View Full Version : ECU Flash
- interface close??
- Noob....need ecu flash cable..datalog?
- GM 3.5 BAR MAP Sensor -vs- JDM Map sensor
- Idle Stepper Maps?
- Speed Density with stock ecu
- MAF Screen / Honeycomb - How do you prevent it from getting sucked in?
- Another check my logs but with a twist
- Controlling boost with restrictor pill removed
- a couple of logs, 1-2 counts of knock, advice please
- help! trying to get ecufash to work
- ecuflash problem
- Evoscan, UTEC compatible
- Trying to fix my "PRO" tuned maps (please review my logs and help)
- 7500 RPM, WOT, 14.xx afr, 35 degrees 0 knock!
- lean idle? perfect cruise/wot
- Pimp my log
- New cams, tweak what?
- ECUFLASH cant download my rom - IX
- Meth and knock!
- These Open-Loop values correct for fuel efficiency?
- Check out this Mivec Map???
- Is this AFR okay? Still learning so pls be kind.
- ecuflash on evo 8 and 7 *help*
- What is wrong with this 04? Datalog Included..
- ECUHACK for ABS?
- i need a map
- Speed density on stock ECU dyno results
- Engine cold map /// Emissions /// ???
- Zeitronics Calibration
- Race Fuel tune experience
- Links to Valuable ECU topics
- 98950010 datalogging higher load than the fuel map
- Lopey Idle via MIVEC
- Autometer Wide band and ECUflash compatability
- soft boost-cut
- Rear O2 as loggable input?
- Problem with injector voltage.
- Easy way to add additional column of ECU LOAD for evo8
- what load should I expect?
- my IX mr not started
- IDA Pro tutorial request
- ecuflash gauge display
- Quick Question
- MIVEC tuning for Cosworth Cams
- How To Tune an Evo
- Noob to EcuFlash, many questions...
- Looking to find usb and obd 2 cable and ECU flash software
- Ecuflash 1.29 plz
- Ecuflash 1.29 plz
- Ecuflash Help
- fuel trims
- Walbro 255?
- 1st time logging with evoscan?
- Datalogging with AEM Uego
- Unstable RPM after NLTS Mod
- Some quarter mile logs for your viewing pleasure
- Pocket PC and Tactrix cable
- School me in Opensource
- e7 rom definition file needed for 98640016
- 88590015 wastegate solenoid xml
- Mod request: Knock count buzzer
- GM solenoid getting frustrated!! Need help
- Knock on NLTS
- So I pulled a MAP of a 04 ECU, and.....
- The final ok number for knock.
- My gt35r on 91oct evoscan log. Some questions, please help.
- High Knock from 5K to Redline
- open loop load?
- So confused on 2byte setup... need help quick
- Stock IX Voltage Latency Settings w/Stock Injectors w/Injector Size Scaling set to 48
- AFR 13.3 w/o knock?!?
- Alpha Testing: log.reader... web-based dynamic graphing
- Patch Idea: Can you help Tephra?
- Stat. rev limit with high boost
- Evoscan error again...
- Can anyone help plz..
- PTE 780cc Injectors Scaled - Piece of Cake
- DOes the avcr put you into closed loop fueling?
- Unusual load reading during datalogging
- Subaru EcuFlash Resources?
- Altered Idle stepper and ISCV tables
- ECUFlash Tune Milage and Mods
- Getting an error with EcuFlash
- Help with Knocking at 7000RPM
- Evoscan gauge Templates
- How to MOD your ROM with NLTS or others!
- evoscan questions please
- ECUFlash: Adding more Load/RPM Cells?
- Problems..
- Do Fuel Adjustments Impact Timing?
- who needs a tune in hawaii
- Will either of these 2 Serial to USB Adapters work?? Please enlighten!
- everyone replacing restrictor pill at WGA?
- Datalab??
- spool up timing/fuel question.
- strange problem with launch, thinking it is ecu related..
- Help: 2byte Airflow (96240008 RomID)
- Exact Formula.
- evoscan problem
- Evoscan .99 issue( need some help)
- Evoscan 4th gear pull from last night... thoughts?
- help! map sensor clip - possibly OT
- 2 Byte Load for 96420008 ?
- A quick question about Accel Enrichment
- Stationary Rev Limit not working?????
- FIC 750cc Injector Scaling/Latency?
- how to tune for VTA BOV with ecuflash
- Please check my gt35r on 91oct log
- Vehicle Speed Sensor Readings
- V1.33 problem
- Problem with fuel maps INF
- look at my rom?
- Datalogging guesstimate HP
- Compare Ecuflash tunes here
- How exactly does elevation change the tune?
- Tune Fix
- Question about NLTS shifting.
- *** EvoScan Feedback Required ***
- Evoscan questions
- help asap
- Care to analyze my logs...
- My Tune - All My Settings & Logs
- Would someone care to check my logs?
- high logged load?
- LC-1 and ECUFlash
- majorrrrrr headache
- Need Help! definition file for JDM EVO 8 MR.
- help with ecuflash/tactrix cable
- EcuFlash 1.33
- Cell AFR verus actual AFR?
- noob to tunning/engine management
- Best Place to buy ecuflash/evoscan cable?
- Please help analyze my gt35r 91oct log
- DLL defination file
- how do I know
- Evoscan error, please help!
- Help with Evo7 STFT/CEL as well as VDP com port
- EvoScan: Can not find log maps in folder..
- Log Reqest: JDM MAP and Stock Airbox
- mitsulogger and data log lab
- DLL Results Vs Dyno Jet
- Lift off knock (cure?)
- swap question
- Accerlation Inrichment
- OK who did it, Someone selling flashes on EBAY
- Antilag Evo 8's
- Ball park date for gas?
- Question to the California guys.
- Newbie Play Nice
- Is Evoscan 1.0 out??
- Lean spool AFR opinions
- Standard Rom Versions
- Scaling/latency for 750's
- JDM EVO 9 logs... need input
- Older ecuflash versions
- PATCH: NLTS + Valet + KnockCEL
- Looking for logs to correlate load to massair/rev
- FlashEvo with Tactrix Cable ???
- Not Pulling Codes
- Mind looking at a couple logs?
- 2-byte RPM HOW-TO
- How to upgrade evoscan??
- Incorporating a Meth Failsafe into the Stock ECU
- Enhanced resolution
- EcuFlash 1.32
- Newbie question
- is it safe?
- What else should I add to this write-up?
- Help ! !
- 3rd gear log
- looking for a -008 US Evo8 rom.
- windows mobile
- A few Questions about Ralliart ECU and Flash ...
- Timing pulled in different ACD modes
- Reading/logging 2-byte load.
- How to setup evoscan or data log lab to show correct hp or torque?? please help!!!
- Launch Control
- I'm a n00b...
- 680cc injectors
- IDEAL BOOST CONTROLL patch discussion.
- good AFR, good timing, and no knock BUT higher EGT's??
- Very low load numbers?
- The list of current ROM modifications
- Got evoscan working on 2nd gen DSM
- usb to serial using 2 usbs does it work ok?
- adding cams mild modding sorting out idle jdm 8mr
- evoscan intializing
- A few Ecu Flash questions
- Smoggy Log - 2byte load
- Boost Error Gone Wild
- Wierd GM Boost Solenoid issue
- Question to the CEL flash mod people.
- Cant Flash or Read ECU.
- rescale rpm axis?
- Minimum TPS value?
- Took some logs
- What is the most HP tuned on stock MAF?
- Scott @ TTP - FLASH RETUNE W/ WIDEBAND READINGS?
- Ecuflash version 1.32
- how ECU calculates its final value
- New to evo. what is all this Ecuflash/mitsulogger/evologger stuff?
- Trouble with 2-byte airflow in 96940011 ROM
- Evoscan does not record all of my log
- Strange knock issues....VERY STRANGE
- Help! ECUFlash cannot read my ROM
- Switching back to stock injectors, need help!
- Guys with JDM MAP and 96940011 ROM
- BEZ is breaking out the patches
- Anyone care to look at some logs?
- Mitsulogger vs Vista
- Knock from a twin plate clutch
- suggestions on my Log
- Vendour recommendations and experiences please
- Load Decreasing
- e-mail for evoscan 1.0?
- New to EcuFlash(and any tuning in general)
- Any ecuflash tuners able to tune with Mac??
- Patch Request: Pull Boost on Knock
- another fuel question
- help with evo 8 lean spool disable?
- how-to: ECU-based direct boost control
- How much hp with good timing?
- Tuning for nitrous.
- Fq 320/340/360
- Currently logging boost with motorola 3bar
- Idle Problems with GT35
- Mitsulogger 2-byte XML addition?
- How does ECUflash use definition/xml-files?
- Samco Intake Hose
- evoscan
- Dialing in idle for cams
- How to log boost one edm evo9
- Help understanding Map Test Voltage tables
- Ecuflash - Actual performance increase?
- 2 byte load reading
- Dyno Tune knock Gadget and ECU datalog knock
- Low Octane flag at idle?
- Knock @ Stationary Rev Limit
- hitting 24lbs on stock bcs?
- Evoscan HP????
- 2 byte load mod on 94170015 rom??
- ecuflash failed in the midle of a flash
- Stalling with AC on issue
- evoscan v1.0 ?
- How do I post hex file (map)
- Tuning lower load cells - help?
- Problem starting 1.29 ecuflash
- Let's see those IX fuel maps...
- coil dwelling on stock ecu? any tuners know anything about this??
- Jestrtuning M1 or subscription?
