PDA
View Full Version : ECU Flash
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40
  1. Cant view maps
  2. weird problems
  3. Switch aircon (a/c) off when at WOT?
  4. Continued testing biggie boost on 91 octane
  5. Trying to log evoscan with zeitronic external wideband
  6. Why do you need a Resistor with the GM 3 Port?
  7. Evoscan logging Evo 6
  8. MBC/OE BCS Hybrid
  9. Adding RPM points
  10. Need help with MAF scaling
  11. new tune and sputtering
  12. Phantom Knock?
  13. problem with evoscan
  14. Missfiring problem & P0304, log attached
  15. 94170008 no injector scaling help
  16. Mitsulogger - cranking engine
  17. Raised 2-step now it misses when using
  18. Differeces between GM 3Port and OEM Sol for Pump Gas?
  19. reading/access on a locked ecu, now identifying the rom
  20. installing older versions of ecuflash and crashing
  21. figured out how to associate ODB-II error codes with error checking subroutines
  22. Tactrix cable question
  23. Interesting pix we might learn from
  24. tuning in high altitude
  25. help with ecuflash and evoscan
  26. hesitation during pulls
  27. e70
  28. Broke my wastegate solenoid boost line
  29. Can I Run Stock 05 Rom on 03?
  30. Knock sensor question
  31. tuning idle
  32. Different Fuel - Way different AFR's
  33. Total noob to tuning....few questions
  34. lol @ this timing map...
  35. MITSULOGGER ERROR hex file
  36. I have problem logging
  37. zetronix Wideband not working lambda sensor hot tho?
  38. Boost solonoid harness able to be used for input?
  39. Boost limit table
  40. What is the purpose of using 2 byte?
  41. Trouble with MAF
  42. Evo VII GT-A EcuFlash
  43. Can't get Mitsulogger to work
  44. EvoScan support?
  45. change closed loop a/f
  46. Tuning with an External WG dump
  47. Where to download EvoScan ver 2.1
  48. Just got EcuFlash and EvoScan, what to do?
  49. Can't flash my ECU...
  50. show your designed load curve
  51. Intake temp?
  52. LC-1: No real time data link? HELP
  53. download evoscan .97
  54. Good lesson learned!
  55. boost change
  56. stalling issue w/new build
  57. EvoScan logging with AEM UEGO???
  58. Problems with EVOSvcan 2.2 and crazy reads
  59. Screenshot from working DMA live map/log + Tephra V5
  60. installing new turbo tonight and need tuning baseline hlep
  61. Which BRAND of injectors are the easiest to work with/scale?
  62. IX FQ340 missing top clutch switch wiring
  63. Ralliart Map
  64. Idle tables for 94170008-15?
  65. Tuning 272's cams
  66. Need quick help on disabling patch for P0443
  67. openloop idle
  68. small laptop ecuflash?
  69. trying to flash
  70. Quick Question
  71. 1-2 shift hesitation?
  72. exhaust pop when engine braking. What's the cause?
  73. Random ECU questions...
  74. Does BDEL+BCLO equal 2 byte load?
  75. Is my AFR ok? few new mods evo IX
  76. removal of battery
  77. DV flutter = knock?
  78. how-to: Log AFR from the LC-1 w/o a serial cable
  79. post ECUFlash MUT table definitions here
  80. Tuning the Green - Initial impressions vs. Stock Turbo
  81. LC1 power supply and electronics question
  82. worried about my tune
  83. Instructions for removing a pin from an Evo 9 ECU plug
  84. does this make sense?
  85. LogWorks 2 Map Tracing not Working.
  86. knock at 6000-7000 rpm, 92 oct, need tuning advice...
  87. LogWorks 2 OBDII or MUT?
  88. Questions about GM 3 Port Tuning
  89. 3 port solenoid - what is the best way to control???
  90. Shameless EvoScan Gauge Layout
  91. LC-1 installed, logging AFR without serial cable
  92. 36 Counts of Knock
  93. Load Error & WGDC Correction Address
  94. EvoScan2.1 Problem - Link Succesful... NO DATA
  95. ECUflash 1.34 problem with vista???
  96. About to get back into speed density testing
  97. Fuel problem on a 2G
  98. Ekcutek ROM compatibility with ECUFlash????
  99. Need help re scaling maf
  100. MAp tracer will not work.
  101. Any benefits in advancing idle mivec?
  102. ecuflash problem(stat rec limit)
  103. Mitsubishi OEM Boost Pill
  104. 88840013 ROM and EcuFlash definitions
  105. Logworks and fuel trim logging
  106. Possibly a new mobile logger?
  107. Lower Thermostat Temp?
  108. Looking for input on my logs
  109. Evoscan cable flashing ACD and ABS lights....
  110. Semi-offtopic: brush up your assembly skills with Corewar
  111. Reflash help
  112. Disassembly question
  113. I can't scale my pte 880's.. help
  114. Best way control boost with the stock BCS system,
  115. Retune needed ?
  116. ECU Question
  117. Easier way to calibrate GM Maf?
  118. Need some tooning help to rid knock.
  119. evoscan when I start logging RPM goes to +/-2500
  120. Who can tell me what "accel enrichment" specifically does?
  121. Qucik help
  122. multiple ecu's
  123. Which one; OpenPort 1.3U vs. OpenPort 1.3M for an EVO
  124. Timing vs. AFR in relation to making power
  125. Scantek to work in older cars?
  126. How do you tune a car from scratch?
  127. P0505 with "super" MIVEC
  128. 272 cosworth cams, how to tune mivec table??
  129. Can't install Evoscan 2.1
  130. map tracer
  131. P0300 code and EcuFlash
  132. ECU disassembling?
  133. Defi BF vs JDM Map accuracy
  134. Stock ECU and COP
  135. Looking for 06 Evo 9Mr stock ROM
  136. Tephra, can you make a mod to fix the VIII's p0300 issue?
  137. Evoscan gauge Templates V11
  138. Looking for help on setting up my fuel
  139. Any ideas why my stationary rev limit is not working?
  140. Shipping EVO to Germany
  141. Question?
  142. problems with Evoscan
  143. Let's see your customized EvoScan Data.xml
  144. Strange issue with trying to read '06 Evo 9 MR ecu
  145. What is the best program for data logging?
  146. Evoscan 2.2 --How is loadcalc related to fuel table load
  147. how to disable second 02 sensor?
  148. EGR VALVE: when is it open and what makes it shut?
  149. evo scan and ecuflash questions need help
  150. 9653006v5.1 NLTS and other rom questions
  151. ECUFLASH(Pakistan)
  152. just adding an open filter what to do...
  153. need help: new xml files for upcoming ECUFlash release
  154. Knock Problems
  155. problems getting stock rom
  156. Aquamist HFS-1, GM BCS, and Tephra v5: together at last!
  157. i don't know what i did
  158. Quick question regarding stock turbo setups and peak loads hit
  159. faint fuel smell in cabin during pulls
  160. Is there a basic/cheap IAT Sensor?
  161. System Too Lean(Bank 1)??????????????????
  162. What can I do with OpenECU software?
  163. Issues, need to tap into the collective..
  164. How to use Evoscan and plx widebands
  165. 9653006v5 WORKS for 05 USDM (9694011)
  166. EcuFlash and EvoScan problem.
  167. Data missing in EVOScan logs ???
  168. Current ROM Mods?
  169. Is it time for new injectors or what?
  170. 96940011 rear O2 sim patch
  171. need rom defs please help
  172. Evoscan wide band reads 5.000 at idle Gauge reads normal
  173. Question on Tephra Mods
  174. Wrecked tactrix cable?
  175. Rom Mods for ECU controlled BOOST
  176. Map rescaling..
  177. more boost control tables found
  178. 1.34 Problem
  179. Changed injector scaling after disconnected battery
  180. Ecuflash with mac
  181. Max WGDC Correction vs TPS table
  182. RPM Error in EvoScan Log
  183. Any ECU flashers want to help a brother out
  184. Which Tactrix cable
  185. changing roms
  186. 2byte - im lost
  187. Switching IGN 12v source for LC-1 (not acc)
  188. IDA output to gas input
  189. 93660005 ROM Swap?
  190. Issues with DLL graphing Load%
  191. Evoscan
  192. Biggie Boost on 91 oct
  193. Alternate Roms for 96940011 / 2005 USDM Ecu?
  194. PATCH: TephraMod V5
  195. How to disable immobilizer on EDM Evo9?
  196. TBE + semi-tune results on 92 octane
  197. Getting 5+ knock counts ONLY on hard shifts??
  198. Maximum ignition retard for IX
  199. EVOSCAN ISSUE 2.1 When start up
  200. Entire fuel tables path
  201. How to copy ECUFlash map table data from excel to ECUFlash?
  202. timing map for anti lag
  203. SAS Hardware
  204. Drag log for you guys to play with
  205. Map Switching indicator in EvoScan??
  206. Are 780's enough for a Green on 30psi ?
  207. Help
  208. need advice on my tune
  209. Highest whp on stock ECU
  210. Stock Timing/AFR Maps Evo7 and Evo9
  211. Clutch Slipping Dyno
  212. EvoScan 2.1 Fuel Trim Formula
  213. Wideband shootout test
  214. post your timing/afr maps:
  215. Log review request
  216. Can EvoScan log 0-5v output from AEM Uego?
  217. Request ID: Open/Closed Loop?
  218. Trouble Logging 2byte Load
  219. Perephery patch Interesting. Could fix my problems?
  220. 1150cc's Work great on stock ecu W/e85
  221. need a good tuner in the seattle area
  222. Logging at Idle w/ Mitsulogger
  223. H8 Rom Definition
  224. new coolant temp and intake air temp entries for EvoScan
  225. Setup to active immobilizer with my key!
  226. 50 trim help
  227. Mac problems
  228. q45 on stock ecu?
  229. 05 Evo VIII ECU with an 03 Evo VIII wiring harness
  230. need injector scalling format
  231. Problem initializing ECUFLASH with car!!!
  232. Ceramic Cat vs. 100 cell Metal Substrate Cat
  233. Direct ECU boost control/ecuflash problem
  234. Injector Sizing and Latency - Observations and Thoughts
  235. Test Pipe VS 130 cell MS high-flow cat
  236. 88840016 vs 88840017???
  237. Evo X MAF in a VIII/IX?
  238. Comments on log for 94oct
  239. need help reading ecu
  240. idle RPM - neutral
  241. Apexi AVCR MAP sensor for logging?
  242. Keeping all 3 maps the same?
  243. Knock Help PLEASE
  244. problems getting ecuflash to download ROM from evo ix
  245. Question about maf scaling and fuel trims
  246. 2 step ?
  247. Cable connection/ ReFlash
  248. remote start/2step
  249. Knock on fast shift
  250. Speed Sensor Question
