View Full Version : Cobb AccessPORT
- Looking for Stage2+ SF tune
- Evo X Recommended AP Gauges
- 2008 Cobb Stage 2 Maps
- “Green” Speed?? Any workaround for etuners?
- Anyone have the Cobb Stage 2+ LWG maps for a 2008 MR?
- Custom Map interchangeability between years
- Somewhat new owner
- Teach in - Accessport and Tactrix
- COBB Accesport maps for Anti-Theft and Valet for EDM EVO X GSR
- Trouble reading codes with the AP
- Cobb AP V3 Remote tuning
- My AZ Emissions Experience. ECU Tampering?!
- P0137 Rear O2 Bizarre Behavior
- AccessPORT Stage 1?
- Stage 3 ready?
- AMS Intake with Cobb AP
- Cobb AP Target Vs Real Value - Intake and Exhaust Cam URGENT PROBLEM
- question
- COBB Accesstuner Race Software
- Cobb AP stage 2 with Injen Intake
- Cobb V3 Lost
- need a tune with my modds with a cobb ap
- Uninstalling AP with tune
- Can accessport be tuned for map tuning?
- Cobb AccessPort Status
- Connected AEM wideband to Rear 02 sensor
- advise about AEM Wideband and Etune
- Anyone have Stage 2 93 + AMS Intake Scaling
- MAP Scaling Template
- 2011 log check for newbie to cobb
- Cobb OTS Map Question
- Ams stx300 (cobb ap v3)
- 2015 Final Edition Log Check
- Cobb AP Map Question
- cobb vs gst
- Cobb AP V2
- 2010 EVO MR Datalog
- Evo X Stage 4 Power Package and OTS Maps
- AccessTuner Race Software Evo X 2008 ?
- Log for 2014 GSR USDM
- Got cobb ap3 no access to atr any otc maps have rear o2 turned off???
- CobbAP Stage 3 not hitting target
- Stage 2 ACN91 ETS Intake Recalibration
- Cobb AccessPort EVO X how to Data log for Etunes
- Can the AccessTuner Race tune the new stage0 v403?
- 2009 wm evo x
- AEM Intake 2015 evo x gsr
- 2015 gsr available maps
- Cobb v2 windows 10
- Help with CobbAP
- Stage 1 OTS map with ETS upper intercooler piping?
- accesstuner software needed
- Cobb eco tune
- Tuned on open source but want to installed V3
- Accesstuner Race Updates
- map questions
- Stage 1 performance?
- Cobb accessport vs ams stx300 package
- Purchasing a car with Cobb AP
- Could tuners and ap pros give their opinions on map reading please?
- Stage 3 + 4" Intercooler = Knock
- Cobb has the best Customer Service!!!
- OTS Stage 1 93 LWG getting knock
- OTS Stage 1 Issues
- Cobb Stage 3 boost situation help please....
- Cobb AP V2 compatible with 2015 Evo?
- Stage 3 Cobb package. Do I still need a protune?
- Over Boosting. Please help :(
- Evo X Final Edition : cobb APv3 does NOT work on all models and Cobb is not saying
- cobb ap on Evo FE
- Help out a Newbie - AP v3 with ETS intake & Knock
- 15' GSR Stage 1 93 *Advice*
- Installing Cobb AP V3
- At what gear/RPM should you hit max boost?
- Flex Fuel with COBB Question
- Ots map suggestions
- My cobb ap v3 map help and target boost
- Can't boost above 19PSI - Target boost Pro-tune 27PSI(log attached)
- Just purchased v3 ap few questions help!
- Evo X MR engine tune
- Stock to Cobb stage 3
- SST/AP Question
- ETS Intake & Engine knock
- Cobb AP Stage 2 with ETS Intake and ETS HFC
- ETS intake and ETS Quiet Exhaust with AP V3
- Cobb stage 1 not hitting proper boost help
- Cobb maps
- Tuner
- Cobb help please
- Unresolved questions about AP
- Cobb V2 vs V3 from an experience cobb tuner perspective?
- noob AP stage 1 questions
- Noob Accessport Question
- Stage 3 Pro Tune Problems
- Installed DP and Stage 2 map...Knock concern
- Stage 3 boost issues
- Help: EV0 X issues with V3
- Cobb Stage 1
- First Data Logs (what do u think)
- COB V2 any good?
- 6-7 Knock Count in 5th/WOT: Data logs inside
- Won't connect to ECU
- AP Help As Far As Adjustments
- Cobb Stage 1 CHFF Evo x MR 2015
- Question for Cobb: Cobb Stage3 with stock catback
- AP3 and Boombah Big Bore Throttle Body
- Newbie questions before protune
- running stg 1 93. is a cobb high flow filter worth it?
- EBCS Question
- Need help adjusting fuel trims on ATR
- Question about Cobb Stage 2+ tuning
- AP v3 Beta Firmware 1.7.1.1-9633 release notes?
- Logs are only showing 18lbs of boost but the AP says 26?
- Anyone have experience with Cobb Stage3 roadcourse temperatures?
- Cobb question
- Exhaust alternatives
- Cobb V3 experience so far and some questions
- Help install accessport fail
- Need Help reviewing datalogs...knock and shutter
- accessport v3 evo x mr
- EVO 2014 GRS Tuning COBB AP Issues
- Functionality request
- Noobie questions about OTS maps and current mods.
- Big, public thank you to Cobb!!
- Panel Filter
- Map to flash with bolt-on's
- Repetitive Knock Stage 1 Cobb AP
- Knock sum 17.?!
- Code P1071
- MAF Scaling Utility
- Knock Count, Stock on Stage 1
- Tune going to stage 3 or not?
- 2014 gsr , w/b issues with ap
- K&N Intake with UICP maps ?
- Stage 3 Newbie question
- little help please
- Got check engine light, should I go to stage 2?
- Newbie on stage 2 need help
- Cobb AP issues - Can't Boost/Backfire
- Simple question for intake values.
- Question before purchasing
- Newby wanted info on Maps
- Cobb AP question
- Unmarry accessport without engine?
- SST Gear Rev Match. help please
- 2015 Evo X GSR with Cobb Accessport
- Stage 1 low boost pressure
- Cobb AP different numbers than AEM boost gauge..why?
- Ecu service engine soon codes?
- Is Live Tuning possible?
- ATR shows vacuum/boost -60+60 psi
- innovate lc2 and ap
- Map for 2011 Ralliart with Intake and Exhaust
- Stage 3 installed today. Bypass Valve Flutter
- 2014 X ETS Intake Map?
- Wideband reading with AP
- Need a MAP for my evo X
- Stage 3 map not achieving boost target?
- AP Software
- How to Setup and use Dual Maps?
- 2011 mr stage 1 issues
- High knock sum on stage 3 2014 GSR
- AP V3 Mounting Solutions?
- Cobb stage 2 fine for my mods?
- Ap for my 2014 evo x
- Stage 2 91 Oct
- Should I flash a base map before I go get tuned?
- Which map should I use?
- need some help with knocks.
- E85 OTS MAP for X?
- new to AP on the Evo
- stage 1 questions
- Best MAP to use?
- Need help which map to run.
- AcessPORT v3 and speedo gauge?
- Access Tuner
- Datalog Review: '13 GSR 93 LWG Map, 10 knock count
- Accessport V2 Compatibility Question
- Cobb Stage1+CHFF 93 v403 Map, 2014 GSR Dyno Results
- Analyzing AP Datalog
- LC-1 and Accessport
- Cobb AP V3: STFT, LTFT and AFR's
- AP Stage 1 Overboost ?
- E. 85 tested low @ E 80 not sure what to do?
- Cobb v403 Stage 1 - Rev Hang
- Cobb AP + Cobb SF Intake mapping
- Cobb V3 AP Launc control/FF shifting
- Cobb Stage 3 running lean?
- Need Advice For Tune...
- need a E-tune
- 2011 GSR 92 octane
- 08 GSR Stage 2+ 91oct, 3rd gear log
- Rich AFRs after letting of throttle
- Injector Scaling Questions...
- Accessport, Relays, and Gauges
- Anyone see anything wrong with my log
- Help...
- GSR 2011 COBB Map Choice
- Accessport V3 issue
- map advice 2011 GSR
- Cobb AP alter Evo mpg calculations
- AP V2 Issues after firmware update
- GSR 2014 cobb AP tune
- 26psi on 93oct v403 Stage 3? Not sure if shes runnning right.
- 28.93 PSI For Stage 1 ACN91 ?
- Stage 2 CHFF 93 Log
- Stage 1 with K&N Typhoon safe???
- ETS V2 Quiet specific map?
- Can you remove custom maps from Cobb V3
- stage 1 v3 tune ?
- 2011 v3
- Cobb AP question
- 2014 Cobb MIVEC irregularity
- Stage 1 CHFF 93 Octane Data Log: Please Review!
- cobb evo x stage 1 lwr v403 (boost problem) HELP
- Normal wastegate vs Low wastegate OTS maps
- perplexed by p2253, p0138, u0167
- v403 vs. 1.08 2008 MR?
- Cobb ap when to flash stage 1
- ap tune help
- can't log AFR via ATR(AEM EUGO) help plz!!
- stage 1 lwg 93 k&n '10 se
- cobb stage 2 93+sf lwg map not available anymore?
- Ecu learning
- tuning question
- ap dead
- APV3 and 2008 EVO X JDM issue?
- ECM reflash
- Stage 3 map for panel intake and 3 port
- Help i own a mac mini
- Cobb Accessport Question
- Why only sell a Cobb Stage 3 upgrade on your web site
- Cobb ap v3 compatability question.
- stage 1 or 2?
- Evo X Aftermarket Intake Calibration Guide
- Knock Sum?
- AP V3 Gauge Index/definitions?
- V2 vs. V3
- Intake question for Cobb AP stage 1
- Gifted COBBv3
- 2012 Evo X with ETS Mods what tune?
- '11 MR Stage 1 + SF intake - 1 bad pull (v403 ACN91)
- Why was the wideband logging feature removed?!?!
- MPG with basic bolt ons boost pill removed and AP "protune"
- Stage 1 wtih K&N drop in filter
- access tuner
- How come my logs have different values?
- Feels like I'm going in circles scaling my MAF and MAP :(
- High Knock Count in Low Load
