PDA
View Full Version : ECU Flash
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40
  1. car stalls with a/c on
  2. Carbon fouled plugs after a short trip...
  3. WB instead of front o2 -> tephra, mrfred et al.
  4. EGR Solenoid Loggable?
  5. Dynojet versus Dataloglab graphs
  6. Stock Evo 9 IDC's
  7. need help with 3bar Map
  8. Can't log WGDCCorr
  9. Fuel trim ?
  10. Bad Gas???
  11. log request: stock evo 8 low load
  12. Evoscan 2.5 and fuel trims.
  13. ICS relay pinout for Evo8?
  14. A/F at idle is WAY lean
  15. Anyone Forged and Logging with EvoScan?
  16. EVO Scan Wideband AFR Log fixer!
  17. evo scan 2.4 question
  18. flashing check engine light but not constant...
  19. HHO and Dyno Tune
  20. Br350 evo 9 will not read rom
  21. Need some help with GM Boost Control
  22. Openport 2.0 Cable, Aktivematrix is beta testing!
  23. evoscan dyno question
  24. throttle hang induced knock fix
  25. Innovate might be dead
  26. Is fuel pump require for ECU Flash?
  27. Front O2 Sensor Heater Cel Removal.. With Math!
  28. EGR Advancement for 96530006
  29. Boost map question
  30. Is my 2byte load logging correctly?
  31. ecuflash wont read my computer!?
  32. How long is to long????
  33. Question about knocking.
  34. Can anyone confirm that EVO X MAP sensor is same as JDM MAP?
  35. Tephra map switching and E85 Q?
  36. Coolant temp impact on AFR, ECU AFRMAP and subsequently - on Knock?
  37. RPM increase after no throttle
  38. Load differences per gear
  39. What knock do stock Evo's make?
  40. How to spot ignition misses due to spark gap
  41. options for 96420008 roms
  42. Advice for UK FQ-300 please, am struggling
  43. First Log (2 byte) take a look
  44. Car wont start after moding the MUT tables Flashing CEL
  45. Stock ECU Tuning Wiki is up and running
  46. First tune, impressions?
  47. patch for 88590015: control front and rear O2 with wideband
  48. MUT tabe mods...what cell? (Pics)
  49. Knock Help
  50. LC-1 + Leaned NBO input = Spiking AFR
  51. ecuflash ic sprayer definition descriptions
  52. Made a Boo Boo :-(
  53. lean in first but more then enough fuel in second??
  54. post your e85 fuel maps!
  55. EVOscan - Load Values on MAP Tracer
  56. Evoscan 2.5
  57. My First tune..take a look please
  58. ecuflash 1.29 and 1.30 problem connecting
  59. ecu reflash question
  60. 88590015 xml definition
  61. Quick Noob Question on Tephra.
  62. Same setup, transfering tune...
  63. EvoScan Actuator SAS Mode
  64. Tephra CEL flash knock mod Question
  65. AFR's went lean from last drive
  66. DashDAQ possibilities?
  67. Mac having problems with Evoscan and ECUfalsh
  68. how to turn off knock control?
  69. EcuFlash, EvoScan, ECU Patches - Organization Needed
  70. Maf scaling/fuel trim questions
  71. 94170008 to 94170015 = no more cruise p0300
  72. Will the Innovate LM-2 replace the Tactrix Cable?
  73. JDM 3-Bar Map Sensor Group Buy #2
  74. Crazy Map issue
  75. Help: EvoScan .99 not logging certain parameters and fuel trim question
  76. how to log from the odb with logworks
  77. Dataloglab results from a newbie
  78. 10.0 and 18.9 idle drops, Im rdy to blow this thing up!! Need some help
  79. Please help me understand Boost Error
  80. Random thought on rear O2 readings
  81. HowTo: Identify Diagnostic Cables by PinOuts.
  82. tactix cable / jumper question
  83. Ralliart rom & Engine fan
  84. +25 hp & 17 ft-lb from Cosi cams with ECUflash
  85. ECUFlash 1.35 Trys to read ecu and freezes
  86. ECUFLASH 135 error loading FTD2XX.DLL
  87. how powerful of a laptop needed?
  88. How is 2-byte Load found?
  89. Evoscan v2.4 fixes
  90. re-flash question
  91. 99860002 JDM7 To 99270000 EDM8RA Dilemma
  92. deleting rear o2 and NO CEL light.. little right up/how to
  93. explain my log
  94. now simulating front O2 signal using WB signal
  95. AFR Problem
  96. I need your opinions on my log....
  97. Cannot connect to vehicle interface!?!?
  98. Knock free on 3rd but knocking on 4th
  99. Wideband O2 Questions
  100. thinking about ditching my LC1
  101. Why to log the Battery Voltage on EvoScan?
  102. roms and tephra patch
  103. ecuflash x&y wrong values
  104. How can I increase EVO IX Lauch Control Limit?
  105. Quick question on GM 3 port boost solenoid
  106. Rom routines - Tephra Mfred etc etc
  107. tatrix cable not working and im getting pissed
  108. How many of you run MAFTPro/ECUflash
  109. ecuflash dies again
  110. 9gsr, flashing any rom
  111. what to log??
  112. 03 Evo 8 Tune Help- Fuel-Ignition Map
  113. rom 94170015 and V5 patch.........
  114. i need ecuflash 1.29......... someone link me
  115. EGR removal and CEL
  116. Is WGDC Correction acting correctly in this log?
  117. how long to get a evoscan ticket query back?
  118. question about latency
  119. 16g Choke Flow?
  120. have problem with knock retard
  121. stock cold start rpm is too high
  122. IX running rich, changes to fuel table not working
  123. Strange ECUFlash crashes
  124. Innovate LC-1 Install & Location
  125. Unknown Rom Definition?
  126. AFR #'s for completely stock IX?
  127. knock sum 22 , what did i do wrong
  128. rear o2 sensor patch / help
  129. Evoscan 2.4 my coolant and air temp logs backwards - need fix
  130. Turning off knock sensor under certain conditions?
  131. ALL DIY'ers: READ THIS
  132. Need opinions about my "hot lap" logs
  133. Asus Eee issues
  134. 10 knocks at 2843rpm (stationary)!?????
  135. LogWorks 3 released
  136. how-to: Log AFR from the LC-1 w a serial cable
  137. Mitsu loger
  138. Patch needed: run less than -10 degrees
  139. swapper ecu?
  140. ADC Inputs - Which ones can we use and how can we use them
  141. tactix cable ?
  142. Can't log data with EvoScan on IX MR
  143. 400hp EVO's need help
  144. EvoScan Logging a single load cell
  145. log boost on uk jdm E8 (with no map sensor)
  146. New Motor Build, Looking for Tuning Advice..
  147. ECUFlash 1.35, EVOSCAN 2.X, and EVOSCAN Flashing Cable (universal) - Cannot connect
  148. How do I download the new Evoscan?
  149. Ecutek has a lock on my ecu?
  150. what do you think?
  151. Which gauges to trust; dyno or self gauge?
  152. Higher boost = lower timing?
  153. Need help with EVO 9 RS EDM ROM
  154. Evoscan
  155. not feeling the love for open loop cruise
  156. disable rear o2
  157. Open loop cruise creates missfire when leaned beyond 15.2
  158. vista 64-bit and evoscan and ecuflash
  159. Tuning issues; car won't lean out?
  160. will a tune with no mods make a gain?
  161. Innovate LM1 "Cuts-out" while logging Evoscan 2.3
  162. Please help!!! Evo IX stucked in Canada.
  163. wideband wont log afrs in evo scan
  164. Basemap for Cossie M2's
  165. evoscan not connecting???
  166. OpenPort 2.0
  167. Patch for Failsafes on stock ECU
  168. stock map thread
  169. Innovate Wideband working, but not logging correctly
  170. Data Junkies - One Lap @ Redline
  171. Safe Boost for Stock Turbo
  172. Odd injectors ...
  173. PTE 1000cc scaling?
  174. Ecuflash 1.35 cant reflash
  175. Log Plots of EVO 8; Do they look OK?
  176. EeePC true test...
  177. evoscan user manual/guide
  178. Question from the new ECU flash/Mitsulogger user
  179. GURU's please look...36 knock counts!!
  180. Knock Sum
  181. idle afr
  182. How do I make sure all drivers are deleted?
  183. new cam now car won't start
  184. Idle and cruise AFR
  185. Having a bad p0300 issue lately...need help
  186. hks blowoff on ecu
  187. evoscan/ecuflash noob with question
  188. MAF scaling with a wideband - am I doing it correctly?
  189. Jumpy AFR's at low load
  190. need to save money, writing patch to control closed loop with WB
  191. evoscan calculate hp/tq
  192. ecu flash wont read my ecu
  193. Log Viewers!! Which one is best??
  194. noob ecu awareness
  195. Formula for Airflow in lb/hr?
  196. Log help
  197. Where to get Data Log Lab?
  198. Data Junkies + DLL dyno surprise
  199. always some knock in the first pull when tuning
  200. Map Switching and Me
  201. Tactrix Boost Control Solenoid (Plug-n-Play for Mitsu)
  202. cables
  203. a/c idle problems
  204. ecuflash first use
  205. Running lean @ high load
  206. Noob needs help
  207. 96940011 issues
  208. Need Opinion on Logs
  209. Newb Need Help
  210. Here's a wierd one for you...
  211. You know it's warm out when...
  212. fuel cut problems
  213. Jdm Map & Egr
  214. Evoscan 2.3 released.
  215. Comparison graph of boost before and after O2 and Manifold install (91 octane)
  216. Problem between 2500-3000 RPM
  217. Need some guidance
  218. New injectors = adjust your IDC alky trigger ;)
  219. Evoscan wierdness
  220. Gtech or DLL
  221. Evoscan not saving Datalogs?
  222. evoscan v2.2 question
  223. New input on EGTs
  224. timing at idle help
  225. Pin for ecu clutch position sensor
  226. Beginner tuner here in need of advice
  227. starting up new 2.3L for the first time
  228. Best place to mount knock sensor
  229. Need help tuning!! Cash Paid for services!!
  230. AEM Wideband.
  231. TephraMod V5 88590015 - Evo 9 - Help
  232. Adjusting Cam Lope
  233. IPW Formula
  234. LC-1 Access denied Evoscan
  235. LTFT Maf Scale
  236. which is the best evoscan
  237. what is wrong with my ECUFlash?? Someone help...
  238. Question for tephra, others. RE: map header addition factors
  239. boost at twostep launch
  240. o2 sensor fix w/ ecuflash?
  241. Can Fuel Trims be Perfect?
  242. AirflowMUT2byte
  243. Meth Fuel Map---is this look correct?
  244. Changing the Int ID
  245. Hot air causing knock?
  246. TPS 98% + IDC Accuracy
  247. Fuel trims
  248. JDM 3 Bar Map Sensor Group Buy
  249. JDM 3bar MAP Sensor + Evoscan 2.2
  250. Injectors Scaling
