PDA
View Full Version : ECU Flash
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
  1. What is Speed Density?
  2. car only does 100%WGDC
  3. problem with morning start
  4. SD Rich Part Throttle but Lean Tip In
  5. Trouble with ECUFlash/Tactrix 1.3
  6. I need help! open loop
  7. Tephra for 3-plug ECU
  8. Anybody local to Seattle Wa?? ECUFLASH Issues need some help!!
  9. which Tactrix cable should i get
  10. good Mivec map for GSC s2's and 6262
  11. Ecu Interrupt Routine help?
  12. EvoScan bigger Injectors
  13. twin BCS evo's
  14. Pin outs
  15. decrease ecu sensitivity to MAF/NBO2
  16. E85 tune Help!
  17. E85 Timing number on Stock IX Turbo
  18. Cannot Connect 1.3U Cable to any car
  19. OmniPower 4 Bar Map Issues
  20. wideband / afr lag
  21. Openport 2.0 won't connect to my 9 or gf's 8
  22. having trouble
  23. Speed Density Closed Loop Operation Questions
  24. Were is the Spark timing map!?
  25. Issue with LC-1 logging
  26. Can't won't start help?!
  27. Evoscan Issue
  28. Stalling and Fueling at Idle - New Perspective?
  29. evo 6 tme reflash, anyone do home jobs
  30. Evoscan 2.7 and 2.8 vs Fuel Trims
  31. what load is LTFT Low?
  32. patch for knock tables
  33. Please help! How to log Innovate MTX-L to EvoScan or Openport 2 microSD???
  34. Need help logging AFR
  35. logging boost with jdm 3 bar on 90550001
  36. ECU cutting power / check engine light / poor idle / stuttering
  37. Need a little help...
  38. EvoScan not reading diag codes
  39. How much timing with 35r?
  40. help with p0505 and IAC
  41. looking for 88580714 big maps
  42. Evoscan 2.7 problem
  43. Car won't spark, Mitsulogger log attached (after I re-did wiring)
  44. service engine light
  45. Fuel Trims Not Updating
  46. Evo VI JDM project, Tuners I need help please.
  47. JDM Evo 9 8857008 definition file?
  48. Alt Map Not Working After Car Warm
  49. Part throttle stutter 100-180 load ranges <3100rpm
  50. JDM MIVEC map??
  51. fuel trim mid never changes??
  52. Roadracing/Track tune check please.
  53. Looking for MBT with Virtual Dyno
  54. Tuning for autocross
  55. Yet another stumbling evo: Log attatched
  56. 96940011 USDM EVO 8 Stock Map Please
  57. Help! P0011 Code!
  58. Misfire after FIC 1450 install
  59. Need help getting out this knock
  60. 2-step and AFRs (i've searched)
  61. 3g ecu compatibility
  62. JDM RPM speed to gear mod
  63. FIC 1450 help
  64. Evo 9 USDM or EDM ecu in EVO 9 GT JDM
  65. Removing Pin 9 on chassis OBD connector?
  66. No MAP on evo8, can i install it?
  67. HKS bov problems, what i need to do?
  68. immobilizer
  69. Ingnition base map for a stroker
  70. Evo 9 GT JDM and Tephra V7
  71. Several Tables,?
  72. EVOSCAN Not instaling in program files. HELP.!
  73. 1 byte Load not logging on Evoscan
  74. ECU Bench Help
  75. Load / fuel trim logging problem..
  76. Reading knock voltage data....?
  77. Openport or EvoScan 1.3U
  78. Anybody try this?
  79. "Cranking Primer Initial Pulse", and RC 1000's on pump gas?
  80. HOW DO YOU: Properly set Up NLTS
  81. error P0141 and P0136
  82. Need help, exhausted all options.
  83. Tactrix cable order from EVOSCAN
  84. Another Quick Q
  85. Ecuscan gps
  86. How to tune 800whp
  87. 96530706 Boost issue
  88. Load -> Power?
  89. Tial BOV opens/ stutters while on boost
  90. Cant read/ Write to ECU!!
  91. "Jerky throttle response after Decel"
  92. What loads do you see at ~25 PSI?
  93. Tephra V7 question
  94. can't connect to anything
  95. Knock tables with Built Motors
  96. Evo Scan Logs
  97. bad gm iat sensor?
  98. Review of Grimmspeed BCS on EVO IX RS (dual solenoids)
  99. Dumb Question Knock issues in cold weather no increase in load
  100. warm start up issues... way lean!
  101. fault codes
  102. Trying to dial in fuel and eliminate knock
  103. Knock Tables
  104. Basic question : what load to use ?
  105. Help a brother out. Car wont hit boost, started hesitating, dies at idle
  106. WTF!?? EcuFlash suddenly doesn't work....
  107. evoscan works fine but can't connect to ecuflash
  108. HELP ASAP car wont start plz =((
  109. 90550001 ROM load fix
  110. Judge My Tune.
  111. Which brings more power?
  112. Tuning for bigger WG
  113. Tuning past MBT?
  114. anyone got a stock evo ix and viii map?
  115. Cold Idle issue
  116. E7 with Tephra 5 help
  117. Stop your Car Stalling from Clutch in!
  118. Enable/Disable Intercooler sprayer
  119. ~10.2:1 timing map help needed.
  120. My Ignition tables doesn't match up with EVOscan datalogs
  121. need opinions on my tune
  122. EGR disable question
  123. Whats th differnce between these 1.3 cables?
  124. anyone ever heard a beep from ecu or car?
  125. VERY weird issues, ECU Guru's PLEASE HELP
  126. Weird ignition timing pull
  127. Ironing out Leanspool issues.
  128. why does closed loop refer to maf?
  129. Fuel trims not logging in Evoscan - only getting 0.1?
  130. Assigned incorrect xml to tephra v7 and now won't read
  131. Anyone successfully go from 9417 to Tephv7 9653 with immob?
  132. ECUFlash connection problems
  133. OBD Force Pass Patch Issues
  134. Evo Knock Sensor Filter Maps and their purpose
  135. Help with Ecu based boost control
  136. Using aem uego 5v output as primary o2 sensor
  137. Grimmspeed 3-Port EBCS & External Wastegete Setup?
  138. Periphery2 FCA bit to disable p0455?
  139. ?? Connect Zetronix AFR/Boost to ECU
  140. GrimmSpeed 3-port basic boost settings
  141. Help with this Log
  142. Periphery Bit FAA Bit 9
  143. Can we flash while car is running ?
  144. Flashing the Evo with TephraV7????
  145. Accelation enrichment
  146. Thinking about going tehra
  147. V7 maps and Windows 7. any issues?
  148. Stock IX ECU Flash questions
  149. my website with patched ROMs is back up
  150. Injector Duty Cycle 110%??
  151. Part to half thorttle pulls seem lean??
  152. Innovate LC-1 Issue
  153. What in the hell!!!!!!!
  154. Problems logging iat with v7 sd
  155. Erratic low load timing causing ~2000 rpm jitters -- not following timing map?
  156. Zetronix ZT-2 questions ?
  157. trying to reflash factory ecu... how do i get started?
  158. How to modify Idle Stepper table for Tephramod?
  159. Why am I Knocking?
  160. stock 05 evo viii load?
  161. FIC 1680 tuning notes
  162. troubleshooting connection
  163. few bits i can't suss. help pls
  164. Load Increase
  165. Logging Boost with Stock MAP
  166. Weird Fuel Enrichment
  167. Help: s.d. and iat calibration and set-up
  168. JDM Evo X xmls wanted please
  169. Getting extremely frustrated!!!
  170. Missfire
  171. Fried Tactrix Cable - How?
  172. fuel ignition compensation tables
  173. EVO IX AYC+ACD missing components help needed
  174. new key
  175. ECU gone to ****????
  176. 9653 SD: boost coming in at 90kpa%
  177. GM 3 bAR fOR USE WITH SPEED DENSITY?
  178. 89 Octane tune ?
  179. 6A13TT Galant
  180. FIC 1000cc INJ scaling
  181. Ecuflash Problem
  182. A Little Tip
  183. So car starts but doesn't want to stay on
  184. 96530006 Family XML Tables - Let's bring it all together
  185. Logging LM-2
  186. ECU patch help.
  187. CEL help.
  188. Little help logging wideband in evoscan
  189. Zeitronix AFR @ 21:1 at idle
  190. Trying to learn to tune
  191. 96531706 definition file
  192. Speed density and Map tracer??
  193. is load a true representation of load?
  194. knock up top on 91
  195. Launch control/2 step not working 88590715 V7
  196. Tactrix Cable
  197. Help!!!!
  198. OCT nr goes from 255 to 0 in one step only then starts knock. Is it normal?
  199. Safer to run more boost less timing?
  200. Got tuned on Friday, Flashed a different map now car won't start
  201. lean AFR 6500 RPM but 5bar Fuel pressure???
  202. EvoECU and 4g94 engine
  203. 93oct with meth?
  204. Logging AEM UEGO with e7 ecu
  205. how do i
  206. LM1 not working with EVOSCAN GPS help required
  207. 89280002 help please
  208. Need help. Just tuned, map sucked, tried a different map....car wouldn't start.
  209. lc1 and 2.0 integration
  210. Intercooler Spray Maps - 88580013
  211. asynch VS TPSDELTA
  212. Problem with Live Mapping
  213. Logging Load Error and WGDC correction
  214. Car runs like crap after reflash
  215. Evo IX with Evo VIII head
  216. HELP can't read my ecu, car won't start
  217. Help me pick out a new Laptop for Tuning
  218. Is there a way to keep the fans running?
  219. Having trouble loading my maps.
  220. rear 02 CEL fix
  221. o2 trim freezing up, trims not recording...
  222. Cannot connect to vehicle interface!! Searched but no one has a fix!
  223. V7 fuel cut
  224. 2-step timing figures
  225. P0134 - 12.0 idle/cruise AFR
  226. how to paste my tune info on here..
  227. urgent help quick
  228. Airflow scaling?
  229. Tuning the Evo 8.
  230. Odd load upon spool
  231. 2 Weird Questions didnt know how to search for them
  232. 93660005 xml
  233. How much boost?
  234. EvoScan logging RPM's to 7968 only...
  235. Check out my Log..
  236. Knock issues?
  237. Request for start log with the push of a dash button
  238. EvoScan V2.7 - Maptrace Issue
  239. Do I have a bad tactrix cable
  240. Unstable idle running on the heated-up engine
  241. Changed to 96530006 and now cant communicate with ACD?!
  242. reset fuel trims
  243. Gear based boost control patch?
  244. phantom or real part throttle knock (stroker)
  245. AMS E-Flash
  246. Timing Map since i increased my Boost
  247. V7 SD STFT +24 WB 10.0 on cold start.
  248. Why can't I get my actual A/F anywhere close to my fuel map??? Running lean!
  249. idle hunting 1000rpm to 1800rpm
  250. Can 5 Bar Map be used with SD?
