PDA
View Full Version : ECU Flash
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
  1. Log file of sd incompatibility 3d /2.0 : start idle lean:
  2. Can't edit rom metadata folders
  3. 94170008 to 94170015 Question
  4. Hybrid Boost Control
  5. Help, anybody have EcuFlash 1.42?
  6. High Knock!
  7. Will the evo 9 ever get a rom with coolant trims
  8. Edit: NM, got it.
  9. Reflash stock ECU
  10. AFR richer in wet weather..
  11. 94170008 to 94170015
  12. need help with tuning
  13. Pinout for output?
  14. Stock Rom vs Tephra
  15. EvoScan support for PLX SM-AFR?
  16. Data log
  17. Power seems lesser whenever WOT?
  18. ecuflash definition files
  19. Evoscan not reading KnockSum?
  20. def 92460000 launch control not functioning
  21. E-mail Tuner Help
  22. EvoScan v2.9.0023 "load calculated" !!
  23. Defining Knock: Pre-ignition vs Detonation
  24. Misfire at WOT only on E85
  25. Tephra/EvoScan Dual stage meth not possible?
  26. How do circuits in the stock ecu work?
  27. Disassembly
  28. Start-up Fuel and ISCV Tables
  29. Which version of Evoscan can log intake cam position?
  30. LTFT and STFT not logging
  31. still getting knock
  32. I will pay you to fix my cold start issue. Fic 1150/8859
  33. re: ecuflash evo7 ecu
  34. Evo ecu
  35. evo 8 ecu tuning
  36. Need some help tuning my car, just got her back from being built
  37. Unbricking evo 8 ecu
  38. Deatschwerks 1000cc injectors scaling for Evo VIII
  39. Should i worry for ''AFRMAP''?
  40. Please help getting a ROM definition
  41. Immobilizer (again)
  42. stock evo 8 rom
  43. evo rom
  44. ECUFLASH will read but not write
  45. speedometer input/ tachometer output
  46. Idle stability problem
  47. noob question
  48. Serious help please, makes no sense
  49. Evo 7 Ecu in Evo 4
  50. warmup tuning?
  51. contacting "Peteyturbo"?
  52. TephraV7 Grimmspeed 3-Port Boost Control Issues. HELP!
  53. Can we tune the boost control on a stock evo 6 ecu?
  54. Aem Uego Logging
  55. SD Omni 4 bar scaling 88580007
  56. immobilizer window not big enough
  57. Logging Question?
  58. Tephramod v7/ECUflash v1.44 (88590715) Help needed
  59. more "ign retard limit question?"
  60. Knock and P0011 after Engine Build
  61. What does the ECU Periphery00 (F9A) Bits Do?
  62. 96530006 Rear 02 patch
  63. SD 9417 Rich for few seconds after letting off
  64. Can I use a Tactrix cable for cobalt SS/TC on EVO 8?
  65. Misfire Stutter Issue?
  66. 88591715 tephramod serious problem in 88840016 edm evoix
  67. Fuel changes revert back to normal
  68. Idle AFR and Cruise AFR rich HELP
  69. How to Tune Accel Enrichment
  70. Stock 1 bar MDP scaling
  71. Precision 1000cc injector scaling for 98 octane
  72. Injector/Fueling Issue
  73. ECUFlash 1.44 problem
  74. Tephra mod/general q's
  75. Fuel Cut after Updated Latest Ecuflash 1.44.3719 & Changing Load Cell
  76. ECU reflashed without user input
  77. New EcuFlash 1.44 problems
  78. 9653 vs 9417?
  79. How to tune ''Turbo boost single solenoid'' all maps?
  80. am I logging wrong timing ?
  81. ECUFlash 1.42 - No Known Code
  82. Dual Map Tuning Tephra v5.10 Question
  83. I'm confused with read/write and tephra v7 mod!!
  84. Help with Cold Start
  85. Low Voltage to the MAP
  86. Disable ltft how to?
  87. SD with open loop tuning
  88. help with finding maps.
  89. VE calibration for AVCR map use in SD mods
  90. stock maf scaling
  91. EcuFlash Unable to Connect Problem
  92. Crazy ecu problem HELP!
  93. Need help understanding 2byte load w/ corrections
  94. Injector scaling vs actual afr in close loop? Also does ve change closed loop fueling
  95. Car wont start
  96. Help me read my EcuFlash
  97. Disable Imobilizer
  98. Annoying versions.php
  99. AFR Map issue
  100. Chasing knock - negative timing at peak boost?
  101. reflashing
  102. Setting up ecu for Pte1200cc injectors
  103. From scratch...
  104. idle surge after recirculating catch can install
  105. SD self tuners/tuners keep an eye on map:kpa
  106. Who just got sick of the wbo2 mod and went serial?
  107. from Stock to Tephra V7 and no Power anymore
  108. Need A LOT of SD help...
  109. read rom, now car wont start!
  110. Need HUGE help!!
  111. timing belt. or tune issue
  112. another logging wideband question(i've searched)
  113. Suddenly lots of knock...
  114. Newbie need some help here.
  115. Questions about Omni 4-bar before install
  116. ECUflash/Evoscan ecu read/write issues
  117. Help connecting with Ecuflash
  118. V7 Big maps smoothing tool - light version
  119. Tuning Boost in High Gears?
  120. EcuFlash Starting Out
  121. Easist way to log oil temp with tephra?
  122. What is the limit of stock Evo IX MAF ?
  123. evoscan wont install on windows 8
  124. 88580014 Definition Clarification Needed
  125. swapping tune parameters?
  126. Ecuflash --> no possibile to write, read or test write
  127. tablet for ecuflash
  128. grimmspeed 3port & omni 3bar= Regrets...
  129. weird problems with rescaling the Big Map
  130. cold start problems sd 96531706
  131. ecuflash unknown rom...need help.
  132. stationary rev limit issue tuning launch maps
  133. SAS system fuel injector delay: until rpm = 6000?
  134. load jump from 300 to 10 @WOT ???
  135. EGR - Who uses it and why?
  136. can't go pass 14psi with grimspeed...
  137. What map would be best to go with, not many mods, Just want a little extra power.
  138. Tephra Tinkering and OP2 SD Datalogging
  139. how to create new 2byte entry?
  140. Tephra V7 - Richer AFR's after big map conversion?
  141. OP1.3 cable question, identify capacitors.
  142. Pop's & Bang's Map...Is it BAD?
  143. Flashing an Airtrek Turbo
  144. Can't see periphery bits
  145. Base map
  146. How to get worse? They did it.
  147. 1.3U cable got offline during logging and unable to reconnect...
  148. use OBD-2 with MUT Requests
  149. Fuel Tuning - Open Loop Temp Threshold definition?
  150. Weird ROM issue
  151. Question for you full open loop tuners
  152. AFR @ 14.2+ at WOT - EFFECTS?! need help!
  153. Why does 20 psi @ low rpm = more load than high rpm in SD?
  154. HKS 272 smooth idle
  155. Dyno Graph/Possible Fuel Issue/Chime in If You Want!
  156. Evo 9 Mivec problem
  157. Grimmspeed 3 port ebcs, need help
  158. knock after oem DV install ?
  159. Weird Load # at WOT & Stuttering
  160. Map switching problem 8859 and 8858
  161. EvoScan Error (0xc0000005)
  162. Immobilizer
  163. boost problem..need help plz!
  164. Incredible issue, What's wrong? edm ecu
  165. Need help with formula to log aem uego in evoscan
  166. Disable FAA bit 9?
  167. Help Opening Map
  168. Tuning and request address advice please!!
  169. 3D SD Question...
  170. Serial data logging and windows 7 with aem
  171. Map switching hardware: IC voltage regulator?
  172. Adding second map sensor
  173. Pls advise my water/meth tune map...
  174. Jitters on SD FIX?
  175. ALS implementation on all V7 Tephra Roms
  176. Search Patch for Boost Map in each Gear (96530006)
  177. rich on idle
  178. How do I fix this? Tables not working correctly
  179. Knock vs Knock voltage
  180. WOT LEAN ISSUE.. E85, SD, need some help
  181. Weird Knock log
  182. New EVODROID7 EvoScan Android GPS/Logger/Reflashing CarPC Touchscreen Review
  183. Evo 8 jdm map sensor question...
  184. Blitz SBC Boost Solenoid
  185. Several Idle Questions
  186. dynotech ecu switch help!
  187. 2Byte Load, Temp and Baro Compensated for 90550001
  188. Need some basic advices for Ecuflash/Evoscan
  189. closed loop target afr
  190. Yet another ecu wont read
  191. Tips on how to keep your tuning device from eating itself!
  192. Chromebook?
  193. Timing Issue
  194. Anybody willing to help out?
  195. ecuflash 1.43.3252 3d view
  196. So, got my fuel trims back, now questioning my tune
  197. How lean can you go on partial throttle?
  198. Fuel Trims are not Reading
  199. Tuning fuel for constant 12V to fuel pump
  200. car falls on it's face after cam install
  201. boost help please!
  202. EvoScan issue
  203. what do I need for ecu controlled boost
  204. lean idle after rebuild
  205. can someone email a stock 8 rom?
  206. Some guidance would be much appreciated
  207. NLTS Problems??
  208. SD Baro input
  209. Evoscan Weird Problem
  210. brwaking up and fouling plugs @ 5k rpms
  211. Evo 9 very reluctant to change
  212. EGR solenoids (quick question!!)
  213. Looking for a coding guru
  214. Compressor surge after GM 3 port
  215. How to Interprete Load Cell?
  216. How to Tune Accel Enrichment?
  217. Please kindly comment on this Evo 9 tune map
  218. Help Needed, PLEASE.. 03 Evo
  219. 2 step
  220. injector pulse
  221. what mivec map to run?
  222. ecuflash max load changes question
  223. Tephra V7 - Weird BoostError/WGDC corr. Boost control only works in 6th gear.
  224. Aem failsafe boost sensor in Evoscan
  225. need some help please
  226. How to disable P0011 DTC? Rom# 88590015
  227. Water/Meth Tuning Info Needed...
  228. Grimspeed issue
  229. Evoscan2logworks - convert evoscan logs to logworks offline.
  230. Understanding Roms, using 88590715, should I change?
  231. Mapping Evo 6.5 TME
  232. tuning help!
  233. Pulling readings from a maf while running sd?
  234. In need of cable 1.3D/R/U In NJ
  235. Help tuning idle down, mivec
  236. Comprehensive list and explanation of ecuflash tables
  237. suddenly cant log 2byte load 94170715
  238. Need help from a guru!!
  239. Idle surge and stall Evo IX
  240. FreeFuel ECU patch - a flex fuel implementation to Evo ECU
  241. Phantom Codes?
  242. rescaling sub 100 load area ?
  243. Best Ecu flash tuner via email?? Or person close by WV
  244. DMA rom set up, help? 88586714
  245. Stock ROM
  246. Knock Jump
  247. is it a boost leak ? *pic*
  248. Car wont makes little boost
  249. Help with CEL< no cell in ECU
  250. EGR issues
