View Full Version : ECU Flash
- Back to stock?
- Problem- Evoscan not logging
- wrong x and y axis values
- help with idle
- Afr calculator
- Disable ODBII totally?
- Flashing error
- Changeable boost problem
- How does the HighOctane/LowOctane stuff work?
- Tune or flash
- Evoscan Issues - Thread Failed During Processing
- injector question? newb
- need a dedicated tester for TephraMods
- Need flashing logs from various romids + ecuflash version
- Starting over with ECUflash and Evoscan
- need a tune
- Found Thermo Fan Switch Conditions
- Removing stock BCS
- smog.. obd2.. help.. :)
- limitless 1.3U cable= flashing anti-lock light when connected
- Tuning Help - New Injectors
- mac version of evoscan
- Unknown file type ROM id
- Help with AC idle and cams
- logworks3 time delay..
- What would your perfect logged AFR map look like
- 1.29 vs. 1.41 trouble shooting
- How do you set your launch boost?
- accel enrichment table is not defined correctly
- Need help rescaling load in evoscan
- Tactrix cable fault? Detailed troubleshooting!
- ECU Pin for clutch switch
- Question about my maps and my datalog after cam install
- glitch with 2-byte airflow logging in Logworks
- ECU vs AYC
- rom evoVIII 2.3
- My turbo wont boost above 20psi at the track???
- How much knock pulls timing??
- Mounting GM solenoid
- How does one log load accurately?
- p01238 o2 sim patch fix for ROM 94170015
- Live mapping and/or speed density instructions
- how do you activate the Tephra mods?
- Suggestion need on my 4th gear pull
- Still throwing codes P0037 and P0138, while using tephra mod 88590015.
- Live Graph Download
- An Interesting idea for cruise AFR :(
- "Correct" Idle MAF Hz
- EcuFlash and Windows 7?
- Evo 7 question & tuning
- 96530006 Live Map download
- Hows my Fuel and Timing look ?
- How the DMA code works
- problem lots of knock while cruising.
- MAF No Screen / Who's doing it?
- acamus' automatic disassembly script is ace
- Injector Scaling Issue
- Modified ROM 94170008
- ECU Flash Problem on Vista
- Breakup After hardshifts, Possible Knock , please help.
- 9626009 xml
- 1 byte vs. 2 byte
- Any ACD/AYC evoscan logging experience?
- loginig software for my needs
- Lean Spool ?? Help Pls.
- HELP!! evo ix audm DEFINITION
- how do I log STFT<FT
- MAF Hz and Load at idle.....spikes
- Issue with BARO and P0107, with Potentiometer
- Question regarding "the switch"
- Towards a universal ECU
- FP Red is FUN
- tranny temp monitoring on EDM Evo IXs
- wb o2 help
- What is the key to getting WB AFR to match the map AFR?
- P0300 Code
- Show case your Evoscan GPS Display
- adjusting clutch switch for NLTS
- Evo 8 post reflash - RAM not cleared
- why I read my ECU paramiter is ecual=7.4?
- Evo IX Flash...Can anyone send me one..
- Trying to device a formula for "suggested" timing
- 03 Eclipse...
- Is there a way to save a flash on a laptop?
- Cant edit MUT table
- no knock count
- I've had an idea
- Lift Off Knock
- GM MAF and translator Max Air hz?
- What's the difference between "PATCH: NLTS + Valet + KnockCEL" and "Tephra Mods"
- IPW adder
- Tephra, can you tell us what address to map switch
- 500rpm stumble
- So we had an idea at lunch...
- Unsolvable knock after FP 4R MIVEC cam install
- Hot Key issue in evoscan.
- cam install and idle issues
- 94170015 error found
- how much timing do you run?
- Evoscan formula for temperature
- WBO logging problem on wot
- ECUFlash Error
- Evo live map source
- Tuning issues
- ACD Reflashing ??
- Immoiliser disable with openport 1.3
- EvoScan2.6 and Tech Edge 2J1 WBo2
- Lean Spool AFR Mapping and Accel Enrich Tables
- EvoScan: Saving Injector Scaling?
- knock on light throttle spool up
- Car knocks no matter what. help
- Injector Latency for 2G GSX
- Help with scaling - FIC Bluemax 1450's
- accurate 90550001 xml's
- Problem with Evo8 JDM 9626007
- Evo Live Map videos on YouTube
- Please Help
- Need Help for Evo 6 TME map definition
- Please comment my LOG
- GM 3 port question
- Double Pumper Tuning
- po141 help
- P0134 and P0172 after rod/piston install and dying when clutch is pressed in?
- Internal Id Numbers
- FIC 750 - Scaling and Latencys have drove me to drink heavily.
- Using Logworks to log
- HELP..Can not LTFT low to cycle
- Idle timing, vac, ISCV steps, NOx
- Periphery Bits
- No Low load LTFT on 272s and 1000cc injectors!
- What E-mail tune to choose?
- gaps in wideband logs
- Taxtrix VS Limitless Cable
- 5th gear issue (tephra v.6)
- How to Undo a ecuflash mod basics / concept
- Cant read injector duty cycle
- Req flash control of coolant temp switch point, MrFred
- Map rescaling question
- WOT Sputter Issue
- ABS Actuator While Logging and not Moving?! - Evoscan Logging Problem
- HELP... my car stalls at stop
- fuel map
- Write new code?
- Rear O2 sensor disabled from the ECU !!!!
- Map Color Question
- Warm-up enrichment issues
- Wiring AEM to OEM ECU SD on US cars
- Start up Tune Help please
- Legnum VR-4 Def File
- Anyone using the LM-2 yet?
- Looking for Input: 2.3L/Bigger Turbo, Part-Throttle, etc.
- evoscan logging incorrect innovate afr
- ECUflash Newb Question Help!
- Switched from 99860002 to Tephra 5.10 90550001 getting P0400
- Can't Get EvoScan To Open
- Sputtering at 2k, wont accelerate in 5th gear
- pill controlled boost, reference points?
- MAFT setup used with ecuflash in a converted 2g eclipse?
- Quick Map Question...
- I looked but can find max hertz values for upgraded turbos
- Anyone had success loging LM-1 with Evoscan 2.5?
- Tatrix 1.3 not connecting!
- Red/pump 3rd gear datalog attached (can anyone help with DLL?)
- ecu plus MAP
- EvoScan v2.6, EvoScan GPS Navigator, EvoX, OpenPort2.0
- Can't connect to my E6 with ecuflash
- MrFred ECU boost control mods question
- Quick ones Evoscan 2.5!
- Walbro 255 Install - Now 30+ knock count
- Changing ROM IDs and Migrating to Tephra v6
- EvoX support for EcuFlash and EvoScan
- EVOSCAN supports Openport 2.0 Tactrix Cable????!!!
- Timing value in ignition maps
- GM 3 Bar Map Sensor Evoscan formula?
- Anyone use a LC-1 and a USB to Serial adapter
- 1.29 works, 1.41 doesn't (1.3 cable)
- Fuel cut problem. Logged at 320 load at 25 psi
- openport 2.0 cable with ecuflash 1.29 are they compatible?
- Ecuflash will not read my ecu but it will write into it!?!
- Intermittant hard starting after Injector install
- quick question, ecu monitor oil?
- Ecu Boost control vs. MBC
- Colt czt ecu flash ?
- This cable work ?
- ECUFlash Basics - tutorial - getting started
- Ecuflash for other cars?
- 2003 jdm evo 8
- 2byte Load log question
- DTC patch disscussion
- basic ecuflash upgrade question
- Possible to log MAT and ambient?
- Rom 88840013 swop with another updated rom???
- Need latest definition file for ROM 88840013 !!!Thanks
- Problems with tutorial on how to rescale maf
- Map Switching Help
- Tps reads 100 all the time. Help please
- Looking for a good map...
- MAF table questions ? ?
- GM 3 Port on External Wastegate
- Octane Level
- Easy speed density? First test...
- Evoscan Data XML File change
- High Fuel Consumption with 88840013 ROM after reprogramming my ECU
- EvoScan GPS Navigator New Release.
- Evoscan Issue
- EvoScan v2.6 New Release.
- Can someone please host ecuflash v1.34 or 1.35
- Knock Control Problems
- Flashing the stock ecu not to throw the P0172 code??
- 2005 Evo MR WTF is wrong with it???
- EcuFlash and Windows Mobile
- New FIC 1000cc injectors. Car Idles @ 2,200RPM
- P0031 code keeps coming back
- EvoScan error, please help!
- Need help tuning the idle with kelford 272's
- ACD reflashing
- question about tephra mod
- error code
- Links to jcsbanks' Speed Density patches
- JDM Map values
- TPS 13.3% minimum wtf
- Ecuflash and windows xp problem
- open port 2.0 issues
- TephraMOD V6 - testing!
- Accuracy of NarrowBandO2
- Tial bov with MAF?
- Evoscan Plotting Graph Issue
- Evoscan 2.6beta7??????
- PLZ help will not read pic included
- GM MAF natively?
- evoscan 97
- Evoscan cable broke burnt out after only a day
- Ecuflash update?
- 1 byte load not right?
- Rescaling the Injector Latency table
- Unable to read ECU?
- LTFT Low FIX Found ! !
- 2Byte load dropping to 0 ???
- 94170015 vs. 95070008 I Found an issue
- what rs232 to USB adapter??
- evoscan or logworks and LM2
- ECUFlash Version Issue
- Max Load???
- sorry I havn't been online recently...
- evo8 swap into an eclipse
- ECUFlash rear o2 disabled
- Anybody else having trouble downloading evoscan?
- Is the jdm map sensor required ?
- Can i ged rid og all the selenoides on the back o the manny?
- XML definition file for 99270000
