View Full Version : Cobb AccessPORT
- AP on Europe models?
- Cobb e85
- AccessPORT and AccessTUNER Updates for Mitsubishi EVO X and Ralliart
- 2008 GSR. 91 Octane K/N Filter Stage 1 or 2?
- factory warranty 08
- First COBB AP logs
- 2011 GSR stage 2 21 boost...
- Data Log wiki or tutorial
- why am i picking up so much knock?
- check my data logs
- New to all of this, could someone look at my logs and explain any bad values to me.
- Cobb AP Change Shift Times in SST?
- Cobb ap stg 2, 91oc / restrictor pill pics
- What is the point of the boost pill?
- 2011 GSR Cobb Stage 2 Map Log
- Cobb AP considered "tuning"
- AP,ETS Intake and ETS test pipe
- Cobb AP for Heavy Modding?
- Can someone take a look at this log?
- Off the Shelf Maps From Websites
- How Does the Yaw Control React after Tune?
- 2011 GSR, Cobb AP and ETS intake
- 2012 Support?
- Custom AP maps for 2011
- Spectre intake?
- Cobb Accessport Newbie Questions
- Test pipe, air intake & AP
- Stage 1 ACN Data Logs.
- PLEASE HELP! WOT Jerk/Bump As Approaching Redline in 3rd
- Anyone actually denied warranty after unmarrying?
- Trying to work out this plan relating to exhaust and cobb, need to know...
- Cobb AP on Stock vehicle
- First time Data Logs.
- Initial experience
- Mod23 with Android Torque
- New to accessport
- Boost spike after shift
- Anybody had this problem??
- How to tune with access tuner
- Engine Overspeed
- Is there anything like Cobb AP for export model X ?
- My Cobb AP - stage 1 stock intake LWG. AccessTuner turned off my p0037 rear o2 cel.
- Should i trust the AccessPort?
- Question for AP owners
- 2012 evo x accessport
- Good Map for this setup?
- Can Cobb AP Access Tuner clear CEL p0037 on stage 1?
- AP not reading some DTCs?
- Cobb Logging Parameters/Values - what is safe/acceptable for each values - Draft 1.
- What stage to flash
- AP Dyno function
- new to the cobb ap
- Different years and trim
- Economy Mode for Cobb AP
- Can't find Knock Retard
- Stage 2 Map location?
- Ets intake scaling 2011
- Which map to use?
- Cobb AP tune question
- Access Tuner Race Program
- Tephra mod X
- Grimmspeed problems! Help please!!
- Is it time for stage 2 map???
- Boost pressure on psi?
- 2012 mr
- Re-installing AP after dealer reflash for recalls
- ATR - editing map - WTF???
- Adjusting resolution of ATR: How do I do it?
- Tune question
- Map for 2011 Evo X MR Stage 2
- Map for Evo X MR Stage 2
- knock retard help???
- 2011 GSR hitting fuel cut: WTF?
- First log on the X.
- skeptical about AP
- MR tranny not shifting right after install
- My 1st time using ATR: looking for guidance please
- AP Datalog shows more than 100% Injector Duty Cycle; should I be concerned?
- AP for sale
- Looking on some detailed write up's on how to use Access tuner race.
- AEM inline UEGO controller...fits of rage, frustrations, headaches...
- Identify different version of AP
- Need a OBD 2 Connector For The Cobb Accessport
- Cobb AP 93 Oct Stage 2 on Stock
- valet and anti theft 2011
- Help with AP Datalog
- 2010 AP to 2008 GSR?
- Is this typical behavior for the stage 1 tune?
- Running rich on Stage 2 OTS AMS 93 Oct
- 2.8 knock w/ stage2 AEM intake ots map
- How critical is logging in 4th gear?
- 2011 EVO X AccessPORT Off-The-Shelf Map Survey
- Please Help Me: AP Logs and ?'s
- AP out of Box DOA, but there is a silver lining
- Boost control limits of AP
- 2011 STAGE 1 (MR) and STAGE 2 (all) ALPHA INJEN INTAKE MAPS
- Cobb AP with AEM Tru-Boost
- **Cobb AP + SST** S-Sport mode selection
- Does AP leave a trace?
- COBB and Tephra
- AP load timing (load)
- Ecuflash to Cobb ap
- Cobb Access Port, AGP Intake
- Quick Cobb AP questions
- Think AP bricked 2008 GSR. Need help!
- Harmon Motive Intake and Cobb AP questoin
- question about cobb AP
- Cobb OTS maps - running rich
- AccessPORT Beta Support for 2011 EVO X/Ralliart and Faster Data Logging!
- cobb ap and grimmsped ebcs question
- Closed Loop Fueling Target HELP AccessTuner Race
- cobb tuning accessPORT question
- Cobb AP plus ETS intake?
- Cobb AP PSI
- Cobb AP for 2011 Evo X?
- Is it worth it? Buying used cobb accessport
- Cobb AP vs. Vishnu flash for MR
- Cobb Accessport Problem
- Cobb AP: ?s on product, features, and various maps incl Perrin maps go here [merge]
