PDA
View Full Version : Evo X Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. Coilovers w/ Independent Rebound & Compressions Adjustments w/o Remote Reservoirs
  2. What is the best drift tire model please help me
  3. Looking to get a new set of 275 tires and wide wheels for DD/Track
  4. Volk RE30s rubbing against wheel wells
  5. New wheels help
  6. evo x spacers?
  7. How big of wheels?
  8. Any X's on Cosmis XT-206R ??
  9. Sway bar for rally
  10. Alignment after H&R Spring install?
  11. Enkei PF01 Evo
  12. FA 500 Coilovers: Standard vs Swift Springs?
  13. using a 1"1/4 spacer/adapter with a 18x9.5 wheel and 35 offset
  14. Question On Fitment 18x9.5 +12
  15. Work emotion cr kiwami (ultimate)
  16. Tread depth of new Advan A13C (oem rubber for X)
  17. ARK GT-F Spring Opinions?
  18. evo x brembo 6 piston monoblock caliper upgrade brackets
  19. Anyone know what these wheels are help !
  20. Car Pulling, tires cupping...?
  21. Will Muteki Fit
  22. 265/35/18 on Grids 18x9.5+20 concern.
  23. Good midrange coilovers for DD?
  24. lug nuts for track
  25. Staggered
  26. white or gold powdercoat for cosmic blue
  27. 275/35 or 265/35 ?
  28. spacrs on stock susp.
  29. Brake pads
  30. What 9.5 fits without rolling fenders?
  31. Want to buy Ce28n for my Evo X... 18x9.5 +15 or 18x10.5 +18?
  32. AMR Engineering
  33. Best tire for New Wheel ?
  34. My tire got screwed
  35. Option lab rims. Any experience?
  36. weird noise when turning...
  37. Help!
  38. What do you suggest?
  39. Darn curbs
  40. Evo X MR just started randomly pulling to the left and right
  41. Perfect paint match on Evo X silver wheels! FYI
  42. Whiteline RCK and Swift Spec R
  43. Bilstein PSS10
  44. TE37 tire size
  45. Stock EVO MR Advan A13c tire wear
  46. biggest wheel to fit stock tire?
  47. The perfect wheel / tire combo?
  48. Neal Out Until Dec 27th
  49. Bc br swift upgrade?
  50. New tires too tall?
  51. 1-Piece rotor for MR on street?
  52. New rotors?
  53. Factory alignment problem
  54. Effects of Upgrading Control Arms
  55. Bosch brakes
  56. Will these lugs work with OEM wheels and extended studs?
  57. Evo x slicks all four or just the front?
  58. Neal Out Until Dec 2nd
  59. Work VS-XX Fitment questions
  60. New lowering springs or Used coilovers
  61. Anyone have the rota mxr?
  62. Brakes squealing really loud
  63. whiteline front control arm bushing worth it?
  64. Blizzaks smell
  65. Anyone know what kind wheels these are?
  66. KW Variant 3
  67. Am I missing pins from my front hubs?
  68. Whose running Varrstoen ES1's?
  69. Spotting Fake Brembos
  70. HELP! Lots of questions about wheels
  71. Site Article: Ohlins R&T setup by CBRD Speedfactory
  72. Brake Fluid Flush Interval
  73. Toyo or Nitto
  74. Spare tire on front wheel
  75. R1 Concepts Rotors...whos running a custom set? Post your rotor pics!!
  76. Conversion kit question
  77. Brakes & Rotors
  78. centric premium rotor
  79. Lowest drop springs
  80. hub centric rings rays gram lights 57dr
  81. can't decide on what size wheel
  82. Winter Tire and Wheel Reminder
  83. Even though Advan says they can, the stock tires don't fit on a 9.5" rim. LOL inside
  84. Best drop/handling spring?
  85. Spring rate help
  86. What tires should i get for RPF1s
  87. Perrin Endlinks
  88. Which tires and can I run a 275?
  89. aftermarket wheels
  90. Will NT03 18x9.5 +40 fit on an 08 Evo X
  91. evo x mr brake question
  92. Touch up paint for the brembos
  93. damaged two of my wheels--options?
  94. What is the widest tire that would fit on stock rims?
  95. Changing Brake Pads
  96. MY JRZ RS1's
  97. Which one should i go with ?!?!
  98. 3rd Gen run-flats?
  99. 335
  100. Using Reman Autozone / Pep Boys Calipers?
  101. Tips to stop snapping brake bleeder valves / stripping bleeder valve threads
  102. Dummy Question about Lug Nuts
  103. Opinions on good winter tires?
  104. Stripped Bleeder Valve Threads, Where to buy a replacement?
  105. Cobb lowering springs Vs. Megan Racing
  106. Winter Tires
  107. MR Brake Rotor and Pad replacements
  108. Bolt sheared off of Front Floor Brace/Cross member
  109. Will Lancer GTS wheels fit?
  110. Feedback needed...Whiteline RCK kit worth it?
  111. Squeaking brakes
  112. Installed coilovers. Need to sched an alignment... Questions first.
  113. Best lowering springs
  114. Wheel/Tire issues
  115. What wheels are these?
  116. This doesn't look (or feel) right!
  117. evo x coilovers questions
  118. pro-kit install prices?!
  119. Best coilovers for $1500ish
  120. When to Replace Rotors
  121. Hankook V12 245/40/18 on Enkei RPF1
  122. Camber plates maxed out, still have excess camber?
  123. Conti 265/35 DWS on OEM Enkei
  124. Yet Another Brake Pad ?
  125. Coilover Question....
  126. Should the car get lowered different heights or same all around?
  127. slight squeek
  128. Suspension ramblings from an idiot
  129. Tire Fitment for 285/35 on te37sl 18x10.5 +22
  130. Some real racing suspension :)
  131. Wheel speed sensor snapped off
  132. List of all rims
  133. Cross-brand comparison chart for racing brake pads
  134. Tire, Rim, Suspension choices...
  135. bad clunking over bumps
  136. Where to buy factory parts
  137. Vibration from left side of car after off track excursion
  138. Boss 302R wheels
  139. Wheel fitment question
  140. Prematurely worn Rotors on stock brakes
  141. Hose Size for Brake Bleeder Nipples
  142. Street / Track Cars: How often do you bleed and / or flush brake fluid?
  143. Eibach Sportline for Evo X
  144. New to the forum and looking for some help on installing lowering springs!
  145. Goodbye blue brake fluid
  146. AST 4100 vs HKS Hipermax III (nonsport) vs KW v3 vs Robispec KW Streets
  147. Anyone have 19x9.5 +28 pics?
  148. Forgestar super deep concave
  149. Brake Smell and Wheel Wobble
  150. help diagnose my wobble in front passenger side!!
  151. Compare my current brake pad set with one I'm thinking of replacing it with
  152. Rotora super challenge brake system 6pot brake pads replacement
  153. CZ4A chassis weak points discussion and understanding AMS shop Evo's chassis upgrades
  154. How is this done??
  155. Alignment for new springs?
  156. Recommeded offset and tire size for 18x9.5 rims
  157. Looking for replacement for brake caliper tube thingys
  158. weird noises from front left suspension
  159. New Michelin Pilot Sport A/S 3
  160. HELP!! Does anybody know what or where this sound is coming from?
  161. Need help chosing a proper coilover setup.
  162. Blew a tire today
  163. H&R or Stance Go Pro?
  164. Hours away from buying my rims
  165. 18x9 Advan RG2 Best Tire Size?
  166. Looking for drilled/slotted rotors that fit OEM brembo brakes on the 08 GSR
  167. What is the smallest wheel to clear Brembo GT BBK?
  168. Tein coilover super street help!!!
  169. How long did your DD brake rotors last?
  170. How long on stock axles?
  171. Stock enkies vs rpf1?
  172. Rear arms really needed?
  173. best wheels to sit flush?
  174. fancy hand-brake shoes
  175. MRR NEW "GROUND FORCE" concave wheel what do you guys think?
  176. Are Konig torch good?
  177. coilover question?
  178. Any one have the Gram Lights 57C6?
  179. Anybody use Prospeed RS683 brake fluid?
  180. Camber kit for aftermarket springs?
  181. Neal out until July 8th
  182. SS brake line recomendations for use in winter
  183. Beefier tires on gsr wheels?
  184. Fortune Auto 500 - Spring Rate Selection
  185. Eibach or swift sport springs
  186. Stock Rear Camber Adjustment Range
  187. a bunch of brake related issues
  188. need advice on coilovers
  189. BBM Rims on the 2012 GSR
  190. KW V3s, share your setup and experience with them.
  191. What goes *clang*?
  192. painted original gsr rims
  193. DD and Track day help
  194. What tires to get so I don't have to roll my fenders.
  195. Recommended alignment spec - 18x9.5 +15 RPF1 & 265/35/18 PSS
  196. Help Me Pick a Wheel for my WW EVO
  197. Latest GRM mag....Evo X set up tips for newbs or low buck racers..
  198. Tire Question. Different tread pattern rating (180vs 160). same treat depth.
  199. Whiteline Rear Endlink Issues
  200. Michelin pss first impressions
  201. JRZ RS1 on a budget
  202. Camber Plates Required for Lowering Springs Only
  203. Complete Brake Failure?!
  204. Help: Fortune Auto 500
  205. ENKEI WHEELS 17" 5X114.3 EVO8 would fit in a 2008 Lancer
  206. Daily driver wheel and rubber upgrade
  207. Rookie question about new wheels and camber
  208. Wheel question
  209. Braking at high speeds, whats the deal?
  210. yet another mystery sound - knocking when car is warm and moving slowly
  211. DW's or RE760
  212. Rbf600
  213. Lots of rust on wheel hub?
  214. Wheel fitment question
  215. I have no TPMS light but no TPMS sensors?!?!
  216. Just track/road tested Dunlop ZII's, BFG Rivals,
  217. R888 width
  218. rotors and pads
  219. The New Volk Racing CE28RT
  220. Varrstoen ES1 Wheels?
  221. Tire Damaged - Hit a Curb
  222. Tires similar in price as Hankook V12's
  223. Where can I get Front LCA?
  224. Ohlins DFV vs Tein Super Racing
  225. Front control arm bushing question
  226. Spacer and Spring Question!
  227. offset and wheel help needed
  228. Alignment after spacers ?
  229. Requirements to fit 285/35/18 all round
  230. Neal out till June 3rd
  231. Ticking From Front Brake Calipers
  232. Camber bolt Question!
  233. Front brake caliper bolt parameters?
  234. Need help removing stripped nut on strut bar
  235. stupid question alert! but i need a straight forward answer.
  236. looking at getting aftermarket wheels but cant decide on tire size...
  237. Need more low - coilovers or springs?
  238. rotor for DD
  239. Not your ordinary brake squeal
  240. What size PSS on Wedssport SA55M 18x9+20 ?
  241. Spring Spacers
  242. Alignment Issue - Feedback?
  243. brake problem after coilover install
  244. Slight Wobble Over Bumps, Please Help!!!
  245. Quick question (rear camber bolt)
  246. EVO X + OZ Ultraleggera HTL - What Lugs?
  247. GTWORX and WhiteLine Install
  248. KW V3 Front Coilover Speed Bracket Help
  249. stock strut mount arrow position
  250. Different end-links for rear and front
