PDA
View Full Version : Lancer How Tos / Installations
  1. Dual stage power circuit for fuel pump NA lancer
  2. OEM Hands Free Bluetooth Install (Non FUSE, 2008-2010 Lancer ES/ES Sport)
  3. Ralliart trunk to lancer?
  4. Grandson's 2008 Lancer has not heat
  5. How to make my 2009 lancer faster?
  6. How to make my 2009 lancer faster?
  7. 2011 CVT lancer gt shifter thread pitch size?
  8. 2013 lancer sunroof issues
  9. Does the front end look bigger with Evo x front bumper?
  10. Mitsubishi lancer GTS Easy way to tune ?
  11. Black box with VLAND tail lights?
  12. 08 lancer turbo oil feed line instal location
  13. No front fog lights
  14. Automatic 2016 lancer es shifter size
  15. 2016 Mitsubishi Lancer es exhaust
  16. 18x9.5 +35 avid av60s on a Lancer DE????
  17. YL-388 relay fog light wiring harness relay conversion
  18. 2014 lancer hyper flash fix
  19. 11 Lancer Gts front bumper swap
  20. NEED CONFIRMATION - 2009 lancer ES/DE/GTS, Are the brake rotors the same?
  21. 13 Lancer ES Lifted
  22. Radio Swap help
  23. Help! How i can remove the alternator on a Lancer GTS 2009
  24. Catalytic Converter
  25. Swapping body parts from 2009 Lancer GTS to 2014 Lancer SE Limited Edition
  26. Chinese Lancer Ex
  27. OEM Bluetooth installation advise help
  28. Evo x style cover up overlay
  29. Mitsubishi Lancer 09' DE Parking Brake reference
  30. How to remove the evaporator core and expansion valve?
  31. Help pls
  32. Will it fit???
  33. Heat and A/C Wiring diagram
  34. Will it fit???
  35. Front and rear crossmember replacement
  36. OEM touchscreen headunit
  37. HELPPP!! 08 lancer
  38. 4g63t SWAP
  39. 2008 lancer gts catalytic converter
  40. Back up Cam?? How
  41. Lancer ES Sport Key Fob
  42. Evo rear bumper cover installation on a 2013 lancer es?
  43. 2012 LANCER SE Spoiler Install
  44. 2012 SE CVT Shift Knob Replacement?
  45. steering wheel control lancer sportback 2010
  46. help with replacing stock speakers
  47. stereo upgrade options? OEM please
  48. Windshield Dimensions?
  49. My car didn’t come with a Spoiler
  50. Help installing Fog lights for my lancer using signal switch
  51. Can anyone who has swapped in EvoX cams testify?
  52. Newb
  53. Brakes
  54. Looking to mount an Evo front license plate bracket on a 2008 lancer es
  55. 2008 Lancer Dealer Manual
  56. My 09 build - will need help.
  57. 2008 Lancer Stereo volume knob issues
  58. Help. Newer GTS bumper on 09 base model
  59. 2016 Lancer ES LED fogs
  60. topspeed pro1 short throw shifter
  61. How To install an OEM Evo X Front License Plate Bracket
  62. How To retrofit yellow capsules into your fog lights
  63. How to install a radar detector and conceal the power wires
  64. Putting a EvO GSR rear bumper on a 2014 Lancer GT
  65. Keyless entry in non keyless lancer
  66. Lancer 2008 power window cables identify
  67. Cómo instalar un Bee R Limiter Rev en lancer 2009
  68. 2011 lancer turbo kit
  69. How to install new dashboard panel?
  70. Side view camera install
  71. OEM HID to Aftermarket HID
  72. Performance Upgrades??
  73. 2014 Lancer DE A/C Install
  74. MMCS activation after battery off
  75. Take apart my AC blower motor
  76. AYUDA CON instalacion del navegador lancer gts 10
  77. Steering wheel controls with aftermarket head unit
  78. Ckp sensor tests
  79. steering wheel problems
  80. How To: Install a Evo X ecu on a NA Lancer.
  81. Is it possible to install a Evo Steering wheel to a ES Sport?
  82. Cruise control system install
  83. 2015 lancer fitments
  84. Need a solution with my aux "PLUG".
  85. 09' Lancer GTS Muffler.
  86. Changing Brake light/ 2008MitslancerGTS
  87. exhaust change
  88. Help: 2008 Lancer Es Repair Manual....anyone?
  89. Installing Help Of GTS Bumper?!?
  90. Lancer engine swap
  91. Upper front strut tower bar
  92. Is it possible to put paddle shifters and sport mode shifter on 2009 Lancer SE CVT
  93. Crash beam evo x or jdm on a gts
  94. i need help installing cold cathodes
  95. Lancer 08 GTS Rear speaker problem MITO-02
  96. HELP! Going from LED to OEM taillights
  97. Installing Whiteline front sway bar on 2012 Lancer.
  98. Ideas for new front bumper!!!!
  99. anyone have 2010 Lancer es Repair guide?
  100. How too/ If Possible.
  101. Help with Interior Please
  102. 2013 mitsubishi lancer after market Deck
  103. HID headlights.
  104. Question about rrm pully
  105. HOW TO: Black out your front badge with Plasti Dip
  106. 2011 Lancer ES: OBX Header to Tsudo Headerback Catback Exhaust
  107. DVD in motion
  108. How to change your Cabin Air Filter
  109. mp3 in 2008 gts
  110. Stereo removal and aftermarket install
  111. Rockford and Fuse install in 08 Lancer ES
  112. Ready to install 08-10 Full grille.
  113. NEW METHOD: DRL's and HID's
  114. Triple gauge pillar pod
  115. Did my 90K service
  116. How to: Rewire stock RF sub for 2 ohms
  117. How to: Painting Interior Trim
  118. How To: Improve your stock 08+ Lancer bumper for $20
  119. Finally complete alarm and system
  120. How to: 08+ Mitsubishi Lancer Short Shifter Install DIY
  121. Evolution X Gauge Cluster in a Lancer... Setting the Record Straight
  122. DIY of Lancer 4g18 backlight smoked from chrome to black.
  123. How To: Change Fog Light Bulb/Assembly
  124. How To: DIY Coolant Change
  125. Blacking out tail lights and de-badging
  126. How to plasti dip front without removing it
  127. How-To: Replace Spark Plugs
  128. How To: EvoX Style Side Fenders
  129. plastidiped the chrome part of my grill
  130. How To: Relocate your battery to the trunk
  131. How To: Carbon Fiber look spark plug cover
  132. Install Interior LED Lights
  133. How to: Installing a 2nd Amp w/ RF System
  134. HOW TO: Install ebay fog lights
  135. How to: Run wires through the firewall
  136. 2inch drop. do i need a camber kit?
  137. Concealed garage door opener
  138. DIY 30K mile service
  139. How To: Custom dual pillar pods
  140. HOW TO: Install OEM Evo X Projectors on regular 08 '09' Lancers
  141. Disabling DRLS on 2008+ Lancer
  142. How To: Painting the Grill Black
  143. How to unlock DVD in Motion on MMCS
  144. How to: Debadge your Lancer 2008 GTS
  145. How to Install the Accolade Lancer Evolution X Body Kit
  146. How to: Install OEM Evolution X RECARO seats
  147. How to: Install Electromagnetic Horn for Lancer
  148. How to: Install Evolution X MR spoiler
  149. How To: Install a TWM Performance Short Shifter
  150. How To: Engine Bay Painting
  151. How To: Pollen/cabin filter change
  152. How to: Center console removal & iPod wire install
  153. How To: Rear sway bar
  154. How To: Spring install
  155. How To: Install RRM CF Exhaust Shield
  156. How To: DRL's and HID's
  157. How To: HID Install w/ Harness
  158. How To: DIY 7,500 mile maintenance for $25
  159. How to: Rear Camera Installation
  160. Door Panel Removal/Aftermarket Speaker Mounting
  161. Oil change info
  162. How To: Amplifier Installation + Remove Radio.
  163. How To: Amp and Sub install walkthrough
  164. How To: Taillight and headlight corner tinting
  165. How To: Installing Mitsubishi Aux/MP3 cable
  166. How To: Painting the middle of the front bumper
  167. How To: Front Bumper Removal
  168. 2008 Lancer bulb list
  169. How To: Amplifier and subs install
  170. How To: RRM crankshaft pulley install
  171. How to install: RRM crankshaft pulley
  172. How To: Oil change (with pictures)
  173. How To: RRM SRI install
  174. How To: Painting the interior
  175. How-To: custom fiberglass pillar gauge pods
  176. How To: Window moleskin felt installation *MERGED*
