View Full Version : ECU Flash
- Warm start issues resolved FINALLY!!!!
- EVO 8 ECU or EVO 9 ECU? which one to use?
- Airtrek Roms?
- add or remove timing globally vs iat
- Best ECU for the Flash > E8 USDM ECU in E6RS JDM
- Cold weather err correction
- sd trouble anyone willing to look at my maps
- Negative fuel trims
- V7 - LOAD error logging on 96530706
- help with this wierd issue
- Need Help!!!! Evo 5/6/6.5
- 03 EVO 8: SD tuning problems / ROM problems
- AEM WB error in evoscan 2.7 HELP
- Considering 1st time tuning and using Tephra v7
- Alt low octane in V7
- MAF comp. table
- V7 - AFR safety monitoring settings ?
- Help with start up tune for new engine.
- Tephra donation
- OP Error,
- Craziness after exhaust upgrade
- Problem with map switching
- Help with E85 Timing on EVO IX
- dual map question
- Omni 4 bar
- can't flash back
- ecuflash install help!
- Ecuflash car selection table
- any side effects running constant open loop ?
- ecuflash 1433252 beta
- Ecu-Flash Features on a Evo 6 Ecu.
- Log boost with evoscan
- SD: evoscan: how to log iat ?
- Not reading ECU
- FIC1100: Mid fuel trims stay zero?
- Fuel pressure on idle?
- Order evoscan + cable, and a smal tune fix
- Bigger turbos!!!! Lag VS Launch
- immobilizer bypass
- non-ISC throttlebodies
- Cams / idle / advance timing
- 96531706 xml
- 88592130
- Upgrading Tephramod v5.10 to v7
- Adjusting rev-up at start
- Running duel maps
- Adjusting Stock WGDC with EcuFlash
- Anyone got a Diesel Pajero to work with ECUFlash?
- Tactrix cable inop
- Very quick ECUFlash question
- 88590015 conversion issue
- I need a stock evo9 map!!!
- The wierdest EcuFlash problem.
- Evoscan logging problem
- newbie question
- lean misfire
- Is cruising very lean on e85 a problem?
- Idle Stepper Lookup Table help
- Removing stock Boost control selenoid, ecu periphery bits change
- evo 8 ecu in new talon build question
- NLTS on V7 (JDM evo VIII)
- 2 Step on JDM Evo VIII - Tephra V7
- Evo 7 ECU issues
- Where is the mitsulogger software?
- P0325 and 8-9 counts of off throttle knock
- Tephra V7 FAA Bit 11
- help with Startup tables
- Basemap for Eov 8
- Up shifting jerk 1st to 2nd normal driving
- Evoscan 4 Android
- Evo 9 ECU issues
- fuel pressure regulator, need help!!!!
- Reflash Connector?
- Evo IX with Evo 8 Rom ID?
- ACD Pump turn on w/ gas pedal running dual map ?
- P0340 & P0335 freaking me out!!!
- Ecuflash only loads base 9 rom?
- Eratic idle with aircon on
- Noob here trying to get things started
- is it too lean on spool-up ? log included
- Where can I download Mitsu Logger?
- New BR 2.1L Base map?
- 88840016 how to sd?
- H8 ECU Mods for 3000GT
- 2003 Evolution VIII Help
- "Sorry, errors were found in the original data.xml"
- having idle issue, wondering if i have stock rom?
- GM 3port only increases boost at 100%WGDC
- Final consensus on SD for a daily driver?
- need evo7base xml with mut and periphery
- needing 02 stock ecu rom
- transferring ceddy mods
- how to add xml's to evoscan 2.8??
- fuel cut? log inside please help?
- Speed density help!
- tephra v7 alternate cranking primer table
- Advice about fuel pressure and injectors
- O2 won't cycle on initial start
- Ecuflash Colt Czt
- What tuning adjustments for new cams?
- evoscan best version?
- adding launch control to my 6 TME?
- Problem with knock, Pull timing???
- Speed density
- Hows my tune look? (log and map inside)
- plz help me!!
- limiter cut sequence?
- Cant find a thread on disabling an immoblizer
- ecuflash doesnt recognise rom image?
- v7 boost control issues
- Need help. DMA does not work in Live Map.
- ok so Prosport wideband wired into input for rear O2
- Help with tune
- Higher idle and odd AFRs after track day
- mac inspection...
- V7 - Boost Cut Load
- AIT/TPS Issues w/Tephra V7
- problem with ecuflash..
- So a Question About Big Maps
- few quirks, multiple CEL's :(, idle afr swing
- Question about EvoScan
- Please look at my rom
- Alt Maps V7 - map switch not working
- tephra .bin wont flash into car
- Hitting low load during spool
- MAF Scaling
- Can you tune PSI based boost control without a 3bar MAP sensor?
- EvoScan MMCFlash ECU Reflashing Software
- vp import
- Help with setting scalies/lattency on FIC 1450
- Speed density iddle 'n
- V7 load vs PSI boost
- Care to share your tuned ISCV tables?
- ECU FLash and Tuning for Okada Direct Plasma Coils
- tephra V7 Boost related table definitions
- tuning with det-can tips
- Fuel tuning advice?
- Help this Evo...whith file and photo.
- Massive amounts of knock
- BC 272 cams on Evo IX
- Tephra V7.1 and high load
- evo ix ecuflash screen shot
- Reading Current Tune
- EcuFlash definition needed
- VDR users a couple questions
- Why is my timing so low?
- Timing vs MPG (Closed Loop)
- need help to find evo 9 88780008 xml def
- need stock 94170015 rom
- cant log adc / ayc on evoscan Help
- Lean spike at 5k-5500?
- Need Injector latency value's for NGi 2200's, anyone??
- peak torque late ?
- 2 Step on STI
- EcuFlash works, EvoScan does not?
- EvoScan for iPad 2
- Openport 2.0 windows 7 error help!!
- V7 questions
- Load 1byte falling under high load?
- No Response To Any Known Code
- Scaling 1450's help
- speed density car wont start HELP?
- Any way to disable P0183?
- Cant Access the ECU Unlocker ZIP file
- FIC or not FIC
- Fic 900
- Did my tuner do a good job?
- temp scaling C to F
- understanding LTFT low
- Spark signal only on pin23 (coil2)??
- Hard to dial in 2150’s
- Denso 720cc injectors hard to tune?
- JDM MAP Sensor pin-outs
- AEM 5 Bar Working/ Units
- Converted to SD, Evo won't make even 5lbs of boost without issues
- General non-information about factory ALS
- Cruising AFR's a little rich!
- Logging / Scaling questions
- OpenPort 1.3 vs 2.0
- Backwards Load
- 88840016 2 byte load
- evo9 ecu swap?
- Delete rear o2 sensor CEL in Evo4
- disabling EGR 2006 EVO 9 EDM 88580714
- Video of my Evo 9 with Tephra v7 demonstrating NLTS
- AC stalling/bouncing issue
- evoscan 2.9 release?
- Afr as rich as 10.8 when moving off from junction. What can I do?
- Help Starting Idling
- Simular issues with two different versions of the same rom... Bad ECU???
- Connect to ECU Help
- Is closed loop necessary for a street car?
- AEM Inline WBO2 formula
- Ecu Unlock
- is there a way to log fuel pressure?
- Lots of timing pulled for heat?
- open loop?
- anyone with e6x on evo 4-7
- Timing Trim Per Gear
- Stock 2005 MR ROM
- Evo IX - EvoScan Datalogging Issues
- formula for logging KPA w/ jdm 3 bar
- Pajero Evolution Need xml
- Cant find rom file anywhere...
- Locked ECU---Help Me
- SARD 650c Injector Latency
- I have silly questions... sorry chaps.
- Openport 2.0 and Mac? HELP
- Scaling and ECU Boost control ?'s
- Accel enrichment & injectors
- Wanted (please): Ralliart C1 ACD/AYC ROM
- How does my Log look?
- Jdm evo7 map sensor
- Got a favor to ask...
- Where to get a "base" map
- Can't edit XML for 94170015
- boost cut limit
- 962 Rom not working with a edm E8
- few little issues
- Flashed car won't start
- Car goes lean when cold only for a second
- having trouble with load readings waaay out of whack
- HKS GTII + BC 272 cams?
- Fuel Trims are slightly negative, but AFR a lot leaner at wot than in Fuel Map
- EVO Ecu Pin 24!
- New self tuner and maps so far....
- Help! Trying to locate (JDM MAP SENSOR)
- ecuflash 1.29 frustration.... plaese help
- Problem trying to Connect LC1 to log from Rear O2
- logged load seems high?
- no start after speed density conversion.
- Injector latency voltage?
- TephraMOD-96530706-v7 Rear O2 ?
- Another 2.0 cable issue, but drivers installed
- EVOScan 2.8 reading AEM Wideband
- 94170008 decel fuel cut tables
- Have control of some of the on/off outputs on ECU
- Causes of pcm commanding +15% fuel
- Denso 660cc scaling/latency
- What is the best WB02 from YOUR experience?
- Going very lean up top Lots of knock tephra v7
- Permanent Wideband O2 Sensor
- Help flash evo8 outside car
- Complete Rear O2 Delete Patch (88590015)
- FIC 2150 Speed Den. Base Map?
- Strange TPS related cut problem. Tephra ROMs
- P0105 MAP (Baro) Circuit Malfunction CEL on WOT. HELP!!
- SRS (Airbag Light) Anyway to check it
- Question RE: Decel Transition From Injectors off to on for idle
- Tephra v7 Load?
