PDA
View Full Version : ECU Flash
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40
  1. WOT log
  2. Can someone look at my logs???
  3. help saving my current rom
  4. what afr gaguges work with mitsulogger?
  5. Effects of pulled timing on power (pic)
  6. Was searching aktivematrix for some ecurom info and now I'm excited
  7. Anyone tuned EVOGREEN on stock ECU?
  8. Tuning 91oct
  9. Tuning 1000cc injectors on ECU Flash
  10. 12.04@114.8 evo 9
  11. Logging WGDC / No Worky
  12. Car stumbling/dying
  13. Brand New
  14. My First Logs with New Evoscan and LC-1
  15. Annoying closed loop problem
  16. tunning for Cams
  17. EVOScan Help, trying to log on an Eclipse
  18. Is there a way to eliminate the rich spot I get at peak TQ/boost/load?
  19. Wideband LC-1 - Power and Ground? Where and How?
  20. Negative Calculated Load Values?
  21. Question about EvoScan log files
  22. Quick Q about timing vs afr
  23. EcuFlash Read from ECU Button
  24. 110 octane
  25. Evo Scan and Windows Vista....
  26. Idle Stepper Look-Up Table Alittle messed up...
  27. Please view my log...
  28. ECU Timing Question
  29. Success dialing boost?
  30. Impressed with Ecuflash
  31. Evo7 ECU transplant to a 6?
  32. Question for those with 2byteload,airflow,and baudrate mods
  33. MitsuLogger question
  34. MUT Table 94170014 help, I think I found it
  35. E85 flex fuel switch on the fly
  36. Pill Placement for ECU Boost Control
  37. EcuFlash noob questions...
  38. 2 step/launch control is very slow on my car??? help!
  39. A Virgin Logger's first log (impressions+questions)
  40. Logging a 6 TME.
  41. Dump question about turbo!!
  42. Simple question
  43. First person to answer this gets a . . .
  44. E85 Cold start/Coldest air temp loged on wot pull
  45. Strange Knock
  46. error msg opening Ecuflash
  47. upgrading a few things from last reflash
  48. Decel enrichment??
  49. OEM Style Gauges for EvoScan .99
  50. Long term fuel trim
  51. various loggers
  52. Evo IX 2-byte Load & Lean Spool for Dummies
  53. Throttle Hang?
  54. I need ECUFlash v1.29
  55. How to disable the boost limit
  56. I need an opinion
  57. tuned our 2.3 evo project car with ecuflash...
  58. ECUFlash Error: rkrv: preamble 1 error
  59. Pasting Data from Excel to Ecuflash
  60. HO Igntion Map / Low RPM range question
  61. Evoscan v.99 Problem
  62. Mitsulogger 1.6 beta 4 - SNEAK PEEK
  63. Real time picture
  64. Evo scan 0.99 problem
  65. New fuel pump. What to change
  66. EvoScan v0.99 - Zoomable Graphs / RealTime Alarms / Power & Torque Graphing.
  67. EvoScan 0.99 out
  68. DLL numbers vs. real dyno numbers
  69. Trouble with EvoScan gauges
  70. EvoScan Log Analysis Needed
  71. ECUflash wont load my rom.
  72. Possible Blackbox?
  73. Wanted: developers for 7/8 realtime mapping
  74. Almost ready.. 2.3 35R..
  75. ecuflash error
  76. BCS Pill Removal Safety
  77. MUTIII data rate
  78. Low Load?...Mitsulogger 1.6 beta`
  79. Restrictor pill..
  80. Did anyone know of this ecuflash feature
  81. Should I'd be flashing soon?
  82. EGT too high, reading 2,200 F
  83. AEM UEGO need help.. Is mine too old?
  84. Mail in Flash...Dyno Flash or Buschur Racing?
  85. Mitsulogger v1.6 Beta 3 ***RELEASED***
  86. 845cc injectors + ECUFlash
  87. the fuel map, a question
  88. Dumb question on ECU reset
  89. Help Connecting...I'm a little flustered
  90. OBD-II Scantech Running on my Bench ECU Harness
  91. log boost with JDM MAP sensor (updated instructions)
  92. boost enhancement start/stop
  93. Partial Throttle Knock ?
  94. noob question for Jestr tuning
  95. log WGDC in EvoScan
  96. Help setting stationary rev limiter
  97. Ecuflash 1.3
  98. dataloglab question
  99. Timing advancing, while knock counts rise
  100. Boost Question on 9s
  101. 2005 Evo8 ECU's have vin# embedded in them
  102. tuning experiment
  103. Cant get Antilag to work
  104. what boost with stock fuel system
  105. EVO8 Bench harness works.. Mostly..
  106. uego 1000 USERS
  107. Data log lab Help??
  108. E85, Idling problems
  109. -12.8 Fuel Trim Low
  110. Please comment on this dyno graph..
  111. Mitsulogger v1.6 Beta 3, INNOVATE SUPPORT to be released
  112. What are you guys logging while tunning
  113. Is this the right cable (tactrix cable)?
  114. A flash I made. Review?
  115. Please comment on my graph!
  116. 03 - 05 MAP. TBE, Intake. Need this map please!
  117. evoscan knock sum question!
  118. question about evoscan knock sum!
  119. question about evoscan knock sum!
  120. question about evoscan knock sum!
  121. Sorting out the details of realtime mapping
  122. Need help.. Review my logs plz.
  123. Need help - Innovate LM1 with ECUFlash Issues
  124. Evoscan log with AFR(uego)
  125. Need a bone stock 03 ROM
  126. ECU wont hit the higher load cells
  127. Boost vs. Timing -- Optimal Power?
  128. Leaving the Openport cable plugged in - does it draw power?
  129. Jestr Mail in Flash....
  130. have 03 post-P0300 rom?
  131. Our ECUs can have eight sets of maps...
  132. po300 "fix" ?
  133. Need ECUFlash 1.28 or 1.29a
  134. Q's about purchasing a wideband
  135. ECUFlashed, heavily modified, and still passes inspection.
  136. Looking for a comletely stock map.....
  137. ECUFlash Troubles
  138. Running fuel map in RAM - tested and working
  139. Advice on these, more power on the table?
  140. Lost Password/Serial Number for ecuflash
  141. Timing at idle- log
  142. Wtb Oem Evo 9 Ecu
  143. Need advise on my flash
  144. Thanks Jestr! + 40 HP
  145. issues with ecuflash not working
  146. phantom knock?
  147. How would I tune my evo8 acc. to 3037 turbo kit?
  148. Wideband Logging LM1
  149. why does exhaust modifications require ecu remap?
  150. Very Beginer Intro please
  151. fired up the 2.3 with ecuflash
  152. Tuning books or courses ?
  153. 05 EVO8 MR map->03 EVO8
  154. Jestr M1 flash gained me 20whp/50ft-lbs
  155. Need help testing new mobile logger.
  156. look at my strange map. need some help
  157. Strangest .98 evoscan issue
  158. A/F R... and Knock,,, what should i buy
  159. Does this look like I have a boost leak?
  160. Stock ECU records!
  161. Can someone pls look at my log??
  162. cant get ecuflash towork anymore.....
  163. New EcuFlash 1.30 released
  164. libmut help
  165. How to use Dataloglab
  166. injector pulse width calculator (link)
  167. IDC & Fuel questions
  168. Ecuflash 335awhp/296torque Street Dyno
  169. Discuss: Real time mapping DSM Link style?
  170. Begginer map, K&N cone, and CatBack
  171. first dataloglab power / logs and a few questions
  172. Value for injector scaling using 660cc injectors??
  173. Successful test of reading any memory location
  174. Vista Compatibility ?
  175. Ralliart Evo 7 rom on stock evo 7 ecu?
  176. Different AFRs for different pulls/ Lean spool/Logworks
  177. Can someone post a stock MAF Scale from ECUFlash?
  178. Innovative 02 Replacement?
  179. Data Log Lab question
  180. 2.3 with 35R other bits, ecuflash, almost ready
  181. EvoScan and AYC/ABS readings.
  182. First tune observations
  183. hitting really high load on stock turbo?
  184. Cold Start AFR's
  185. Just got ecuflash
  186. Mistulogger Vs. Evoscan
  187. Boost Limit Numbers
  188. Idle "ranging" till warm
  189. Dumb question about EcuFlash
  190. Approximate boost number
  191. LC-1 install guide?
  192. Unknown knock source
  193. My 1st attempt at logs...
  194. Best way to spend $52...
  195. Evoscan v.98
  196. Weird Idle - What to adjust?
  197. Fuel trims - constant values
  198. has anyone been able to get their AFR curve this flat with ecuflash? :P
  199. Another...review my first logs
  200. Car will not start after new flash
  201. Wideband with Evoscan
  202. Best Way to connect AEM UEGO to Evoscan?
  203. Evo VII stock AFR ...Lean!
  204. 2 Step
  205. 21.5psi peak 326awhp 323awtq with a turboback
  206. 349whp mustang dyno EcuFlash Map
  207. 36 counts of knock as soon as gas is touched and randomly...
  208. Problem with new Evo Scan
  209. Evoscan knock detection
  210. I dyno'd again 306awhp 312awtq with test pipe and intake
  211. Q about rescaling load on maps...
  212. ECUflash,280's,1000cc, & 35r!
  213. Flashing the 4G69
  214. where to get The Tactrix cable & ECUFlash software
  215. A:F 0.5 leaner when it's colder outside
  216. RPM not showing with Mitsulogger
  217. welcome me to shouldn't be
  218. Mitsulogger v1.6beta1 To be released
  219. Plx M-300....
  220. Man i love ecuflash.. some other tidbits..
  221. evoscan "air temp"
  222. Vista and OBD2 Scantech issue
  223. MapTracer for Evoscan and Mitsubishilogger
  224. Cable Recognized...Still wont connect....HELP!!!!!!
  225. Boost/evoscan/boost gauge
  226. You & Your Wideband & Evoscan
  227. EvoScan v0.98 Now with Power & Torque Graphing - Map Tracing completed also!
  228. Target AFR and Actual AFR
  229. removing phantom knock with thermal insulation.
  230. Hks Dli 2 ?
  231. fuel map smoothing?
  232. Bad Gas/Injector/etc?...log inside
  233. changes to ecu map
  234. Mivec and Knock..
  235. Some help with my timing maps
  236. Evo 8 with ecu-based boost control
  237. Maximum Timing Advance: IX
  238. "No known code"?
  239. Assembly language confusion - please help me understand linkers
  240. is this boost dip look normal?
  241. Data Log Lab Question / LoadMax160?
  242. SES light after flash
  243. mitsulogger???
  244. Questions about EcuFlash...
  245. If you have to ask, maybe you shouldn't be tuning yourself..
  246. Still waiting on evoscan .98
  247. windows vista???
  248. F/S Tactrix Cable
  249. Unable to read ECU
  250. Looking for E85 help
