View Full Version : Lancer General
- Lug Nuts Question
- definition file to tune ecu
- Suggest Decals??
- What is this chrome piece?
- Just Bought My Lancer ES Sport FAST Key Issue
- Service indicator - correct reset? 2012 SE
- Evo MR and Lancer GT
- Do 2010 doors fit the 2009 lancer?
- no spark
- Es front struts to oz front
- lancer seat swaps
- Phone for GPS - Mounting Options?
- Flutter Sound at 3k (possible dumb question)
- Just wanted to say hello.
- Can't figure out what is wrong with 2005 Lancer... HELP!!!
- Fuel Pump Location
- recommendation on top of the line car battery?
- 2008 Mitsubishi Lancer parasitic battery drain
- lancer repair manual
- 03 oz rally cat question
- 1.8 Lancer Transmission Swap
- Mitsubishi lancer 1.8 cvt 2015
- 03 lancer oz rally help
- Anybody interested in these parts?
- Mitsubishi Outlander (Sport?) 2.0 Turbo 4WD
- What is my minimum and maximum offset for 17x7.5 wheels?
- CK4A Suspension advice?
- Where's everyone at??
- 1998 mitsubishi lancer speedo,revcounter,fuel&temp guage not working
- I'm adding all performance parts to the Lancer
- 03 outlander throttle body on 01 mirage
- Trying to get new and wider tires
- Hood
- Hid
- Can a Mitsubishi dealer restore to factory default an ETACS after a bad flash?
- need help rebuilding the front of my 2017 lancer
- Cracks in gas cap causing fumes?
- Why do people keep having to hit my car....Again
- led headlight bulbs
- nav head unit
- Hey everyone im new on this forum and to moding cars
- Random Wiring/Plugs Lancer 2009
- Has anyoneused "Full" Brand filter on their Lancer? Are they good?
- 02 CG vrx suspension replacement
- August 2017 Featured Car of the Month
- New toys (10.2" Android Indash & Paddle Shifters.
- RR wheel locked, need self adjuster for drum brake
- Trouble fitting 4g64 in 06 Lancer
- Lowering my Lancer
- Rear spoiler: 2006 Ralliart on 2011 Lancer SE?
- CVT Fluid Question
- compatible parts
- angel eyes
- Installing OEM Rockford Fostgate system into a lancer that didnt came with it
- New member with a new Lancer
- 3" test pipe
- Dash board
- Turbo Kit-2014 Lancer GT 2.4L
- Buying a Lancer
- 09 Vibration in steering
- Jerking when shifting gears. PLZ HELP
- Ce lancer
- Help. Best colour and style on my white lancer 2013?
- Hello
- 3900$ 27,000 miles, worth it? Only rear damage
- Turbocharging an old Lancer
- Nick here
- 2011 lancer.. leaking brake fluid
- evo conversion from 2002 mirrage de coupe 1.5l?
- 2003 mitsubishi lancer verses a 2003 evo lancer
- Where can I find this shift knob? Is it that rare?
- Cs2 lip
- Question about Lancer Exhaust.
- Turbo Conversion?
- 2014 Lancer Limited Edition Mods
- Which lancer trim is this ?
- should I stay wingless?
- Replacement roof rack caps for 2010 lancer gts sport back
- Help me save it from the scrap yard. 2004 ES
- Swaping 4g15 gdi to 4g63T
- I think the tailpipe is too long
- Need help finding my rom id
- car got wrecked any advice on if insurance company will repair it
- Should the front 2 fans be running when the car is not on? (engine not running)
- 02 lancer cranks but won't start
- 2017 Mitsubishi Lancer GT Video
- Wheel well plastic splash guard clips/fasteners?
- 2006 Lancer Ralliart Steering Rack Removal
- New to the forums.
- 2008 Lancer GTS In-Motion Question
- Lancer Engine Swap 3.8L
- AfterMArket Exhaust
- 2013 Lancer SE AWD Motor Noise
- Looking for Virage Fog Lights for 05 Lancer ES
- 1999 Mitsubishi Lancer Evolution to buy or not?
- Is there a winter front?
- Oil Change
- 2014 Lancer SE
- What is the differences between ES, GT, GTS, SE?
- Questions about 2016 lancer compared to 2006
- Cat delete on axleback exhaust
- Please help with engine trying to stall
- In need of your help
- In need of help
- Air inlet tube needed
- Just bought a newish to me lancer es
- 08+ seats in 02-03
- Tein Basis. You buy fronts, I buy rears. 2002-2007 OZ Rally Lancer
- What muffler to install?
- 2016 Lancer ES Sport Auto
- Lancer 1.3 GLX CK1A fuel gauge advice
- Warning Light "Service Required"
- New here and first Car is Lancer Elegance (UK) got as few questions
- Need advice on a exhaust
- Looking for Evo X Spoiler.
- hey every body its been a while...
- Parts/Upgrades for 2015 Lancer SE Limited Edition
- Dimmer switch problem
- 5 speed transmission problems
- bay area lancer group startup
- Nurburgring 2016
- Trying to remove/disable remote starter
- New Member - new (used) 2002 Lancer OZ
- looking for splash guard clips
- BBS Evo X Wheel can fit Lancer EX?
- Lancer fast key help?
- New User- 2003 Lancer OZ - 200k maintence
- Small light next to the headlight?
- How much fluid does a CVT take?
- 4g94 turbo conversion assistance/ advice
- Car has shaky idle and low RPM after cold air intake instal
- How to change brakes on a 2011 Mitsubishi Lancer
- Speedometer stopped working
- CVT bad fuel economy fix
- Powdercoating Rims
- TPMS issues for a 2010 Lancer es
- new user 2011 ES sportback
- 2010 Lancer es advice please?
- Code P0043
- Is this Color Stock?
- 2013 Lancer GT CV Axle, please help.
- side skirt removal
- Wanted urgently, AMS intake manifold?!
- 2000 Lancer Wagon 1.8L Glxi
- New to the forum!
- lancer 2008 keyless issues
- 2011 Lancer speaker wire colors. Need help
- 4B12 engine questions
- Lancer Electrcial junction box
- Evo 10 / mirage rally car
- ★ i need help for the cluster light replacement for 08 lancer ★
- need help with 04 lancer sportback spring selection
- Mitsubishi lancer gearbox
- cruise control not working
- Problem with fog lights
- Insurance
- Radio
- Need help pleases
- Crankshaft position sensor 05 lancer ES
- 2016 Mitsubishi Lancer
- Replace Head Gasket or Whole Engine?
- 4b11 - 4b12
- New to the forum and also new to the lancer fam
- Tranny mount for ls 2.0
- Oil on spark plugs 4g18 engine CS3 lancer
- Headlight Retrofit anyone??
- Cherry Bomb?
- headlamp replacement oem8301c354
- New to site
- A/C not blowing
- Need help with my 2011 ES
- Mark Ervin, Art N Motion rendition of my car.
- Arp studs for 4g18
- if your not tired of answering the same question
- HVAC controls links-Hard to turn problem..
- What's up everyone?
- 4g93 sohc and 49g4 sohc arp head studs ????
- Any Lancer Techs!
- Greetings
- evo 7 cluster on lancer cg 03
- 2009 Lancer GTS CVT
- Need new antenna
- 08 lancer cant start
- Under the hood...
- sunroof
- 4b12
- 1999 MR Lancer Problem
- 2013 SE AWC Noise and vibration at 1100 rpm
- Turbocharging a lancer limited
- What performance mods/visual can i do to my lancer? Evo hood?
- Turning a lancer 1.8 into an EVO
- How to figure outwhich lancer i have.
- touch up paint for wicked white lancers?
- metal rolling pins behing bumper
- Matching headlight to LED side marker
- 2006 Lancer SE Timing Issue
- New to the boards with my almost 10 year Lancer
- AC still not cold after repairs?
- Cant find part anywhere?!
- Inconsistent friction point and clutch chatter
- 2012 GTS lancer, need ideas.
- Price suggestions for Lancer 2015
- 12' Lancer GT Transformation to Evo X...
- Very Rare TecnoCast 18" wheels
- Does HID fog light that is 2500K exist?
- been awhile
- New Here, new suspension?
- 2014 lancer SE vs. 2014 Lancer Evo GSR Stock Wheels
- When is time, it is time...
- 08-14 Lancer Headlight Housings (Exceed)
- New here need advice
- Please Answer Me This Question.. 2014 Lancer SE
- 2014 lancer GT MODS
- Halo Size for 08+ lancer Projector
- 02 lancer oz
- Do you know Bey Lon Lau II?
- ECU swap
- Question about interior lighting
- considering a lancer de
- 2009-2012 Mitsubishi Lancer second hand advice?
- Mitsubishi Carisma: Making it fun for not much money?
- Does Anyone Have This?
- Project 2004 Lancer ES
- Lancer Work - Beginning To Present (Lots Of Pictures)
- P0421 changed 02 sensors; diagnostic question
- what is this pigtail?
- 2016 Mitsubishi Lancer Imagined
- Buying a Lancer cheap
- 2010 lancer keeping steering wheel audio controls
- Audio help!!
- speedometer
- 2013 Ralliart new owner clarification
- is this lifter noise?
- Do Ralliart Parts Fit The ES?
- exhaust help :(
- Blow Motor is damaged..
- December FCOTM
- Drivers door interchange
- Lancer '15 headlights help!
- New exhaust suggestions?
- Beginner need help
- Question about 2012 mirrors...
- 2013 lancer service?
- eclipse and lancer
- Buying VRX Lancer
- 4g64 dohc swap
- MITSUBISHI LANCER 1.6 Invite
- 97 Lancer issue
- anybody experienced.....
- Mondial de l'automobile 2014 Paris
