View Full Version : ECU Flash
- How-to flash your ECU using ECUFLASH
- USEvo8 Ecu immobilizer bypass
- Tuning for Injen start-up issue
- How to set up datalog lab?
- ecuflash question obdII
- ecu flash and top speed
- Boost too high?
- Wideband Newb
- Interesting case study
- Datalog Lab .car file for IX SE?
- Problems with Mitsulogger
- EvoScan + DatalogLab + EcuFlash
- max wastegate duty
- Mass Air Transfer functon
- need help
- E-85 and EcuFlash
- Certain Mod Flash
- MWDC Tables ?? Please Help...
- Accuracy of IDC calculations???
- where to get evoscan
- How many times have you flashed?
- Continuity between high octane timing maps
- ECUflash window display problem
- Where are your closed loop maps
- Boost 24 psi +
- High & Low Octane Fuel Map Question...
- 10.5-11.5 (difference in power)?
- Evoscan Help
- problem reading ecu with ecuflash
- EVO flash
- Tuing the MIVEC ???
- Same old question
- Has anyone heard from Jestr/John?
- 2 Air/fuel questions
- i need TPS resistance value???
- Decel fuel delivery, stoich @ 0% tps? WTF!
- NLTS possible with ECUFlash and stock ECU?
- DIfference between Mobil 93 and Shell 93 with 10% Methonal
- texas tuning
- How long until evoscan .98 comes out?
- EVOscan question..newbie?
- What program is needed to run ECU unlocker v1.1???
- Restrictor Pill pics - IX Jestrtuning flash *pics*
- Data Log Lab Definition File For TurboXS Tuner
- inyector change
- Forgot to write down Evoscan Serial # STUCK!!!
- Injector Size Scaling Question
- OK guys, playing with ECU FLASH, I need ANY Rom/Tune. 4 Testing only!
- Question after dyno pulls
- Where to download ECUflash from?
- Any ECUFlash tuners in Dubai
- base performance map (to begin with)
- Out with the old, in with the new - Tuning session with TTP-E
- Is this timing map good?
- viewpoint on ecuflash and evoscan...
- EcuFlash Self-Tune Question
- JDM Evo IX MAP sensor group buy
- major screw up
- Compressor map calculator
- need help with ecuflash!!
- stock injector rescale
- EvoScan FTDI read timeout
- EvoScan v0.98 Wideband Support
- dyno results ecu flash
- Boost Error correction/Desired Engine Load.
- Ok I did my first logs
- For Euro ECUFLASH users --> ROM & Def for EURO evo 7/8/9
- Did my first log
- Knock through the gears.
- 12:1 afr for daily use?
- See if you can figure this one out.
- Need Some Help
- Code P0171 After EcuFlash
- Distinguishing USDM from EUDM and JDM from VIN code?
- EVOscan love for PLX?
- status of 2 byte load?
- ? About EcuFlash and OBD 2 Generic Scan Tool
- Evoscan help please...
- EVO IX ECU Reflash
- How often does your tune stray?
- Going to JDM land
- Questions PM'ed to me..
- NEED Serial to USB driver please...
- 3 logs... got any suggestions ?
- For those trying who need info on GM 3bar
- Tactrix Cables on ebay
- open/closed loop.
- Interesting findings from a weird setup...
- Added IDC?
- Anyone can help me out with e Evo 8 Map???
- My downpipe is likely causing false knock
- Immobilizer Question
- Need a file please... Stock IX map...
- Odd Immobilizer problem w/ dealer
- does anyone have the cable in stock?
- How to change Idle RPM?
- FQ 360 IX mivec/ ignition maps
- 500whp Tuned MIVEC on stock turbo
- JDM MAP sensor vs real load value
- Cali's 76 vs Shell 91 octane.
- when tuning what needs to be changed
- Macs and ECUFlash/Evoscan
- Help needed installing Ecuflash
- Method For Tuning Part Throttle
- Why!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- I have knock that I can't explain
- ecuflash maf translating?
- tune for better gas mileage?
- HELP! EVO wont start after flash
- Some advice with knock and adjustment [pics]
- Setting up Wideband.
- Post and Evo Scan?
- Unknown ROM image please help
- My First Evoscans..... What do you guys think?
- flash question
- New GUY
- Obd-ii Scan Tool Software That Works!
- Help, car will not start
- Westgate and Boost control
- AFR map advice
- ecuflash cables, maps?
- Attempt for the final answer.
- ECUflash v. ECU+ compatability?
- MAF Calibration
- Need evoscan.txt for latest evoscan + dll
- calculated load taper?
- Ebc?
- MAF Sensor Filtering
- Next version of Evoscan?
- 03 evo ecu -> 03 eclipse
- question about injector scale
- MAF Scaling
- Unable to connect
- AEM UEGO Serial Cable Instructions
- adjusting "boost cut"...
- Quick Off Topic Opinion.
- smog?????
- Boost/Taper fluctuation in different Gears.
- Ecu flash question?
- EcuFlash & Tools... 64 bit Support?
- Have ECUflash and cable, now need logger software, any ideas???
- Strange RPM values
- Cured my knocking issues. Wasn't the tune.
- Battery Voltage?
- Fuel Trims don't change in evoscan
- What timing are you running for peak torque and max RPM
- Hotter day = more power
- Silly idea to log boost in EvoScan??
- Can't install EVOSCAN Help!
- Inconsistent Air/Fuel Ratio
- High Load Calcs
- Evoscan Download help?
- throttle tip-in adjustment
- Opinion on low and high maps.
- Mitsulogger v1 Officially Released
- low octane maps leaner?
- MitsuLogger v1 to be Released this weekend
- question on afr on maps
- Quick easy question, please help!
- Aftermarket DP with built in bunge?
- 2-step launch.
- What happend to the small description?
- Evoscan Log Viewer?
- recommended boost pressure question
- tuning...
- Innovate LM-1
- Fq340?
- flash or custom tune on dyno?
- Recommendation for wideband please
- Opening JDM Maps????
- Are base e_flashes interchangeable.
- Stock Evo IX map
- Wideband serial connection
- AFRs, Low RPM, High Load ??
- Need Some input! back 2 Basic Bolt ons
- Has anyone had success getting the load to read correctly for .97 Evoscan?
- odd timing
- Mail-in tune, No MIVEC Changes?
- Dataloglab definitions for use with evoscan .097
- Gauges for Evoscan v0.97
- Load with GT-3076
- Injector size?????
- Boost Taper with MBC Evo 9 MR
- How to retune the block of 8* timing?
- 100 octane + Ecuflash
- Gas stations based on Experience?
- EcuFlash+OSX [screenshot]
- Tuning for Intake?
- Is there any Closed Loop Adjustment in Ecuflash?
- Questions on new and old software
- Need Help changing Immobilizer
- ECUFlash Cable ?
- AFRMAP numbers
- Those with Dyno experience >>> Timing light ???
- Best Wideband??
- anybody has a flash on a stock evo?
- Help with EvoScan, EcuFlash.
- unstable afrs?
- unstable afrs?
- Load Cal off???
- Deleting error codes
- CEL codes with Evoscan?
- Evoscan / Computer help
- Air Volume Reading?
- On road Dyno graphing? with .97?
- Idle target AFR map?
- Can oil pressure be logged thru EVOSCAN
- ECUflash Experience
- I'm maxxed out. WTF
- Un-associating deffinition files
- Don't think it's the tuning - trying to find the culprit
- Heading to dealer, got questions...
- EVO 9 Open Loop Throttle Low and High?
- 1000cc injector Calibration
- Why the hell won't my computer install my cable?
- Request IDs
- Anyone have EcuUnlocker 1.1
- final say.
- false Knock
- New Logs - These Seem Better Except One
- Knocksums and Timing
- Any ECUflash tuners Have 91 octane experience?
- Controlling Radiator Fan with ECUFlash
- Highest safe level of PSI on 91.
- HOW TO - Control boost using ECUFLash and the stock boost solenoid
- My flash and and locked ECU!!
- can not open maps evo IX
- May have solved my knock problems...
- out of stock injector...
- MitsuLogger V1 Beta 3 to be released tonight!
- Weird load calc. with log analyzer
- short term fuel trims reading high
- EvoScan v0.97 supports for Innovate LC-1 / TurboXS / PLX
- What do you think about this log?
- Throttle hang and the Idle Stepper Table
- Designing a logo for EcuFlash?
- Serial Output on WB -> USB Cable -> Laptop?
- Proper Way To Lean Or Richen Afr?
- Still confused on Taper down.
- ECU Locked
- CAN'T Download Flash
- ECUflash 1.29
- MitsuLogger v1 Beta 2 Released..
- Still playing with boost, need some advice!
- How do I log AFRMAP?
- Knock sum with 100 octane and 1.6 bar??
- getting started
- whats wrong with this pic
- How much load??
- cars feels like boost cut but its removed
