PDA
View Full Version : ECU Flash
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
  1. Needs the help. EcuFlash reads but does not write
  2. Will scaling 880s to stock cause me to run out of fuel easier or effect drive ability
  3. flashed V7... car will not start
  4. AFR changes when in different gears
  5. PASSED NJ inspection.
  6. Throttle hang, recirc or VTA ?
  7. Wondering about octane on demand, 2nd fuel tank
  8. tables not showing in ecuflash
  9. Illustrated SD nub questions
  10. Problem with LM Programmer LC-1 ?
  11. Squash my knock!
  12. Stumped on Misfires and wandering A/F ratio
  13. help ams tune on evo 9
  14. Definition assistance for 128k ROMs MD347224 & MD347223
  15. Help with map on new car.
  16. trouble using vdr.
  17. Hard to start with ID1000's on 93
  18. XML Definition File
  19. Closed loop lt trim controls
  20. Airtrek XML definition wanted
  21. EcuFlash & Readable OBDII Codes
  22. question about cable purchase
  23. What's the minimum amount of logs per second that's safe?
  24. Rom id
  25. dead front o2 sensor
  26. LTFT Mid not coming in...
  27. 96260009 ignition trim defs
  28. How do you guys control Torque vs HP?
  29. couple Q's before my turbo upgrade. Inj. and cams
  30. Mode 23
  31. n00b SD tuning questions
  32. Scaling AFR map to match actual wideband...
  33. SD Low RPM Leaning out Fix (different way)
  34. Does a EVO VIII ecu plug rite into a Evo4?
  35. Clutch switch/NLTS/Speed sensor
  36. load error and wgdc correction qs
  37. What the hell did I press (EvoScan)
  38. accell enrichment.
  39. Stock maf scaling?
  40. maintaining afr in RR conditions
  41. knock sensor values for 2.3
  42. STFT stuck @ 25%
  43. Virtual Dyno - Standalone Software
  44. TephraMod V7 89960000
  45. What brand of laptop do you use for tuning?
  46. 88570008 mut table
  47. big map translator problem
  48. 4G18 on ecuflash
  49. Please help with LC-1 problem
  50. AC idle issue
  51. digital dash question (wiring)
  52. EBCS Grimmspeed for External wastegate
  53. Over boost problem ONLY on 4th gear onwards
  54. Sub-routine Structure
  55. What boost?
  56. PLEASE HELP!!!! Disabling Immobilizer
  57. Whats typical AFR's on spool up?
  58. Is it bad to knock to redline?
  59. 90550001 DMA rom and xml needed
  60. ECUFLASH issues
  61. Rear O2 impact?
  62. OpenPort 1.3U vs. OpenPort 2.0
  63. AEM 3.5-Bar MAP Settings
  64. Maptracer not working
  65. About running Lean a/f?
  66. Just discover that Timing maps are baro compensated!
  67. Any of you a genius at Excel Macros and Visual Basic??
  68. HELP with SD fifth gear duty 0%
  69. Evoscan weird DTC list !
  70. tephra maf question
  71. Lets see some 2.4l timing maps
  72. 96530006 to 96532706 = car won't start Plz help
  73. STAT rev limit not working properly
  74. Anyone hopping on a Dyno very soon?
  75. Wierd change in AFR ???????????
  76. Ecu based fan control ?
  77. can someone help with 8857008 rom?
  78. 88580714 in SD
  79. evoscan v2.7 AEM error: port closed
  80. Increasing Idle
  81. rom 96420011
  82. How are u guys launching with V7 launch map
  83. EvoScan 2.6 question
  84. how to make the LM-2 read on Evoscan?
  85. VDR help!
  86. 90550001 livemap/dma rom needed
  87. Open Port 1.3u Driver Help
  88. Ecuflash Not able to Read or Write
  89. trying to get my new set up atlest running.. help..
  90. Ecu Flash READS but doesnt WRITE BACK!!!
  91. Check out my timing Map
  92. V7 PSI based boost control
  93. Wtf...More Knock different place now.
  94. ECUFLASH isnt reading!!??
  95. Drivers??????
  96. Map switching with Zeitronix ZT-2
  97. Help with 96530706 live map
  98. Shift knock but only if i Shift fast
  99. COLD Start rpm
  100. HELP PLEASE!!! Injector Cranking Enrichment Table
  101. Comments on friend's big turbo ignition map please?
  102. about evoscan
  103. How rich it too rich?
  104. I need help about ROM 96530006RS2
  105. Scan or battery mess with flash?
  106. Anyone have a good standard 35r tune
  107. Try to tune an NT
  108. A/C fan temp adjustment???
  109. Peak Torque knock... before, during and after
  110. Evoscan disconnecting at WOT???
  111. Cossie M3s not loping :(
  112. Need some opinions on my fuel/timing maps
  113. Ecu based boost control. Help with EBC settings
  114. Perrin intake and filter
  115. Evo9 Sensor & Analog Ground Pins?
  116. Injector latency ?
  117. Holy knock!!
  118. will someone show me some maps?
  119. Load only showing one value?
  120. ECU not listening
  121. Concerned about EGTs
  122. Evocan estimated horsepower?
  123. Injectors help
  124. timing help
  125. Speed density extreme lean condition when starting off from a stop (9653 V7 SD rom)
  126. EvoScan Boost (MDP) Logging
  127. Finding 2-byte Load
  128. Rear Dimister
  129. Additional mods, retuned but difficult to start??? HELP
  130. EvoScan v2.6 does not work on 1.3 cable
  131. Min. temp for closed loop address?
  132. EcuFlasth for Evo3
  133. 94170008 to 94170015 question
  134. deatschwerks 880cc
  135. Tuning Help
  136. Injector Scaling help
  137. Ecu scan software
  138. Knock after Shifting
  139. Disable P0139?
  140. Disable egr advance
  141. Can some copy over my tune??
  142. Lets see some SD Map VE/SD Rpm VE Tables for non stock/motors/ turbos
  143. EZ question - How do you tell if the BCS is working?
  144. Air Con Compressor Control Via Stock ECU
  145. My MAT Scaling table is jacked up
  146. EvoScan Stock 05 Map?
  147. Help for my RS from the experts:)
  148. Need help
  149. Ignition Map Load Adder? MrFred?
  150. Logging LC 1 throught std evo 8 ecu (JDM)
  151. A/C Condenser Fan Rewire
  152. Error - unknow ROM Image
  153. Starting to Tune!
  154. Question to Tephra and other mod makers
  155. scaling dw 880cc
  156. EcuFlash xml help. (Window Switches)
  157. Mitsulogger 2.0 and ECU Unlocker 1.1 Downloads
  158. Adding XML to mac...
  159. Tephra - e85 sensor question
  160. HELP! PLEASE! wierd issue with tephra mod...
  161. IAT manifold or uicp ?
  162. which parameter need to log to use with maptracer
  163. Big Maps are too small...(smoothing your maps)
  164. SD help on evo 8
  165. iPad + EcuFLash ?
  166. tephra mod file for 96260007
  167. lc 1 problems
  168. High idle after larger injectors.
  169. SD on 888400017
  170. Help: Evoscan skipping/overwriting data??
  171. Please post your V7 ECU load Based boost settings and what PSI they make
  172. JDM EVO8 map sensors question
  173. Low Load Knock Help
  174. crazy afr at idle
  175. Reflashing ECU and OBD2 readiness
  176. rear o2 disable patch for 88580714 or 88580014 or 88840016
  177. no lift to shift
  178. tephra 96531706 how do I disable p0325
  179. Cam Sensor or Crank sensor for timing?
  180. Are 12.x values okay in the 200+ load area?
  181. evoscan error - tactrix cable help!
  182. Evo VIII Ecu (USDM) in Evo IV (JDM)
  183. What wideband for install on Evo 8
  184. FIC 1100cc high Z question ????
  185. Help: V7 ecu boost setup
  186. Map sensor required!!!
  187. SD to MAF help
  188. Tactrix not flashing/reading - bad fuse?
  189. EvoScan 2.6+7 Help with Tactrix Cable
  190. PTE 780cc Injectors at 80%idc @ only 13psi????
  191. looking for a evo 8 stock base map...
  192. Thanks to all the ECUFlash programmers
  193. ideas on dip in power
  194. ECU cant be read or logged with Evoscan
  195. Tephra v7 Launch Maps Help
  196. CEL = Shift light?
  197. Car misfires after LS Disable
  198. Locked out
  199. need help mivec problems ?
  200. Need help fast??evoscan not working?
  201. Evoscan reading 6.00 AFR with LC-1 why??
  202. EcuFlash tries to use Serial Cable.
  203. stationary rev limiter
  204. Wiring aem wideband as front o2 sensor
  205. sharing tunes???
  206. LC-1 won't work with Evoscan ?
  207. Tephra v7.0 First Try
  208. ROM 96420011 question(s)
  209. Having problems with car holding the 2step or launch maps too long.
  210. Tuning a little question!
  211. Big maps-too big
  212. new to tuning, question about evoscan
  213. openloop fuel question cruise area
  214. 96530706 tephra v7 please edit and help
  215. gm 3 bar map sensor scale
  216. d.i.y "race" gas who tried it?
  217. Evoscan estimated torque?
  218. rom 24430002
  219. AEM UEGO Evoscan Function
  220. Evo9 Gsr Ralliart rom boost drop ?
  221. Help,racing tomorrow and ECU wont switch from Alt map
  222. Un-related to ECU flash -quick question
  223. Regarding Injector Latency...
  224. Windows 7, EcuFlash 1.42, OpenPort1.3
  225. ECU Toast?... Input Requested
  226. denso 1000 cc scaling - need help
  227. HELP!!! ECU flash unable to read Evo 6 ecu
  228. Knock Threshold adjusting?
  229. Can't Download Rom from ECU - Searched Already!
  230. Need help with evoscan gauge templates
  231. Need some XMLs - 90550001 & 99860002
  232. S2 Cam Idle Advice
  233. Knock ??
  234. Afr map ?
  235. Brands of gas effect performance?
  236. Windows 7, can't replace EvoScan .xml
  237. Help for scaling and latency RC 660cc injectors
  238. Wgdc
  239. About WGDC?
  240. AFR Tuning: indications of boost leak (pics)
  241. EvoScan buggy...
  242. JDM EVO8 Map sensor question,Please help!!!
  243. Knock Then No Knock
  244. Car is weirding out
  245. 89960000 any info ??
  246. wgdc not cooperating
  247. Trouble starting after injector install and tune! HELP
  248. Open loop load tables
  249. using tephra v7 map switching as meth failsafe
  250. Urgent Help needed
