- snow tires?
- Wheel spacers **le merged**
- My new tires (bwahahaha)
- composite lug nuts?
- Rim hole size for valve stems
- Evo 9 vs. Evo 10 struts/shocks
- KW clubsport settings for Exo X
- If you don't live in Florida
- Blizzak WS60s
- Hmm which tires? Too many too choose from bah
- hankook ventus v12 evo on snow??
- Wicked brake squeel
- weight - wheels
- Win a Sony Playstation 3 (PS3) or Gran Turismo 5
- Michelin Pilot Sport A/S
- Question about braking differneces
- TPMS Help
- Tire Chains?
- Largest wheel spacer for evo x
- KW ver 3 what top mounts
- Falken Tire liquidation sale...
- Cracks on stock Yokohama Advan tires
- Looking for right suspension
- Roll center kit alternatives
- Sears black friday goodyear vs conti dws
- 2010 lancer ralliart rims on evo x
- can i get girodisc front rotors and keep my oem rears?
- Best places to buy VOLK TE37
- Can 17's fit on the X?
- Front Camber Plates
- Prefilled nitrogen tank
- Evo X RS brakes vs. Evo X brakes vs. lancer GTS brakes ??
- Would the stock tires work on these rims?
- installed coilovers help!
- Torque Specification for Front and Rear Brembo Calipers '06 EVO IX?
- will these fit (looked over stickies, don't understand them)
- 235 vs 245 snow tire
- Cusco Braces
- Eibach Sportlines
- stock 2010 camber/caster non adjustable?
- Eibach Multi Pro R1/R2 write-up + inside look at manufacturing process
- Question: Putting new tires on my Evo X stock rims, need advice on spacers. Thanx
- TPMS warning, cold weather.
- HELP!: wow sears....
- tanabe df210 lower spring
- Question. 2008 Evo X Mr stock comes with wheel spacer?
- Control arm bushings
- Spring brand based on color help
- tire loses traction in rain!!...need help
- Hankook V12's vs. other "summer tires"
- Got Conti DWS' mounted today... impressions...
- GSR vs MR suspension Top Hat
- To Rota or not to Rota..
- looking for coilovers
- Nitto Tire on Facebook, LIKE to win tires
- Evo X with conservative drop and wheels, need advice
- Preferred Lugnuts?
- Who's Rockin DPE, iForged, etc??
- What rim and winter tire combo do you use?
- Replacing the wheel bearing
- Yellow Speed?
- Anyone here running the Rota G-Force Rims?
- JIC-TAR 11/14k = saweet !
- Has this ever happen to your Brembos ?
- Best Paint for TPMS?
- Can you identify these Evo X rally brakes?
- screw in tire
- Blizzack ws60 vs ws70
- Performance Friction Rotors please help
- Pressure crack? Attempted tire slash? What does this look like?
- Swapping out summer tires...
- Continental ExtremeContact DWS - 245/40R18 93Y BSW
- Need some help with Winter Tires please.
- How Often For Alignment?
- down to these two tire choices, help me decide
- Drivers Side Clunk, Knock, Pop or noise from front
- Coilover help
- Cosworth Streetmaster Brake Pads (Any reviews)
- swaybars- links etc
- Ceramic pads for Slotted/Dimpled Rotors?
- Wheels curbed
- Boiled the brake fluid!
- Toyo Poxes R1R 245/40/18 93W
- Lightest 18 9.5 wheel thread
- weird tire problem, please help
- Need Front and Rear stock tophat images from Evo X MR
- 25mm rear sway bar and wider tires question
- After Install Brake pad Question??
- rotors and pad question
- tanabe sustec spring for evo x
- Bad wheel bearing
- H&R Coilover Review
- bent coilover?
- AST4100 or Muellerized JIC??
- Wheel Spacers and track/auto-x racing, safe?
- MR BBS lugs...
- Whiteline Roll Center Kit
- How or Where to Remove stock wheel weights w/o Damage?
- Pirelli PZERO NERO all season???
- Zeal Coilovers?
- Flat tire - question on replacement
- Best winter setup?
- quality of the Wedsport wheels?
- Pic request blue rims on black evo
- Racing Brake or Ferodo??
- Would anyone be interested in Bailout Rotors or the X
- Stock TPMS on Type C
- Need caster plates for my KWv3 Coilovers... ideas?
- Eibach pro kit question
- Ugh Worst luck ever!
- Coilover Help
- wheel fitment question
- Brakes little spongy..
- Little help
- Endura tech shock dyno
- Savini Mono Forged wheels
- Girodisc is now has Direct fit EVO X Magic Pads!
- Stock suspension pics
- Need Help with Tires?
- What is the best winter tires for an evo x?
- Rear Brake Pads... Is this possible?
- Ohlins Road & Track stock spring rate?
- Question regarding Volk TE37 and Offset
- Braking issues- road course use
- AST 4100 quick review
- Centric Drilled and Slotted Rotor review
- Noob, Spring Question
- Anyone running H&R Springs on their X MR?? Will it fit GSR and MR?
- will 19x9 +25, 265/30/19s RUB????????
- tire recommendation please
- Are stock tires a sell-able item?
- I got Muellerized!!!
- stock X suspension on an 8/9?
- 18x10.5 +22 fitment with mild drop , what do you think ?
- how long our stock Yokohama Advan tires last?
- Height Opinion! Go lower?
- Winter Rims/Tires help??
- review/info request: muller evo x lowering springs
- Hub Assy
- Brake and Wheel problem. Anyone Else?
- Swift spec r vs tein ssp
- BBS wheels on EVO X GSR?
- Can sitting fluid absorb moisture?
- Nitto NT-05 or Kumho XS for sheer grip?
- stupid tpms thingers
- Stock tires on 18 x 10.5 +15?
- Swift Spec R - 2008 EVO X
- Stock rubber on 9.5" rim
- Your opinion needed...Thank You!
- 2010 Evo X + Swift Spec R = WIN!
- TE37 18X9.5 +22 fitment question with 275s Hoosier R6??
- Swift Spec R springs Reviewed!
- ARC Aluminum Strut Bar
- Finally lowered my X
- New MR-T Steering wheel vibration and wheel balance question
- SSR Type F - Custom Painted Gunmetal :)
- Rota DPTs or Grids?
- coilover damper settings, what you runnin
- New Subaru Rota but want to spark some Evo X interest
- Greddy GREX 6-pot brakes from Evo IX -> Evo X
- Swift Spec-R for the X is in finally???
- 19 inch wheels suitable for track?
- SSR Tire Specifications
- Odd Suspension Combo
- Work XT7, 18 x 9.5 +20 w/ 265-35-18.... will it blend?
- how do you remove e-brake assembly at rear hub?
- Knock coming from suspension?
- eshop
- Lookin for some AME TM02
- enkei rpf1 sbc
- powder coated stock wheels
- tire wear bad on fronts!
- replacing pad question..
- Lowering Springs Installed
- Continental DWS?
- Car pulls left AFTER inflating
- Missing Wheel Weight
- Review and pics of H&R coilovers for Evo X
- Seriously, how hard is it to center the steering wheel on an alignment rack?!
- Anyone heard of TR Motorsports
- brake pads for nearly street-only DD
- WEDSSPORT 19x10.5 +24mm BBM (For EVO X) Pics **
- Do you guys resurface rotors when changing pads?
- coilover poppy sound!
- Brake noise common on evo x?
- Very weird/uneasy feeling during hard cornering after coilover install
- Racing Brake ET300 or ET500?
- Jay Leno talks about Tire Chamber wear on Evo X
- WEDSSPORT TC105N 18x10.5 +12mm RR Face - 17.6 Lbs
- Swift spring & Whiteline F&R sways + RCK
- Golden's new Rota Torques
- SA-55 owners please sign up and report your complains here.
- Affordable Coilover Long Term Reports Please
- Odd Sound - please help identify it
- Silicone Bead on Rolled Fenders???
- APP (Aviation Performance Products)
- SWIFT Sway bars
- Tire Pressure: Continental DWS 265
- Fortune Auto or BC Coilovers?
- The official EvoX Wide Tire Thread
- Neova 255/30/19 91Y OK to run on an X?
- Looking for a pic of the Konig Illusions on an X
- Aftermarket Wheels
- BBS MR wheels on a GSR? Spacers needed?
- Rear Sway Bar after install?
- Tire pressure montioring system
- RPF1's 19x10 +22 vs 18x10.5 +15
- Volk Racing TE37 Super Laps
- Wheel Speed Sensors
- TF- 360 degree view of TE37SL & RZ-DF
- Broke a stud
- 19 x 9.5 +22 & 265/30.. require fender roll?
- Tire Size For 18x9 +20 SA-55M
- 18x10.5 nt03-m et30 ?exactly what size spacers needed for front caliper clearance?
- Hankook v12s
- Wheels for Rotor Glow, need suggestions...
- Is Fully Repainting Damaged Wheels Acceptable?
- Last set of F-zero blue TE37
- Winter Tires?
- pros & cons of wheel spacer?
- Front Swaybar Only?
- evo X brake options
- Cusco Zero 3S or KW Variant 3
- StopTech Street Performance Brake Pads - Thoughts?
- Megan Racing Lowering springs?
- anyone bought powder coated stock wheels from South Coash Mitsu?
- GTWORX EVO X Tarmac Springs and GTWORX Rear Swaybar (GTWORX EVO X Tarmac Package)
- Bilstein W/ Lowering springs
- All Year Suspension Help?!!???!!
- Clarification please: Where is it safe to use anti-seize on new pads?
- Rotors Stuck !!!!!!
- brake cooling question...
- Wheel Lock specs for GSR
- Rotation of strut bolt
- HKS Hipermax III Helper Springs?
- Robispec
- TSW Wheels - anyone running them?
- Carbon Fiber Wheels?
- Question for ADVAN RZ-DF
- swift -SPEC R
- Ohlin DFV's Pics/Review/Thread/Discussion
- SA55M - Thin Paint?
- Coilovers for a better DD?
- Kumho Ecsta XS - Chunking in the middle... discussion
- My Impressions of Girodisc Magic Pads
- Tire vendors?
- setup
- Wheel offset/fitment Question 18x10 +22
- Coilovers - too rough for daily driver?
