- New MR - Spacers and Springs?
- 18x9 +25
- Running Spacers
- fitment advice
- Bleeding Brakes after magnus CMC install
- Changing rear rotors/lugs
- Oem lug length?
- Aggressive NT03s
- Another spacer question.
- Control arms/frame
- isc coilover, anyone?
- Will these tires fit and/or they worth it?
- Proper tire for 18x9.5 +15?
- Newest Lightweight ADVAN Wheels RSII (RS2) *** 18" @ ~ 18 Lbs ***
- What material to use for wheel spacer inserts
- Remounting stock tires
- Tire Size for 19 x 10.5 +25
- its time to change out the brakes and the rotors
- Brakes squeaking bad!
- greddy type s coilover
- Fortune Auto Dreadnought Pro 2 Gen 4 VS. Ohlins R&T
- How long have you gone on your spare? Bent wheel 150 miles from Home
- Does anyone know the length of the factory studs?
- Help me pick a tire
- Thoughts on some new sneakers...
- 8k Miles, New tires/rim/camber questions
- Circuit Sports Spacers?
- Rear Camber and Toe arms for the X...
- OE Brembo Brake Question
- Swift Spec R / GSR strut / 25 mm spacer / OEM BBS RUBBING?
- Question
- What brakes to buy?
- Dunlop Star spec ZII
- 19x10 et 20 how aggressive?
- Need wheel advice
- Ichiba wheel spacer question
- Can we change just the valve stem on our TPMS?
- girodisc 2 piece rotor experinces?
- Suspensions for DD
- Width of Michelin PSS versus Ventus V12?
- Opinion on these Hankooks
- Curbed a chunk of a spoke on my black rota...
- TPMS sensor keeps going off...
- Wheel and tire question
- Best coilovers for daily driver?
- delete
- delete
- Evo X Wheel suggestions and fitment questions.
- New Rims/Wheels....Any Tire Pressure Sensor issues??
- suspension shops of East coast!!!
- 285/30/18 on 18x10 +18. Rubbing Issues?
- XXR 522's 18x8.5 +30
- Clunk front driver side when braking and turning
- tmps sensor?
- Robispec rear sway bar
- Airmotion suspension
- Rota G Force 18x9 +30mm?
- best brake pad is ?
- Bridgestone Potenza RE002? Good?
- Help with not rolling fenders..
- Dont know how to buy rims?
- Rear alignment adjustment problems
- Looking to organize a group buy for Rota DPT wheels in custom offset!
- suspension help
- Evo X MR Autocross & Track Day Setup
- strange noise from the front
- Deals on rotors
- HELP GUYS!! Advan RS 19x9 + 38 OFFSET!!
- Just got a used '12 GSR! Tire upgrade recommendations, they are bald!
- Stock Advans
- lowered; strut and shock mounting question? did i do it right?
- Brembo Race Kit
- how wide can you go with a roll on stock suspension
- Fusion zri vs falken ze-612
- Tires / Rims Help!
- Alignment help..
- 18x9 +25
- Eibach Sportlines for 2012 evo?
- Which Tires?
- Procoat inc. Powder coat, vancouver, wa
- Rally suspension?
- SSR Type F... Question
- Squeal shields necessary?
- Pic request: Bronze Enkei Raijins
- The Works Wheels
- whiteline vs hotchkis
- Noob questions about tire sizing. please help
- all season tires
- front sway bar and more mods
- Brake Pads: Stoptech Street Performance vs. Hawk HP Plus
- need suspension adjustment advice
- TPMS Sensor - Good Problem?
- Better riding quality
- New Tires - Daily Drive - $1,000 Budget
- d2 or Ksports
- recommend suspension upgrades please
- TSW Interlagos, 18 x 9.5, +40 + H & R 15mm Spacers + 265 R-S3's
- Ohlins DFV R&T coilover system review
- Tire recommendations
- lowering springs vs cheap coil over
- Any one running DBA cross drilled and slotted rotors??
- Swift spec r's what sway bar setup?
- Rota Grid Questions
- Wheel Spacers/Adapters Question
- TE37SL 18x10.5 +22
- Need some help on fitment
- Just removed my Eibach ProKit
- Ohlins DFV
- xxr 521
- Some dumb questions
- Coilover recommendation
- knowledgeable feedback about bump stops
- Pirelli P-zero vs. Yokohama Advan
- Whiteline Endlinks
- Difficulty Braking Hard (Hawks Street)
- Fitment help
- Coilover: KSport vs ........... ?
- BFGoodrich g-Force Rival Official Review
- Lowering springs
- Which rear camber bolts?
- screwed up my tire, what to do?
- wheel fitment and offset question
- Effed my tire, what to do?
- Best Dual Purpose Street Track Pad for the rear with ST43 in the front?
- Kratos wheel/suspension specs
- 2nd set of TPMS
- Declassified Tire Testing Trip. The New BFGoodrich g-Force Rival
- Brakes//Could some help here//Paranoid
- Evo hit curb :...( Help pls
- Rebound/Compression Ratio Calculations
- OE swaybar dimensions
- DId some suspension upgrades.. question
- Neal out Mon - Wed testing a new top secret extreme performance summer tire
- H & R Camber Bolts in the Top Slot, OEM Eccentric in the Bottom Slot???
- Cost for brake replacement
- Evo X BBS center cap the same size as the GSR X caps?
- KW V3 Spring rates replacement/ Upgrade
- Ohlin coilovers max height guidelines inconsistent
- New Wheels Fitment
- Stockers with 15mm Spacers or XXR 521?
- Gtworx springs and neg camber
- New brembo rotors
- How to adjust height of the front coilover ohlin
- Best tire for a budget of 200$ a piece?
- Evo X raw data for suspension math
- help front wheels
- long wheel stud install - rear
- Handling issues with new Continental DWSs...
- xxr wheels what hub centric size?
- Continental Extreme Contact DWS (Ultra High Performance All-Season) - Great
- Camber Correction?
- Time for New Tires - From Yokohama OEMs to ?
- spacers questions?
- How to torque rear shock shaft nut
- 265/35/18 Extreme Summer Tires
- how long to settle
- 245/50/18 winter tires
- XXR Wheel Questions
- Turning from straight to lock
- Opinions on RE-760 sport will it fit?
- Will i need coilovers for wedsports tc105n
- Best price for Continental ExtremeContact DWS
- Aftermarket Lugs and Spare
- Fortune Auto 500 Coilovers - Concerns & Technical Discussion
- Whiteline sway bars setup
- New tires and now rubbing?
- After market brake pads choice?
- new coilovers... clunks in rear after a thousand miles or so?
- Rota Torque question
- H&R Coilover
- Clunk with inital movement
- Drive shaft measurements
- Alignment Question
- Sliding in wet with Yokohama IG20 winters
- Are stock GSR struts "good enough"?
- Swift to eibach springs.. Few questions..
- Kumho tire specials
- Ferodo DS2500 = I'm in love!
- Advice Needed 18x9.5 or 18x10.5
- NT03 on my 2012 Evo X?
- Photos of an Evo X with Wedssport TC105Ns in 18x9.5 +35?
- Speed Bleeder Gone Wrong
- If You Have GTWORX Springs: How's the Ride Height?
- Cant decide...
- XXR Flush fitment
- Evo X GSR - 18" vs. 19" in handling and performance
- duralast cmax pads
- Newbie in Suspension need some insight.
- Winter Project
- Curbed my enkei SBC Rpf1s
- Anyone got photos of a WW Evo X with Gram Lights 57DR 18x9.5 +22s?
- swift spec R spring help
- It's time to change tires
- [Evo X] 19" best tire size???
- Do AME TM02 18x9 +15 clear our Brembos?
- Neal out till Nov 26th
- Anyone running Progress springs with 18x9.5 +20 wheels? Any rubbing?
- Tirerack shipped me a 5 year old tire :(
- Work XT7 18x9.5 weight?
- Pic request: Enkei Raijin on stock suspension
- Umbrella VRH
- Rota Grid Clones?
- BRAKE SYSTEM SERVICE REQUIRED light.
- Winter Tire Fit 245/45/18??
- WORK XD9 offset?
- Fotune Auto 500 coilovers.. Creaking sound, ALREADY?!?
- Winter tires - Michelin Alpin PA4
- All Season Tire and a H speed rating.
- Quick question regarding coilover preload
- It's snowing and I'm running stock Advans...
- Tire reviews: Post your data
- Stock MR Critical Damping?
- New sneak peak OZ for 2013
- Stock Advan blew out this morning...
- Quick review: Fortune Auto 500 coilovers
- KW v3 Adjusting rear rebound?
- Widest Tire Size for Stock BBS Wheels?
- Megan racing lowering springs..
- AP Racing Fake?
- Help for lowering springs
- Help installing Cusco rear underbody brace
- Front sway bar broken
- Question on sliding
- Clunk Help Left back shocker
- Apexi S1 coilover question
- How to spot fake Rays lug nuts
- New rims rubbing
- Stock EvoX higher in front?
- Will I need alignment?
- HELP!advan rgd 19x10+30
- Pilot sport plus A/s or Conti DWS extreme
- Has anyone experienced this? rear sway bar link bracket
- Rear Endlink's incompatible with Tein Flex?
- Has anyone changed out of Eibach Pro-Kit to any other spring?
- Which Alignment Specs for heavier steering feel?
- Info on stock suspension components, future upgrade path
- Xxr 521
- Question on wheel fitment
- Rally Armor Mud Flaps Now At Tire Rack
- Evo X Brembo brakes are obnoxiously loud at squeaking!
- Wheel Spacers with Rota Grids?
- possible alignment issue?
- 205/60/16 rubbing
- Tire won't hold air after spin off
- Question About Rays Wheels!
- wheel noob need help
- KW V3 installed - Caster Off
- Brake swap complete.
- new Ultra Deep Concave WORK Emotion Kiwami - 18x10.5 Spec
- Spring Help?
