View Full Version : ECU Flash
- Enabling Alt Maps
- Setting up a IAT compensation curve
- How to patch in Big Maps & Launch Maps
- Tuning for Pikes Peak
- Need help with a definition!
- Need help 94650009 ecu def
- where do i get the xml. file to copy to my directory for v7
- evoscan not logging wb02, please help!!
- Knock with NLTS?
- Quick help please
- FAO Ceddy RE.evo 5/6 boost limit
- Lets see some SD Map VE/SD Rpm VE Tables for non stock/motors/ turbos
- 88591715 made yet ?
- rom question
- Laptop VS. Netbook for Tuning??
- How to log load with v7?
- should the tephra mod download look like this?
- hitting fuel cut need stock ecu basemap
- What requirements for the LapTop?
- Quick question for the MUT geniuses
- 96531706 SD flashed P0125 fault
- HELP: EVO8 way too rich between 1000-2000RPM
- ATTN: Tephra, or any other "developers"
- Async TPS Accel Enrichment adjustment?
- crankshaft sensor bad????
- 93670005 definiton
- tephra MOD
- Open Port 2.0 wont log on evoscan 2.6
- ? Un-install ecuflash... completely clean???
- Tactrix 1.3U cable question
- Need help no start after flash attempt.
- EvoScan Engine Diagnostic Code Support?
- Ecuflash problem
- Few Random Questions
- ARF's During 2-Step?
- help with horsepower formula
- USB to Serial Windows 7 64 bit
- Immo. Issues
- Need some help
- AEM Wideband on EvoScan 2.6 & 2.0 tactrix cable issue!
- NGK AFX wideband
- will tephramodv7 work with rom 96420008
- Rom Question
- Interesting Day On the Road Dyno
- omni 3 bar settings...i've searched
- 9366005 ALS table evo 8 jdm
- ok to remove older versions of the Tactrix drivers
- Evo internal dyno
- Evo7 question.... re Tephra Mods
- Lean On Throttle Tip In - Accel Enrichment?
- My CarPC/gauges - video
- HELP! CEL and AFR will not adjust
- weak cold idle
- e85 cold cranking issues
- Tuning on a Mac
- NEW netbook with windows 7?
- Break-thru: Reading ACD ECU with EcuFlash
- SpoolinUp SD plug-n-play harness development
- RC 1000cc injector latencies??
- New FIC 1100cc High impedance Injectors
- Trying to understand timing map
- Log AEM UEGO in evoscan using analog output?
- maf translator, do I need one?
- No Knock 11psi, massive knock at 15psi??
- Reading Evoscan log files
- 94170008 rom with 399 maf and non evo turbo lancer idle issues
- Ecuflash - Portable app?
- How to disable NLTS?
- Having trouble adjusting latencies
- 94170715 V7 Issues
- Speed Density Throttle Splutter
- Calling some Excel Experts
- Flashed to 9417 v7 now car won't start
- help with tephra v7
- Scaling the injectors?
- How do you "shrink" the actual sizw of a displayed 3D map?
- Just had a great idea!(maybe)
- About Tuning "If u live in PA,NJ,DE" look!
- Kavlico 5 bar Settings ???
- another WB issue w/ evoscan, not the "norm"
- Instructions for installing JOT map switch?
- will wiring the wideband with the d sub connecors work with mitsulogger
- Collecting old versions of EcuFlash
- What is the best OBD cable to flash and datalog
- Evo9 cpu specs
- Woot Woot FINALLY................ got the MapTracer to work. LOL
- Jdm map - mivec??
- Anyone using a Turbo XS Tuner to logg AFRs in Evoscan?
- Rom ID and Inherits help
- Big thanks to scheides and mrfred for the help and comments to share ...
- AFR Calculator
- Looking for ECU definitions
- Effects of external dump o2 on tuning??
- bitter experience with tactrix.com
- A Few Questions....
- Going back to 94170015
- need help. injector scalling and latency.
- injector values 1000 cc pte
- P0069 dtc???
- ????? about speed density after problems
- 600+ build - Dyno graph
- closed loop sub routine
- speed density
- How to build aXML ECU definition?
- Is this ecu stock or tuned???
- high impedance injectors?
- ecuflash with 1995 eclipse gsx?
- JDM EVO 7 ecu def help.
- Sd ix xml ????
- open port 1.3 and log works 2/3 plugin
- Ecuflash read button grayed out WTF?????
- evooscan 2.6
- Dtc u0100
- Evo9 ecu beginner questions.
- would negative timing cause boost creep?
- ecuflash version1.31 or earlier
- MAP AFR (MUT 32) not maching map afr?
- OEM ECU or AEM EMS evo 8
- logging with the AP cable
- After V7 Tephra xml and bin for uk e8 fq330
- Can't find solution - Ecuflash doesn't react for xml changes
- Car runs weird after hitting boost/fuel cut. Maps keep going weird. Help
- Need some help ... VIII goes really lean up top on E85
- how would go about a 5th injector? dont laugh
- question about ROM id's and patches
- What variables affect 2 byte load calculation?
- E85, 0.015 Plugs gap and still misfiring. Help!? Any tuning expert? Maps inside
- Stock 05 Turbo Question!
- Speed Density 2.0?
- Yet another ecuflash connection prob...
- v7 REV LIMIT not working
- how do you workout xml equations
- Identifier << << << <<
- what are your nlts settings
- Copy mut table when doing V7?
- What tephra v7 for JDM EVO 9 GSR
- EcuFlash Connect issue
- 96530006 evo8
- Tephra V7 RPM/Speed to Gear Table
- honda iat sensor for sd
- 264/264 Optimal settings
- FIX: 96530006 V7 tephra stationary rev limit does not work
- what pieces do i need to convert stock ecu to speed density? I already have a omni 4
- I searched and tried for days!
- 88570008: universal JDM/UK Evo 9 ROM
- Speed Sensor OBDII (P0500 code) fault
- injector values 1200 cc pte
- Quick one (i Hope)!
- Help needed. Lots of different questions.
- Cosworth 272`s on an Evo IX
- IPW minimum?
- Cant log fuel trims
- 88840017xml
- Ignition timing, cam or crank sensor
- e7 ECU into e6 swap gone bad, suggestions?
- EcuFlash HELLLLPP!!
- Mitsubishi MUT III Manual
- Launch Control WTF?
- Evoscan formula to log boost
- Low RPM Lean Issue on 96531706
- In need of questions. READ PLZ
- Is my wb02 sensor starting to fail?
- Odd load spike. Log inside.
- IAT based fuel comp tables found/verified?
- TPSless, can it be done using stock ECU??
- Suggestion for Technical Thread Updates
- Looking for male diag connector
- (a*b+128)/256 Say what???
- wideband narrowband simulator for 9653
- windows 7
- How much timing for Evo 8 Peak
- Noob question closed loop
- TPS help
- Anyone wana help me out with my log?
- pte 780cc
- IPW dropping to ZERO during WOT
- Trouble getting ECU flash to connect
- lc-1 install
- Weird Problem. Ignition?
- 96530706-V7, possible problem found.
- High Res Evo8 PCB pics?
- Limitless Designs cables site ??
- Turbo Effeciency Tables
- FIC 650cc Injector Scaling / Latency
- Cant write ROM to ECU with ECUFLASH
- Need rom definition for ECU Flash
- How to disable lean spool on JDM Evo6
- Tephra mod help ** Urgent***
- can`t read 05` RS ecu
- DIY - Trip computer
- Ecu flash help
- MAF Adder for Tephra V7 found.
- Fuel Cut
- SD Troubles: JDM MAP -> OmniPower 4bar
- Can't hold 2500 RPM for smog test?
- Tuning for faster spool
- lost and missing tables found...!!!!!
- Spool vs load
- Car RPMs drop and Shuts down when connected to EvoScan
- Need Evoscan 2.5
- MUT 8A/8B for 88570008 (ECU boost control mods)
- Ecu Flash problem
- evoscan log issues
- Fcon Vpro with Stock ECU help
- Help Please Newbie New to mods
- injector scaling 450cc help
- 2-step
- Logging AFR using AEM UEGO without a serial cable
- tuning question
- VDR Reality Check: 3°F ambient 4th gear pulls inside
- Maf Rescaling
- Mapping JDM evo 6
- bad scaling definition for max downward WGDCC
- tephra v7 maybe?
- Where to start, don't understand all this stuff.
- Anyone tried IDA 5.6 yet?
- n/a volume vs volume under boost
- Hi and Lo Octane fuel and timing maps
- Idle position switch on/off in Evoscan - big problem
- Evo 7 flash problem
- ECU boost control mods for 90550001 ?
- 608 Load in HP?
- can anyone help?
- evoscan v2.6 and vista issues
- Ecuflash with Ecutek installed
- took a log, want advice.
- Any Suggestions?
- upgraded to gt35r and mass air problem?
- [Dev/Disassembly] A/D Converter Lookup
- AFR fluctuating a whole point in certain RPMs
- low load knock after GSC S1 cams
- Tune went whacko .... why ?
- fuel cut between shifts
- linux
- FP Black sale - $1749 from FP
- Too much boost?
- Take a look on my maps, need advise
- help!!!
- help with cold start/timing
- Can't Edit Boost Error Correction, Boost Adder or Baseline Boost tables?
- 96531706 SD & direct boost, JDM MAP sensor upgrading to OmniPower 4bar questions
- Remember me?
- Thank you ECUFlash forum! (remember your first time?)
- Intrepid ECU?
- can jdm evo 7's log boost?
- 2 Guys, 2 Tunes, 2 Days, $800 in Salt Lake City
- unknown rom image
- Need Guru Help !!!!
- disable nearly all OBD tests
- Let's see your fully tuned timing curve
