- Help! COBB Stage 2 93 v403 (pulls attached)
- Download old maps
- URGENT tuning help!
- EVOX COBB drag times
- COBB v403 Maps for 2008-2010 Evo X GSR and MR
- stage 2 map
- Cobb Accessport "not installed on this vehicle" After firmware update???
- A few tools I made to assist with tuning EvoX using COBB AccessTunerRace
- Cobb Stage 2 with AZ Emissions?
- Cobb AP Stage 1 Question
- Best way to resolve boost spike at 3000-4000 rpm?
- Stage 3 evox gsr 2008 ????
- Cobb Stage 3 v4.01
- Wastegate opening prematurely?
- E Tune by Adam Wade aka Beeble Tooning
- Restore stock ROM from ecuflash
- COBB v402 OTS Maps for 2011-2014 Evo X GSR and MR
- AMS ECU Flash
- Cobb and Protune after, Why?
- MAP Scaling Questions...
- Anyone have a 2013-2014 with AMS Intake and exhaust?
- tuning map tables
- Timing Question
- Dyno Function
- Going for a pro tune…. what else should I get before going?
- Monitors and Data Logging
- Knock at low RPM
- Need Help with COBB AP Map
- version 2 monitors
- Failure to go into 1st - 2012 MR TC SST - Cobb AP Stage 1 93 - Stop and Go Traffic
- stage 3 review/feedback
- perrin map for MR
- What Happened To Stage 1+?
- Stage 2 AMS. Loss of power?
- Custom tune tomorrow. Boost pill removal?
- Cobb stage 3 possible with this setup?
- 2012 Evolution X GSR - stage 1 tune boost question.
- Cobb Accessport needed after a custom tune?
- First tune help
- V2 vs V3
- Cobb A/P
- How accurate is boost logging with Cobb?
- COBB stage 1 vs Perrin stage 1
- Reinstall Boost Pill
- CEL P0068 in Cobb Stage 1???
- COBB AP Stage 1 First Impressions
- TPMS support
- Some accesstuner questions
- Baro pressure?
- New AccessPort v3
- access port freezing
- Cobb v201 maps.
- noob question - what is knock/knock sum?
- cobb forum closed for good..??
- 2013 GSR Cobb Stage 3
- Stage 2 +SF 93 LWG v400
- Where is my CEL?
- knock 6?
- Cobb Map question
- COBB Mitsubishi Release - June 2013
- 13 GSR on AP
- Cobb AP holder options
- Maps for 2010 MR- EDM - Europe version ? help pleas..
- Final beta tweaking?
- 2012 X with AP and K&N
- knock after WOT
- AP Loads Map. Cant data log.
- Firmware update issues
- Cobb AP AccessTunerRace and AEM UNGO Wideband
- MPG After Cobb mods
- Cobb accessport version?
- Cobb AP question
- Best tune to use with AGP intake
- 2011 x failed emissions
- 2013 evo gsr map selection?
- Letting off throttle make engine buck.
- new AP user, few issues/questions
- My cobb experience
- Accelerator position to 100%???
- Boost Discrepancy
- OTS map with Injen intake
- Sf intake vs custom with coob app
- Disable rear O2 changes idle/cruise A/F ratio?
- Monitoring function Not working
- OTS maps V400 vs. V108
- Cobb and Canada
- Cobb stage 2 and boost restrictor pill????
- efr 7670 cant hold boost above 7k??
- SST Tables Modified Through AP?
- COBB Releases Accesstuner support for 2013 Evo X MR and GSR!
- With Cobb AP sf intake vs stock evo
- Buying COBB ACCESSPORT for 2012 GSR - QUESTIONS
- Cobb AccessTuner Race limitations?
- 3 port install directions say not to trust ofs maps
- Cobb AP. ECU re-flash (best Power gains)
- AP Stage 1 or 2???
- Knock problem help COBB!
- Access Tuner Race 2012 for a 2013?
- New heat shield for cobb sf intake!!!
- accessport lost connection during uninstall
- Severely Overboosting!!
- What intake to run with AP?
- 12 psi?!?!
- Log plotter/grapher
- Anyone running the stage 1 91 v400 on K&N drop in
- stage 2 ver 400 underboost?
- Cobb Stage 2 question
- Newbie cobb question
- Dead Cobb AP
- v400 AFR
- V400 idle problems
- Idle question
- 2012 MR stalled after using cobb map
- AP base maps
- How long to wait to data log after flashing ECU
- Innovate LC-1 and AP
- 2012 MR maps
- Cobb With K&N typhoon intake
- Finally did my first Data Log can anyone help boost seems low
- Got knock on my first use/Cobb AP
- Just pulled the trigger on a Cobb AP
- Which map should I run (2010 GSR)
- Overboost?? Stage 2 AEM 93octane
- Got 1 knock count on Cobb Ap
- Cobb AP mode 23 work with evoscan?
- cobb ap unmarry question
- Cobb Accessport progress
- UICP and LICP
- Will Cobb ap wipeout my current tune?
- 2011 Evo X GSR - Beta map
- My own tune, thanks to everyone that helped!
- Which beta tune should I run ?
- HELP!!! Cobb Stage 2 wont BOOST!
- rear 02 delete question
- Cobb AP Stage 2
- question on which map will be best? 2008 evo x
- Cobb beta maps for 2011 gsr work on mr too?
- How much whp should I expect with a ots stage 2 with this mods?
- Possible knock issue on MR with OTS maps
- Mitsubishi Evo X AccessTUNER Gets Massive Beta Updates
- Boost spiking to 26.6 lbs on stage 1 injen 91ACN map
- AP 1.08 issue
- HELP!!! .Dose anybody have any preload AP maps i can use for AGP CAI.
- AP Dyno
- welp can someone help with my high knock lvls...
- AGP cai, what AP map do i use AEM or AMS
- Starting some coding for a program to plot data...
- High rev issue....I don't know what to call it
- Question on Cobb TBE Stage 2 AP 93 MAP
- COBB-AccessPORT-OTS-BETA-Testing-for-the-2008-2012-Evolution-X-MR
- Cobb AP- 2012 Evo MR / what are the other options?
- Anyone know a place in MN for Cobb tuning
- Any one doing their own tuning with cobb?
- Problem with Boost/WG Flutter/ Trans
- Nice combination - COBB intake & AP
- New to Cobb AP and Evo X
- Any OTS Maps Suitable For This Intake?
- First Time Data Log
- cobb tuning - where are you?
- Weird shifting and knock
- AP Data Log
- Just want to make sure... Stage 2 AP question..
- car still feels off? help
- Cobb AP and Injen CAI - keep 2-into-1 hose setup or not?
- ETS intake, piping and fmic
- 2013 gsr Cobb access port
- Evo x World Market Cobb AP
- 2011 Evo X Maps gone!
- Greetings! 2010 Evo X MR checking in with a couple of questions
- mixed feelings about AP
- Comments On This Tune Please
- cobb stage 2 pass new york state inspection?
- Planning on Cobb AP !
- Is stage 2 right for me?
- COBB ATR questions
- here's my mod list. Can i run stage 2?
- I need a place to start looking for more boost..help a brother out
- K&N Typhoon Intake W/ Cobb AccessPort
- 2012 Stage 1 Map boost Higher than Stage 2
- which Map for AMS intake
- Cobb Version 2.0 Maps
- Cobb stage 2 with just test pipe or HFC
- stage 2 feels slower than stage 1
- recommendations on a map?
- Stage 2 93 boost issues
- E-tuners
- Where do people get variations of different maps?
- ETS intake and catback.
- AccessTunerRace question - changing stationary rev limit in a MR
- Few questions about a Stage 1 map
- Grimspeed EBCS + Cobb Stage 2+SF+CBCS 93 v201!
- Help aem intake boosting at 27Psi with aem stage 1 map
- OTS DW800 E85 overboosting/underboost
- Which MAP for ETS Intake?
- Am I heading in the right direction? (MAP question)
- Injector scaling/latency problems.
- Anyone know if they WB LC-1 function is working?
- Stage 1 = worse gas mileage?
- Will the 2011/2012 maps ever be finished?
- 2011 gsr Stage1 91 v201 vs v300?
- Stage 2 AEM 93 Results
- Ots maps for injectors??
- AFR's 08 Evo X Cobb AccessPort Stage 1
- Tephra mods with Cobb Accessport?
- Can't clear P2096 code
- Stage 1 2012 GSR felt slower than stock?
- Used AP?
- Access Tuner and OMNI 4 Bar
- trouble downloading maps
- AP Logging - What to look out for
- Going to Stage 2 - Questions
- Buying a used 2011 COBB AP for a 2012
- Cobb Stage 2 Overboosting
- E-Tune help?
- Problem: v201 stage2 on MR : max boost 20psi
- AP - dual map switching "on the fly"
- Stage 2 Dyno numbers
- Cobb ap idle issues?
- 08 GSR stg 2 93 ocatne 1/4 mile
- Is there a AP Launch control RPM feature for the GSR?
- Datalogging OEM Map?
- Stage2 91 v201
- help!!!!
- Perrin air filter
- Cobb Updates
- Stock Map?
- Stage 1 93 Octane on 2012 GSR
- stage 2 28 psi?
- What does stag1+CBCS means ?
- Injen Crap?
- ETS intake with Cobb
- Bad knock or Normal....
- 0-60 times cobb ap pics thread
- Is it really worth it?
- Put Cat Back on, safe to run Stage 2 map?
- AP or not?
- Cobb tune for 2010 with aem intake
- Cobb AP v200 maps for 2010 MR (USDM)
- Cobb AP OTS Tune reliability concern
- New intercooler with Cobb AP
- 2011 MR AP mod questions
- Is the Dyno accurate at all?
- My Cobb Access Port Experience Stage 1 - 93 Octane (Stock 2011 GSR)
- How is 93 oct with 10% ethonal?
- Cobb AP and Zeitronix ZT3 wb.......
- Stage 2 logs without pill
- Breaking up at high rpms
- Cobb accessport and dw800
- ETS and AP
- stock stage 0 afr at 20.0???
