- 1 new strut and all new brakes before 20k?
- Any problems with ebay Muteki Lugs
- Before I click the BUY button.
- Help with Brakes!
- Brake System Service required displayed then gone
- Steering wheel alignment issue
- bad wet weather
- uneven tire wear - drifting?
- Rear Sway bar question
- Ichiba Spacer Questions
- Which Winter Tire
- Apexi S1 dampers (coilover) install, impressions, and review
- HELP, Rays locking lug nut KEY
- Spare Tire?
- Te37 alternative. Focal X-FF ?
- Help identify...
- Project Kics R40 with RPF1s?
- A tpms solution proven to work
- McLaren style suspension? this could be useful
- no-drop springs
- Why is only one corner lower?
- New Enkei RS05RR
- 285/30/18 issues?
- Any X's Out there With BBS LM's?
- Uneven tires wear
- The Official Beat Up on Noize for His Virtual Drag-racing Thread
- GSR top hats on MR Bilsteins
- MR Bilstein shock revalve info
- Yokohama YK580s
- Yokohama YK580s
- Spring/Wheel combo?
- (Resolved) Need help deciding on coilovers
- Stretched tires and autocross
- What tires to buy?
- Lug Nut specs
- Help on Ohlins R&T setup
- Rear sway help
- New Rotors?
- Aftermarket wheels, stock ride height?
- Summer Tires- Thinking Bridgestone Potenza RE760
- Dropped on tein flex
- Snow tires and rims
- I think my brake line got cross threaded?
- solution to TPMS issue
- Blizzaks WS60 with Coilovers
- Auto-x settings
- Sumitomo HTR A/S P01
- Handling question?
- custom coilovers
- Nt05?
- New wheel options??
- Nitrogen instead of air in tires?
- SSR Type F Center Caps ???
- Aftermarket strut bars? Worth it?
- prodrive gc 014i
- Bigger tires on Evo X enkei...
- 2011 MR Rear Suspension Question
- brakes worn in 11,800miles?
- Snowchains
- XXR 521 18x8.5 +25 Clear Stock Brakes
- Ichiba Wheel spacers??
- R-compounds for B-Stock
- Auto x q about tires. driving to and from an event.
- No lug key, now what?
- Coils / offset suggestions
- TPMS won't reset. :mad:
- wheel stud question.
- Gold Konig Milligram
- Powder coating wheels
- alignment numbers look ok?
- ABS switch
- Interested in Buying Exo X already lowered 5hrs away...
- Coming Soon... Candy Teal AME TM-02's!
- whiteline rca for dd?
- New Evo owner looking to lower
- Opinions Please: Fortune Coilovers
- Car pulls to the left.....
- Good Rain Tires
- Lug nuts
- hub and wheel bearing
- Swift Spec R Springs... First Impressions
- Anyone on RotorPros Performance Plus Brake Rotors ?
- What kind of wheel style is this ??
- which Tire dimensions for CE28N 18x10.5 +18
- new twm metal shifter cage
- New DBA Rotors
- Ichiba V2 Wheel Spacers help
- Brake Pad Replacement
- calipers chipping after a trip to the body shop.
- Valve cap
- Stop bump question - Eibach Prokits
- Brembo Pad Pins and Clips - Where to Find?
- Dunlop Wintersport 3D
- Quick question: issue with reinstallation
- Eibach pro kit question
- Buying 2012 X MR soon Help
- Blue Wheels???
- Best tire for beater wheels..
- Winter Tire Question
- Stock evo vs. ralliart suspension
- New Enkei Raijins
- Tyre advice for 19 x 9.5 Rota Grid Drift (ET20)
- Advice on coilovers..
- Performance Brake Rotors
- Help finding Nitto NT-01
- noob question
- My Car Won't Stop On Snow/Ice!!!??
- Help guys: Fortune Auto 510 series or AMR coilover for X?
- rear brakes for 15" wheels
- How to install Eibach Rear Sway bar with stock Endlink
- how to instal coilovers using stock top mounts
- Will Sti BBS wheels fit on the Evo X?
- 2012 WEDS SA-50M and WEDS Kranze Cerberus III
- Can I fit 255/40 R19 on EVO X MR?
- Helper Springs Positioning
- cheapest all seasons???
- anyone have pics of WEDSSPORT SA60M mounted?
- Progress Sport Spring Evo X MR
- Tein Flex coilovers with edfc ?
- Any experience of ATS brakes?
- 255/40 can I put them on Evo X mr?
- KW Variant 3 Review
- Offset Question with Eibach Pro Kit
- OEM Rims center cap ?
- sway bar setting with swift spec r
- Coils came in today! KW V3
- $300 a good price to powder coat stock wheels?
- 20mm Spacers Cheap..
- That time of year...
- Is The Roll Center Correction Kit Necessary?
- What Wheels Are These?
- Problems with Rota Grid's
- Stock MR BBS Wheels - Will they fit on 07 MS3?
- cusco brace members
- Bronze or Gunmetal on PB (Advan)
- "Rotating" Brake Grinding Sound... Because Of Lip On Rotors?
- Swift spec-R and GTWORX tarmac springs
- Anyone here setup with KW V3's on their X?
- works 11r ggx
- what do i need to do to fit 18x11 CCW classics and what tires should i go with
- Would this fit
- Help me choose my xmas rims :)
- Fortune Auto coilovers
- Rim size suggestion
- Brakes (calipers) --- babied or used
- Touge Factory
- Beefing up the suspension.
- Megan Racing Lowering Springs (PICS)
- Order Tires online or Buy them here? HELP!
- Winter tire help...
- looking to see what is best? springs
- Brakes are squeaking
- Bartec 400 TPMS Question
- Rear toe adjustment
- Brake advice
- Swift spring spec-R not blue???
- Need some advise..........
- JRZ RS / RS1 / RS Pro
- Brembo Pads fit Evo X, 08+ STI and Genesis Coupe Track?
- Where can I buy OEM TPMS for cheap?
- 18s or 19s on an x gsr?
- small Wilwoods in rear of Evo X
- swift spings spec-r allignment issues
- Tire Depth Difference-S-AWC service light
- Brake cooling
- Ride Height with Fortune Auto Coilovers
- Trim s tech springs
- Rear wheel stud
- Ever use Sears for alignment?
- if $$$ wasnt a problem
- Anyone run 12k springs for DD?
- I want to drive from Cali to Tahoe - Winter Tires?
- Very Deep Dish Wheels
- Toyo R1R
- Whiteline Roll Center Kit ???s
- Opinions on s-tech springs
- Weird mechanical sound from brakes
- Volk RE-30 18x9.5 +35 on an EVO X???
- Is it me or are RPF1 weak?
- PB X MR with Black Wheels
- My GSR with Snow Tires + MR BBS + spacers + springs + TPMS
- questions about investing in suspension
- Rear Sway Bar Question...
- Drag DR-31 Flat Gray on Apex Silver
- Is 265/35 overkill for 312whp Evo X?
- Work Wheels? Any good?
- Curbed Rims
- Functional tire width
- MR Suspension Question
- What do you think about these?
- Lug Nut questions
- buying Volk GT-C plz help!!!
- Knocking noise from braking
- evo x coilover
- 18x10.5 +15 rpf1
- What size spacers do I need
- RAYS TE37 Bronze - 18x10.5 + 22mm - Aggressive Concave Face
- 255-40-18 w/ springs
- 18x9.5 tire size ??
- VOLK TE37 - TOKYO TIMEATTACK! 19x11 Anyone?
- New Endlink Option
- GoForTires - Michelin X-Ice Xi2 Winter Tire Review
- Looking to buy all season tires
- Camber Kit help
- Weight of stock Evo X lug nuts and locking lug nuts
- Rays te37 sl
- WedsSport TC105N (18 x 8.5 +32) wheels - the real weight. :(
- Muteki Open Super Tuner Lug Nuts
- 18X9.5 rOTA GRID
- OZ Alleggerita (Orange): Love/Hate?
- tire size help !!!!
- Kics LeggDura fancy locking aluminum ("duralumin") lug nuts
- Can someone post some pics of stock wheels black on a ww evo x???
- 18x9.5 +28, Nitto NT-01 275/35/R18, will it fit?
- How do you guys keep people from stealing nice wheels?
- brake grinding!!!
- Whiteline rear sway bar: adjustment ???s
- Winter Tire/Wheel Advice?
- Valve stem broken
- AMS wilwood rally brake kit
- Question about black RPF1s
- Continental ExtremeContact DW VS Hankook Ventus v12
- 10mm wheel spacers ... need info on extended wheel studs evo x
- Tire Choice ?
- Places besides dealer that can program TPMS
- Buddy Club P1 Racing SF Wheels
- 18x8 et40
- 18x8 tsw wheels for winter setup
- blizzak lm-60 or yokohama ice guard ig20
- Front strut tower torque specs?
- Enkei RPF1 color choice
- TPMS question
- Tire size help needed.
- WORK Meister S1R | 18x10.5 spec | Full Bronze Lip | EVO X Flush Fit
- Rust on stock shock body
- Anyone had a luck re-programming TPMS with ATEQ VT-55?
- Stock Advans-Realistic Snow Driving
- Will Drag DR 31s clear
- Pic request - Weds Sa55m & Advan RS
- FREE Lug Nuts?!?! Yep!
- newest Edition VOLK Racing RE30 Club Sport Edition
- Girodisc Braided Brake Lines
- newest Edition to WORK Emotion Lines / CR Ultimate Kiwami - 18" Aggressive Face
- Tein or Eibach
- Need Some Brake Advice
- Quick question about changing brake pads (Brake shims)
- Tire recommendations ?
- lowered and Snow driving question
- MB battle wheels + stock tpms sensor?
- Anyone with Whiteline Bushings
