View Full Version : ECU Flash
- EVO 9 Cruising Issues
- No fuel cut on decel
- Omni 4 bar scaling
- MUT tables change depending on XML used?
- Problems after WBO2 signal into rear O2 ADC
- CJ Lancer
- Unknown ROM on JDM Evo 8 GSR
- Can't read the ROM from ACD ECU
- Tuning help for Evo 9
- Dsm sd rom
- High load figures, is this normal?
- Omni 3 bar settings
- need working xml
- Alpha N tuning on DSM
- flex fuel for evo 8 what pin do i connect analog output?
- Need stock map for 96530706
- Hitting Boost Cut On MBC
- Verify 2 byte values!
- need working xml please
- Tephra Mod Evo7 ROM/XML
- Car won't make power, stumped
- Grimmspeed 3 Port Boost Control Solenoid
- Polish Evolander stage1
- Evo 8 MR Tephra Mod 96260007/96260009
- E39a Galant
- SD map sensor vs RPM VE 96531706
- EVO IX 8859 comes out of open loop at idle
- EVO9 88580714 goes lean after gear change
- elm evolivemap
- FIC Bluemax 1450cc Evo 9 map
- 2 byte load/rpm/airflow
- Greddy Profec OLED
- Evo 8 stutters and goes lean above 20 psi.All of a sudden.
- Need help disabling rear 02 sensor
- Switched to v7, car runs for a few seconds then dies
- Looking into to tuning my Evo 8
- car breaks up around 6800 rpm
- Stock evo 8 speed density calibrations
- Flashed evo 8 and confused.
- Id1050x scaling and latency
- ID 1000 or 1050X FOR STOCK ECU
- Changing ECUflash Default COM/USB port
- Help need with tephra mod
- Injector scaling issue with V7 SD
- Immo off 2006 Outlander 1.8L
- Live Tuning/Logging
- new 2.4l issues with fuel trims. plz check logs need help
- Options for logging car during track runs ?
- Unknown ROM - Finding Definition
- read codes or log ABS on usdm evo9 with evoscan
- HELP - ROM 9339000 Ecuflash Problem with Idling/Tune
- Help with ecu flash tune
- Id 1700
- problems logging boost and afr in evoscan
- Lost. Need ecu id and immobilizer code
- Unable to read ROM v7 speed density
- tune for the ecu
- EvoScan Logs Missing Data
- Deleting Rear o2 wires
- Re-write rom after reading?
- evo 9 bigger turbo lag and ignition retard
- How to install Anti-Lag with EcuFlasher?
- 96531706 map ve
- Adjusting Idle with ECUFlash
- noobish SD tuning, looking for advice
- Evo 5/6 Speed density using Ceddymods?
- Reflash
- Non working Tactrix Cables WTF
- -20 timing patch
- 93660005 tephramod?
- Boost error correction settings causing overboost?
- egr settings
- Ecu boost values question
- Log Fuel Temp Sensor?
- Race map q16 switch to pump gas map
- Please Read my ROM !. ECUFLASH
- New build Tephra V7, SD, No Start/Spark
- Help Identifying Maps
- Omni 7 Bar Definitions & Scalings
- Switched to Speed Density 2.0 and getting P0105
- Boost desired engine load setup
- Decel fuel resume RPM for 9653... mrfred, look, please!
- lean spool afr
- E-flash. Who do you recommend
- Cranking ipw adder
- Attempting to tune my bucket of bolts..
- NEW INJECTOR DATA Check this out when scaling injectors
- Been M.I.A. for a while. Could use some help.
- on-AC stuck at 85 steps
- definition problem
- ISCV demand & ISC step maximums
- Returning Evo 8 to stock map...?
- ALT maps switching issue-
- Crazy afr, maf? injector? Fuel pulsations?
- Tuning Peak Load E85 QUESTIONS
- Coping 'stock' rom info onto tephra, few questions
- Evoscan Load. WOT Dropping.
- Speed Density Questions Rom 96531706
- locked rom evo 9
- Sketch sound after flash to stock
- How to log afr via Aem Uego and evo scan?
- Need help finding a H8 ECU SD evo 5/6 rom!
- aem uego intermittent logging issues
- Base map for GSC S2 / FP Green speed density stock ECU
- 99650115
- Need Help going SD, car don't start on 2th Time
- Emmision fail, OBD2 "not supported"
- Need help with tune.
- Closed loop breaking up
- help with strange log
- noob wanting to start tuning
- car won't start after flash
- high positive short term fuel trim value
- Evoscan DLL ERROR please HELP
- Tephra v7 decel very rich
- Can't read vehicle interfaced
- Odd injector and idle issue
- Evoscan log issue
- P0500 VEHICLE speed sensor disable
- How to hook up an aftermarket Tach
- Transfer to SD, WGDC lowe than before and target map
- Evo VII ROM .XML need Help
- Evo IX BRICKED from ECM reprogramming recall
- EcuFlash Not Showing Rom Tables After Editing XML
- Logging AFR using innovate MTX-L wideband
- SD xml equation for MPXH6400A map sensor
- Installed Omni power 4 bar map sensor now it has a code P1400? Help
- 88590715 NTLS failing
- Program help
- Program help
- rich idle help please
- how to shoot flames
- Evoscan reading zero- ECU ID0000
- LC-1-> serial -> USB -> Windows 10?
- 3000 gt ECU
- Evoscan data displaying on graphs
- How to get rid of jitters, SD rom
- Deatschwerks 1000cc are they good injectors
- Tactrix 1.3u cable help
- ⛔★ Way too rich on Deceleration, can't figure it out (high cold idle fixed tephra v7)
- ⛔★ Initial cold idle too high, help
- Evo 4 / IV - 510CC injector latency values
- Can anyone look at my logs and help me out
- need help! High idle after EVAP&EGR removal & ported throttle body
- How to tell if your ECU has been reflashed?
- Weird tacho issue
- EVO V with TME GSR ECU some issues.
- Logging MIVEC Timing with Evoscan 2.9
- Ecu flash problems
- How to setup free C compiler and assembler SH2
- evo 7 tephramod v7
- Boy, am I frustrated with ECUFlash
- Aem x series logging
- EVOSCAN AEM x-seires logging
- cant opne my .hex file
- rich at idle need help!
- cold start die than runs perfect
- Rom and XML for Evo 7 thats V5 or non big map
- speed density on base lancers?
- Can't find xml file for my rom
- Light Throttle 1st/2nd Gear Knock
- Unknown Rom Image ECUFlash
- Converting analog sensor signal to digital reading
- Air Temp Fuel Tables?
- Outlander Turbo remap
- 2004 jdm evo 8 mr 340
- Plug n play tune
- Hitting higher psi after omni4 bar install
- Maf 2 Map rom
- apexi boost solenoid
- can somebody have a look at my fuel maps
- Evo 9 redline
- Downpipe/Test pipe install - Very simple question about Rear O2 Heater Patch
- 94170014 v5.10 + xml
- evo8 mr which rom to use
- Tephra V7 and Omni MAP Scaling
- Evo 8 auto shop
- Carisma cold start problem (evoscan logs)
- Adjusting Fuel Maps
- Tuning problem evo X
- Cannot connect to Evo 9 ECU
- Can this be done with our cars. WRX ecuflash Antilag
- STFT max + with 3D sd
- Tephra V5 rom and def for Evo 9
- Tuning out long crank with FIC 1450cc injectors
- Lancer evo 7 20g upgrade
- Can't connect to evo ix
- ⛔★ Evo 8 stock MAP sensor OpenPort issues
- SD tune evo X 3 bar to Omni 4
- ⛔★ Evo 8 tuning, logged KnockSum 2-8 knock count fix?
- 96534706 - 2150 - Idle issue
- Evo VIII ecu in (95) 2G Eclipse
- Can't get ECUFlash back to where it was
- evo 7
- Negative Mid LTFT and more issues!
- Evo 9 bench flash
- strange MAT scaling for iat scaling table issue
- 2001 jdm evo 7
- Input on logged 1b load and logged map psi
- EVOSCAN ISSUES [solved]
- Full boost coming very Late.
- How to upload Logs.
- Need help from Ecuflash/coding experts!!
- E85 target afr help.
- Last ecuuflash Module MH8115F issues
- Can't get wot to lean out
- Evo 8 JDM, Car not running smooth
- Pls help... my Beautiful small island has no tuners
- what sd rom for evo 8 to use with gm iat
- Pte 880s with e85
- Interesting Development the new SOHC 4cyl
- new livemap client
- WTF ??? Mirage 2014
- Calling Tephra, Merlin, or any Disassembly Guru for location of this switch
- IPW patch on Tephra
- Fuel Trims no work, out of ideas, any thoughts?
- Evo 8 Tephra Mod, Issues controlling wastegate duty
- Why is there lots of timing at low loads?
- WGDC Fixes (what are they?)
- EcuFlash turn off fuel cut on decel evo6
- Another wierd tuning issue, multiple symptoms, please help, I've looked
- Omni 4 bar values not chaning
- Pajero 3.0 6G72 Need xml
- Evoscan 2.9 logging (fast logging)
- Tuning for Colder Thermostat...
- Pulled my (speed density) rom from my EVO 8, can't find definition....
- Getting past the 30.1 PSI limit...94170715 ROM
- 1G DSM with 2G ECU and ECUflash - Where to start?
- OBD Pin out Evo 8
- Exceeding 30psi with a JDM 3bar map sensor
- Evo 8 ecu in 2g gsx radiator fan not kicking on
- Tephra 7 Alt Maps/Launch Maps issue
- Low Load @ 24 LBS of boost. 230 Max in logs...
- 96531706 BOSCH HIZ 2000 cc injector tuning
- Decel Knock...???
- Big Map Translator
- Evoscan Logs - VBA to split it
- Can any one tell me how this table, "Lean Spool Correction" works?
- Reading high load out of boost
- 94171715 IAT read 280* plus F
- Evo scan 2.9 Virtual Dyno Estimates vs JackOftrade Excel VD
- need help setting SD, car lean and stall
- SD - Cold Startup Lean Spike
- Dual map toggle switch wiring?
- ECU Resetting?
- Tables for acceleration from a stop?
- Phantom knock options. 96530706 tephra v.7 e85
- Checksum question
