Perfect Street/Track Setup??
- Strut Bars??
- Swift Springs
- Drilled Rotors.
- new GSR clunking over bumps
- New Whiteline parts for EVO X!!!
- may new pad brake affect the S-AWC control ?
- blitz techno speed z1 19"
- Xxr 518
- Black evo 8 Gold rota svn wheels
- Lug nut question?
- Advan Rz Searching
- Nitrogen mixed with Air????
- anyone know when the new eibach coilover is coming the the US?
- Pleae help somebody!!!
- Cobb Springs
- brake dust
- Those taking DPT initial delivery....
- Spring binding
- Advan RS - Paint Chip!
- Help!! Help!! Service light w/new Wheel
- Getting New Works.....Couple questions
- Who is not running TPMS Sensors?
- Wheel shake at 70+
- Springs for EVO X?
