View Full Version : ECU Flash
- reminder- exhaust leaks boost leaks
- Ignition Timing Question
- EVOSCAN and LC-1(LC1) question
- Map Tracing App (EvoScan) - Preview ONLY
- Strange deceleration / engine braking
- Power graph of FPEvo Green
- Please review my maps
- Steps to Injector Scaling - ?
- Small Tool: Offline Map Walker
- Don't forget to look at your low octane fuel map!
- Getting my Evo 9 ROM
- Tuning STi's???
- Jdm Evo Ix Rom Help
- boost dropping around 6k?
- Evo IX Ignition map differences / Boost Desired Load / Lean Spool questions
- Knock Count Unit of Measurement
- help!! my evoscan wont save my settings
- Evoscan not working
- Evoscan for MAC's???
- reflash
- Log & MAP Question
- who is using aggressive cams on flash..
- How to disable ECU knock control - if you really want to...
- does EVOSCAN do this??
- Discuss: Scheme for real time mapping
- Load scale view changes
- Totally Lost, please help
- help tuning
- How to XML a Bin. file?
- ECU tracing and MWGDC Tables
- Acceleration from Evoscan?
- Map switching up and running on my Evo IX
- next step?
- 1st Log - A few noob questions
- Anyone have 880cc latecy and scaling tables?
- Is venting your crankcase bad for your tune?
- Brief retardation knock 10 counts[pic]
- Theoretical aspect of knock in respect to piston speed.
- Understanding load
- How to adjust for a 255 fuel pump
- ecuflash /ecutek gurus
- Is it safe to increase by 0.2 bar
- Please review logs.
- Safe amount of knock?
- AFRMAP differs from fuel map too much
- I'm dropping into open loop and getting 10AFR at idle [screenshot]
- Need advice jester or custom dyno tune
- MAF frequency / fuel trims / P0300 questions
- i seem to be having a knocking issue no matter how i tune my map
- Selfmade Pocket MUTLogger/Dash first alpha release
- Tutorial: How to scale your MAF [pics]
- Difference Between RALLIART FQXXX AND OEM ECUs
- Stock timing/fuel maps...
- Ecuflash vs Power FC
- What's the difference between these two cables for datalogging?
- step by step to 2 byte
- ECU-Flash & cam set up on the IX
- What would cause a car to knock?
- How do you add a custom scaling
- unlocker program ?
- Windows Vista Compatability?
- questions about setting up ecuflash
- FQ360map for EVO 9 MR?
- Your estimate when tuning.
- Dyno #s
- LM-1 Issue
- Mitsulogger v1.5 Alpha featuring Wideband Support!!
- AFR adjustment
- IsEcuflash a pirated software from Ecutek?
- e-flash
- 03 Rom
- ecu tuning for meth injection failsafe
- New to 91 octane tuning!
- SOme LC-1 Questions for Understanding
- Pros and Cons Evo Scan VS. Mitsulogger
- DSM Link Cable?
- My logs using the Innovate Motorsports LC-1, LMA-3, OBD-II cable, & LogWorks2
- knock questions
- Jestr anti-lag
- EvoScan DTC/SES Light Checking...Help please.
- how long of wait for flash
- Need some Advice here...
- ECUFlash error...quick question.
- Little help - making it leaner at idle
- tune to shoot fire ball.
- Sharing ROMs So We Can Learn
- So I emailed Jestr Tuning...
- Hanging Throttle, and the "cruise control" effect [POLL]
- Idle w/1000cc injectors and 280 cams
- TPS problems
- What flash from who? for New Hampshire
- Does anyone have this with the 1.29 ECUFlash?
- 1.3M cable problems?
- anyone use mitsulogger and zeitronix simultaneously?
- Wastegate duty cycle maps 1-4...???
- OS X libmut logger
- Why won't Aktivematrix verify my account??
- Newb Zeitronix Question
- Here is my datalog on Evo IX!!!
- EcuFlash Dyno Tuned 328 awhp
- Question: Driving technique in order to log appropriate data?
- MBC needed higher boost on ECU Flash
- how do these look? Newbie...
- question logging with mitsulogger
- why i can't save/open rom?
- How to get ECU FLASH??
- my tps only goes to 99.6?
- how much is acceptable? knock
- Antilag table defined
- TPS adjustment,?
- Wierd Knock...logs inside
- What parameters do you log and why?
- need help downloading Mitsulogger
- Tuners "Scrambling" their maps.
- email rom to my self? how?
- Evoscan
- stock timing @ peak torque
- Are loggers all getting EVO RPM Wrong?
- JDM evo wants to use ecuflash?
- 91 octane to 100 octane tune on a IX
- ECU Flash
- Lean spool address in 05
- Help needed using ecuflash and a tactrix cable?
- Tuning for a flat Torque Curve
- Idle, low speed cruise, high speed cruise question
- EvoScan help
- computer requirements for Eflashes
- The Best ECU Flash Tuner
- Boost pressure differences from 1st thru 6th gears.
- 880's with reflash???????
- Help....2002 Airtrek Turbo or Evo7 GTA xml Definitions wanted
- Ecuflash tuning question
- Anti-Lag Question
- Evoscan and LC-1 - Weird readings
- TTP e-flash
- Finally success!!!!
- Is my tune safe for a long road trip?
- EVOScan Download Question...
- Which ignition map to change?
- Considering ECUFlash on my IX
- stability of boost with stock bcs
- Mitsulogger v1.5 - Can it be?
- EvoScan and check engine lights
- Tuned on 100 octane/evoscan log??
- EvoScan Frame by Frame?
- P0300 error happened to me
- Clutch pedal position sensor
- Maf Honeycomb Q Not kidding
- AFR Map scaling values when tuning
- Base Map???
- Vendor e-flash question
- smooth or rough?
- NO wideband with flash!!!!!
- Rescaling load.. When to do?
- How much longer until evoscan .98
- how many pulls?
- Sending logs to a tuner
- just want to see something,
- Ecu+ & EcuFlash running on linux ....
- Tactrix cable problem...
- Obd2
- Drawing the line with inconsistency?
- TTP-Engineering Re-flash = WOW!
- 91 VS 100 Octane Tune
- Evoscan Datalog
- need help with "Unknown ROM Image"...
- Logworks and Dataloglab
- I only drive in 3rd gear
- pls review my datalogs
- Bought myself a laptop for logging/tuning...
- Logging Questions
- Water Temp
- How to tune for more torque??
- Knock adj.table
- Riddle Me This - EvoScan 02 Feeback Trim
- 298awhp with a test pipe and intake
- Scaling for PTE 780 Injectors
- Flashing for mods?
- ECUFlash newbie
- Disconnected battery??
- Help needed - rkrv: preamble 1 error
- Evoscan help
- Load
- Cannot read ECU - Blank Prompt - Help?
- Explanation needed for "Min Coolant Temp for Closed Loop"???
- First log with Logworks/Ecuflash
- Flashing back to stock
- Engine stumbles... can this be tuned out?
- Getting Data Log Lab to Run Right????
- Minor ECUFlash and Logging rant..
- Unclipped 2 byte airflow logged
- Check out this log
- EvoScan Setting File
- Newbie, but not an idiot...need a couple clues
- question about datalab
- EcuFlash & Mac OS X
- How to log AFR and RPM using LM-1 and Evoscan?
- EvoScan Timing Doesn't Match EcuFlash Map?????
- What do u do after you dial in your injectors?
- How to: Tune your own MIVEC maps
- What racegas to tune for??
- NGK AFX Wideband-- Compatible with EvoScan??
- evo 9 vs evo 8 load calc.
- HELP -- no response
- Maf Scaling table
- Open/Closed loop mode question along with fuel trim/injector latency issue
- First Logs...your opinions?
- Where the F do I buy the Tactrix cable?
- openecu webpage ???
- reading ralliart euro ecu for evo8
- EcuFlash download
- Knock Issues(?)... what do you think is up?
- Stock Evo IX DLL Dyno
- ECUFlash / Evoscan / Mitsulogger Questions
- Which logger has the dynograph feature.
- Please help me understand some before-after dyno figures
- injector scaling and injector voltage latency
- HOW TO: Change the .xml to open maps
- EcuEdit - Impressions
- ECUflash and Evoscan problem... not reading car..
- Knock in 2nd gear pull
- mitsulogger & zeitronix zt-2
- Brand of cable for serial to USB?
- Datalogs of completely stock 05
- Valet Map?
- EVOScan parameters
- Boost with Ecuflash
- EVOscan: TPS not registering...
- another source for cable & afr sensor
- increasing boost.
- Need help with my rom please!!!
- injector scaling question
- new to ecuflash logs to look at
- Feul Trim ?
- what do i need?
- evo IX ecu part number
- WHAT RPM IS YOUR 2 Step LAUNCH SET AT?
- EVOscan HELP please
- Latency and battery voltage question
- looking for email maps
- Stock turbo, stock actuator, intermediate gears, top end on pump gas
- Minimum boost on an E8 MR ?
- Misfire? EvoScan+R-500 log
- closed loop at 15.3
- EGT - a tuning parameter?
- Good results from EcuFlash on TBE Evo IX
- cable question
- stock Iridiums vs NGK BPR7ES
- Does this look bad?
