View Full Version : ECU Flash
- new tune help
- measurnig AFR at tailpipe difference
- Seeing 2-3 degrees difference in timing mp vs log.
- Anyone have a good 93oct, 35R 10:1 compression tune they care to share?
- RPM based A/F issue Stock ECU only
- Do i need to retune my Fuel & Timing after decreasing Injector C.C?
- Questions about fuel tuning
- strange load increase during wot
- help me tune for e85
- Log load on stock Rom
- Good tuners in GA area
- Q about cable selection
- Can a stock Evo 5~9 ecu be lock?
- Stock ECU/Wiring Experts. Evo 9 engine/stk ecu RWD swap NO Start.
- Decel fuel cut delay interpretation
- Ecuflash: Tune for desired AFR , updated program included
- Modified XML, new tables not appearing in ecuflash
- knock voltage ?
- Adc 0f problem.
- evo8 260 - changed maps - pls. check
- Tune help with EGR delete
- What happens if you disconnect your knock sensor to troubleshoot knock?
- Which version of SD are you using? ...And Why?
- How do i Log my Load @ Evoscan Live Map Tracer?
- ECUFlash issues -- related to USB 3.0 port on computer??
- Car sometimes "cuts out" at 3,600-4,000 RPMs...
- E85 1600cc base map for newbie.
- How to change this map?
- knock partially solved with big cams-
- lean idle, but after driving idle is spot on.
- How can I tune my SD without starting on a MAF?
- Evo Scan Issue
- unknown rom image after tune.
- I give up...
- need definition for Galant EDM V6 2.5
- Aem UEGO wiring to evo 9 ecu
- evo7/8 - copy ECU mapping??
- My Current Tune Map - Pls Advise
- Evo Scan software slow to refresh?
- crap cold start, help needed!
- horribly slow (useless) evoscan logging speed
- How to Add Load Cell?
- What are your thoughts on these logs/knock
- Could really use some help
- Is it necessary to tune SD starting with a MAF?
- drop boost on high knock
- Strange 1 byte Load Error Logging 9417 V7
- Cams + Im : timing +afr
- 89970010 open loop throttle
- Need help Comparing to stock Fuel/Timing maps
- Idle Stability Timing Control for 88590015
- Timing- Logged vs requested
- Wrong parameters
- Installed Omni 4 Bar Drove then SES light no start
- Going Crazy cold idle low with V7 94170715
- gt3586r peak torque?
- Wiring an LED to CEL?
- *please help* LC-1 keeps loosing calibration data
- Ecuflash Problem with Tephra 941760715
- help please guys
- map tracer problem...need your help!
- evoscan q
- Need help reading my rom from new vehicle
- Random Leaning While Crusing
- How to Tune MAF Smoothing?
- what causes almost 100hp to disappear?
- Evo 7/8 RS Ecu + 96260009 = stalls after ~3sec
- Someone PLEASE HELP! Is this real knock???
- When you guys tune...
- SD Tune Using Brass AEM 5 bar gauge sensor?
- Tuner near the tri-state area
- After 2150's Front O2 SES Light???
- Turbosmart EBoost2 to log boost for evoscan, possible?
- flashing cables problems
- Disable o2 rear ,what's wrong?
- rescale WGDC & BDE boost tables?
- Need some input
- speed formula with FD of 4.09
- Looking for tune input (logs, maps, vd, etc inside)
- EcuFlash load cell odd numbers...
- Alt ign map trouble
- Logging Wideband through 02 MUT table?
- Help Tuning Idle
- Deleted egr....
- Stock AFR what should it be??
- ICS Light Output, Alt Maps and USDM IX...
- Car wont log LTFT low after injectors...
- Help reflashed cranks won't start
- Improve low end torque with timing or fuel?
- Need a start up tune!
- Trying to do injector scaling.. what am I doing wrong?
- Need assistance with logging
- Super Rich when Immediate Full Throttle.
- A/C idle issues
- Rear O2 delete patch clarification
- question about jdm evo 8 ecu
- weird powerloss causing knock!
- check engine light help!
- Stock Maf Stock Ecu - Load Drop at HighBoost - Mellon Racing
- What sd iat method to use for more consistent fueling?
- Injector scaling issue, weird results...
- Tactrix 2.0 openport
- 1.3u cable problem
- Is this phantom knock?! ...Driving me nuts!
- E85 + BBK + 1100S & warlboro 255 = 430whp and out of fuel??
- why is my load so high ?
- ISCV address request - evo 9
- 560's maxed out at 14 psi ?
- Altmaps "alt injector latency"?
- open loop question...help needed.
- EcuFlash Not Flashing
- Need help urgent!!
- map smoothing tool help..
- boost load limit increase?
- Does Rear 02 Sensor Delete disable WB02?
- Lancer ecu and ecuFlash on a GM engine
- Fuel Trim, Scaling & Latency Question
- E6 ecu pinout for reflash
- How to log EGTs in EvoScan?
- Logging raw timing
- Tactrix 2.0 help
- rev limit question...
- help! need the diagram obd2 to usb for 4g93
- help with periphery configuration
- Tip-In Stutter/Lean and Low Load
- Knock even with timing pulled
- Big map translator question...
- rebuilt engine, missfire after first WOT
- Strange ZT3 WB AFR Readings?
- Colt/Lancer CJ/CK fuel tables?
- Knock Mystery, need assistance
- 2003 Evo 8 stock tune??
- How to Interprete Load Cell & ECU Load?
- intercooler sprayer input as pump activator
- Broken finger cable worth it?
- AFR cant goes below 11??? Why???
- Fuel cut multiplier on 96260709
- HKS 7460 Idle issue
- 3 Bar MAP Sensor
- Stupid question - Which Tactrix
- How to set a Evo 6 ecu to full time Open Loop?
- Rich AFR when lift off causing Idle & Stalling Problem.
- Noob, need help
- Need an XML ASAP Mirage LS '99 1.8 N/A
- help with maps before restart
- Silly question - how to limit timing fluctuations at idle
- immobilizer help needed.
- Cat Converter VS Test Pipe
- Evoscan 2.9.0019 graph display bug
- Electronic det cans and usage
- Rom file needed
- tephra v7 install..
- Trying to flash my 05 Evo 8 back to stock
- OMG am I reading this right?
- Speed Density Need help
- Need advice, P0202
- Having trouble reading ecu. Need help.
- need tuning
- tephra mod 7 logging load
- Anyone have a stock 94170014 rom file?
- stock rom's and MAF IAT WGDC Correction
- disregard...
- Need help locating Ignition Trim vs Air Temp table address
- tunning help. Stalling/startup issues.
- Can't Read ROM
- re-enabling the EGR
- OpenPort 2.0 and Evoscan no responce from ecu...
- USB problem with Evoscan
- Rom 8858 AUDM to 8859 USDM
- Edm rom to usdm
- omni 4 bar acting up
- s2 cams knock tables.
- OB2 table in ECU flash
- Why does injector scaling affect SD MAP Sensor VE?
- is this O2 sensor dead ? *log*
- Need some info about JDM evo 7 ecu pinout
- Idle & Stalling Problem.
- Loading tunes on a mac with osx
- 89980000 any info?
- Will 1.3U work with latest ver. ECUFlash?
- lots of random DTCs...any suggestions?
- unknown error codes
- 96530006-v5.10-xml.txt thepra
- how to scale MAF from scratch
- 1150cc scaling issue
- Broken 1.3U Cable
- decel fuel cut ignition retard table - trigger conditions?
- HKS Camp 2 and knock
- anyone logs Knockbase&Knockadc ?
- ecuflash load rescale map..correct or not?
- Ignition trim vs air temp 88840016
- Confused: V7 injector scaling missing?
- 350~450 AWHP Fuel & Timing Maps Sharing.
- NGK AFX Won't Log In EvoScan 2.9
- Non Waste Spark Coil On Plug with Stock ECU
- Can't get to idle under 1500rpm
- rescaling load values ?
- Ecu problems
- ecuflash help!!
- NLTS help!
- Searched Still Lost. I have Unknown ROM Image
- PTE 1200cc hard start!?
- Omni 4bar reading odd.
- XML out there?
- Definition file needed-pajero nm 3.5l 2002 at5
- EVO Scan GPS work on any Windows CE device
- Evo 9 Base Maps?
- FIC2150CC single walbro e85 ?
- [Problem]Open Loop Idle weird AFRMAP
- 06 STi ABS codes...
- ECUFlash Unknown ROM Image
- Bought a tuned EVO IX, now what?
- 251 counts of knock?
- Need tips to tune for cams and big IM
- lean afr above 8000 rpm after airflow, load and idc drop
- tephra v7 and 1byte rpm logging with evoscan
- Tactrix cable identification
- Disabling Codes
- Noob Tephra 7 help
- default 1byte eval
- Why cant i log my Fuel Trims?
- Timing Dippin down low
- tephra launch maps
- Ecuflash, stock injector Scaling?
- [SOLVED] Problems logging MAT with 88590715
- 2008 EvoX NO XML DEF OUT THERE?!?
- Speed density - Using IAT WGDC correction table
- Engine Decel
- Evoscan data edit
- Evoscan auto-disconnect
- Still cannot read!!! Help!!!!
- Communication error... mini battery voltage?
- switching to v7
- Double-din/In-dash Evoscan Interface
- MUT Table
- need help "resetting" ecuflash
- Evoscan for iphone/ipad?
- Cannot Download Evoscan
- weird load issue round #2!
- Newbie needing to get stock ROM and map to tune with.
- Running into a snag
- Need help: tephra mods on Evo 7 with 99860002
- Boost Settings for HKS EVC 5 w/ AMS-750 Turbo(3076)
- Ignition code
- MAF IAT WGDC correction on SD
- NLTS not working Tephra V7 SD 88591715
- Need some tuning advice
- Evoscan on 4M40 diesel Delica
- 12.6 on peak torque - too lean ?
- mivec tuning question
