View Full Version : ECU Flash
- Anyone have have the JDM Evo 9 RS MIVEC map and settings
- problem with load commanded vs/actual
- Gear dependent boost control
- FIC 750cc Injector Latency Table Required
- inconsistent Knock
- P0125 after thermostat change
- Evo 7 with 90550001 v5.10 problem
- Rom changes necessary after installing omni bar map sensor?
- Issue: Unable to make changes to fuel and timing map
- Help finding the correct .xml definition for this 94170015 ROM, No start on reflash
- Stock 9 to FP HTA71, theoretical Rom changes expected
- EVO IV stock ECU rom on EVO 8 ECU
- FIC2150 tuning notes
- What's the latest and greatest Rom and XML for SD these days?
- Car wont start in cold
- 88580714 Desired ISCV initial step position with AC off-Neutral
- Wont start after adjusting the latencies
- Anyone using a serial-to-USB with a Dell Venue Pro?
- Renesas SH7055 ROM non EVO non WRX help.
- Error when trying to flash randomly?! HELP!
- Problem with knock
- Speed Density MAT Scaling for IAT Scaling Table on 94171715... Is this right ??
- High Cold Start Idle with clutch in
- Hitting fuel cut - multiplier setting not working?
- Odd TPS WGDC table values cause no-start if changed in Tephra 88590715
- Serious timing issue 88580714 V7
- Understanding Knock
- Altering one table changes another?
- Weird load reading, 88580714
- High Idle Timing Cold Start Problem
- What Pump Gas Timing do you guys run?
- Rough idle when cold on E85: Please Help
- Tephra V7 not following BWGDC
- Can someone convert a non tephra rom into a tephra rom for me
- Theres a Trick to run stock maf without air intake?
- boost/fuel cut limit load doubler
- help on setting up on evo8 ecu to 2g.
- 1byte load goes to 0 above 4k
- 94170715 need mut table address
- Load MUT 2B
- launch map issue - car stalls
- evoscan/ ecuflash on google chromebook?
- Tables showing odd values after reading ROM
- ecuflash on iOS can read but can't flash
- Scaling injectors bigger than actual
- No ignition reading!
- Possibly the worst tune I've seen.
- SD Tephra map stock injectors
- part throttle hesitation, then leeeeeean
- EcuFlash Tunning Map Suggestions
- Help with ecuflash
- 96260009 dma
- MPX 4250AP map sensor
- flashing without car
- Increase maf inlet size- changes to maf settings?
- Best practice for built motor knock mulitipliers?
- GSC S3s
- 4th BWGDC Table
- radiator fan control (Teprha V7)
- MafHz to lb/min ?
- some tuning questions
- Cant read my rom
- 2g Evo 8 ECU swap, injector tuning problems...
- stft not reading
- ISCV Table
- HELP need t lower IPW at idle
- ecu flash won't read my ecu anymore
- Necessary to log EGTs?
- A little help with SD tephra v7 - evo 8 ... weird VE values?
- Load in Evoscan v2.9
- timing question
- CP9A ECUFLASH Questio
- Structured Rom .srf file? What is this?
- Two Step limiter not working??
- Can I log Ngk Afx in Evoscan via laptop?
- PLX AFR settings for EvoScan ??
- AMS F1i + boomba 75mm
- Omni 4 bar map sensor!
- ecuflash ignition/dwell cop kit
- 03 gs ECU immobilizer Disable
- Getting check engine light on rom 9417 for Cam and Crank sensor
- Need a definition file created
- Create Evo3 fresh ROM file 96532706
- big map translator
- constant knock count of 9, no matter what
- Problem in Data Logging AU EVO X MR - Data Missing
- Evo 8 ECU / Ecuflash problem with injectors
- any cons of full time open loop ?
- Patch 9417 throws CAM ANGLE and CRANK SENSOR check every time on Evo 4-6 w/ 8 ECU
- Help with Idle
- obd2 readiness please help!
- IDA command makecode failed
- Question about my Log
- IDA disassembled ROM
- Having a editing issue..
- Questions about removing Fuel and Load limits
- Tephra Rom ignoring "Closed-Loop, Min Coolant Temp"?
- Flames Throwing Tune with EcuFlash
- Tephra strange problem
- Bad FIC 1650??!
- MAF comp vs coolant
- understanding my tune
- Need help with tephra mod installation
- EvoX & Ralliart TC-SST Gear Information
- 96530706 ic sprayer
- I want to learn to tune my car willing to pay for lessons
- can I rescale MAF past 1600 Hz ?
- Jdm xml 88570008
- Knock Knock
- how to lower boost with grimmspeed and tephra 7?
- Closed loop with big injectors problem
- 1byte load is way off only reading up to 159 on a car boosting 23 psi
- Fic 850
- Videos not available
- HELP tuning for weather changes?!
- Disassembly question
- AFR wierd change from heating
- AFR wierd issue.
- Evo 8 - Cold Start, Idle issue & Wideband reading odd numbers - Please Help!
- WGDC 100% under LOAD vs TPS WGDC %
- Speed triggered output
- HELP!, I can't connect to my ecu anymore.
- Advice needed: Retune for AMS F1 intake
- Knock Issue During Spool
- slow rpm drop.(not rev hang)
- Evo 8 rom 20030101_1201. hex
- Need help setting up SD rom with Omni 3 bar and AEM iat
- Need advice on knock!
- Tuning for FIC 850 injectors
- Shot down Evo 6 ECU. Need your help.
- async accel question
- E85 on speed density sputters and runs lean in closed loop
- Launch control wont work
- Tephramod-94170715
- am I logging correct load ? - help needed
- Need Help
- Evo8 Ecu in dsm
- Base tune help
- Evoscan Help!
- A/D Channel Input Processing Question
- Tune help please
- Airflow rate lb/min logging really low numbers
- ecuflash remote tuning
- Making use of ADC inputs
- Tephramod V7 Idle startup lean-rich
- no more cam lope after manifold swap
- what causes car to go pic rich coming off the line?
- My launch control doesnt want to work
- ECU Flash not not wanting to read
- Easiest way to log load without using tephra v7?
- GM IAT sensor part #
- Revised big map sizes for new ROM
- Ecuflash/Evoscan/Mitsulogger doesn't work !!
- Massive Thanks to evoscan!!
- EvoScan reading too rich testing-for-intake-boost-leaks
- Lean spike during spool at 4500
- Help with unknown rom
- Evoscan with Surface Pro 2
- InternalID 9417008 Back After Long Absence
- front o2 sensor simulator?
- Tephra v7 Alt Map + Aquamist Question
- AEM UEGO wideband logging problem in evoscan
- Injector flow rate linearization table
- New laptop - cannot open Evoscan 2.9
- A few questions about idle
- LC-2 to evoscan logging.
- Idle timing advanced stuck at 50?
- Strange idle problem with AC on
- Uknown Rom image in ECUflash w/ tactrix 2.0 openport
- anyone use OMNI 7 bar MAP sensor for SD?
- getting high knock low load
- Lets talk peak "tq"
- Openport 2.0 logging via SD card
- my 'Boost Desired Engine PSI' is wrong
- Advice on how to proceed with my tune
- vta bov decel tuning
- fault code p0135 and p0403 after ecu swap
- MUT Request ICS
- Change back to stock ecu
- 0015 boost limit/cut map issue
- No Lift To Shift test
- Idle and cruise AFR are hella rich
- Evoscan reads ECU, ecuflash does not
- 2.3L, 10:1 CR Tuning Advice Needed
- Speed Density and Warming Up
- ecuflash trying to open saved xml
- Setting up SD V7
- knock problem
- Maf Comp vs Latency question
- Question regarding immobilizer and rom info.
- Help! Need someone in NJ with Tactrix 2.0 open port
- omni 7 bar map sensor experience
- Ceddy rom (sas settings)
- cranking issue
- log of Evo VIII "dying"
- dangerous issue: fuel cut / load drop
- Async Accel Multiplier vs TPS Delta for 88590715
- Is this a faulty knock sensor? 7-9 counts above 2250 rpm
- If not ecuflash.. Then..
- Outlander turbo, after reading does not start
- SD goes lean on throttle tip-in or light cruise
- Problem connecting Ecuflash to Subaru Impreza STI 2008
- another lean spool question thread. sorry
- tephra mod/logging load help please
- Trouble transfering tune from stock rom to Tephra v7
- MD346675 swap woes
- New Build Startup Trouble
- Can't save my updated xml file
- MegaLogViewer HD new version
- quick tune
- 21/27.7 mpg - optimizing mileage
- Cant find a ROM/XML file needed
- Idle Tuning
- 05 mr tuning questions
- Fuel cut out issue
- Evo v remap (new evo owner)
- Stock rom
- how to get ecu flash???
- Ecuflash makes car idle crappy
- Boost control correction woes
- Fic 1550cc scaling
- 90550001 sd for evo 7 Geekmapped down
- Bunch of CEL codes after SD
- Evo 9 speed density/jdm map and fuel temp
- crazy timing jump in log
- Ugly rough fuel map
- nlts problem revs
- Please help!!! 94171715
- MAF scaling evo 8 maf swap into airtrek turbo
- Sd cant log load?
- Problem with 2step
- Need Tephra for EVO 7RS. Id:98650015
- Changing roms
- Knock @ 2500 RPM, 60-100 Load
- CEL P0122 - TPS - disabling it through Periphery bits?
- Writing problem
- How do I lock my map
- Open Loop Cruise - AFR leans over time
- Missing tables? Tephrav7
- Evoscan - Can't Log Speed
- Evoscan not reading my wideband
- Running lean after FPR and 416 install
- Ecuflash not saving patched rom!!!!
- EcuFlash keeps closing itself
- Failed NYS OBDII Inspection
- Problem with ecu flash
- Problems AEM UEGO via Serial Cable (Evoscan)
- Need help to set my 2step
- Inexpensive 4-channel temperature acquistion for EGT or other
- 2.3L Build, No power, help!
