Log In
View Full Version : ECU Flash
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
  1. Decel Fuel Tables and how they Work
  2. Fuel Trims
  3. PTE 1200 Fuel Trims
  4. Rich after throttle released
  5. How to Log AEM UEGO in Evo Scan
  6. Problem with evo 9 (huge fuel consumption and P0170)
  7. My car will not idle
  8. Interpolation vs Resolution
  9. EVOSCAN and Map trace ???
  10. Knock Filtering?
  11. Tephra v7 9653 thottle hang
  12. GM BCS issue.
  13. Correcting a few 96530006 definitions
  14. What other tables use the same values as MAF Scaling?
  15. Problems with - Full Time Open Loop
  16. Tuning JDM Evo 7
  17. Tephra BIGMAP table size?
  18. Ecuflash doesnt find definitions
  19. 7 ECU -> 6.5 Car (EGR + EVAP CEL's)
  20. Car got over 1 point leaner at WOT
  21. Load based boost help please
  22. wgdc wont move?
  23. Success w/ 94170015 fixed a couple issues; driveability + knock
  24. Evoscan and Innovate LC1
  25. op2.0 problems
  26. Help making graphs
  27. Getting started ???
  28. Is it advance or base timing?
  29. error retrieving rom from jdm evo 9 rs
  30. 97250001 Load calculation problem..
  31. AFRs rich after EGR enable/disble patch...
  32. Speed Density Issue
  33. tactrix cable
  34. wierd ecu issues....
  35. high timing during cruise that i cant change.
  36. LS disable for 94170015 ROM
  37. JDM 3 Bar vs OMNI 4 Bar
  38. ecu flash for mac?
  39. no honeycomb
  40. 2 step help
  41. Speed Density Problem
  42. anyone got CORRECT xml for 98640014 and tephra mod for that?
  43. Adding load columns and RPM rows to maps
  44. how can I get into the evo V ecu...
  45. First time Logging with Question!
  46. Anyone unplug their factory BCS and disable the P0248 CEL?
  47. ecuflash cant read Ecu evo 8 2003
  48. need help!!
  49. Software fix for P0136
  50. ECU ROM mod - double the "Fuel Cut Load Limit" range to 638
  51. openport 2.0 SD flash card logging?
  52. evoscan maptracer
  53. ECU boost users - Do you want a higher boost cut load?
  54. My tuning/logging netbook for sale
  55. do i have to delete xml file to change patch
  56. mut table question
  57. warm up afr
  58. What causes backfiring?
  59. Help - 2001 JDM EVO7
  60. Stat rev limiter - evo 6/7
  61. Password on evo stock ecu
  62. Asynch SD Tables
  63. Placement of MAT for SD with Water Injection
  64. Another idle question
  65. Knock
  66. Alt MAP= Main Map
  67. [Dev/Disassembly] The beginners' guide to Evo ECU table lookups
  68. Open Port 2.0 Purchase feedback
  69. ECUFlash / Vista64 fails to read previously flashed ECU
  70. EcuTek to EcuFlash???????
  71. fully defined 94170015
  72. What maps are affected when scaling is changed
  73. missing tables in ecuflash?
  74. Fuel trims LTFT Low, Mid not adjusting now?
  75. MAF Hz and Load spikes at idle QUESTION ? ?
  76. MAF Scaling and wierd numbers
  77. ECU Based Cruise Control...Plausable?
  78. Anti-Lag Two-step
  79. Tuning for different altitudes & air densitys
  80. Cool link for injector latency
  81. Alternative Map in the Traphra mod v5.10
  82. HELP! I need a 2003 Stock Map!
  83. Does your check engine light flash after tephra mod
  84. EVO X 53040010 XML file needed
  85. Openport 1.3 Unversal
  86. Using lean spool tables to match AFR's
  87. Alternate Map for tephra mod v5.1 9642001
  88. BlueMUT - logging via cellular
  89. New help finding some maps in two ROMS
  90. tuning problem with evoscan
  91. tuning questions
  92. Why big cams throw a P0300 code?
  93. timing during spool up
  94. ecu unlocker compatibility with vista
  95. Has rescaling your load caused the car to bog when the engine is cold?
  96. Rear O2 disabled thanks Mr.Fred
  97. 22.5 PSI vs. 26.5 PSI pump gas results
  98. Any one know what this Unit is?
  99. trims logging, strange values
  100. Help me to identify this connector
  101. Clean in 3rd, Knock on 4th
  102. converting 99860002
  103. Not scaling injectors???
  104. All bow down and give praise to the great disassembling ones!!
  105. Logging EGT via EcuFlash
  106. Definition File needed for EVO 8
  107. MAF Compensation Table
  108. knock tuning.
  109. ID2000 scaling and latency
  110. need help on which periphery bits to enable
  111. installing a GM 3-bar MAP sensor
  112. Major problem with my log *Please Help*
  113. How to set address?
  114. Will I have To Tune Again?
  115. Is this normal while logging Speed
  116. I think I may have found a new 3port boost solenoid...that comes on every EVO
  117. No activity from fuel trims
  118. Rescaling question
  119. 880cc Injectors installed. Scaling and STFT confusing
  120. Logging problem with Evoscan 2.6
  121. help ME open it
  122. How to read an ACD Error code?
  123. how does my timing look to you? no knock
  124. Had a weird issue with Ecuflash yesterday
  125. Help. i need a MAF Scaling
  126. evoscan root element missing
  127. in over my head with how many roms i have help
  128. 80040154 error
  129. How many have switched to SD? (anonymous poll)
  130. PLS help me open rom80230006
  131. WGDC is actually what is controling/building boost?
  132. ECUFLash ROM Deffinition Refference Data Base
  133. Speed Density Air Temp Correction
  134. Simple SD question
  135. Surging on stock turbo?
  136. disabled egr via faa bit 11 and now crappy cold start help
  137. Can bad fuel cause knock at cruise but not at WOT?
  138. how to log actual timing?
  139. Timing logged at idle
  140. Colby, Tephra, EVO4Mad and the rest of the experts, take a look.
  141. Alt Map not working (logged)
  142. 3 bar map sensor
  143. MUT table question
  144. Help: EDM EvoX 53040007 - no definition
  145. 3 Port Boost Solenoid
  146. can anyone tell me the scaling and latency for Denso 660CC injectors
  147. new to evoscan. help me
  148. boot limit
  149. ecuflash not reading help
  150. I need a 2003 stock map,,,
  151. Agressive E85 ignition timing
  152. Openport 2.0 Cable for RVR in NZ
  153. Werid issue adjusting 2step and rev limt 2003 stockmap
  154. Help : Evo7 EDM FQ300
  155. looking evo 8 gsr RA xml
  156. A quick question on Map Switching for Tephra or others
  157. ECUFlash idle tables with A/C on
  158. ECU Unlocker
  159. Uprated Coil Packs ?
  160. Ever seen Knock like this?
  161. Need some quick help.
  162. ECU load commands at ignition startup...help?
  163. Hanging RPMS
  164. Inconsistent Logging Data
  165. JDM 3 Bar sensor pinout - anyone.
  166. Need XML for 5304-0010
  167. need help w/ roms
  168. Evoscan Request ID's
  169. Map stock boost on ecu??and definition file help
  170. NLTS(No Lift To Shift) For Beginners
  171. need help
  172. Speed density !!!!!Need help ASAP
  173. Map Tracing on EvoScan v2.6 ?
  174. stock mas limit finally found?
  175. EvoScan and WHP
  176. Ecuflash 1.41 unable to read EVO VIII
  177. EvoScan logging issues
  178. Help with tephra 5.10
  179. close loop timing vs open loop timing
  180. P0135 fix
  181. Phantom Knock??
  182. NLTS worked 'great' for me...
  183. Coolant Temp CEL periphery bit
  184. 1BYTE load going from 330 to 20? Logging rate Hz?
  185. Evoscan and WRX
  186. Weird Tuning Problem - Please Help
  187. Can't read 03 evo?
  188. Speed Density Help
  189. EvoScan MAP Tracer
  190. 96530006 SD issue?
  191. USB Detection on PC
  192. !Help with Openport 1.3!
  193. Serial wideband input freezing on vista64 with dynex on evoscan2.6
  194. Important ECU Thread Links
  195. New Code Help. (Code Gurus Needed)
  196. Speed density + NLTS patch??
  197. Anyone Have A Base Map For Evo VIII?
  198. P0243 problems.
  199. ECU Control Boost and Tephra Mod
  200. Injectors scaling after a cam install???
  201. For those who have problem logging wideband signal with Serial-USB cable
  202. Just did GM 3-port and Omni 4-bar. Got a few questions.
  203. Problems logging with Evoscan
  204. Looking to convert to Speed Density...help needed
  205. Gear based timing map (drag vs road race tunes)
  206. 2 Inherits?
  207. can i bypass the immobilizer on my '06 MR?
  208. gear based A/F? or am i missing something?
  209. 3 bar map sensor and Evo 8 EDM
  210. Best 2 Step Settings
  211. EcuFlash manual
  212. Big Cams Cruise Tune for the Evo 8
  213. LM-2 logging with EvoScan?
  214. got a quick Ix timing question.
  215. Some 969400011 Periphery Mapping Information Help?
  216. Prescision 880cc and scaled to 713 is this not correct?
  217. 94170015 ROM with 2 Byte load
  218. To those running SD on stock ECU: need logs
  219. ECU not reading over 100load?
  220. need help with 96420008 to 94170015
  221. How does the ecu determine which gear you're in?
  222. RC750cc Scaling & Latency
  223. kelford 272 cams - Vacumn Idle
  224. Evo 5/6 ROM disassembly?
  225. Quick Fueling Question
  226. Windows XP or Windows 7 for EvoScan and EcuFlash
  227. issue with throttle after acceleration
  228. help with evoscan can't find logs..... kinda
  229. ecu adds timing????
  230. MAF Hz to lb/min formula?
  231. Can/how do I disable the MPD sensor??
  232. Logging and tuning on a flat road
  233. 96530006 and EGR/EVAP
  234. Need Ecuflash 1.31
  235. Curing overboost with ECUFlash
  236. Kelford 272's, TBE, Perrin filter. LOW OUTPUT on E85
  237. 3.5 bar sensors...AEM & SSI...one the same?
  238. Noob Tuning
  239. any power to be had going from 10.5 to 11.5 afr?
  240. comment on choice of MAP sensor for logging boost, SD, etc
  241. evo reflash info
  242. HELP:Can't view all my parameters for my rom (newbie).
  243. evoscan with aem wideband probs
  244. car suddenly running like crrrrap
  245. ROM 88840017 - JDM MAP and TE 2J1 WB
  246. Need Help, rough iddle with Cosworth M2 Mivec
  247. p0171 & p0300 after tune w/bigger injectors
  248. I need a 94170015 .bin .rom stock factory tune file
  249. disabling rear o2 sensor: which method did YOU use.
  250. Lost my evoscan program
